View Full Version : Want to Buy
- 3 inch cat converter
- WTB: EK Parts / SI Lip / Exhaust / Springs / CTR Wing / CTR Carpet
- WTB 92-93 EG Rear Quarter Window Inside Trim L+R
- WTB EP3/RSX Tie Rod/Steering Rod ASAP
- ~~WTB~~CiVIC SI 1999-2000
- wtb da seats
- WTB: Enkei Racing S Centercap
- wtb: 99-00 vsm ek fenders
- wtb 90 91 crxsi dash harness
- WTB: civic 92-95 gauge cluster
- wtb: OG plastic spoon mirrors(DC) and Gab's center cap
- WTB: Si center caps
- WTB: d series turbo kit
- 90-91 civic 4 door clean!
- WTB: 91 EF hatch exhaust system
- obd2b to obd1 harness and p28 ecu
- WTB OEM gsr catalytic
- WTB:jdm obd2a p72 or 73
- WTB: BC cams NA
- WTB: 96-98 red ek front grill
- WTB: Pr3 obd-1 Intake manifold, Fuel rail, and CTR Crank Pulley
- WTB: SSR Comp, Enkei RPF1 or other / 15x7.5 or 15x7 / 4x100
- wtb GSR shift knob + oem gsr shifter
- WTB: Roll cage for EG
- looking for 92-95 civic parts pass.front end
- wtb a complete and running d16z6 swap.
- wtb body kit
- WTB valve adjustment tool!!
- WTB: ROTA RBs 15x8
- WTB B20 P8R head!! and EF tailights
- Wtb: Itr trans
- WTB SSR type C's
- WTB: Acura Integra 1994+, Auto. Nothing above $4,000
- wtb:optional sides
- WTB. Konig Helium
- wtb crank pulley and bolt. d15b2
- WTB:94-97 integra RS Hard brakelines
- WTB obdII evap purge solenoid
- WTB 88-91 civic hatch and 4door
- WTB Yellow Stitch ITR rear seats JDM
- WTB NJ Turbo, clutch, injectors, intercooler, b-series
- b18b1 parts
- Tranny
- I needs a low milage running d16z6
- WTB 96-00 Civic coupe parts
- WTB: Skunk2 Intake Mani
- WTB 96-98 ek9 OEM Civic Type grill
- Wtb obd1 p72 ecu
- Wtb: 99-00 Civic Si
- wtb:anything turbo related for a f22b2 motor
- WTB - three (3) HFP factory optional 16" wheels OEM ss-7
- WTB: 0bd1 LS Harness!!! Cash in hand!
- *wanted* buddy club front and rear camber kit EK civic brand new
- WTB 92-95 2 dr pass side fender
- wtb jdm integra front end parts, k trans.
- wtb: 94-97 2dr mud flaps
- WTB: b16 2nd, 3rd gear
- WTB: hydro LSD B16 trans ASAP!!!
- WTB B-series Vtec DOHC all motor cams camshaft gears
- WTB: 38mm Dump for a log mani D16
- Wtb: Obd1 ecu. P72 - p61 - p28 - p30 - p06 - p05
- Wtb steering wheel
- NJ WTB: Something 5 speed and Power Sunroof. NO HATCHES
- **WTB: AEBS Intake Manifold for GSR**
- WTB 99 00 si front end
- wtt pistons
- WTB High HP Parts *Look *
- 2.5 or 3 inch aftermarket eg exhaust and eg coilovers
- WTB: Subaru WRX LONGBLOCK
- WTB: 92-95 JDM EDM CDM USDM Civic Catalogues and "Honda Access" Accessories Brochures
- Need a water intercooler
- WTB Real MUGEN spolier, Side skirts, Rear bumper
- Fs:d16a6 ecu PM6
- WTB: i-VTEC Intake Manifold Cover for RBC
- WTB: 2000 SI UPPER Radiator Hose, 5 speed integra throttle cable.
- D series Greddy turbo manifold
- WTB : Seats for my DC2 [Bay Area; NorCal]
- Wtb pw0 stock ecu
- WTB in Socal
- WTB : RC or Precision injectors !
- WTB: STOCK Harvard Blue EG Complete or Shell w/Interior
- WTB OEM exhaust 2000 EK coupe EX
- WTB: Integra parts in MD area!
- 1988-1991 Civic Hatch FR/RR Shocks
- Crx Parts
- WTB" E-brake cables, B-series stuff
- Wtb: Midori green ek
- 93 eg parts needed
- Wtb: Si vtec lip, amber turn signals, c pill bar
- jg 303 cams b18b
- WTB: 99-00 Civic Si Center Caps
- WTB Type R Main Caps & Bolts
- WTB 99-00 SI Power steering pump
- Spoon Duracon
- WTB. MEMORY FAB RAILS for DRIVER Side For SPG!
- wtb: turbo, something for 450-500whp range
- Wtb: ek driver side motor mount (spaceship looking mount)
- WTB: Stock catback exhaust for 88-91 Si (hatchback model)
- WTB: Injector clip
- wtb s300
- SELL me your OBD2b->OBD1 Conversion Harness!!
- WTB:Gsr Aem Cold Air Intake
- WTB: ITR Cluster
- WTB 92-95 Civic Ferio EG8 EG9 Side and Rear Window Visors
- WTB: Wrecked Del Sol or EG w/D16z6
- OBD0 Distributor Needed!!
- wtb front LCA's
- wtb-complete vtec solenoid for b series
- WTB: 99-00 Si Grill Taffeta White
- WTB: B16 Mounts in EF hatch
- WTB: COMPLETE 88-91 CRX HF or CRX/CIVIC SI SWAP -SO CAL
- USDM ITR interior pieces and trunk carpet
- wtb d16a6
- WTB: EG plastic dash cover for mirror adjustment control + Integra Trunk Light
- WTB: SOHC Stage 1 VTEC Cam.
- WTB: 92-95 Civic HB Lowergate
- bare p8r head
- Need Manual Pedal Set Assembly for my '90 civic 24 Hour of Lemons Car
- WTB: JDM RHD 1992-1995 Civic EG6 Bezel (the part surrounding the cluster)
- WTB: White Carbing 3-point strut bar
- delete
- WTB P30 or P72 VIRGIN ECU'S !! ASAP !!
- WTB: Hasport mounts
- I need del sol parts
- Wtb: Obd1 p72 gsr ecu
- amber/orange corner lenses for 98+ Integra
- WTB: Wheels and stuff in VA
- wtb: new rotors & brake pad for ek
- **WTB: 96-98 EK4 SiR lip** new or used
- wtb some injector o rings
- WTB: Proportional valve. GSR oil pan
- WTB:B20 Head,Injectors,arp,b-series parts
- WTB: CTR Door Panel Inside Handle Trim.
- WTB: EG Hatchback Shell, H22A4 crankshaft
- itr wing
- WTB: 84.5mm pistons
- WTB: A Few Integra Parts !
- WTB: Driver-Side Sun Visor for 99 Civic 4dr
- WTB: carpet for EG hatch
- 1st gen crx wheels
- I have RC 440's and want to trade for RC 310's
- WTB: Running clean ek/eg/w.e MD 3-5gs
- WTB: f22 head parts.
- wtb integra 94/civic rear camber kit
- WTB Type-r B18C5/6 crankshaft
- Hood - PART NEEDED - EF civic 89-91
- wtb: captiva blue front end EG6
- WTB Apexi WS Universal Muffler
- WTB: LS short block
- Want to buy: B16 Crank Pulley
- WTB: 1996 JDM Type-R exhaust manifold
- wtb or trade Hondata s200 with boost or s300
- ***C**B**R*** 600 RR northeast
- WTB: Complete Swap (D-Series)
- WTB - Hood or hood latch ef 89-91
- Guy's looking for 07 Si Rim
- B18b1 Oil Pan
- WTB stock del sol front and rear bumpers
- WTB in dash DVD
- Obd0 dizzy??
- Wtb:after market shift knobs/thermostats(must fit D -series)
- WTB 98-01 Silver Integra Bumper
- WTB EF hatch - NJ or surrounding area
- wtb: parts for 98 hatch. lots of stuff.
- WTB mugen nr10's
- I Need a B Series ACT Pressure plate + Half Size Rad
- WTB: Defi Racer Oil Pressure Gauge 52mm
- WTB turbo kit
- WTB: 93 del sol glove box
- WTB: 92-95 JDM EG6 Taillights & Climate Control
- WTT for recaro seats- red
- 99-00 Si Wheels
- WTB: 99-00 Si Prop. Valve & Brake Booster/Master Cylinder
- WTB - Civic Ex Knuckles up to 1991
- F/S and WANTED integra parts -- gsr rims, si rims, splash guards etc...**
- ************1999 - 2000 Honda Civic Si Cluster ANY MILEAGE*************
- WTB EK side moldings.
- Wtb: stock b16 headers or ls ...(exhaust manifold)
- jdm crx parts/ h22
- WTB: D Series turbo kit
- WTB: 96-00 black front bumper w/ lip
- Wtb: 99-00 oem grill
- i need a single cam
- WTB: B series axles in EF hatch
- WTB: 88-89 CRX Cluster Bezel (Black)
- need BC seat rails
- WTB Integra 98-01 silver hood, bumpers, driverside fender
- WTB EG rear bumper
- B20 B18b LS ARP head main and rod bolts and studs and B20 block
- WTB:B16a Del sol/SI A/C Bracket for SOHC compressor
- shift linkage!!!!!
- WTB: S300 or Neptune RTP!
- civic cabin harness
- WTB: wiper switch
- EM1 lip
- WTB: GSR rear t-bracket // p72 Oil pan
- Ky/wtb: B18a/b or b20 long block
- WTB: 99-00 civic coupe mud guards/flaps
- Looking for K series 6 speed transmissions
- WTB exhaust can for 96 civic
- WTB 98-2001 OEM GSR Clutch
- Stock ctr, itr, or si springs oem
- Wtb: Jdm folding mirrors eg 4dr
- WTB: Running NON-TVEC Motor
- WTB: 92-95 HB Exhaust
- WTB: 96-00 Integra LS Intake manifold.
- WTB: 93-95 coupe bumper covers in Milano Red
- WTT: 15' Bronze Slips for Polished Slips ONLY 15's or 16's
- WTB: OBD1 Integra LS Catalytic Converter
- wtb 96-98 sir lip
- want 2 buy are trade 4 a B series hydro trannie help
- WTB K20a3 Primary o2 Sensor
- wtt/ 07 civic si tranny, 11k miles, 6 speed, lsd
- WTB b16 parts asap
- WTB: Miller Syncrowave or Lincoln Precision Tig Welder - So Cal
- WTB LS crank
- WTB : EG power window stuff
- WTB: Carbing Front Strut Bar with Master Cylinder Brace / Stopper
- WTB: 92-95 Civic Hatchback Glass
- WTB: Realtime Racing ITR/NSX Posters
- WTB: 92 to 95 civic rack and pinion
- WTB: Fixed Back Race Seat Wide
- wtb - h22 trans
- WTB: 4th Gen Accord Wagon - SoCal
- WTB: OEM B-Series Ignition Wire Cover
- WTB: hasport rear mount for 94-01 integra, etc.
- WTB: Del Sol or Eg Stock parts, misc
- WTB: Honda Civic EX 1996-00 2-door OEM Muffler
- WTB oem eg cluster with tach
- 99-00 civic SI T BRAKET and crankshaft Pulley (NEED ASAP)
- d16y8 Engine
- HUGE Want-to-Buy List!! B17/b16 parts, integra gsr knuckles, etc
- WTB: Seats
- WTB: CW ITR Front lip
- WTB: b16a3 Dizzy and other..
- WTB:99-00 EBP si grille
- WTB:99-00 b16 a/c pump and bracket!!!
- WTB - B series tranny
- WTB GSR 5th Gears or Trade for Ls 5th
- WTB-ASAP B series Rocker arms
- WTB:Bronze Rotas
- wtb: ground control(KONI) for 96-00
- WTB, Tein S tech springs.
- Wanted: Need to read Hondata Stage 3 ROM
- wtb, wtt 8.1 , 9.1 comphression pistons.
- WTB/WTT JDM hood
- wtb: skunk 2 exhaust for 1999 civic ex and other parts
- WTB: STOCK EK Hatch 96-98 Red CX
- ****WTB**** Hasport Mounts for 90 crx b series cable
- WTB H22 Block
