View Full Version : Want to Buy
- WTB: Mugen LSD for 99-00 Civic Si or 90-01 Integra RS/GS/LS
- 91 civic
- Need new front and rear bumper for ep3
- WTB: Front seat 99-00 Civic
- wtb: obd2 lower timing cover
- WTB: 99-00 SI Parts
- WTB Honda Factory Spoiler for my Em1/99 Civic Si
- parts for my 99/00 coupe
- WTB: Honda Civic Front Bumper / Side Mirrors (96-00)
- WTB: Integra front passenger fender vogue silver metallic
- WTB: 1980-1983 Civic
- SoCal WTB 4DR 94-01 GSR BLACK/CHARCOL CARPET!
- WTB: Obd1 h22 fuel injectors
- WTB rsx fender liner
- Stock b16 injectors
- wtb integra lca asap dmv
- 93 del sol interior door handles
- WTB: Skunk2 Stage2 Tuner Series Cams
- WTB H23 non vtec valve cover
- !!!!!!!!!!!!!!!!!! WANTED SIR EF COMPLETE FRONT END WANTED !!!!!!!!!!!!!!!!!!!!!
- wtb 89 to 91 civic / crx roller
- wtb spoon mirrors
- used 750cc - 800cc saturated injectors wanted
- WTB: 94-01 Intergra Master Switch
- WTB Del Sol MUDFLAPS
- wtb ef 4 door shell *So Cal
- WTB: Confetti or "Odd" Recaros
- WTB: Aftermarket LS rods. Preferably not eagles
- WTB:99-00 Civic Hazard Harness/Plug
- WTB: T1R exhaust muffler silencer
- BOV;Vacuum Manifold;Oil Pressure Gauge; 3 Gauge Pod
- wtb: d16a6 (ef si/ex) engine harness UNCUT!
- WTD: d16z6 shortblock
- WTB: 99-00 Civic Si oem rear sway
- WTB: EK Catalytic Converter
- WTB ASAP: BBS RS HEX CAPS
- WTB: Engine Block Cores. B18, H22, K24...
- WTB H22 swap
- WTB - Catback For EDM ITR
- WTB: SSR professor SP1 center caps/ stickers
- 92-95 civic oem air box
- Anyone have any stock EM1 Milano red body parts?
- WTB: Integra front and rear bumpers!!
- WTB:: USDM Type R Front end, Rear, Seats, Type R ETC!!
- Apexi EL electric boost gauge Verion I not II old school And Hondata S300 P72
- End links for Ek SI Sway bar
- WTB/NEED SI Blade or Meshies Center Caps!!!!!
- >>>>WTB 04 TL Items<<<<<<<
- WTB: 96-96 acura integra wiring harness obd2a
- WTB B16B Civic Type R engine Harness
- I also WTB 92-95 Hatch rear cargo carpet and mud flaps.
- WTB Axis Maglite, Mag-lite
- WTB: 96 97 98 civic parts
- Wtb: 97-01 Prelude Base Intermediate Shaft
- WTB Brown Audio Console for EG
- WTB: "99-00 civic" lock control box for power locks
- wtb stock civic in cali
- WTB: Confetti Recaros
- WTB: fjt custom i beam rods
- WTB: H22 engine Harness
- WTB: Type R lsd for 99 gsr.
- WTB: CF hood for JDM front integra
- WTB used full coilovers for an ef
- WTB:89-91 ef or dx AC compressor in WORKING order...
- wtb: p54 or p7j ac bracket
- WTB: GSR/B18C1 Power Steering Upper/Lower Bracket
- 91 Civic Hatch Fuel Meter Unit?
- WTB: Ls motor
- I need stickers!!!!
- need motor and trans or full swap
- WTB: ITR Rear Seats, Armrest, or Armrest delete
- need a honda or nissan in Pa
- WTB: Skunk 2 coilovers (and maybe shocks?) to fit 88 crx/civic
- WTB: 75.5mm Vitra/FJT custom length rod setup for D16z6
- WTB - S300
- WTB: B16 knock sensor ASAP!
- WTB: GSR B18c Crank Pulley
- WTB: 06 DC5 PARTS
- wtb 90-91 civic Main wire Harness
- WTB: LS 15" Mesh Wheels
- WTB: 99-00 civic fenders
- WTB Rubber connector for cheap ebay intake to gsr throttle body (just the connector)
- WTB Si door panels
- WTB Sunvisors for 97 coupe
- WTB: 1999-2000 civic A/C mount
- wtb 96-98 civic ex m/t engine harness.
- WTB 2 16inch 4x100 Full Polished Rota slipstreams
- obd1 distributer! asap
- WTB: Integrated Control Unit
- WTB: EM1 Si center caps or similar
- WTB Y7 block in Tri State
- Wanted 1 h22 stock piston
- WTB: 90-93 4dr Integra Manual Window Regulators
- wtb 03 or newer trans
- WTB B20 bottom end parts
- WTB: ROTA GT3 GOLD 15' WITH TIRES 4X100
- WTB: gsr rear disc conversion- perfect working condition!
- wtb...need help buying a car
- WTB B16 suplies.
- WTT/ black 16" rotas for 16" gold or bronze rims
- WTB Stock / OEM exhaust for integra - 2 door - Long island NY
- 88-91 Civic Non A/C Parts - HVAC Tube and Firewall Grommets
- wtb: type r intake manifold
- WTB: front and rear Acura Integra disc brakes. (Northeast)
- WTB: 92-95 Civic si/vx/ex cam cap
- WTB: 92-95 CIVIC HATCHBACK RED CLEAR TAIL LIGHTS
- WTB Driver side front seat 00 Civic
- WTB: 1991 honda crx struts (kyb,tokico, etc)
- WTB 99 00 CIVIC HOOD (SILVER)
- b16 aftermarket intake
- wtb!! B-series motor and trans
- WTB: EK 99-00 Carbon Fiber Mugen Lip
- I need the following asap: seats, rear lca's,beaks + more look
- I am Looking for JDM B, K series motors
- Integ/Civic
- Looking for JDM K20A iVTEC Type R
- WTB: (2) Skunk2 Dual Bend Short Shifter for Integra
- WTB~ CRX rear bumper and support.
- WTB: Apexi SAFC2 or NEO
- WTB : EG D series dual bend short shifter
- WTB: 94-97 Integra Si-VTEC Front Lip and Corner Lights
- WTB: D series EX/SI manual transmission
- WTB: 92-95 Eg 5 speed ignition switch wires
- wtb Stock 98 integ suspension
- WTB: 96-98 Civic EX engine harness
- WTB ANY FULL DASH!(CT)
- WTB: EK Driver Door ASAP
- Wtb: EG Hatch parts
- WTB 99-00 Si Rear Lip
- WTB:\ P13 ECU
- WTB DB 4DR INTEGRA PARTS
- gsr s80 tranny casing
- looking 2 buy smashed s2k! show me what you got!!!!!
- Looking for a 96-00 sunroof Visor
- WTB: ASAP Front and Rear Camber Kit for 01-up Acura CL Type S
- WTB: A/C lines D-series 99-00
- wtt ecu
- WTB:: Integra Tie Rod Ends, inner and outer(94 Integra)
- WTB: Car for around ~$2k (So. Cal)
- WTT/WTB Jdm SRS Steering wheel hub
- WTB RECARO BRACKETS ASAP
- [:.WTB.:] - 2 Black interior EG panels
- wtb 1st gen dsm RUNNING for DD for under 1500
- WTB: IN PHOENIX,AZ S2k Hardtop
- WTB: d series 8.5lb or less flywheel, used.
- WTB: S2000 OEM rails
- anyone parting a 96-98 civic coupe? or at least have wiring for one?
- WTB Moroso LS valve cover
- Autometer Pyrometer EGT Guage Pro comp Ultra lite only.
- SELL ME YOUR BYS OR airwalker Replica
- WTB: h22a wiring harness
- WTB: EG OR DC SHELL IN SOCAL
- WTB: 96-00 driver side air bag
- 99 integra ls auto radio harness
- WTB: EM1 Motor mounts
- WTB: ASAP.... 89 Crx Si SUNROOF
- WTB: Integra GSR knock sensor
- WTB: GSR shift Knob
- WTB stock 98 integra intake airbox set up
- wtb: obd2 oil pump, crank sensor, obd2 ls intake manifold
- 2 post Driver side B16 mount
- WTB: GSR BLADES
- WTB!! B-Series mounts for 96-00 Civic!!
- WTB Preferrably 92-95 Hatch, Will consdr newer years
- wtb 98 driver side headlights for integra
- WTB 96-99 OBD2A TO OBD1 JUMPER HARNESS GSR
- WTB BYS Wing CFRP or FRP for an EG
- WTB: used dc2 ARC induction box and filter
- WTB: D16z6 forged rods, d16z6 oil pump, GSR arp headstuds,
- WTB: Blue crx seats 90-91 $400
- wanted mint crx si floor mats
- wanted: 96+ b18b valve Cover LS + eg/ek side skirts
- WTB/WTT LIST
- wtb EF b series mounts
- WTB: championship white EK hatch with k20
- WTB: Under dash harness - 92-95(EG) civic - MANUAL
- WTB: bseries parts/ turbo parts ASAP!
- WTB: VX Wheels + Rear quarter panel
- WTB: 1991 honda crx si floor mats
- wtb - JDM integra Bumper and fender!!!
- WTB: OBD2 Integra VSS(Speed Sensor)
- WTB: BUILT BOTTM END
- wtb... aftermarket half rad (EG), 13x7-8 dragracing wheels,t3/67-ho or GT35R
- 750cc injectors
- WTB:: B18B1 complete or not, built or rebuilt
- obd2 gsr alternator
- WTB: 98-02 honda accord 6 disc cd player
- WTB: 96+ integra crank sensor harness
- Wtb 99-00 Civic Si Full Nose Mask
- WTB GSR Intake Manifold BLOX/Skunk2/AEBS
- WTB: DC Rear brake calipers, OBDII Alternator
- 99 civic front end red!
- WTB: EJ & EM 3rd brake light "Lense"
- Need EJ1 parts
- WTB D16y7 exhaust manifold need to pass smog help please!!
- WTB: EG B Series Mounts
- vtec cam caps
- WTB: Broken intake manifold and messed up cylinder head (VTEC if possible)
- WTB 99-00 Civic si/ex engine harness
- WTB Yakima Bike Rack
- Trade your h2b header for my Camp1320 header
- WTB Complete 96 civic auto to manual swap
- WTB: Stock GSR cams and cam gears
- M8 x 0.75mm Tap
- WTB: 17 inch rega evo valve stems
- WTB: 17 inch reaga evo valve stems
- WTB: B18C5/6 crankshaft
- wtb enkei 92's 3inch center caps
- wtb: PR3 piston
- WTB 1 Itr or CTR Rim
- WTB R Crew Master Cylinder Brace GOLD!!
- WTB:EF8 EF9 JDM T-Bar
- LTB: obd1 to obd2 distributor harness
- oem si grill
- WTB: 94 AND UP INTEGRA HOOOD AND FENDERS
- WTB: 96-00 civic Carbing cooling plate, 3in flex pipe
- WTB - A/C Compressor - 93 DX
- Wtb eg mirror block off plates
- wtb stock 94+ integra shifter
- WTB: NICE Civic 96+
- OBD2 B series Alternator
- ITR flywheel
- wtb: Front SIR Lip 99-00
- WTT: b16a block and crank for vitara's and rods
- WTB: LS cluster 120-140k
- wtb integra, ciic, accord in IN/KY/TN area
- Wtt: 1st gen Cr-V trade for my 2000 Civic Hatch.
- FL WTB - 90-91 Integra OEM optional lip
- WTB.honda civic,acura integra,prelude
- WTB: Skunk2 Engine Accessories oil cap, radiator cap, solenoid cover, etc.
- stock catback for 97 accord
- WTB: T3/T4 Turbo
- 2002 honda civic si EP3 Carbon Fiber Wing
- wtb nsx shell
- WTB: 94-01 Integra window visors
- WTB IAT sensor for 94 GSR
- WTB Roja Formula 5
- WTB 240 sx exterior parts!!
- WTB Knock Sensor Plug
- WTB: A good condition D-series AC Compressor
- WTB:: JDM Type R front end, for 1994 integra
- WTB: Sparco Seat Sliders (Track Set)
- WTB: Mugen EG6 Lip
- Lower rad support piece!!
- WTB:JDM 4-1 ITR Header
- WTB ECU P30 or P28 (OBD-1, AT)
- WTB: b18c head, b18c block, b18b block
- wtb mugen eg sides and all clear tail lights
- wtb bottom half of the ctr wing.
- 92-95 honda civic CX or VX parts
