View Full Version : Want to Buy
- <<MI>>[]NEEDING 96-98 CIVIC PARTS! HELP![]
- WTB 2nd Gen CRX Si distributor
- h22a4 rods (oem)
- WTB b series t bracket
- WTB LS B18B Shortblock
- WTB GSR Upper Power Steering Bracket
- WTB: 96-98 civic red front bumper
- WTB: Spoon N1 or J's Racing 70RR For RSX
- WTB FJO Wideband!!
- wtb: eg hatch oem cf trunk
- wtb d16 eagle rods
- WTB: 96-98 civic headlights
- Wtt: eg6 fenders w/side marker(socal)
- WTB: OEM 14" steel wheels, set of 4
- WTB:: 2.5" B-Pipe / 94-01 Integra dc2 dc4
- WTB spoon front lip jdm dc2
- WTB acura/honda center caps
- WTB: 98+ integra rear bumper NY
- 96-00 civic ek power door Panel
- wtb itr 98 spec spoon gauge cluster
- Wtb 99-00 oem hood, bumper, and headlights
- WTB obd1 ls engine harness 5 speed
- WTB: H22 Type S
- WTB: AP1 REAR WHEELS!
- WTB Rota Grid Offroads
- WTB: EG QSD H2B kit & K2H adapter
- Camshafts for injectors
- WTB: 88-91 Civic sedan carpet
- wtb: ls crank and valvetrain
- looking for 00 civic si hood bra
- wtb: dc/eg full body coilover
- WTB: 1991 Civic EX dash harness
- WTB: ek edm/jdm clock
- WTB: 13" lensos
- WTB: Hasport b-series ef shift linkage
- WTB: knock sensor
- WTB: DOHC B-series Vtec Solenoid
- WTB: 88 Crx Dash Harness
- WTB 1997 ITR Nose Mask
- WTB: Tilton release bearing
- WTB: B series turbo manifold
- WTB-->>EM1 99-00 CIVIC SI ENGINE HARNES!
- WTB: JDM EG6/EG9 long armrest
- WTB: 40/40 Prop Valve ASAP
- WTB: lenso w/23in slicks
- turbo stuff
- WTB: red recaros and cf hood
- WTB: UKDM OEM CLEAR CORNER LIGHTS
- WTB: OEM civic radiator and em1 a/c radiator
- WTB: BLOCK or CRANK GSR "cash in hand"
- WTB: Stock ITR shifter
- Wtb nitrous express nx20200
- WTB an eg hatch in Ohio
- WTB EP3 STEERING WHEEL!!
- WTB: D16Y7 5 speed IACV
- WTB: DC Integra seats (CLEAN)
- WTB GSR Door panels DC2
- Traction bar for 99 Civic SI
- WTB 87mm Crank
- WTB: D series motor
- WTB: H22 header
- WTB: DOHC obd 1 vtec solenoid
- WTB: B20B / B18B Longblock - Connecticut
- WTB: TEIN Full Body Coilovers CRX NO Basic. Omaha Nebraska.
- WTB: Full EM1 interior
- *W-T-B 1994 sedans stuff and 93-95 civic parts!! cash in handd
- WTB NJ: B-series Transmission w/ LSD
- Wtb: obd2a engine harness
- WTB:gsr/b16 tranny
- wtb nardi deep corn replica wheel
- Wtb spark plug cover. B16 vtec
- WTB Camber kit for 94+ integra
- WTB: New Golden Eagle 84mm b series head gasket
- 92-95 civic parts
- WTB: AEM PNP ECU 30-1080 VTEC
- wtb LENSO's
- wtt 88 civic hb doors for b16 head
- WTB: turbo parts- BOV, turbo timer, oil catch can
- obd2 alternator pigtail
- WTB: PASSWORD JDM INTAKE B SERIES
- looking for ek hatch door panels manuel
- WTB: Gathers GXC-7148SFA cassette radio
- WTT: K20A2 SWAP for turbo B18C
- WTB: anyone have some new aftermarket spark plug wires????
- WTB: EG hatch OEM front bumper
- WTB: GSR/ITR 4.4 final drive
- NY - WTB: EK hatch, EK coupe or DC2 - CLEAN!
- WTB: COMPLETE a/c system for a 92-95 civic coupe
- wtb sir/grs front seat head rest
- WTB: 92-95 civic manual window crank handle
- looking to buy performer X for b16
- WTB: Wide EG Front Fenders
- LF 96-97 Del Sol Bumper
- wtb motor mount bracket b series 2 hole
- WTB: oem d16 exhaust manifold
- WTB: OEM em1 DOHC VTEC stickers
- WTB: Lower Control Arms
- WTB: single eagle rod for d16
- *help*need asap... 19 wheel bbs lm replica time attack
- WTB 96-00 CIVIC HATCHBACK HEADLINER/MANUAL DOOR PANELS WITH ROLLERS
- Aem series 1?
- WTB: Shift linkage, axles and motor mounts for my 92-95 manual DX civic
- WTB: Stock EK Springs
- WTB :: 90-91' Civic Headlights (L&R)
- B18B Valve Keepers
- WTB WALBRO 255lph fuel pump
- mods please delete
- WTB: STOCK Civic DX 92-95 manual p06 ECU
- 96-00 Honda IACV Needed
- Wtb: IACV
- B20 Timing Cover
- FOUND FOUND FOUND
- WTB: Arc Winglets / Splitters
- WTB : Skunk2 Pro 1 cams
- WTB B16/18 Type R LSD Diff
- wtb pr3 ecu and p72 throttle cable bracket
- WTB: OBD2A Engine Harness
- wtb: front for lip for an ef sedan
- WTB:b16 obd1 intake manifold
- WTB 96-00 EK Parts
- WTB: honda/acura/any car 2500
- WTB Coilovers for 94+ DC
- WTB: OBD1 Integra Cabin/Dash/Chassis/Firewall Harness. GSR SEDAN Black Interior. More
- wtb: lookin for 96-98 civic coupe front and rear MUDFLAPS
- wtb: b series axle part
- WTB: ORIGINAL Comptech 94-01 itr/gs/ls intake
- WTB: Ported and Polished D16Z6 Head.
- wtb: Dc2 spoon sports drop in filter
- s300 with obd2b plugs
- WTB:96-98 Sir lip and headlights!!!
- WTB: Integra coilover
- WTB: ARP head studs and rod bolts
- WTB: crx parts!!!!!
- WTB: 1998-2001 Integra GS-R or ITR Shell
- WTB: Catalyitic Converter & Intake Manifold
- wtb eg hb oem trunk in white
- WTB RS mechine pistons or oem itr's
- wtb: 96-00 y7 header DOWNPIPE
- D17 Exhaust Parts
- looking for a high pressure gauge isolator
- WTB 96-98 Civic Mug Guards!!!!!!!!!!
- WTB: DC2 OEM LIP KIT AND '01 OEM BUMPER
- 94-01 integra DB8 4 door carpet
- WTB: GSR Skunk2 Intake Manifold
- wtb dc2 front knuckle.
- wtb: koni ground control rubber tops
- Fuel Pressure Regulator
- WTB: SEDAN (EG) 92-95 driverside mirror
- wtb 90 crx front mud flaps, Skunk2 front camber kit,si rear sway bar
- Wanted. 44mm vband WG and Intercooler
- WTT JDM ITR CLUSTER
- WTB: EJ1 Front and Rear Bumper
- WTB EK COUPE PARTS
- sampletegi ***WTB List***
- WTB OEM Metal ZC Hood for EF
- Looking to rebuild b16 head in Miami FL
- WTB DELSOL LHS FENDER ASAP
- 98-01 USDM INTEGRA TAILLIGHTS
- Wtb 94 DB8 abs delete parts!!! ASAP
- wtb: look for a fuel pressure regulator for my 1997 HX civic
- WTB D16Z6 sohc vtec motor!
- WTB DC5/RSX headers
- WTB crower h23 rods
- OBD-1 B-Series VTEC Dizzy
- WTB: LS CRANKSHAFT!!
- GARRETT T3/T4 50 TRIM .48 a/r
- d series camgear
- WTB: 88 CRX Parts
- Garrett GT3255b
- WTB: 92-95 b series dizzy
- WTB: DC 4-2-1 HEADER, FASTLINE SHIFTER
- WTB: Hytech twin loop muffler, Bisimoto D-Series Header
- WTB: 92-95 Civic hb interior
- WTB: 93 coupe black interior
- WTB - EG/DC parts -- ASR / LCA's / Velocity Stack / Momo-Spraco wheel....
- OBD2a Integra GSR distributor.
- wtb 96-00 civic sunroof switch
- CA: gramlights 57c
- FS: 92-95 Civic and Del sol glove box
- WTB: Vented VC for B20vtec
- WTB- chipped p28 & dseries mounts
- WTB: 26mm Mugen Front/Rear Sway Bars for DC2 Integra
- WTB civic wagon parts
- WTB: 99-00 Civic foglights
- WTB: S2000 - I've saved $12,000
- WTB Starks
- WTB: DC2 function 7 LCA's
- **WTB: z6 cam gear**
- WTB M&W pro-10 setup
- WTB- Civic Si Stock Springs EM1 99-00
- wtb: edelbrock intake manifold (d16z6)
- WTT GO AUTOWORKS RAM HORN MANIFOLD FOR YOUR A/C COMPATIBLE RAM HORN MANIFOLD.
- WTB 92-95 bubble shell in NY
- ITR Exhaust Valve
- WTB: Skunk2 Front and Rear Camber Kits
- RHD S2K clip
- WTB: b-series trans gears. Looking to get GSR or LS 3rd and 4th gears!!!
- [B]WTB RHD eg bezel!!![/B]
- WTB: 1st GEN Blox IM B16A2
- WTB misc B series parts
- WTB OBD2 96+ Integra OEM injectors
- WTB 99-00 si midpipe/cat converter and 90-93 integra intermediate shaft
- B16a internals needed
- WTB: ITR rear seats
- WTB: D16Z6 adjustable FPR
- WTB 96-00 Hatchback & Coupe parts
- WTB: 99-00 OEM Grill -- OR -- 99-00 SI Grill
- WTB: 96-98 Ek Floor Mats
- WTB: mvs wastegate
- wtb : b16 obd1 engine harness and ecu
- WTB A K24 BLOCK
- wtb: virgin p28
- WTB: EM1 engine harness B16A2
- WTB! INTEGRA. . . .
- wtb: eg6 oem floormats
- 2004-2005 civic front end
- WTB DA Suspension forks
- WTB: b16, itr, or DC sports header
- B16 Low comp. pistons 81.5mm or 82mm
- WTB: 02-05 Civic si HB rims
- WTB: Honda CRV Steering Wheel, $$ or Trades..
- WTB: ITR Steering Rack & Entire PS Assembly
- Map Sensor/Radiator Fan
- WTB: *NEW* OEM Type R intake arm/tube.
- WTT
- WTB: ECU 37820-P0H-L01
- WTB: EG Parts...
- WTB:Obd1 b16 Dizzy
- wtb supercharger and hedder
- WTB: Oil catch can
- WTB intake manifold, clutch, vtec dizzy, fuel pressure guage, electric fan
- WTB EF9 fuel sending unit
- wtb:98+ rear integra bumper
- NTB: 88-91 crx si/dx front seat upper portion
- wtb oem b series head gasket and piston rings
- wtb vision imus frp black
- WTB: need d16z6 dizzy ASAP
- Extended top hats. Like ground control's or Custom made
- JDM B16A Throttle Body
- NTB: z6/a6 Crankshaft ASAP
- NEED oem si endlinks or aftermarket
- WTB: D17 Trans
- WTB: H22 or H23
- WTB : a good intake - cai or airbox- for B16
- WTB: B18B
- wtb: ej1 rear speaker covers & fog switch
- WTB: Camber kits and coilovers sleeves, wheels
- WTB: one SSR Type X
- WTB: lookin for DIZZY for my HX civic.
- WTB: OEM FACTORY INTEGRA CASSETTE TAPE PLAYER
