Transmission & Drivetrain Gearboxes, Differentials, Clutches
CC stage 4 after 4 years
Old 08-26-2016, 04:54 PM
Fishy_hondaman's Avatar
Default CC stage 4 after 4 years
About 300hp with a lsd, what you guys think of it?
Throwout bearing spins normal.
As you can see in the 2nd pic the spring holder (silver metal thats between the black metals) is broken missing a wall, the other ones are bend from spring pressure.
Some paper towel left behind and water from a wipe down
Old 08-27-2016, 12:07 PM
RTFM
v4lu3s's Avatar
Default Re: CC stage 4 after 4 years
I am impressed. My buddy had about 300 whp and 350 torque and had to replace his CC stage 4 every 2 years or so it was so worn out.
Old 08-27-2016, 02:28 PM
stolenracer's Avatar
wow looks good no hot spots. i am about to order a stage 3 for a dd turbo build. did you have any issues while using it
Old 08-27-2016, 04:59 PM
Yeah first gear engaged really late sometimes, like almost at the end when you let your foot off the pedal. It engaged fine tho. And it wasnt a cold start thing.
The more serious problem is the launch, you can rev it to like 3-4k before dropping the clutch and the engine would go like 3k 4k then drop back to 2k and "restart" the whole gear.
Made me loose some off the line races. I had a fresh CC stage 4 in a different car and it never had that issue.
Platinum Playa
01-10-2006 04:16 PM
lohatch
12-20-2004 09:58 AM
legendboy
07-16-2002 12:06 AM
dustin
03-21-2002 08:36 PM
Smurf
09-15-2001 06:04 PM
Quick Reply: CC stage 4 after 4 years
