Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Windsheild wiper fluid motor?
Old 12-15-2010, 02:55 PM
AutoXer's Avatar
Default Windsheild wiper fluid motor?
Hey all,
I've been having problems with my wiper fluid lately. One day, they weren't really working, but held the switch and eventually got flowing. Figured maybe the nozzles were just a little frozen and all was well.
After a couple days they stopped working again and just figured it was empty. My wife took the car to work today, as I was working on hers, and she just called me and said she filled the tank and there was no flow. This was a car that my Mom abandoned in my driveway so I have no idea what has been in there or for how long.
How do I tell if it's a problem with frozen lines / nozzles or the motor itself? If it is frozen and I pull the stalk, should I still hear the motor try to pump? Is there some other way to test the motor?
Thanks
Old 12-15-2010, 03:10 PM
ekb16's Avatar
Default Re: Windsheild wiper fluid motor?
if u can here the pump working then its good and not ur pump.
if u can here ur pump and then see a puddle of water on the ground afterwards then theres a leak somewhere in the bottle, lines, motor seal etc..
if u can here the pump, no leak but will not spray then ur nozzle is probably clogged
if u live in really cold climate then yes the fluid inside the bottle can freeze
Old 12-15-2010, 03:37 PM
AutoXer's Avatar
Thanks, that's what I was hoping. Just wasn't sure if there was blockage that it would stall the motor. I'll check it out tomorrow.
Old 12-19-2010, 11:24 AM
Pothole987's Avatar
wow even if it did freeze the heat from the engine should thaw it out enough...
Old 12-19-2010, 03:33 PM
AutoXer's Avatar
That's what I would have thought, but apparently that wasn't the case (it's been down in the single digits here.) I brought it into the garage today and let it sit after having the car fully warmed up and they thawed out. Ran a bunch of fluid through there so that the lines would be full with the proper stuff. New one for me, thanks guys.
moonchies
08-11-2017 03:03 PM
SLMachine
Welding / Fabrication
08-26-2011 07:12 AM
onereving7
Acura TSX
04-11-2009 12:38 PM
wdissident
02-09-2009 10:53 PM
VTECtravler
07-28-2004 01:18 PM
Quick Reply: Windsheild wiper fluid motor?
