Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Front end conversion
Old Mar 23, 2010 | 11:37 AM
sk8board{Pete}'s Avatar
Default Front end conversion
is it possible to convert the 01-02 civic front end to the 03-05 civic.. similar to how it is done on the ek civics
Old Mar 23, 2010 | 11:51 AM
Pothole987's Avatar
Default Re: Front end conversion
https://honda-tech.com/forums/honda-civic-2001-2005-78/faqs-guidelines-read-before-posting-2101211/
Quote:
Q: What parts do I need to do an 01-03 to 04-05 front end conversion?
- A: You will need the hood, headlights (with brackets), grill, bumper, fenders, and radiator support.
Old Mar 24, 2010 | 08:16 AM
01em2slvr's Avatar
dont mean to steal the thread and sound like a noob but.... on the radiator support is it just the bootom or is it the whole front metal like where the hood latch is attached to ? help a guy out if u have pictures i would appreciate it. thanks!
Old Mar 24, 2010 | 09:58 AM
baron340's Avatar
the whole thing.. it requires you to drill and reweld the spot welds.
Old Mar 24, 2010 | 04:36 PM
It Wasn't Me's Avatar
Another tidbit from a different thread..
Originally Posted by StuntmanMike
The rad support is optional...You can get away with bending the mounting tab on the outside of the headlights but I don't recommend it. You can indeed drill out the headlight support portion of the rad support and bolt up the 04-05 style headlight bulkhead in place. The only other thing is the fender bolt closest to the headlight will have to be relocated no matter what. Other then that pretty straight forward. I did mine in about 8 hours taking it at a nice easy pace.
Old Feb 5, 2013 | 11:13 AM
thericepatch's Avatar
To do this conversion you will also need to wire the headlights from single bulb to dual bulb. Just had to do this so I figured I would share the oe diagram and the conversion. For the conversion you will need to wire the red w/white stripe to the low beam, red w/blue stripe to the high, and the solid red, red w/yellow stripe (depending on side) to both (I used black for the common).
Old Feb 5, 2013 | 12:07 PM
new bulbs and connectors are also required if you don't get them used with your headlights. they require 9005 for the high side and 9006 for the low side bulbs.
toyonda
Feb 18, 2013 08:41 PM
racerx510
Aug 5, 2012 12:33 AM
MauricioJDM
Aug 21, 2011 01:35 AM
EM2K20
Aug 5, 2010 04:35 PM
Black Maverick
10
Jun 30, 2006 01:59 PM
