PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Pinging and Code 45 Help
  2. bolt sizes
  3. Honda CR-V 2000 LX 4WD - power steering adjust bolt?
  4. Honda CR-V 2017
  5. Need Advice On CR-V Purchase
  6. 2008 Hinda Element
  7. Need help!!! 2000 CRV Rear Mount T bracket!!
  8. How come no abs ring on outer cv joint?
  9. I think my timing belt is loose. Does this sound right? (01 crv)
  10. Part Identification
  11. Project 2012 CRV questions
  12. 03 Crv JDM swap ?
  13. 2011 CRV Front Transfer Case
  14. Root audio screen of Honda CR-V 2018 LX
  15. Touch screen of Honda CRV 2018
  16. Odd Door Issue 2001 CRV
  17. CRV Gen 1 5sp MT - weak reverse gear?
  18. Shopping CR-Vs for Wife. What to Look for?
  19. 01 crv b20b swap no fuel no spark.
  20. 2004 CRV suspension problem
  21. New CRV smells hot
  22. where can I buy a cheap catalytic converter?
  23. Replacement Tires for Honda CR-V 2017 Touring Edition
  24. found noise in engine and good and bad mechanics
  25. Pilot horns in a CRV
  26. Door Handle Repair and Clean Ups to my 99 Cr-V
  27. High Beams Only, No Regular Headlights!?
  28. Crv rear diff
  29. 98 CRV ac belt needs tightening
  30. 2003 Honda CRV rear crank seal
  31. Clutch question, not trusting mechanic
  32. Another front end shake thread
  33. 2002 Honda CRV KYB struts
  34. CRV RD1 ECU Pinout Needed
  35. Hanging rpm between shifts
  36. Honda CR-V 2017
  37. 2002 Honda CRV Front suspension query
  38. 2009 CRV suspension
  39. Brake Caliper Pistons Overextended
  40. Busting THEM
  41. 2002 Honda CRV
  42. 2005 Honda CRV - Headlights on alert
  43. CRV Front/Main Screen wont turn on.
  44. Help 1999 honda crv camshaft pulley
  45. 2000 Honda CR-V codes
  46. 2012 crv driver seat . Help a girl out.
  47. 97-01 crv rd1 tailgating button doesn’t work I have to use key how to fix
  48. 2000 Honda CRV worth fixing?
  49. CRV Petrol Knock Sensor ECU Bias Voltage?
  50. 2009 honda crv VSA modulator brake fluid bleed
  51. 1998 crv auto rt4wd “270k On. Chassis”. Questions regarding transmission flush
  52. Custom lift springs reasonably priced.
  53. 2018 CR-V Low Battery, doesn't start without assist, and barrage of Problem Messages
  54. car wont start
  55. Wiring GPS tracking/Alarm to 2004 CR-V
  56. 2009 CRV starting issues
  57. Humming sound at speeds more than 30 mph...
  58. Real time Awd to Full time Awd conversion; a discussion
  59. How to install camber ball joints
  60. 2004 CR-V trim, what is it called?
  61. AC blown, should i change AC type?
  62. Honda CRV Sputter
  63. 2007 Honda Element transmission problems
  64. Help! 2003 CRV AWD | Progressively Loud Noise Into Shutters! (Passenger Side) w/ Vid
  65. I shorted bulb, fuses good, 1/2 of lights are out
  66. 2016 CRV - texts reading out loud
  67. Jdm B20b Ecu Help
  68. 2009 Honda CRV Rear Panels
  69. Please 'splain this to me
  70. CR-V with TSX head???
  71. 2003 and 2006 Japanese Crv instrument cluster wiring required
  72. Charge lamp weakly lighting or not lighting
  73. Honda CR-V MKIII headLight
  74. 2008 Honda CR-V Multiplex Unit
  75. 2000 USDM Honda CRV with JDM B20B Crank No Start
  76. Auto to manual
  77. Auto to manual
  78. Crv H2b swap AUTO
  79. Steering issues; Axle compatibility
  80. Engine light is on, error code p0135 and p0141.
  81. 2013 CRV vibration when accelerating
  82. 07 CRV on H&R springs
  83. Not your typical crank no start...
  84. New Transmission or Just a Fluid Change?
  85. Distributor Rotor Off 180
  86. 2002 Honda CR-V Passenger Side Oil Leak
  87. 02 CRV Tachometer does not work on wet/damp mornings
  88. Is my immobilizer working?
  89. Help? Strange possible coolant leak issue?
  90. Anyone know what this is?
  91. RD1 CR-V Frame Stiffener Question
  92. 2014 CRV throwing tire pressure light all the time
  93. Replace fog light bulbs
  94. ABS problem
  95. Catalytic converter problem
  96. K20A4 European CRV performance upgrade Help
  97. Oxygen sensor pinout
  98. Whine before and after installing new power steering pump
  99. Honda #14120-RAH-H00 camshaft
  100. 2005 CRV - oil consumption & P0341
  101. 2006 Honda CRV Propeller Shaft Replacement forgot to mark
  102. 2011 CRV code 2422 evap system vent solenoid valve stuck closed
  103. 2004 Honda Element fuses/electrical
  104. 2003 CR-V Oddities.
  105. Honda CR-V 2017
  106. 2007 CRV DRL Relay location
  107. Honda Element Key Won't Turn in Ignition
  108. Horrible sound quality and interference from FM in 2014 LX
  109. Jdm accessory belt sizes
  110. 2019 CR-V Beeping After Starting
  111. The 2012-2016 non-CVT vibration roll call and brainstorming thread
  112. 2020 Hybrid CR-V for US market?
  113. VSC light on, car shutters/bogs during harder than normal acceleration
  114. 04 honda crv stuck N park
  115. P1259 & P2646 codes - Tried everything!
  116. Extended Warranty Honda CRV 2018 EX
  117. 2014 CRV for my son
  118. Crankshaft and bearing size
  119. AUTO VS MANUAL INTERMEDIATE SHAFT
  120. How can I make a 2015 CRV recognize my phone??
  121. Help! Finding correct TCC solenoid for unidentified transmission
  122. Is $1100 Reasonable for 2010 Honda CR-V 100K (B14) Maintenance?
  123. 2009 CRV A/C = Dead
  124. 2004 intake on 2006 crv
  125. Looking for ground near internal fuse block on 2015 cr-v
  126. Solenoid buzz form both back doors
  127. 2003 Crv idle problems
  128. Gsr Crv
  129. what would the cost be to replace the rear differential bearing
  130. 2005 Honda Element | Driver/Passenger Power Windows Not Working
  131. 2000 Honda CR-V cylinder misfire. Please help troubleshoot
  132. 2012 Honda CRV AWD
  133. First crv project. troubleshooting
  134. 2006 CRV diesel like noise
  135. How much oil has been consumed after the oil level dropped from Full to Add line?
  136. Honda p/n 52390-SWN-305
  137. 00 Crv crank but no start after replacing wireset
  138. Honda CR-V needs a lift
  139. 2000 Crv Losing Power
  140. Paint code question!
  141. I need real help real fast
  142. 2007 CR-V blows warm air while idling.
  143. Passenger engine mount vibration
  144. 1998 cr-v speedometer isn't working
  145. Weird noise when slowing down
  146. 98 crv head bolt torque
  147. 2019 CRV, front end sensors went off
  148. Honda CR-V 2016 Smart Key System
  149. Gear Shift Panel Repair/Replace 2011 CRV
  150. 2014 CRV - can it disable VCM?
  151. Rear headrest
  152. Cassette player problem
  153. 2016 CR-V question
  154. CR-V engine oil problem
  155. 4 Wheel Drive CR-V: Is It Necessary To Replace 2 Or 4 Tires At A Time?
  156. Starting system corrosion
  157. 2013 CR-V High Mount Brake Light Bulb Replacement
  158. 2012 known problems?
  159. Sound, vibration, etc , HELP
  160. [Honda CRV 2010] Piston replacement vs Engine swap vs other options?
  161. 1997 Honda CRV Pesky Oil Leak
  162. Crv Awd 4th gen
  163. 2000 CRV Driver door lock issue that hasn't been posted about. Help please.
  164. 12 CRV - high beam headlight issue - voltages
  165. Honda cr-v 2002 vibration
  166. 1998 tranny mounts
  167. Transmission Software Update - Can it be Reversed?
  168. Heater pipe removal
  169. check engine - CR-V 2004
  170. 98 crv head bolt torque
  171. 2000 crv Evap issue
  172. 71-80 dtc code
  173. 1999 CRV into light work vehicle
  174. Timing Belt Snapped - Noisy Valves
  175. 2002 Honda Cr-v 5 speed
  176. electric gear shift fail
  177. 2018 honda crv ex-l oil drain plug torque spec.
  178. 2005 CRV dash light P, R, N, D not lighting up
  179. 05 no power steering
  180. Honda Element front springs &absorber
  181. Unknown device found on crv
  182. 2007 CRV front seat interchange
  183. New key with remote transmitter
  184. Putting a 2wd trans in a 4wd CRV
  185. 2000 crv shifter
  186. 2002 CRV ignition / chip reader/ immobilizer issue. Need advice please!
  187. More power
  188. 98 crv offroad
  189. 2019 CRV-Disconnect negative post
  190. 2009 Honda CRV oil leak? Pictures included
  191. 2018 CR-v whining after shut down
  192. Honda CRV 2008 2WD LX (Base Model) - AC blower stuck on Defrost....
  193. 1998 Crv no hot start issue.
  194. 2008 CR-V EX evaporator water drain line replacement help
  195. 2000 Honda CR-V crank no start
  196. 2008 CRV airbag light.
  197. 2013 CRV AWD light stays on
  198. RE4 - Smart Key Operation?
  199. hondalink?
  200. 2000 Honda CRV shudders at 30 - 40 mph
  201. Teggy b20 swap
  202. Bad A/C Compressor, or black death?
  203. Vent control
  204. gas smell
  205. 35100-SCV-C11 vs 35100-SCV-C10
  206. 98 CR-V starter no crank
  207. ECM replacement
  208. 2019 crv lx bluetooth text
  209. Power steering pump
  210. Bogging at low rpm
  211. 2001 CRV Missing Crank Position Sensor
  212. 2003 CRV intake issue
  213. 1999 Honda crv awd grinding while accelerating
  214. Problems with CRVs
  215. 2005 Honda CR-V Transmission Help
  216. 2008 CRV Wheels on a 2019 CRV
  217. CRV smells like gasoline and oil on warm startup
  218. 2002 honda crv NEED HELP!
  219. 2000 crv stuck in park
  220. '02 Lx air/fuel ratio sensor, code P1167
  221. 2003 crv combustion issues
  222. Quality Aftermarket Axles?
  223. 1st gen honda cr-v vs 2nd gen honda cr-v
  224. 2000 CR-V silence horn upon remote lock
  225. Honda Parts and Accessories - ONLINE
  226. Honda CRV help.
  227. Center stop light works; lower ones don't
  228. If motor mount doesn't fit will car be loud?
  229. Honda CRV 1996 - Leaking brake fluid.
  230. So I have a 2000 crv and my rear passenger side tire is toeing in any advice??
  231. Replacement motor mount doesn't fit!!! ???
  232. 2006 ABS / VSA misbehaves - disable?
  233. Honda CR-V 2003 key won't turn AND Stuck in park
  234. Tail light stays on
  235. Transmission Removal need help
  236. Shaking W/Out Power at 60, With Power at 75 MPH
  237. 2001 CR-V with a "dead cylinder" - Is the engine ruined?
  238. 2011 CR-V AC Evaporator Core Problem
  239. Electrical Weirdity
  240. Shaking at 80 mph
  241. 2006 Honda CRV No Start
  242. 2000 Honda crv crankshaft
  243. 2000 CR-V intermittent back-up lights
  244. PGM-FI
  245. Easy Crankshaft bolt removal CR-V 2001 Gen1
  246. Help!!! Honda CR-V 2.4 2015, the gear lever is not smooth?
  247. Oxygen Sensor Replacement
  248. 08 CR V blowing warm air after charge & engine revs in park
  249. 1999 crv power outlet not working
  250. 2000 CRV overheating
