Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Limp mode 4k rev
Old 08-12-2015, 10:31 AM
Colgatetotal13's Avatar
Default Limp mode 4k rev
2003 Honda civic ex 1.7 L vtec 5 speed. I was accelerating last weekend and all of a sudden when I got 4k rmp the car starts jerking and won't rev higher. I found that if I turn the key off pull it out and start the car it'll rev past 4k for a few minutes of driving then just does it again it's through all the gears and even in neutral. I looked into it and have found some people claiming VTEC solenoid and the code that is popping up that is some of the symptoms of the code it's reading also I can't find where to buy the solenoid.
Old 08-12-2015, 02:19 PM
Sanji
toyomatt84's Avatar
Default Re: Limp mode 4k rev
What code are you getting?
Old 08-12-2015, 04:47 PM
I'll have to get it checked again tomorrow I'm away from home and don't have my scanner
Old 08-13-2015, 04:20 AM
9919WV's Avatar
Make sure you check your oil level. If it's low then you'll have the same issue at 4,000 rpm
Old 08-13-2015, 05:15 AM
It's full
Old 08-13-2015, 07:19 AM
9919WV's Avatar
Originally Posted by Colgatetotal13
It's full
Bummer, that's what was happening to mine and it was an easy fix. Let us know what the code was when you figure it out.
tamadrummer1120
10-08-2011 10:41 AM
ef-hatchcrap
02-21-2009 05:10 AM
em1gangsta
06-27-2008 06:42 AM
shadykit
08-02-2004 06:11 PM
Audipwr1
06-30-2002 07:07 PM
Quick Reply: Limp mode 4k rev
