View Full Version : Want to Buy
- WTB: Ls Crank
- wtb: itr tranny
- WTB: Civic HX (D16y5) 5-wire O2 sensor!!need asap!
- WTB: GSR / ITR Oilpan
- WTB: lowering springs for 89 sedan. Rear view mirror for EG hatch
- WTB: COMPLETE SOHC SWAP
- WTB: Type R armrest
- WTB: 2 VTEC(GRAY) PLUGS FOR VTEC SOLENOID AND STOCK D16Z6 FUEL REGULATOR
- WTB: 88-91 CRX Motor
- WTB: JDM Front end conversion
- wtb: HID H-4 headlight system
- WTB: pistons/crank
- WTB: 99-00 Civic Stuff/ Hook me up!
- WTB:ek stock mounts and wiring harness
- WTB: Mugen Lugnuts and Mugen MF10 Center caps
- WTB:d16z6 crank pulley
- WTB: 90-91 integra front bumper
- WTB: LEFT (USDM Driver's Side) Recaro SR-II Bracket
- WTB: Clock Spring for Integra GS-R
- WTB: stock EF springs....... bayarea
- WTB: ACT 4/6 puck DISC
- WTB: Corbeau rails for 96 civic
- WTB: D16z6 flywheel/bolts/clutch
- WTB: stock 96-99 civic hatch rear wing..
- WTB: Blown UP GSR or ITR tranny or Just the gear set
- WTB: Rota 15" bronze C8s w/good tires ( san diego) or local
- wtb: jdm sir-g fog lights
- wtb: cheap JDM wheels
- WTB: Stock 93 PreludeVTEC Fuel Injectors............
- WTB: 90-91 Civic hatchback fenders
- WTB: 94-97 Accord EX 2dr Stock Exhaust
- WTB: 240cc B Series Injectors
- WTB: 92-93 GSR RIMS
- WTB: D16 complete swap
- WTB: H23 manual transmission
- WTB: progress rear 27MM sway bar with endlinks!
- WTB: rims /tires
- WTB: Stock 94+ Integra GS-R Clutch
- WTB: 2000 EK tail lights , eibach sportlines for 96-00 EK
- WTB: 5th gen OEM kit/Wings West RS kit
- WTB: honda hubcaps for 14 inch stock rim
- WTB: rims with or without tires, VA or DE area
- WTB: Complete Exhaust Sytem!
- WTB: ITR, GSR, or LS Clutch/flywheel/fork setup w/ bearings.
- WTB: Cylinder Head Bolts for F22A4
- WTB: Passenger side DOOR for 92 Honda Accord EX
- WTB: '91 CRX hf doors
- WTB: CRX si rear calipers
- WTB: Cam Seal <$20 anyone?
- WTB: HX wheels
- WTB: 99-00 si blue front bumper
- WTB: USDM ITR front seats
- WTB: arp rod bolts, gsr head studs, gsr girdle ....
- WTB: Any one have a LS crank for sale????????????
- WTB:G3 Integra Sir-g Lip
- WTB: DC Integra Stock Exhaust
- wtb: brand new ctr intake camshaft ot 00+ usdm itr camshaft
- WTB: NEED AN EG SHELL
- WTB: CRX SI/HF wiring harness
- WTB: TPS SENSOR!
- WTB: Some stuff
- WTB: jdm ef8 front bumper w/ bumper lights
- WTB:: EG Duckbill wing less than $100 shipped
- wtb: petal assembly 5 sp. 90-93 integra
- WTB: 88 - 91 CRX in OK or TX area
- wtb: b series starter
- WTB: SSR Defi Wheels
- WTB: Type r Sway bar (DC2)
- WTB: 15" rims
- WTB: Timing Light/Gun
- WTB: anyone have enkei rpf1's???
- WTB: I need a B16 Hydro tranny w/low miles.... asap
- WTB: 96-01 OBD2 Integra Engine wire harness
- WTB: 84 MM PISTONS
- WTB: 97 LS Rear o2 Sensor
- WTB: Stock body panel parts for 1998 Cyclone Blue 4 door, SF bay area
- WTB: Polyurethane side skirts for 1998 Civic 4 door in SF bay area
- WTB: 99-00 civic si header
- wtb: cable reel for srs for a 94 civic dx
- WTB: 88 CRX tranny reverse light switch
- WTB: B-Series linkages out of a 94-97 Integra
- WTB: h22 TPS
- WTB: Distributor for a 94 Civic EX D16z6
- WTB: 88-89 civic si underdash wiring harness
- WTB: ANY B SERIES TRANNY!! ASAP
- WTB: 92-95 Civic triple guage pillar
- WTB: ITR Pressure PLATE
- WTB: AutoMeter Z SERIES 2-1/16" Electrical Oil Pressure gauge
- WTB: Bulb condoms for AutoMeter gauges... Red and Yellow
- WTB: 92-95 cluster w. tach
- WTB: civic, integra, GS-R, or any other seats
- WTB: EK ARMREST
- WTB: BRAND NEW OR MINT condition DC2 MUDGUARDS
- WTB: B series 4-2-1 Header
- WTB: B16, B18B1, or B18C5 transmission components! (or entire swap!)
- WTB: Comptech Icebox (Just the box)
- WTB: Comptech 4-2-1 brand new or used
- WTB: 96-00 1.6L Oil Pan
- WTB: 90-93 Integra Aftermarket Muffler
- wtb:ls aftermarket intake manifold,and turbo cams
- WTB: JRSC for d16y8 *asap*
- WTB: ignitor for d16z6 95 civic ex
- WTB: Mugen Font Bumper or Complete Kit for Del Sol
- WTB: A cat-back exhaust for my '94' GS-R coupe.
- wtb: crx/civic si tranny
- WTB: oem body kit for 98 teg and some steelies
- WTB: 88-91 hb blue interior
- WTB: Idle Air Control Valve IAC
- WTB: sol front/rear bumpers or kit
- WTB: D series transmission housing
- wtb: best place purchase skunk2 cams, gears, valves, retainers, springs
- WTB: 98-01 Headlights Locals Preferred
- WTB: 92-92 2dr/3dr stock or aftermaket coners
- WTB: 92-95 BLACK civic power mirrors
- WTB: MSD Ignition for 92-00 Civic
- wtb: thermal muffler 98 integra ls
- WTB: EG6 2/3 door corners
- WTB: stock ex gauge face plates
- WTB: Stock 97 D16 Lx header
- WTB: Black EG interior fuse panel, shift boot w/metal base, black EG doorpanels!
- WTB: 92-93 Integra Ls tranny YS1
- WTB: header skid plate
- wtb: ef cargo cover, 91 ex front hubs(knukles)
- WTB: GSR twisties wheels w/wo tires...
- wtb: civic Si Grill
- WTB: JDM B Series Vtec Red Valve cover used/new. DFW
- WTB: half a b-series tranny case, Not the bellhousing side!
- WTB: Hondata, ECU, Conversion HArness
- WTB: 94-95 GSR Front Leather Seat in Dark Gray.... So. Cal
- WTB: stock shock/spring for a 92 accord LX ASAP
- WTB: black/charcoal gsr cloth seats front and rear
- WTB: Your stock rear Integra Shocks
- WTB: Honda Del Sol 93-95 SI
- WTB: ASAP Drivers side quarter glass...........
- WTB: Integra AC hose that goes from compressor to condenser!!
- WTB: stock gsr shifter
- WTB: were are all the cable si tranny's?
- WTB: desperate for a vtec solenoid or just the green oil pressure switch
- WTB: Ball joint remover 07mac-sl00200
- WTB: 15" Rota Grid in gunmetal w/ polished lip...
- WTB::::: WW Whale Tail........
- WTB: skunk2 cam gears USED
- WTB: Looking for an engine
- WTB:Del sol seats in Jersey
- WTB: Auto Integra Trans
- WTB:
- WTB: 92-96 prelude vtec HELMS MANUAL
- WTB: can anyone get me 84mm 12.1cr pistons???
- WTB: 1 99-00 Civic Si Rim
- WTB: LHT PERFORMANCE INTERCOOLER!
- WTB: B16 head in DFW area
- WTB: 88-91 mpfi swap
- WTB: Stock fuel pressure reg for Y8 fuel rail
- wtb: coilover/spring for my integra
- WTB: Used US-ITR pistons
- WTB: used N1 muffler
- WTB: OEM Integra rear mud guards. Used and abused is OK !!
- WTB: 16inch Rota Circuit 8's w/tires
- WTB: Lowering springs for my 97 hatch for like $100 shipped
- WTB: GunMetal 15" or Gunmetal 16" 5 lugs wheels with tires
- WTB: 96-00 civic side skirts...
- WTB: 96-00 civic side skirts....
- wtb: AC button off the ITR or JDM climate control
- WTB: RSR EXHAUST
- WTB: h22 knock sensor asap!
- WTB: B-Series Torque Converter or auto tranny
- WTB: Ignition Control Module (ICM) for D-Series
- WTB: EG Hatch exhaust ASAP
- wtb: sparco evo or evo 2's in black w/ rails ned these now
- WTB: rota RB
- WTB: B-series Cable tranny!
- WTB: Skunk2 Front Strut Bar!!
- WTB: JDM B-Series RED Valve Cover
- WTB: Integra JDM front end *METAL*
- WTB: 90-97 Accord Stock cambers
- wtb: 240sx in chicagoland area
- WTB: one 2001 GSR wheel center cap
- WTB: Integra Type R Rear Bumper
- wtb: JDM ef8 cluster for my rex
- WTB: Energy Suspension Bushing
- WTB: OEM Optional Teg sideskirts
- WTB: Window Regulator
- WTB: d16a6
- wtb:s2000 antenna
- WTB: Integra front lower arms...... w/ good bushings...
- WTB: 99-00 Si Rear Lip....either OEM or Type R....
- WTB: P13 ecu........need this soon
- WTB: SMSP or IPSRACING.COM Carsound cat 2.5" in/out sacramento norcal
- WTB: ITR Seats and Oem Shift Knob
- Wtb: Auto ls tranny DFW area
- WTB: OBD1 OEM Integra catalytic converter!!!!!
- WTB: AEM CAI
- WTB: 99-00 civic si transmission
- WTB: OBD2 EX harness
- WTB: Civic VX Intake Manifold 92-95 w/ all sensors/valves
- WTB:Stock hood 92-95 civic hatch/coupe
- WTB: ITR seats
- WTB: Stock LS Parts
- WTB: SPort Springs
- WTB:92-95 obd-1 parts i need them!!!
- WTB: Z6, Y8 or B18b, b16 TB with TPS or d16z6 TPS Socal ONLY for pick up
- WTB: 5 Lug Coversion For EK Hatch (SoCal)
- WTB: JDM civic 92-95 rear interior
- WTB: Car Cover for a Type R
- WTB: z6 or y8 tranny **shifts smooth (no grinds)** norCal preferably
- WTB: 90-93 Integra ignition cylinder lock with key. ASAP
- WTB: Stock GSR Head Bolts
- WTB:: OEM 96-98 Civic Front Upper Grill...
- WTB: 16" G-Racing Akita's or SSR Comp. knock offs...
- WTB: 94-95 GSR Cluster.... ONLY 94-95 GSR.....
- WTB: 96-00 Civic black plastic non-powered passenger side mirror assembly
- WTB: FWD 5spd CRV Trannsmission....
- WTB: stock Type R axleback only.
- WTB: Stock Front & Rear DA Integra 92-93 Bumper
- Wtb: 89 crx amber corners
- WTB: Replica Mugen Lip for 99-00 civic
- WTB: 94-95 GSR -P72-obd1-ECU
- WTB: Accord V6 parts... need SOON
- WTB: weather stripping off door of 92-95 civic
- wtb: boost guage
- WTB: AEM ITR CAI
- WTB: 99-00 Civic Hatch Taillights (with clear turn signal)
- wtb: gsr tranny
- WTB: usdm itr tranny in NorCal....
- WTB: civic side moldings
- WTB: oem valve cover for b18a
- WTB: HX rims
- wtb: 94+ integra driver side upper motor mount
- WTB: JDM ITR 4-1 Header or JDM DC 4-1 Header
- WTB: DOHC ZC Motor
- wtb: lude stock axles, 4th gen
- WTB: 99-00 si optional rear lip
- wtb: 4th gen lude stock axles
- WTB: 93+ distributor for my SOHC VTEC
- WTB: USDM P13 or P72 w/ p13 program
- WTB: 94-97 F22 Long or short block. MD/DC/NOVA area
- WTB: New Orleands / Hammond / Baton Rouge / Shreveport area. 15" or 16" Wheels + tires
- WTB: 95-95 Civic Si dealer accessories
- WTB: 92-95 civic cluster with tach
- WTB: HX rims
- WTB: Gen2 Integra Door Handle
- wtb: del sol trunk lid / rear license plate bracket
- WTB: Let me know asap
- WTB: D16 block in decent condition
- WTB: arp rod bolts, head bolts, gsr girdle , oil pan ..ect
- wtb: ITR crank or GSR crank
- WTB: 92-95 HONDA CIVIC EX/Si FRONT LIP
- wtb:endlinks for integra rear sway bar
