View Full Version : Want to Buy
- Wanted: P07-A00 or P07-A01 ECU
- wtb 96-00 hatchback CA STATE
- WTB: EK Coupe Parts OEM
- WTB: 99-00 Civic Coupe Tail light
- Need pure Methanol
- wtb: oem b16 pistons and oem ls rods
- wtb 850-1000cc high imp. injectors and gsr lsd tranny
- D16Y8 starter
- WTT: brand spanking new srp low comp pistons for high compression pistons
- wtb civic hatch but i have ??s
- wtb cheap b series longblock
- Wtb: RBC or RRC Manifold
- WTB: 94 Prelude Wings West lip kit
- B16 cable non LSD Cheap*
- WTB: 94 Integra front Brake caliper brackets or 94 civic
- WTB: Civic VX oem wheels, all 4, in PA, will pay for shipping
- Wtb: 99-00 civic secondary heated sensor
- WTB: H22A turbo camshafts and twin-plate clutch
- WTB- OEM Civic shifter
- WTB: B-Series CP pistons, valvetrain, cams...
- WTB: romulator, emulator ostrich 2.0
- *wanted* 2 bosch 044's
- Winshield Washer Unit for 96-00 Civic
- WTB: 95 Accord axles
- WTB: ITR front shocks/springs
- WTB Prelude F Rotors and other parts
- 99-00 Civic climate parts
- 96-00 Civic parts needed
- 90-97 accord mt
- WTB: Passenger windshield Molding
- WTB d16 skunk2 manifold or edlebrock
- WTB P75 Intake manifold
- WTB: 04-08 OEM TL Exhaust Tips
- WTB EK REAR AVID/HASPORT MOUNT
- Wtb OEM Ctr front and rear lips Need these ASAP
- WTB: B18B1/B18C1 longblock
- WTB: NEED HONDATA S300/Electronic Boost Controller!!!
- WTB: b18 parts
- WTB: CRX mugen exhaust
- WTB eg civic and dc2 integra parts
- Trying to find a PM7
- WTB: Obd1 P72 Ecu
- WTB 99 00 tan 5spd 4 door ex civic
- WTB 92-95 Civic SiR One-Piece Wing
- WTB: Skunk2 Pro 1 cams, or Complete head
- WTB ARC Winglets
- OEM GSR rods w/ bolts and bearings
- LF: Supertech Dual Valve Springs & Retainers - B Series Vtec
- WTB 88-91 Civic HKS Sport Exhaust
- WTB 94-01 DB8 integra 4 door mirrors blk or green
- Wtb: 90-93 Integra clutch cable.
- WTB: 89 WAGON TAIL LIGHTS AND FRONT CORNER SIDE MARKERS & More
- [WTB] ECU P72/P30 Hondata S300/S300 or ostrich/demon
- B-SERIES PARTS
- wtb auto d16 transmission
- wtb b series manual half shaft
- WTB oem integra springs/struts
- WTB: ITR Shortblock
- wtb 96-00 civic steering wheel with airbag
- WTB: A GOOD YS1 or S80 Transmission Main Shaft Bearing
- I need JDM help!
- Wtb quick release hub + wheel
- WTB: D16y7 long block in good running condition
- BC - CAN WTB:2003-2005 Civic Hybrid or 2000-2006 Honda Insight 14" stock rims
- 90 to 91 ef wiring
- WTB: integra gsr passenger side seat
- WTB ITR front lip and sway bar
- NY Local Pick up ONLY! WTB LS cable Trans
- wtb jdm radiator support DA
- Ef sedan 90 - 91
- WTB: rear hubs/bearings off 97+ Prelude
- wtb: backdoor intercooler
- WTB: Set of 4 Michelin Energy MXV4 205/60R16
- wtb: itr carbon fiber interior pieces
- BSQ ITR sway bar mounting kit
- WTB: 01-05 Civic manual tranny
- 98 Accord TPS
- Need parts for build (Ferio EG) And Turbo parts
- WTB: Mint Miracle X CRX bar.. II
- WTB b16 inner, and obd2 lower timing cover
- Need Fender+bumper for 92-95 civic in Louisville KY
- 99-00 Civic Si Ecu
- Wtb: aem cai, jdm itr header, 68mm tb
- WTB Ipad2
- WTB Civic Engine OEM Torque Mounts
- WTB Oem Civic SI Shift Rod and Shift Knob
- WTB: DA6 Gauges
- d-series harness
- wtb sohc cable SI tranny , transmission
- WTB: 99-00 Wiring Harness
- wtb stock or slightly built ls head
- WTB: 99-00 Civic Fenders OEM PLEASE!
- CA WTB: CRX si tranny, oem black front bumper and hood
- WTB: PIC or Hardrace Bushing kit for 96-00 Coupe non-SI
- WTB: Chrome Honda oil cap
- WTB tps connector
- WTB - S2000 NJ/NY/PA
- wtb: ef b series parts
- Wtb: 99-00 civic SI ebrake cables
- WTB: Weld skinnies,T1 shifter,Q45TB etc
- WTB : Ingalls 1-pair of camber kit for Integra DA
- 550-1000cc Injectors Wanted
- wtb 4x114 jdm itr wheels
- WTB: 4dr Integra door mirror
- wtb jdm type s intake 97-01 prelude
- WTB d16y8 head
- wtb del sol black interior,quick relaease
- WTB: 44mm wastegate
- OBD2a to Obd2b jumper harness
- WTB: RS Machine 84mm ITR or YCP
- WTB: obd2 b series distributor
- del sol obd2a b16 ecu or b16 ecu with proper jumper harness
- WTB: 96-00 civic motor mounts oem/stock only!!!
- wtb del sol trunk struts
- 1985 CRX nose panel / header panel
- WTT: Del Sol for EG,EK, Prelude (SoCal)
- if i didnt have bad luck i'd have no luck
- 00' civic hatch dx 1.6 sohc
- WTB: Tial 44mm wastegate
- 4x100 steelies / gsr block
- WTB: D series top end parts
- WTB '92 - '95 Civic Hatch shell
- WTB: 96-00 Coupe / Hatchback Window Motors & Regulators
- WTB: Whale Penis Intake
- CA: Black Miata Hardtop
- WTB: kswap DC/EK
- WTB new Precision SC61 turbo
- WTB: 1 GSR OEM Connecting Rod
- WTB: GSR victorX intake manifold ASAP!
- w2b: ITR DOORS, ITR SPOILER,ITR LIP , REAR BUMPER
- WTB d16y8 96- TD 80u dizzy distributor Vtec
- ef si tranny
- OBD 1 B series alternator
- WTB: 99-00 SI Stock Intake tube
- wtb pspec short shift kit
- WTT OR WTB: S2000 OEM catalytic converter and stock airbox
- d16a6 sleeved block
- WTB: 92-95 Civic HB tail light interior cover lid
- Wtb 2004 tsx driverside fog light cover
- WTB- black interior pieces
- S2000 oem hardtop
- WTB: Hasport H22 EK Mounts
- WTB: EK/B-Series Parts!
- wtb: 96-00 Honda Civic hatchback hatch hb
- Mitch's WTB Thread, (B Series)
- WTB: Yakima Roof Rack
- Where can i source these B20B piston rings
- WTT: '08 Ruckus for clean car - Fastest 50cc Ruck in Chi-town
- 88-91 Civic hatch harness
- WTB: ADAPTER for Personal Nardi Steering Wheel to Momo Hub
- WTB Front Driver Seat for 2008 Element
- WTB: 3" exhaust for 94-01 Integra
- WTB: Whale Penis Intake NON ABS
- OCZC H Beam Rods for B-Series
- WTB D16y7 Clutch
- WTB del sol parts
- WTB gsr throttle body
- WTB: S300 / EF COILOVERS
- WTB: DC2 ITR OEM optional Kit (sides + rear valences)
- WTB honda center caps for ITR wheels
- b20b dip stick
- Wtb civic fender
- WTB pm6 ecu....stock. D15B7
- Wanted 97-2000 Civic hatchback plastic side liner
- TN WTB CHEAP Integra 94/01
- FT: Turbonetics TN-600 (~2500miles, GT35)
- WTB: B SERIES VTEC SOLENOID
- Wtb 99-00 civic ex engine harness uncut
- WTB: EK Coupe Parts / JDM
- WTB D16Z6 Rocker Arm Assembly !!!!
- WTB D16 valve cover w/ breather fittings
- Honda and Acura ECUS!!
- WTB: EK Hatch OEM Car Cover
- Wtb - 94+ stock integra muffler
- WTB full LS intake manifold/OBD1 LS dizzy
- WTB d16 Intake manifold and adj cam gear and more
- WTB supercharger or turbo kit for h22
- WTB 91 Civic SI Steering Wheel
- fit front lip
- WTB: B16A3 complete swap
- WTB Throttle body pulley (non gsr)
- Obd2a b16 ecu-96-97 delsol ecu
- Hondata S200 with PO6
- Throttle Body / Z6 Intake Manifold?
- WTB: A BUNCH OF EK RHD PARTS!
- wtb comptech or ct engineering ice box for 00 civic or integra
- WTB camber kit for EG front and rear
- >>>> Wtb: K swap parts for eg mounts,kpro,harness,header & etc.
- want to buy skunk2 PRO1 cams
- Wtb coolant reservoir / overflow for 94+ Integra
- WTB reservoir cover
- WTB: JTC OR PSPEC Short Shifter for RSX
- WTB EK 96-00civiɔ srs airbag delete tray LHD light grey
- WTB DC2 Championship White center caps
- d16z6
- WTB - dc2 itr rear strut bar
- WTB 96 integra stock parts
- WTB: D16Y8 cam gear
- WTB: JDM ITR Fender
- EF9 Swapp
- 3-4 Stage Dry Sump for B Series.
- 01+ civic right front fender
- WTB: OEM ITR Intake Box w/ Arm and OEM P73 ITR Bare Intake Manifold.
- WTT : Portfow Designs Ported B16A Head
- wtb: greddy td04-15g OR td04-19t
- Wtb:D series turbo setup or parts
- WTB: 70MM or larger GSR throttle body with gasket in good condition
- WTB: Integra Parts
- WTB 99-00 Si/CTR Grill
- B-c pillar for ek
- civic / integra parts wanted
- WTB 1 b16 PR3 piston & 4 valves with keepers
- WTB GSR DISTRIBUTOR MAIN CAP!!
- WTB EF HATCH ROOF RACK
- WTT: B16 JRSC for ac friendly B16 turbo kit
- WTB: 98+ Integra OEM head lights
- WTB ICU for '92 Accord EX
- WTB S2000 sevice manual
- ITR calipers and bracket
- wtb carbon fiber 3 piece jojo callos front end
- WTB: Oem civic si 99-00 rear sway bar brackets
- Need:B series OB2 lower timing cover asap!
- WTB: 96-98 civic oil dip stick
- WTB: 81.25mm pistons rings
- DA integra suspension parts
- WTB mini ram or ram d16
- NEED 84MM HIGH COMP PISTONS!
- WTB: 92 - 95 Civic 4dr white 5spd
- WTB JDM Type R conversion HID
- WTB d series cam
- oem knock sensor
- WTB: Tranny M2f4, M2b4, or T2w4
- WTB: JDM Civic Type-R CTR Sunvisors and Cupholder c
- WTB: Sleeved B18C1, B18C, B18C5 Shortblock
- wtb b16 upper and inner timing covers
- Trade WRX for S2000 AP1/AP2 plus cash
- WTB: TYPE R DUAL VALVE SPRINGS
- WTB: 97-01 AUTO prelude cluster plugs
- WTB: GSR DISC BRAKES FRONT AND BACK!!
- WTB:96-00 D16Y8 Crankshaft Gear and Crankshaft Position Sensor
- WTB : Sleeved 85mm B18 block
- WTB usdm, edm optional audio console for eg
- I need a B18A1 upper timing belt cover asap!
- Wtb DEL SOL struts
- WTB Daily Driver!
- WTB aem v2 for 01 h22 prelude
- Wtb DEL SOL aftermarket struts
- wtb-wtt looking for a 92-95 civic htch or coupe...
- WTB - Daily Driver
