Transmission & Drivetrain Gearboxes, Differentials, Clutches
Highter rpm stall converter for automatic transmission
Old 10-16-2008, 07:56 PM
pureplayaz's Avatar
Default Highter rpm stall converter for automatic transmission
Does anyone make various stall converters for honda automatic transmissions? Shift kits exc....?
Old 10-17-2008, 10:15 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: Highter rpm stall converter for automatic transmission (pureplayaz)
Levelten does, but the stall increase is only 100-200 rpms. not worth the asking price.
Also since most Hondas I deal with turh "backwards" a local tranny builder doesn't know if he can do anything with the internals of the convertor.
The stator fins and everything else is backwards. He regular takes V8 convertors, cut them apart, tweaks then, then welds then back togther.
Stock Honda convertor for one application I looked up was 2600-2800 rpms, Leveltens convertor for same application was 2800-2900 rpm.
Since the 92-95 Civic has a two stage convertor, other tweaks can be used that would be controlled by the ECU.
Look up Buick Switch Pitch TH400 for some idea on this.
domingofig80
09-11-2013 09:44 AM
20-EM2-05
Honda Civic (2001 - 2005)
05-07-2009 10:01 PM
boosted k20
26
02-05-2005 12:33 AM
brenerb
05-22-2003 10:17 PM
Quick Reply: Highter rpm stall converter for automatic transmission
