Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headlight problems
Old Sep 9, 2015 | 05:00 PM
wreckdiver21's Avatar
Default Headlight problems
2002 Honda Civic EX Coupe with 97k miles on it.
So I recently just replaced both my headlights because the headlight on the passenger side went out. It was fine for a day but then the following night I noticed the driver side headlight went out. I took the bulb out and put it back in but that did not work. The headlight only works when I turn the high beams on. Has anyone else encountered this?
Old Sep 10, 2015 | 04:21 AM
GriFFIthS's Avatar
Default Re: Headlight problems
Theyre a dual filament bulb, the lowbeam filament has likely burned off, just to be sure, try swapping bulbs from one side to the other. if the same bulb still doesnt work then its the bulb and not the connection to that headlight.
Old Sep 10, 2015 | 09:32 AM
K24_Y61P's Avatar
I've answered this a dozen times here. There is a recall on the turn stalk. The wires go bad and only your highbeams work. Take it to the dealer, tell them the recall and you wont have to pay a dime. This happened on my first civic and will probably happen on my current.
shouwen
Classic Hondas
Sep 19, 2017 06:28 PM
unclematt
Sep 1, 2016 09:39 AM
NOFX
17
Oct 11, 2008 04:25 PM
otsegolectric
Jul 22, 2008 10:47 AM
94ls
Jan 28, 2005 07:30 AM
