Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
header problems
Old Oct 18, 2010 | 10:32 AM
Drewskii's Avatar
Default header problems
alright so unfortunately i live in california where everything is super strict. only dc and greddy headers are legal here. when looking i notice that i cant find any headers for the LX model, theyre all EX. the EX wont fit will they? if not what modifications do i need to do.
on a side note im also ordering an AEM short ram which comes with a CARB number. will they all come with a CARB number no matter where i order it from? or do i need or order it from AEM specifically?
any input is much appreciated
Old Oct 18, 2010 | 10:54 AM
husyk's Avatar
Default Re: header problems
If you go with an EX header, you will also get the rest of the exhaust system to work. As for the AEM SRI, your gains will be 2 bhp at best, you'll only notice the noise.
Old Oct 18, 2010 | 11:03 AM
toyomatt84's Avatar
Sanji
Look at the Drivetrain section under the FAQ's here: https://honda-tech.com/forums/honda-civic-2001-2005-78/faqs-guidelines-read-before-posting-2101211/
Old Oct 18, 2010 | 11:51 AM
Drewskii's Avatar
aright well i got a new exhaust so will the EX header fit to the new one?
sorry toyomatt couldnt find that in the FAQ
Old Oct 18, 2010 | 12:09 PM
Targa250R's Avatar
be professional
You won't be legal for emissions in CA. The DX/LX engine has the catalytic converter integrated into the exhaust manifold, where the EX has a separate manifold and converter.
AEM intakes are CARB compliant no matter if you buy them direct from AEM or from a distributor.
Old Oct 18, 2010 | 12:20 PM
Drewskii's Avatar
haha well i have a cracked manifold so i wont pass smog anyway...any suggestions?
Old Oct 18, 2010 | 12:41 PM
toyomatt84's Avatar
Sanji
Well, your options are pretty straight-forward:
1. Replace your DX/LX manifold with an OEM replacement (extremely costly, unless you can find one used).
2. Hunt around for an EX exhaust setup from exhaust manifold back (essentially the entire exhaust setup). You can re-use your DX/LX axle-back, but that is all.
Whether or not you want to buy an aftermarket, EX-based manifold is up to you.
Old Oct 18, 2010 | 01:01 PM
Drewskii's Avatar
yeah honda wanted to charge me something like a grand for a new manifold...so a full ex setup will work? will i have to get a new cat aswell?
Old Oct 18, 2010 | 03:37 PM
jdmhondaes1's Avatar
or you can buy a header that fits an EX than buy a megan racing test pipe that has a high flow cat in it from their website. thats what i did for my LX and it works really well
Old Oct 18, 2010 | 08:27 PM
Drewskii's Avatar
thanks man...so will i need to ditch my whole new exhaust system then? haha
Old Oct 18, 2010 | 10:53 PM
It Wasn't Me's Avatar
Unless you can cut and weld, you're not going to be able to mix exhaust systems.
DX/LX and EX and quite different. If you buy the aftermarket EX header, get an EX a-pipe (downpipe/catalytic converter) and b-pipe (mid-pipe), and then you can use the LX/DX axleback.
Otherwise you're stuck using LX/DX unless you buy an aftermarket a-pipe. (as noted by jdmhondaes1) But you'd still need the EX b-pipe to fit between the a-pipe (cat-delete) and the axleback/muffler portion of the exhaust.
Old Oct 19, 2010 | 09:04 PM
Drewskii's Avatar
i have a buddy with a shop that cut and weld so ill probably try that
Old Oct 20, 2010 | 08:30 PM
Drewskii's Avatar
ha found a guy to "pass" my car for smog
going with racing headers
ram50rocket
Feb 14, 2009 08:58 PM
Vermont
Feb 10, 2007 03:11 PM
b0yg0tskills
10
Dec 7, 2006 02:04 PM
Kidnkorner
Jul 15, 2005 08:20 PM
