05 EX Tricky Missfire
Howdy,
I am working on an 05 civic ex that has a bad misfire. It will barely idle and the misfire seems rhythmic and doesn't go away at higher rpms.
We have tried:
I tried swapping the coil pack with another cylinder and the behavior remained on the same cylinder.
So if it is cylinder-specific, and not compression, plugs or coil, should that only leave the injector as the problem? Upon visual inspection, The plastic part on the end of the injector surrounding the nozzle has a bit broken off. I was thinking maybe it is causing the o-ring to not seal.
Any ideas for what else I should check for?
I have a few days while I wait for the new injector. Thank you!
We have tried:
- new spark plugs (old ones were only a few months old but were dry and dark from rich I assume so wanted to rule them out)
- checked compression (all had around 210 psi)
- cleaned the throttle body and IACV
- Unplugged EGR
- Checked for vacuum leaks, couldn't find any. at Idle the map sensor is only reading about 8psi of vacuum (via obd live data) but with revving it got up to about 21 psi
Ledbellyhead
03-31-2014 01:53 PM
ttcheung97
09-24-2011 05:04 PM
Almost Jake
10-20-2009 08:03 AM
Chuck Dean
03-17-2004 10:16 PM
