PDA
View Full Version : Honda CR-V & Element
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24
  1. Wanted to no if anyone on here knows if the center part of a jdm rd1 steering fits on
  2. Name that sound!
  3. CRV 2007 - how to flush/drain coolant
  4. battery
  5. 2007 crv
  6. Could someone P-L-E-A-S-E help - 2005 Element won't start
  7. Connect alarm with lock and unlock of doors Honda CRV 98
  8. v6 crv
  9. 05 CRV Kraftwerks Supercharger A/C problem.
  10. 99 crv help needed
  11. Lower Differential ratio
  12. motor swap vancouver??
  13. Terrible Axle Vibration w/ Aftermarket - Which to Buy?
  14. High Beam light in instrument cluster does not light
  15. 2001 CRV - adjust timing after dizzy seal change
  16. HONDA CRV 2001 OVERHEATING OIL LEAKAGE
  17. Rock Auto DEA/MRC Motor Mounts...Quality or Crap?
  18. excessive oil burning
  19. 2001 crv dome light issues
  20. Broken Axle Vibration Damper
  21. 1998 crv dull grinding
  22. Only P0497 - no other codes, no other symptoms
  23. 96 SMX B20B Headgasket question?
  24. Honda crv 2000 sunroof problem
  25. DIY Auto transmission overhaul help/HELMS manual
  26. After market remote starter - 2016 Honda CR-V
  27. Second-hand CRV tips? What to look out for?
  28. Crv gen1 bull bar. Please help
  29. '99 CRV Roof Basket/LED Light Bar Setup
  30. 1999 CR-V, engine stalling.
  31. Hood Latch Cable Replacement
  32. '98 CR-V Hood Latch - Broken Spring
  33. Rear diff questions?
  34. Crv gen1 (2000) lift spacer. Please help
  35. What could this vibration be???
  36. 98 CRV auto trans test port?
  37. Overheating and exploding radiators on a 01 Crv AWD
  38. Radio Trade
  39. Jhoyrr
  40. 08 Element old problem...Newbee here
  41. 2000 CR-V 5pd Rear Motor Mount
  42. 1998 CRV Shuts off driving wont turn on..
  43. 2000 CR-V Steering wheel Wiring diagram !!
  44. code P0341+ with high oil consumption
  45. Found a plug of rubber blocking coolant to FITV! Fixed my idle issue!
  46. Timing Chain Cover
  47. Windshield wipers always on top speed, Cr-V 2009
  48. Changing fuel injector 2003 CRV EX
  49. Who wants to play "What's that noise?"
  50. Non interchangeable fuel pump?
  51. 2000 CR-V Non-OEM front bumper ???
  52. Help please. Crv won't start, i'm to far from my house.
  53. 2000 CR-V Nerf Bar Reserved Mounting Points
  54. Cruise Control Indicator - Electrical Issues
  55. Turn signal lights
  56. 2000 CR-V Roof Rack Options !!!
  57. 2005 CR-V EX water leaking rear spare well...
  58. Replacing the interior clock?
  59. 00 crv how much hp can the stock cv axles handle and the drive shaft
  60. 2nd gen lift spacers
  61. Installing a JDM window deflector
  62. 2000 Honda CRV No start , No spark
  63. CRV 2002 won't start
  64. 2001 Honda CRV - draining battery
  65. B20vtec code 43
  66. 2015 CRV idle vibration finally fixed by dealership
  67. 14mm "S Bolts" off a CRV
  68. 14mm "S Bolts" off a CRV
  69. Loud noise from passenger side of motor
  70. 2000 CR-V Oilpan gaskets replacement !!!
  71. CEL, radio and tach not working
  72. Misfiring CRV StepWgn : Fixed
  73. Help finding starter for b20 standard?
  74. Code P145C and P0497
  75. Issues after swapping K24A1 in 05 CR-V
  76. '06 CR-V -whining noise and oil press light on
  77. Blow me... softly.
  78. 2013 honda crv need to help
  79. Loud Mystery Squealing noise - Rear End
  80. Gas Pedal won't depress, mapley smell, sputtering
  81. '99 CRV Coolant Leak - Help!
  82. Cranks but won't start
  83. 01 Honda CRV wiring issue
  84. Honda 2013 CRV
  85. Go buy General Grabber AT2's Right Now!
  86. Rear seat belt replacent, remove interior panel
  87. 2nd Gen: Anyone fitted 215/75/R15's?
  88. Need Assistance: 97 crv misfire issue Compression/Leakdown OK
  89. CR-V headlights
  90. New 5spd Gen 1 CR-V Owner & Proud Of It!
  91. Crv no start. help!
  92. RD1 Floor mats
  93. Honda CR-V 2006 slow to crank randomly
  94. Rear spoiler installation 1st gen
  95. 225/70R15 or 215/75R15 ?
  96. Troubleshooting electrical issues on 1997 crv
  97. 2002 CRV Hood Paint Peeling - Which model years are the same fit?
  98. 2004 CRV keeps kicking out of overdrive
  99. questions about test drive of 04 CR-V EX
  100. Honda Crv steering
  101. 2005 Crv MasterSwitch recall.
  102. 04 crv- replaced driver window switch, now srs light is on
  103. 98 Cr-V noise help
  104. CRV engine fan starts when you start the car
  105. 2005 CRV alarm problem
  106. Where to get the plastic end part of the nerf bar
  107. Which size tire? Upgrading to a 16"
  108. Dull white paint
  109. Gen1 CRV - Metallic Sound
  110. squirrels fighting sound when AWD engaged 2001 Auto
  111. 1998 Honda CRV Trans Problem
  112. 2008 Honda Element can powerslide, 2006 CRV can not
  113. 03 CRV REAR 2" SPACER LIFT HELP!
  114. 2001 Honda CRV cranks but no start...intermittently!
  115. Compatible parts USA vs JAPAN - 03 CRV Transmission parts
  116. 2014 Honda CR-V, error U0114?
  117. Toyota Rim with 60.1 hub bore on 2000 CRV ?
  118. 2000 CR-V 5spd Lower Balljoint Removal !!!
  119. 2006 crv offset for new rims
  120. 2000 CR-V Front Jack Point !!!
  121. 16x8 +0 offset?
  122. Just the Clutch, or the whole Compressor? Thoughts?
  123. Factory Subwoofer 2nd Gen CRV
  124. Srs module (airbag unit)
  125. 2006 CRV clutch master cylinder exploded
  126. Need help with neutral safety switch
  127. crv door removal
  128. 2006 Honda CRV only 50k miles electrical problem?
  129. 04 Element SRS Module Replacement
  130. 97-01 CR-V Bi-xenon Headlight Retrofit !!
  131. 97-01 CR-V clock issue fixed !!!
  132. 2013 honda crv
  133. Crankshaft pulley bolt - 98 CR-V
  134. legit site to buy parts from
  135. 2nd Gen CRV clutch pedal excessive resistance
  136. Stock 01 CR-V Radio/Cd Unit in 00 CR-V ?
  137. what head do i need?
  138. '01 CRV Diagnosing Low Compression
  139. 2000 CRV Driver window won't go down.
  140. 2000 CR-V 4WD 5spd Keyfob questions !!!
  141. Brand New 2016 CR-V Questions...
  142. Ap1 Steering Wheel into Gen 1 ( 2000) CR-V 5spd ?
  143. 05 CRV SE awful gas mileage
  144. AC Doesn't Switch to Heat
  145. 2nd Gen CRV glove box switch issues and fix
  146. 2nd Gen CRV tail gate switch issues and fix
  147. '09 CRV Fan problems
  148. 98 Honda CR-V Idling revving problem
  149. buying cars from auctions
  150. 03 CRV EX Fuel Cut HELP!!!!
  151. too much?
  152. Lift, Minor Maintenance, and Compression Test
  153. Honda CRV 2005 problem
  154. duplicate key for 2004 honda element ex
  155. Possible Interior Fuse Disaster - 2011 CRV
  156. CR-V aftermarket rims
  157. Lifted CRV, CV axle shake
  158. Need More POWAHHH. 1998 CRV
  159. JDM engine swap complete: Getting O2 code on '99 CRV - Help decipher?
  160. Iso help with my 01 crv
  161. Abs light after wheel bearing replacement
  162. 2011 CRV Heater Problem
  163. 2016 CRV, dual air issue, passenger side won't blow warm air
  164. 2005 CRV heating blowing hot and cold
  165. Help: 98 CRV Low Idle and Weak Power
  166. 2003 rear seat question
  167. How to put a GSR transmission in your RD1 ( 97 98 99 00 01 CRV )
  168. Head Gasket problem
  169. Starting and Idle problem
  170. ['04 CR-V] Logical/plug-n-play type engine swaps
  171. All Power Door locks not working with the remote key
  172. 1999 CRV Alternator brush assembly: Doesn't match up
  173. Sick 1999 CRV
  174. 1998 CR-V low beam headlight issue
  175. 2007 CR-V Oil Pressure Sensor
  176. Black paint(?) at the base of the window wearing off
  177. 99 crv cranks, but won't start
  178. 2000 crv transmission issues?
  179. 2005 crv HID install help (morimoto H1)
  180. Odd popping sound under acceleration 2001 CRV
  181. 2006 CRV VTEC solenoid filter replacement
  182. Looking to get another RD1
  183. K24A1 into Element
  184. 2000 crv overdrive / torque converter issue
  185. 1998 crv head work
  186. Rebuilt engine suggestions
  187. doing the ckf bypass on crv
  188. Need help swapping b20b into 2001 Honda CR-V
  189. '98 CRV sputtering around 30mph?
  190. new axle problem
  191. Honda CRV 2004 Engine Stop While Driving
  192. 2005 crv coolant temp gauge reading low
  193. CRV 2004
  194. different crank pulley sizes
  195. A/C blower has low setting only
  196. '00 US to JDM transmission swap problem
  197. crv clutch 98 different then 99?
  198. AC works, then doesn't
  199. 1998 CR-V rattling noise while decelerating - Manual transmission
  200. 2015 CRV (Crystal Black Pearl) Trim Paint
  201. 2009 CRV 2.4 auto to manual swap?
  202. Noise there and gone
  203. A/C pressure switch
  204. White smoke from tailpipe (certain conditions)
  205. 09 CRV Fuel Filter Replacement/Location
  206. Honda CR-V 1997 Ball joint press kit
  207. 98 CRV
  208. 2013 CRV no compression on cylinder 1
  209. Replaced starter, car overheated
  210. 07 Element overload
  211. jdm high comp into a 98 crv
  212. need help on my 1st Gen CRV
  213. 2000 CRV- how to slow rot of rear wheel arches?
  214. '04 CR-V Bumper Scratches (plastic)
  215. '04 CR-V Dashboard Scratches
  216. Replacement Door Initiates Window Switch Issue
  217. Test Pipe on 2000 V
  218. Bluetooth button on steering wheel 2014 CR-V broken?
  219. Flow direction of Magnefilter for 2nd gen CR-V?
  220. 2004 Honda Element Acceleration Problem
  221. Crv tire swap!
  222. Just bought a 2004 CRV - Questions on brake and egine upgrades
  223. 1996 JDM CRV CEL and ABS codes
  224. '06 CR-V - need help identifying leaky engine component
  225. Modding a 2000 CR-V
  226. 1998 CR-V tachometer resistor R1 value needed.
  227. Lifted Gen 1 CR-V Reliability and Longevity
  228. 2007 CRV compressor replacement
  229. Honda CRV
  230. 2012 honda crv crank shaft sensor
  231. 2003 CRV LX, hesitation on acceleration but normal RPM. Please help!
  232. CRV engine mount help.
  233. B20B VS B20Z1
  234. New motor time
  235. CKP Pattern Clear/CKP Pattern Learn Procedure Help
  236. Rich STFT after replacing both O2 sensors
  237. '98 V door lock woes
  238. Replacing an AC compressor on 2005 CRV... is it a driveway job?
  239. AC DC adaptor - question
  240. Seatbelt stuck / locked.
  241. Used 05 CR-V what do I service?
  242. 2004 CRV AT Build
  243. Probably a dumb question but here it goes!
  244. Need help identifying a part
  245. Honda CR-V AC/dashboard light/ dimmer/break light/ head light indicator don't show
  246. Honda CRV 2003 A/C Clutch not engaging
  247. First Gen Rear Hub Bearing Replacement
  248. 2003 CR-V Windows
  249. 12V power plug removal
  250. 2005 cr v, CAT not ready?
