View Full Version : Honda CR-V & Element
- aftermarket parts and mods
- CMBS not working on 2018 CR-V LX
- DPF fault
- 2000 CRV crank but no start
- 2010 Honda Element P2A00 OBD2 Code
- 2000 CR-V
- 09 crv cooling fans not working
- 2001 CRV Pulsating when under load
- 2005 Honda Element no start
- Handsfreelink 2013 crv
- 2014 front slide pin orientation
- 2001 CRV: Can a 2WD JDM tranny be used to replace an AWD USDM tranny?
- 03 CRV compressor not engaging
- Secondary Ignition and Starter?
- 2000 CR-V Rough Shifting and Codes After Catalytic Converter Theft
- Power steering hose clamp?
- 99 CR-V AWD Trans issues
- 99 CRV STALLS. NO CELS. Many Parts replaced.PLZ HELP!LZ HELp
- 2013 CRV tune / Kpro?
- 2015 Cr-v 2.4 exclusive warning light
- Average cost for labor front and rear 3" leveling lift kit for 99 crv??
- 2016 CRV LaneWatch Camera Upgrade
- Quit on me
- Ktuner Dyno tuner in socal area
- 2016 CRV valve adjustment
- 2005 Honda CRV
- 02 CRV misfire / struggle's to light off
- 1999 honda crv shuts off while driving
- 99 crv trans question
- Strikes fear into the heart of every weekend warrior
- TPMS control module help needed
- 99 cr-v surging idle and overheats with ac on
- 2004 CRV: Air Conditioner Temperature Inconsistent
- 2014 CRV (AWD) AUTOMATIC no power when accelerating
- Key fob has to be touching the push start button to start?
- Running strange, now won’t start
- 2011 CR-V ac mix door actuator pinout
- Aftermarket Driveshafts 1998 CR-V
- 99 crv with loose front left wheel (video)
- Mechanical grading sound from back of 2013 CRV AWD
- 1998 Honda Crv Crank Bolt
- 2001 Honda CRV airbags deployed, now won't shift into drive
- 2003 CRV code P1077 (hole in diaphragm)
- Problem with Central Locking, sunroof and with trunk open Honda Crv I 1998 128HP
- 2004 ELEMENT axle noise in first!?
- 2016 CRV EX AWD Rear Brake Slide Pins
- Runs bad after warm-up
- Heated Seats 2019 CRV
- Hill start assist problem? 2019 Honda CRV Touring
- brake backing plate rubbing against rear drum how to fix 2001 crv
- 2014 CR-V new air cleaner won't fit...
- Accord/Prelude FD ring gear in a 97-01 CRV trans?
- lost compression #3 cyl
- 2004 CRV Shudders when going up hill only at about 2800 RPM
- NEW KEYS FOR 2002 CRV TYPE T5 ID20?
- Won't start
- 2018 CR-V trans Service
- Honda CR-V timing belt or chain
- 02 crv running too cold?
- 2015 CRV EX- Thumping noise
- 2004 Honda CR-V Rev Limiter
- Aftermarket Motor/Trans Mounts-Any Good Ones?
- 2011 CRV with BlueDriver OBDII scan tool and 41-11 code
- Normal MAF air flow rate at idle?
- CRV 2017 Ambient Lighting
- 2006 Honda CR-V
- 2nd Gen Aftermarket Key Fob (No cutting)
- '98 crv: instructions for interior disassembly
- 2006 crv (K24) mystery coolant leak?!
- CrV Instrument cluster swao 02>04 help
- Oxygen Sensor Wiring
- Wheel hub
- wheel drive control buttons for radio failure
- new '20 CR-V stalls and restarts itself!
- [RD1] Weird semi-inconsistent knocking or ticking noise at idle
- Honda CRV speakers not working
- 2015 CRV EXL Factory Alarm Issue
- Ticking, hissing noise at 4000+ rpm
- Rpm drops and engine throttles after releasing gas crv 2006
- No start. Cold. First Time. Cranks. Runs Fine.
- 2015 Honda CRV EX trunk light in dash stays on even is lock
- Vacuum leak from booster or valve/hose?
- Gen 3 2007 CR-V LX Alignment HELL.
- 2006 honda element
- Crv 2006 car aircon issue and pressure?
- 1998 AWD Rear differential repair
- Master cylinder replacement on 2011crv
- '05 CR-V: Flurry of Codes, but Vehicle Runs Fine...
- 99 CRV. Changed radiator and now crank but no start.
- Engine Overheating While Driving
- 2018 CR-V Brakes Question
- Overfilled oil by 3 quarts
- Immobilizer issue
- 2004 CRV air cleaner box nuts
- 2000 CRV - Replace power steering fluid return hose ?
- Engine vibrating, not the motor mounts
- B20z head conversion on 99 CR-V
- 1st gen CRV with worn tappets
- Biggest tires that fit a stock '03 CR-V
- 04 honda element k24a tsx swap.
- 2006 CR-V instrument cluster reflow.
- Flashing "D" light whilst driving
- 2014 CRV - Interior Lights Not Working
- 2004 cr-v engine swap
- 2011 CRV- advice-red flags or should I purchase?
- What is this? 1998 CR-V
- CR-V Hybrid 12V Battery Charging?
- 2006 Honda CRV won’t recognize CD Player
- 2000 Honda CR-V won't crank below freezing but starts when above freezing.
- 1998 CR-V 4WD Differential Fluid
- Problems with cylinder number 4 crv 98
- Starter failed twice
- 2006 crv tires
- Engine Compatibility Question on 2006
- 2006 Honda CRV -Help
- RT4wd 98 crv rear diff swap HELP
- Serpentine belt.
- 2012 crv CV "axle" replacement
- 97 CR-V water pumps keep failing
- Do i need the plastic vapor-seal in the door?
- HELP!! Trying to install H.O. Alternator
- 2006 Honda Element code P2646
- Variable Timing Solenoid now in two pieces
- 2006 INSTRUMENTCLUSTER
- Valve Adjusting Question
- Jdm transmission?
- 2018 Honda crv 2.4 (non turbo) 100k miles
- An Important Find About ECM Water Damage on 1st Gen Cr-vs
- 2004 CRV taillights dash and radio are Not working
- How much quieter is the 2017 CR-V?
- Trailer lights
- Torque converter swap?
- 2011 CRV radio
- Brake System warning light
- Crv 98 overheating issue
- Should I buy a 2015 CR-V?
- Throttle Position Sensor
- Failing lock cylinder? And bad Actuator?
- Crv brake light displayed and temperature gauge inop
- Is "J 17X71/2J" a 7 inch rim?
- $3,100 to replace Catalytic Converter?
- 2001 RD1 crv aftermarket fender flares
- Oil and Battery Light
- 2004 CRV Reliable Modification?
- '99 CRV Gear 4 not engaging/selecting
- Intake rocker arms are tight
- 2002 Honda CR-V no crank no start.
- Brake Pad/Rotor Recommendations?
- Shift lock/trans not engaging
- 05 CRV charcoal canister and Evap.
- 2006 starter bolt
- Engine Cover Stud Broke.
- Need help diagnosing a problem?? Car crank but No start.
- 99 CRV - Power locks stopped working, looking for solutions
- 01 crv A/T ADJUSTMENT ISSUE
- Quick question
- Loss of power
- 2000 crv ignition
- 2006 CRV NO-CRANK/NO-START
- 2002 CR-V AWD Front Outer CV Boot Replacement
- VTEC solenoid keeps going bed
- 2nd Gen CR-V Tire Sizing from stock
- swap k24a1 on k24a
- Automatic Transmission
- Seat belt alarm
- Remote Starter
- Alternator overcharging.
- Help Connecting O2 Sensor to 02 Plug. '99 CR-V
- Engine Vibrates
- 2011-CRV-Engine oil burning
- Honda CRV vibrates until I lift the gas pedal
- 2004 honda rear hatch weight tolerance
- largest size tires on stock 2004 Honda CR-V
- Countershaft Sensor Connector
- 2000 CRV SE keyless remote question
- Recirculation mode won’t turn off
- JB4 for Honda CRV
- Coilover
- 2004 CRV compressor clutch won’t engage!
- Crv engine whirring sound
- 2013 CR-V whistle or scream? SOS!
- 2018 crv 1.5 tune up plugs, valve nut, cover and torques ????
- 2010 CRV Engine Oil
- 08 crv p0141 code, exhaust noises
- 2014 CR-V dumb Question (EX-L)
- Help!
- Need oil change after 350 miles?
- Alot of Codes
- 2020 CRV EX-L
- 2020 CRV-LX
- Vtec solenoid spool valve
- Transmission problem in morning, 2007 CR-V
- 2005 crv vtec solenoid valve
- How to take off AC outlet vent on 2018 Honda CRV
- Do I need to use sealant on the new intake manifold gasket.
- 2000 CRV transmission problem. Can I replace it myself?
- Persistent Wobbling Harmonic Balancer
- right pull
- 2003 crv O2 sensor signal not getting to ecu
- ATF leak from Neutral sensor?
- Automatic crv b20z2 hp increase
- No Low Beam
- 2013 CRV part number help please.
- I messed with my electrical and now have an AWD light..
- 2000 honda crv upgrade suggestions
- Wheel hub time
- 2003 CRV will not shift out of Park without the override
- 2000 CRV driver's door lock will not unlock
- Major oil leak after dealer service
- Need help repairing this problem *details inside*
- 04' Only Driver Door Power Lock Works Tailgate Won't Lock even with Key.
- 2005 CRV Noise during starting
- 2019 CRV-LX 2.4 Engine cleaning intake valves
- CR-V Intermittent misfire / rough idle
- Auto 97 crv converted to 5 speed b18
- Trailer harness connector wires
- Anybody on Accord coilovers?
- Buzzing noise when CRV is off
- need help to identify part
- Transmission Issue
- 2002 CRV Radiator Fan Not Turning On
- 07 CRV front drop
- Dashboard alert message 2013 CRV
- Help with JDM CRV ENGINE & TRANNY SWAP !!!!
- Element Overheating
- Chirping Noise After R&R of A/C Compressor
- Fluttering at 1500 rpm
- Transferring 1997 Honda CRV transmission to 1999 Honda CRV
- First Gen CRV largest tires?
- NEW BATTERY NEW ALTERNATOR CAR SHUTS OFF AFTER DRIVING
- Do you add PAG oil when replacing desiccant drier?
- Exhaust smoke when hot
- 2001 Crv fuel line and Brake line
- Need Advice On 2000 CR-V Oxygen Sensor Graphs
- B20Z Timing Belt (and other parts) Replacement EXTENSIVE GUIDE
- rd2 gearset swap
- Rd1 Crv clear rear side marker lights
- Rd1 Crv rear disk brake conversion
- Rd1 Crv
- What's a Good Brand for an A/C Compressor?
- Pumping money into a pre owned 05 honda element ex 2.4l
- SCS Service Connector for HDS / HIM. Is this it?
- Is my alternator bad?
- 2017 CRV stuck at 15 mph
- P1399 '00 crv
- PSA4 transmission vs Z2M4 trans
- Help Troubleshooting 1999 Honda CR-V 2wd
- What to Check on a 2007 CR-V Before a Cross-Country Road Trip
