Transmission & Drivetrain Gearboxes, Differentials, Clutches
lsd trans...
Old Oct 6, 2008 | 02:29 AM
1320king's Avatar
Default lsd trans...
im planning on getting a a j1 trans and puting a lsd in that. so if i put a lsd in what parts should i change in the trans any seals ect??
also were could i get those parts??
will the mfactory lsd work with this trans??
Old Oct 6, 2008 | 09:17 AM
Aquafina's Avatar
ISB/seal, axle seals, diff bearings, any bearings/hubs/sliders/synchros/gears/forks that need to be replaced. A complete rebuild is really not a job for a first timer.
MFactory LSD will work.
Old Oct 6, 2008 | 02:23 PM
1320king's Avatar
Default Re: (Aquafina)
well im not planing on rebuilding it i just wana put the lsd in and anything to do with the lsd to change...i dont wana mess with the gears to much.
and i just called mfactory and the lsd dont fit only ys1 trans.
Old Oct 6, 2008 | 02:39 PM
Aquafina's Avatar
O'really? I've put a non OEM LSD into a J1...
Old Oct 6, 2008 | 02:51 PM
1320king's Avatar
ya i called them and thats what they said so idk...
so what should i replace when taking out the diff?? not anything todo with the gears un less theres seals and stuff??
Old Oct 6, 2008 | 02:56 PM
Aquafina's Avatar
Default Re: (1320king)
I'll have to dig through my papers to see what all I did to that trans.
You need to check stuff on the gears themselves. Doesn't do any good to keep a gear if it is going to cause you problems.
Old Oct 6, 2008 | 05:17 PM
1320king's Avatar
well from looking at info on taking apart trans case dont look to bad the only prob. ill probbly have is setting the play on the lsd... cause i have a press and all the tools just what the parts to use to in stall the lsd, is there any seals for the lsd??
Old Oct 6, 2008 | 05:49 PM
Aquafina's Avatar
only the axle seals. all you need is a set of feeler gauges to install the LSD
Old Oct 6, 2008 | 11:54 PM
1320king's Avatar
also are you sure the mfactory lsd will fit??
HOODLOVER
51
Apr 8, 2021 04:47 AM
Mob4life
Oct 23, 2013 04:30 PM
Wh0 Iz UNREAL07
Nov 11, 2010 09:42 AM
Grat_Master
Feb 23, 2010 07:00 PM
lovey408
21
Sep 6, 2007 07:35 PM
