View Full Version : Want to Buy
- wtb manual tranny for 96-00 civic dx
- WTB: 5 Bolt 2.5" downpipe for integra
- WTB: 99-00 EK (OEM) Hood, Fenders, Bumper, Si Lip
- b series hydro trans near pa
- WTB: EK APEXI WS2 CATBACK
- Glove Box EG non airbag
- WTB: 94-01 Integra Long Interior Side Panels
- WTB 92-95 Civic EG Hatch Headliner With Sunroof Hole (S.Florida)
- WTB: RHD DA6 parts, heatercore, blower motor, trim pieces, ANY JDM parts LOOK!
- WTB: Spoon Replica Mirrors for 94 Integra
- WTB: ITR Bar End Links
- WTB B18a tranny
- WANT TO BUY: 1996-1998 EK side mirrors, flat black or black
- wtb: arp head studs for b20vtec
- WTB 96-00 civic AC bracket
- WTB 99-00 EM1 Sideskirts!
- WTB-2 struts for my 99 civic si
- wtb-these parts
- WTB in MD a Missing Link
- Must buy! 89-91 left lwr controlarm (civ) 91 SI AXLE!
- Zeitronix wideband w/ display
- WTB: Endlinks for REAR swaybar, GSR/LS/ITR or compatible!
- wtb: B18B1 Bottom End Short Block
- Need Integra 98-01 driver side mirror
- WTB - 94 - 01 Integra center console cigarette lighter piece
- I need a type r climate control bezel
- wtb/ turbo turbin and top mount for b18c
- WTB: CAT. LS / ITR / 00-01 GSR. Longer version.
- T28/25 Flanged B Series Turbo Manifold
- WTB: Civic SI 2000 Cluster
- Looking for parts!!
- WTB: 92-95 Civic VX ECU (P07) and O2 Sensor (5 Wire)
- WTB:02+ K20a type-R engine,02+ K24, or 98+ h22a
- WTB: Factory Del Sol Speaker covers!
- WTB: 99-00 Civic Si OEM Intake ( Box -:- Pipe -:- Resonator ) Complete! Socal
- wtb: 99 civic windshield washer resevoir
- WTB: skunk2 camber kit
- i need a 88 si motor harness
- WTB: t3 turbo .42/.48
- WTB EK REAR HATCH (TRUNK)SHOCKS
- WTB: working obd0 jdm b16 map sensor and vtec solenoid ((NEED NOW))
- fs 94-01 INTEGRA TYPE R OEM EXHAUST MUFFLER
- 05/06 TYPE-S WHEELS
- WTB DC RIGHT SIDE FENDER LINER
- WTB 92 civic side skirts
- WTB: virgin p06
- LS or GSR Hydro Trans near Cincinnati OH
- WTB RADIATOR for 90 std
- WTB: Red EG hood
- WTB: TWIN DISC CLUTCH
- WTB::B18A or B18B longblock::ASAP
- WTT: My CF EG hood for your white OEM hood + cash
- NEED A 2.5 TESTPIPE 954 & 305 AREA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- WTB...JDM EG6 Fenders.
- (WTB)OBDI GSR Harness
- Looking for a rebuilt or damn near perfect D series motor
- wtb: oem 94+ gsr crank pulley
- WTB: Teins for my DC2/DC2R.
- WTB: GC Coilovers and KONI Shocks
- WTB: B series Turbo Manifold! AC/PS compatible
- WTB: 99-00 Civic SI Power Steering Pump
- *****WTB...EF sedan corners.***
- WTB: set of 2 springs 8"x 2.5" 275lb-300lb rate
- WTB: B18C block
- WTB:GSR/ITR oil pump and water pump (22 tooth)
- WTB: Clean 90-93 Acura Integra 2DR in VA Area
- WTB: LS block w/crank, main caps, and rods & sensors are a plus too
- WANT TO BUY EG,EK,DC,DC2
- wtb: nice lip for an 89 crx
- WTT: 99-00 SI harness and OBD2b-->OBD1 jumper for 96-98 ex harness and OBD2a-->OBD1 jumper
- WTB: EG foglight harness!
- WTB: GSR Main Caps and Girdle
- WTB: 2003 and up Honda Civic EX wheels
- WTB: EBP front bumper and hood for 99 civic SI (FL)
- WTB Hondata 200 with boost
- WTB: integra front brakes/knuckles
- WTB Moroso Oil pan
- WTB: IAB Solenoid
- WTB: p75 manual trans ecu
- WTB: Autopower 4 pt Bar for 98 Integra Hatch
- European/ EDM Parts?
- WTB B18C block w/ crank JDM or USDM, and GSR head , skunk2 intake manifold GSR
- wtb - 1992 radio antenna - gsr sway bar set up
- 3" exhaust system for 96-00 civic hb
- WTB: 94+ integra gsr......northern cali
- WTB: p28 ecu.
- WTB: 92-95 honda civic guage cluster.
- WTB: CRX climate control Florida Orlando
- 90-91 bumper lights and bulb sockets.
- wtb- 89-91 crx civic si cable trans socal aspa!!!!
- needed to finish swap.... 99-00 civic si E-brake cables!
- WTB: cheap set of 4x100 wheels
- WTB: h22 injectors
- stock D15/D16 for 88-91 EF!!!!!
- \\\\\\wtb: stock EF Tailight//////
- WTB: HX rims (with or without tires)
- Help! Need an A/C line for my 00 Civic Si
- wtt 98 rodeo for hatch
- WTB: Left knuckle from 98-99 Acura CL 2.3
- Tranny price
- WTB: 92-95 honda civic coupe or sedan 5spd white EX
- WTB: JDM Integra Visors and BLOX or Skunk2 Intake Manifold.
- GSR/ITR oil pan
- WTB b-series throttle body (stock) and vtec solenoid like rigth now or by tomorrow pls in socal 714
- need pr3 ecu!
- WTB: CF Duckbill, Front Seats, 5 LUG RIMS, Floor mats.. so cal 626
- WTT CRX Si for 240sx
- WTB: 14" tires
- WTB: 2.5" Aluminum Intercooler Piping for 94-01 integra, IC, turbosmart 38mm ultra gate
- WTB: 95 LS Timing belt cover upper and middle
- wtb- 2002 ex civic auto trans
- WTB: Integra Turn Signal Sockets
- WTB: Stock EG/EK suspension - ANY CONDITION!!!
- WTB: d16y7 TB with all working sensors
- WTB: del Sol DOHC VTEC shift linkage & OBD2 GSR P72 ecu
- WTB - 99-00 VIS CF hood & hatch & vision MC EK mirrors
- 99' b16a2 long block w/gsr cams f/s f/t
- WTB: brake calibers for type r
- WTB H22 water pump, lower timing belt gear, and distributor
- WTB: P08 ECU for d15b
- WTB ::: 99-00 Civic Driverside Fender FBP OEM
- B Series Trans
- WTB: 1994-2001 Integra RS Brake Booster + Master Cylinder
- WTB: h23 crankshaft w/ rods
- WTB: tokico blues or tokico illuminas (for a 94 eg hatch).
- WTB: Mahle Pistons(h22) eagle rods, 3bar map Sensor
- WTB NEW JUN cams and valvetrain for H22
- //*5 BOLT turbo*\\ NJ/PA/DE
- Looking FULL interior for a eg hatch.
- WTB: Del Sol Parts
- wtb: aftermarket shocks 4 99 civic
- WTB: Injectorssssssssssssss
- looking for a trans,and a few other parts
- WTB: Unorthodox Crankshaft Pulley for 98 civic ex
- WTB: ITR 4X114.3 WHEELS
- WTB : Gen6 Accord Sedan trunk
- WTB/ willing to trade: sk2 intake mani for d16y8
- WTB: 96-00 b18b lower timing belt cover
- WTB: 94 integra radiator
- WTB: Turbo pistons for a D16Z6
- WTB Civic Hatch in Wisconsin
- WTB: 99-00 Civic Si driver's side pillar garnish
- WTB!! Drivers side solid mount and wastegate spring!
- WTB eg cargo cover
- WTB h22 VSS
- WTB eg carpet
- WTB:headgaskets for y8
- wtb: 88-91 civic ZC hood
- WTB: 90-93 Integra OEM Corner Lenses
- WTB JDM Window Visors for 92-95 civic cash in hand
- WTB Autopower Roll Cage for 92-95 Civic
- looking to buy a eg hb
- WTB: turbo kit b-series EK civic
- WTB : 90-91 CRX Driver Side Seat Pan Foam Cushion
- gt42r...good or blown...PLZ READ!!!!!
- EF b-series swap shiftlinkage
- WTB: B16A3 Intake Manifold and throttle body
- WTB/WTT: Factory JDM Type R front bumper
- wtb: dc/ek shell
- WTB: 99 Civic Si Rims w/ Tires
- WTB Black GSR LEATHER in Central Jersey
- WTB: mint tranny- JDM itr 4.4 or 4.78 FD, USDM itr or B16 near nj
- WTB automatic tranny b'series vtec ecu
- wtb 94 and up integra rs
- WTB P13 ECU
- WTB: H22 VALVE COVER AND FLUIDYNE RADIATOR
- WTB MD: EG 4d window switch.
- wtb: 99-00 climate control
- WTB: OBD2 Cat SOCAL
- WTB: Aftermarket 89-91 CRX suspension
- WTB: OEM RSX rear bumper cover
- WTB: 94+ Integra Intermediate shaft
- WTB: 4 wire 02 sensor for 93 Civic
- WTB Cable VehicalSpeedSensor(VSS)
- WTB: MI: black 16in wheels..
- WTB: D16z6 / 93 civic parts
- WTB EBC...boost controller
- WTB: HID ballast (mitsubishi elec.)
- WTB: EJ1 Grey Interior Parts
- WTB: Oil catch can, shipped to Germany
- WTB: 89-91 Si Tranny in VA. CASH IN HAND!!!
- WTB: Acura/Honda Parts (Dealership) who got the hook ups?
- car fax anyone??
- WTB B16 oil pan in NJ ASAP!
- WTB: NY/NJ area 94+ automatic Integra
- WTB: Type R Aftermarket Header, SMSP, RMF, Toda, Hytech
- V1 Valentine One VEE ONE v1 !! WTB y0!
- WTB: 01-04 CIVIC FENDER VERY URGENT.
- NEED OBD-2 sohc vtec distributor ASAP
- *** SAN DIEGO AREA ***LAPTOP FOR coplete singlecam VTEC swap
- WTB EG HATCH PARTS. NORTH FL
- WTB
- WTB: Rocker assemly for b16a head
- WTB: Passenger and drivers side fenders
- WTB: JDM INTEGRA FRONT END OR FRONT END PARTS!
- WTB: COMPLETE 99-00 Civic harness
- wtt stock 94 civic hatch for stock 96-00 civic hatch or coupe
- wtb: misc turbo parts
- WTB 86 corolla gts
- WTT...looking for 90/91 ls tranny, ex front brakes, and da rear brake swap for EF
- WTB: header & muffler
- WWT: 2000 SI gauge Cluster for Stock EF CLuster
- WTB Volk Gramlight 57C Center Caps
- WTB Civic Bumpers plus Misc Parts
- WTB:ASAP: hondata system
- WTB three wire harness on A/C condenser
- WTB an ek hatch shell in the ny area.
- WTB: 00 CIVIC SI CAT [so cal]
- WTB: 94-01 integra Hatch Tailgate "stay"
- WTB: 94-01 integra Gas door
- WTB ef9 SI shell in socal
- WTB 2 15" wheels 5x114.3 lug pattern
- WTB: Dsm 450cc blue top injectors
- WTB Type R OEM Intake Arm
- WTB:CTR\SPOON\WHALE STYLE SPOILER AND FRONT LIP 96-98
- CARFAX Someone please
- WTB/ Wrecked 92-95 Coupe EX
- 2006 Civic Si Muffler...
- eg mirror
- WTB: Apexi WS/WSII for 98 Integ Sedan
- anybody good with wiring?
- WTB: Milano Red parts for 94 Civic Coupe
- WTB: P28 + Harness
- WTB: Red CRX fender and 4-1 D series header
- Any year honda civic hatchback
- wtb: itr integra type r rear seats, sway bar, fluid reservior, black seatbelts.
- WTB: misc EF suspension/swap...FS: big 'ol amp and subs
- Vtec Vtec
- wanting a carbon fiber lip kit for EG hatch
- WTB: B16 Rear motor mount bracket
- WTB 96-00 hatch
- WTT: 00 GSR OEM Black Hood for CF/OEM Pearl Green Hood
- WTB SAFC
- ***WTB: Hydro B-series tranny case (dont care if it doesnt work) Socal***
- 1 Rota SlipStream
- WTB: 92-95 honda civic stock oem tail lights.
- srp d16z6 10.5:1 pistons
- WTB:ITR rear SWAYBAR 22mm, Ohio
- WTB clutch fork, clip, and boot for B series transmission
- TRADE: brand new 15x7 bronze slipstreams....
- WTB:OEM TRUNK FOR HONDA DEL SOL
- WTB T3 turbo w/5-bolt exhaust..can be new/rebuilt/used
- wtb/ turbo turbine housing
- WTB Mugen MF10
- WTB CRV P7J a/c bracket
- 99 miata intake manifold fuel rail injectors
- WTB: Stock ITR or Integra radiator with fans
- WTB: D16z6/D16y8 complete longblocks
- wtb: 94 integra amber bumper lights
- WTB: 98+ Amber Cornerlights
