Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine problems and srs
Old Sep 28, 2010 | 03:43 PM
deathkiller's Avatar
Default Engine problems and srs
I HAVE A CAR HONDA CIVIC 2003, WHEN TURN ON IN THE MORNING THE CAR AND THE ENGINE TEMBLE. On occasion WANT TO TURN UP AGAIN.
so does this when you have 1 / 4 or less fuel.
sorry not speak English
Old Sep 28, 2010 | 04:32 PM
CRX Si69's Avatar
Default Re: Engine problems and srs
Hey. I don't understand your English all that well, so I'll try and help as much as I can.
Is the Check Engine Light on? if it is get an obd2(I think thats what 03's are..) scanner and connect it to your ecu and see what code's it is giving you, Look them up or post it up here.
As for the Engine shaking, Check and make sure your motor mounts are tight and make sure they aren't broken/cracked at all. If it only does it when it's cold, try letting it warm up for a couple minutes before you drive. You aren't dumping the clutch when you take off, are you?
Good luck.
tarheels1
Jan 17, 2010 06:38 PM
Pruk
Dec 15, 2009 12:02 PM
my Efin SI
Dec 6, 2009 10:24 AM
berttheraider
Feb 18, 2008 06:53 PM
