Will a cat-back exhaust fix P0420?
One of my O2 sensors went bad but I didn't replace it and now my catalytic converter is messed up and throwing the efficiency code. If I just get a cat-back exhaust will the bad o2 sensor still throw a code or do I have to replace the sensor and get a new converter?
Re: Will a cat-back exhaust fix P0420?
the catalytic converter might not be bad, its probably throwing the code because the o2 sensor is bad. and getting catback wont solve the problem.
try getting a new o2 sensor and resetting the ecu. if the check engine light is still on then you may need a new cat.
Are there any codes in addition to P0420, rowo87?
Disconnect the battery, or remove fuse number 6 (15amp) from your under-hood fuse box.
Edit: I forgot to mention that you need to put your car through Idle Relearn if you reset the ECU.
1. Make sure all electrical items are off.
2. Start the engine and hold it at 3,000 RPM without load (in Park or neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 194° (90c)
3. Let the engine idle for about 5 minutes with the throttle fully closed.
If the radiator fan does come on, do not include its running time in the 5 minutes.
Hey guys thanks for the quick replies. The only code it's throwing right now is the P0420 but after driving for awhile the cat seems to seize up and prevents the car from accelerating beyond about 25mph than if I pull over and let it cool down it drives fine until it gets too warm. Could this mean then converter is bad? Or will the O2 sensor alone prevent this from happening?
Your car went into limp mode, its confused over how much air/fuel to use due to your O2 sensor(s). Replace them so the ECU can correctly measure how much air/fuel to use. After replacing your O2 sensor(s), reset by either deleting the code with an OBD2 scanner OR hard reset by disconnecting the battery for 30 seconds. I recommend the OBD2 method so you don't have to redo your radio settings.
The code should have mentioned either Bank 1 or Bank 2. Bank 1 = Before Cat O2 sensor, Bank 2 = after Cat O2 sensor. The first one actually determines the air/fuel ratio to be used. Second one checks the gases AFTER cat converter to make sure your cat is working right.
If they are not fried, you can actually try to clean them off with a sensor safe cleaner first.
Ken
Ken
Take it to Autozone, PepBoys, Advanced Auto, etc. etc. and have them check for stored codes.
We need to know all the codes that have been (or are being) thrown if we are going to provide remedial information.
shawnh55
09-12-2012 05:11 PM
Cashbrun
10-01-2005 09:47 PM
ShittyGSR
07-17-2004 05:59 PM
