clutch and flywheel
clutch and flywheel
I am installing a new competition clutch stage 4 and a fidanza flywheel on my 95 gsr. I have the flywheel bolted up and I'm trying to get the pressure plate bolted up to the flywheel but the alignment pins wont go through the pressure plate hole.Has anyone had this problem? How do you know which way the 6 puck disk needs to face? What parts store carry the pressure plate bolts?
Re: clutch and flywheel (95_red_dc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc »</TD></TR><TR><TD CLASS="quote"> I have the flywheel bolted up and I'm trying to get the pressure plate bolted up to the flywheel but the alignment pins wont go through the pressure plate hole. </TD></TR></TABLE>
Are the pins lined up but they seem to be too short? If this is the case try flipping the disk around. The disk flat side should go to the flywheel, and the raised part should go to the presure plate side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc »</TD></TR><TR><TD CLASS="quote">What parts store carry the pressure plate bolts? </TD></TR></TABLE>
You'll have to order those from Honda. They're rated, with a Hex head. You won't find them anywhere. And they're cheap. Do not use unrated bolts.
D Tranny Guru
Re: clutch and flywheel (paton5g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paton5g »</TD></TR><TR><TD CLASS="quote">
You'll have to order those from Honda. They're rated, with a Hex head. You won't find them anywhere. And they're cheap. Do not use unrated bolts.</TD></TR></TABLE>
Not hex head, 12 point instead.
Re: clutch and flywheel (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">
Not hex head, 12 point instead.</TD></TR></TABLE>
My apologies, they are 12 point.
luderone
09-13-2003 02:01 PM
