View Full Version : Honda CR-V & Element
- Upgraded 12-hole injectors
- Will not start
- 2000 crv Driver (left) front power window common ground
- ECON causes jerking?
- Fob not working immobiliser stopping from starting
- Problems after timing belt change
- 97 Honda CRV no crank
- Persistent Charging Issue - 3 Alternators later!! Ugh!
- 01 Crv timing marks not lining up
- P0139 H02S S2 Slow Response
- Looking for other owners of 2002 jdm (2nd gen) owners
- Hitch for Bike Rack
- 2 items can they be related??
- Reinstalled original headunit but the radio/audio options are gone
- A/C Problems
- 2001 CRV head gasket
- Automatic to 6 speed manual in FWD Element
- 2013 CRV timing
- Lifted 2005 Honda CR-V won’t align
- Air Conditioner Issue - 2003 CRV
- Honda Element JDM Swap Issues - Please help! Sensor Problem??
- 2001 CR-V, Aftermarket Resonator-Pipe B & muffler flange don't fit
- JDM crv Immobilizer Problem
- changing trans fluid lift procedure
- 2011 CRV vibration sound
- 2011 CRV EXL clock issue
- 2006 CRV Shift Lock Cover Missing
- 2000 CR-V shuts off intermittently
- Which gen 2 is awd
- 2013 CRV LX PART OF MULTI INFORMATION DISPLAY INOPERABLE
- 2013 CRV LX AWD. INOP RADIO - ASKING FOR CODE
- Putting a 2006 honda CRV cluster in a 2003 honda CRV
- GSR Clutch In RD1 4WD??
- Replaced Side mirror now car won't start
- '16 CRV - Belt/Pulley Noise
- Remote Start
- 2002 Honda CR-V refurbished Throttle body?
- UNL88 fuel
- Honda CRV RD1 (97-00) JDM Power Mirror/Retract Wiring Diagram
- 04 crv, ignition key won't turn! Plz help!
- Auto fluid check
- 02 CR-V A/C works intermittently/cooling fan missing ground
- Low beams dim
- Honda element
- 2006 CRV Have a random clunk
- 2006 CR-V steering pulling both left and right
- 2019 crv-lx Brake fluid flush bleeding what caliper first and rest.
- 2.2 diesel charge weirdness
- 2002 CR-V: Chasing a fuel trim problem
- 1998 CRV Blinking Check Engine Light
- CRV Cat Location
- Please help error codes P0135 P0325
- 2004 CRV W/ recurring Code P0134: Help
- 01 crv 0420 code
- 2020 CRV Dual Pump Fluid 2 ok to use
- 2014 CRV rear brake hose replacement,
- Lower engine knock. (Best description i can give you.)
- 2003 Clutch master/slave replacement not working
- 2012 crv
- 1999 Honda CR-V won’t start
- CR-V 2002 simulating ABS sensor by a resistance
- SWC Key 1 and SWC Key 2
- The dreaded 3rd Gen CRV coolant pipe
- 03 CRV front right wheel vibration
- 2020 CRV Rattling near passenger dash
- Gear shifter hard to move
- 07 CRV Misfire JDM swap
- Error Codes 83-11, U0416:68 and P0B3B:03
- 2005 crv codes P0442 and P0457
- ISO: Factory Full Exhaust for ‘05 Element
- Does anyone know 100% if 92-00 /94-01 ignition switch fit 97-01 crv
- 2018 CR-V reverse issue
- Cylinder 1 misfire in 2002 Honda CRV
- B series injector differences
- Bluetooth Honda CR-V 2015
- Exclamation Point VSA and Check Engine lights are ion…
- 2010 crv p0172
- 2004 CR-V Cranks but Won't Start
- 2nd gen CR-V squeaking on the 2nd drive of each day
- Help! High revving idle on my 2001 crv
- Crv Diesel swap
- 99 crv / power loss
- 16" to 15" wheels - downgrade to smaller calipers?
- California emissions??
- 2002 Honda CRV - What is causing this noise?
- Random acceleration issue with 2011 CR-V?
- 2007 Honda CR-V engine whine
- Any way to reprogram the D3 button to be a D4 instead?
- Should I buy 1997 CRV with 250k miles?
- 2002+ engine remvoal - top or bottom?
- No heat on drivers side only passenger side
- 2001 CRV steering rack just broke
- 1998 CRV won't Start After Battery Replacement
- 2006 CRV TAILGATE LIGHT ON DASHBOARD.
- Clock not keeping Date/Time
- Honda CRV 2004 O2 Sensors
- VTEC woes
- Supercharger like whine when accelerating only 06 CRV AWD
- 03 CR-V wheel spec and tire sizes that can be used
- Bought an 03 Cr-V with an interesting set of keys
- Can someone confirm bulb part no. for 2003 cluster drive indicator
- instrument panel and radio not dimming
- 98 CRV Engine Flooding
- 1997-2000 RD Model CRV Window Belt Trims/Weatherstrips
- CR-V Remote central locking problem
- 09 CR-V ABS code 27-1 "A problem with ATP-NP signal output"
- Timing Belt Broke at only about 20K!
- Honda Element P2646. Is the factory service manual wrong?
- 2017 Cr V O2 sensor replacement
- Code P0420 - Catalytic or O2 sensor?
- Suspension
- Boost options / swap options for crv?
- How to replace 2003 CR-V Bypass Solenoid Valve
- 2003 CR-V Fuel tank pressure sensor
- Noise at 1500 rpm
- Stalls going into gear
- Tire chains - front wheel only? - AWD
- Front brake pads
- CRV Code P0456 2008
- Intermittent tachometer issues on 2004 crv ex
- 2008 CR-V 2.4 NO-Start
- Antenna for 2005 crv
- Repair book
- Gen IV MV7A tranny filter
- 2002 CR-V hard start, wont rev past 2,750rpm
- 1999 CRV crank no start, no AC clutch, new ECU
- 2005 CRV EX P0685 question
- 2008 crv valet switch location?
- 2005 CRV Transmission question
- Best way to clean stripped interior in crv was flooded
- Engine jerking at low Rpm
- 02 Honda CRV - shot off while driving , no start, oil pressure light on
- 2005 CRV Transmission Whine
- 2005 CRV 4WD Transmission fluid type
- 2002 Honda CR-V won't stay running
- 2005 CRV rear struts
- What window visors are these?
- Humming/buzzing/grinding sound on cold start 2001 crv
- Arm Rests For 2002 CR-V Manual Transmission
- 2006 Honda CR-V AWD system upgrade
- '03 CRV 2.4l
- Lifting 98 crv
- 2001 NO DRIVING LIGHTS
- 97 crv rough idle at start from cold.
- 2009 AWD CR-V questions
- Could someone please help identifying
- Story of my life..Need help identifying this motor/Trans!
- Positive camber on lifted crv
- 2005 CRV shifting problem
- Steering Rack Play
- Honda CRV 2005 Front impact Sensor
- 2001 CRV cuts off randomly
- Can't lock/unlock driver door on 97 CRV
- 2001 honda crv. cranks but not start after driving 30 or so mins.
- Crv running rough once warm
- P1107 DTC on 1998 CRV EX A/T
- Interchangeable T Brackets for Manual Transmission
- automatic transmission
- 99 crv output shaft seal leaking
- 2002 Honda CRV - Battery Light
- 99 CR-V fuel smell
- 07 CRV Alternator top bolt replacement.
- Add Driving/Fog lights to CR-V?
- Thinking about buying a 2009 CR-V
- BG Induction Service
- Install New Steering Wheel Grip in 2015 CRV LX
- 2005 CR-V Dash Electrical issues
- Removing VTC strainer ?
- 2012 CR-V Snow Chains
- 06+ Civic Si seats on a 2005 CRV, seat belts
- ABS
- Engine Misfires and low power after swap
- Bad Alternator yet Charging System Light stays off
- 1998 Honda CR-V locks act weird
- 2016 CRV service reminder A16
- 2005 CR-V tuning - Nothing?
- Need help with using Vtec head
- Does the front guard reduce the damage to the car during a front collision?
- K20 K24A1 swap
- 2004 UK CRV cluster pin out
- Grinding sound on cold start - Honda CRV 2010
- 2002 CRV Multiplex Controller?
- Replacing manual seats with power, 2019 CRV
- 2016 CRV AC Blower Motor in and out
- 2007 CRV power steering suction oring question
- LEDs for 2016 CRV EX-L
- Need Help. 2003 Element Crank, no spark, no start
- Hey everyone. I'm trying to make my stock b20z2 to run on e85
- Battery light goes on and off
- 99 CRV Crank but won't start
- CRV 2004 Electric Window Switch
- 2004 CRV flashing engine light
- Transmission solenoid problems
- 98 crv ac/heater drain tube?
- Should we always buy a Genuine Honda Knock Sensor ? If you buy aftermarket..
- 3rd gen CRV header info needed.
- 2011 honda Cr-v engine Swap
- What is this?
- Lowering Spring H&R?
- Broken cam timing eyelets (cam locks)
- 98 CR-V timing belt tensioner -- the MAGIC move
- Convert pole antenna to shark fin
- Brand new 2021 CRV Touring PROBLEMS
- Heater problem Mk 4 CRV exec
- replace timing belt times
- 2004 CR-V Alarm System wiring diagram needed
- Used Engine
- Honda CR-V 2007 P2135-Please help
- 2003 CR-V Intermititent Starting Problems
- 1997 crv rear cv shafts
- 09 CRV .. VSA & 83-1/Permanent DTC Code
- 2006 crv se 132k rpm 5k at 80mph
- Troubleshooting 1997 CR-V electrical issues
- Help recognizing this broken cable
- 2003 HONDA CRV COILOVER HELP 2ND GEN
- "Lost communication with four wheel drive clutch control module" code U0114 and P0962
- Condenser Fan short and now bigger problems.
- 1998 CR-V Fuel Gauge Test
- 2015 CRV Doors unlocking by themselves
- A/C New not cool/ Knock EGL/ - new JDM motor good story
- Driver's door won't unlock using switch on 2004 Honda CRV
- 2011 honda CRV shudder
- 2000 Honda CRV smoking at idle
- Is this belt tensioner bad?
- 2013 Honda CR-V Linear Solenoid
- 2002 Honda CRV ????
- Rear differential leak
- 2012 Honda CRV Drivers Side Mirror replacement (Glass only)
- '09 CR V Cooling Issue
- Moar 2002 CR-V AC compressor questions...
- 2013 crv exl phone won’t pair keeps searching
- Timing chain clicking
- Looks like my strut mounts are starting to fail...again
- what is this valve/part 2004 CRV
- No Start After Crank Pulley Reinstallation
- 2013 CRV A/C High/low Pressure
- crv 98 ac issue
- Not working autolevel Crv 2007 European model.
- Gen 2.5 crv transmissions
- Power Window Not Working (Rear Passenger)
- 2002 CR-V AC Compressor Question
- 98 crv intermittent battery light
- 2006 CRV EX CLIMATE CONTROL LIGHTS
- Valve Adjustment Too Loose? (Video provided)
- 2000 CR-V P1336 Code
- 09 CRV inner tie rod end rubber stopper?
- Honda Element is not starting
- Need Advice On 2000 CR-V Sputtering. Bad Igniter?
- Hello my Honda CR-V won’t start.
- OBD2
