d17 hunting idle update new problem need help
So a couple weeks ago I posted an issue i was having with hunting idle issue and got no help, so i replaced the whole throttle body with sensors I got from a junk yard. The hunting idle issue is now fixed, but im having an idle issue now. When I first start the car it idles perfectly at 750. Once I tap the gas the idle settles at 1200 and wont drop unless i turn the car off and restart it. What would be the next thing I look at to keep the idle at 750? I didnt reconnect the lower throttle cable, but I believe that's for the cruise control so I don't think that would be causing the problem I'm having. I also have no codes to indicate anything else. Thoughts ideas are appreciated. TIA
