View Full Version : Want to Buy
- WTB: T1R silencer
- Aluminum radiator and slim fan needed for 92-95 Hatch.
- Want to buy b16 or b18 vtec head.
- WTB: Ek suspension & lip
- WTB p30 pistons
- wtb: new or used p72 gsr piston
- WTB: 3" Turbo exhaust for a 99 GSR
- WTB: 98 and up Integra 4 drs Tail lights
- WTB: 90-91 CRX Si center caps
- honda-tech sticker
- WTB 81mm turbo pistons new or used
- wtb: ls dip stick
- WTB GSR, b16, b18 need june 1st
- WTB Integra Cable Tranny
- Wtb: ITR or CTR cams asap!!
- wtb: civic wagon wheels
- trade my vr4 for a built gsr swap
- WTB: P28 auto ecu, d16z6 distributor ON A BUDGET
- WTB: 96-00 Y8 Cold air intake
- WTB: 880+ precision injectors (Ohio area)
- WTB: ALUMINUM RADIATOR (EG)
- wtb ITB's for my b16
- WTB Mint Z6/Y8 trans
- WTB: ZC DOHC Tranny Half Shaft
- WTB K-Pro
- Wtb backyard special lip and exhaust!!!!!!!!
- WTB OEM USDM parts for my 1998 integra type R
- wtb: d series mounts
- WTB: B-Series performance parts and misc. Parts!
- WTB: Engine for lawn Mower
- WTB: Vision dc mirrors/NRG quick release/Nardi deep corn/Rear LCA
- wtb: usdm itr 5 lug conversion
- WTB: dc2 rails/or/sliders/base for bride brix 1
- WTB-OH: GSR P/S brackets/pump
- WTB driver side JDM EG coupe/hatch headlight.
- WTB: D-series Tranny near SC
- WTB USDM stock parts for my 98 integra type r
- Shifter for 92-95
- 94+ integra front knuckles
- WTB Crx parts.
- WTB: CTR Rear Lip 99-00
- WTT Zeal Function B6 Suspension 8K usage for ITR DC EK EG for EVO 8/9 Coilovers
- WTB 1997 Honda Civic 3DR OEM Sideskirts
- WTB: OEM EK9 wing base
- WTB Need ASAP!
- WTB: Ek b-series AC swap bracket
- =========WTB: 92 civic under dash harnes=========
- WTB D-series transmission
- ::WTB:: Integra Si-Vtec Front Lip
- wtb concave te-37
- del Sol aftermarket headlight seals
- WTB: D16Y8 complete or near complete please
- WTB: 02-04 rsx-s shifter mechanism
- WTB: 38mm wastegate, wideband, ic pipe.
- wtb B series swap
- WTB: B Series Skunk2 Pro 1s Cams
- WTB: EK momo hub
- WTB Wii & gamecube controllers
- WTB: 02-04 rsx-s engine/charge harness
- need 02 sensor asap!!!!!!!!
- WTB po6 92-95 dx ECU auto
- WTB: Front lips
- WTB:1 Mugen MF10 s2k
- WTB chragespeed wing for EF9 in socal
- Ignition switch 92-98 with auto
- Skunk sleeves 98 civic
- WTB H22 Vtec solenoid
- WTB ek/itr control arms, function 7
- WTB: D15B7 Motor
- WTB 5lb nitrous bottle.
- WTB: EDM civic headlights
- WTB: DC5 RSX Parts
- Dc Integra rear muffler
- WTB: 14B Turbo in decent condition: Atlanta, GA
- WTB: JDM integra hood
- WTB: passenger side Mirror and assembly
- WTB: Distributor for B18 GSR OBD1
- WTB: DC2 Foglight switch
- WTB: D16/EK oem shit!!
- WTB: 94-95 Integra GSR Bare Block *CA, Bay Area Seller Preferred*
- WTB: B16A2 Complete Swap
- WTB: HX wheels
- WTB: J's racing or J's Racing Style intake for GSR head only
- WTB: Integra 94-01 2-door Driver Side Window Motor/Regulator
- WTB: 96 Accord Lowering Springs
- Please Read
- WTB: EM1 Springs, Airbox and Arm,Rear Seats, Exhaust Manifold and Cat
- Wtb:eg strut bars....
- WTB d series adj cam gear
- *WANTED* H22 intermediate shaft 1996 civic
- WTB engine harness
- need to pass bar.EG w/ b18c1
- Evap canister
- WTB: B series Cable LSD Transmission
- **WTB 99-00 SI front bumper and lip**
- WTB: JDM ITR FENDER
- In need of B series stuff
- Honda Parts Needed A.S.A.P.
- WTB built/semi built block b series NA
- WTB:96-00 CIVIC REAR WINDOW VISOR
- wtb: 89 Crx DX Dash A/C piece
- wtb: crx 89 dx Fuel Line- Firewall- to Fuel Filter Peice
- WTB: E-brake cables Integra/Civic
- wtb! Drag racing axles. Gators,dss etc etc
- WTB: JDM Del Front End
- WTB OBD0 B16 INJECTORS AND O2 SENSOR
- WTB Ign switch with key for 96 Integra RS with auto trans
- looking for parts supliers for my online store ..look
- WTB EK or DC2 Shell
- WTB: LS Cylinder Head Parts
- WTB: 96-98 civic coupe Front Lip! asap!!
- WTB: 96-98 Coupe KEVLAR HOOD!! someone??
- WTB: 99-00 Civic tails
- WTB: 92-95 civic 2 dr harness
- WTB Y8 JRSC kit
- WTB: EK Civic Coupe Sideskirts
- WTB: 94 Accord engine mount and F22A1 Water Pipe
- WTB: H22 Cams (Blox B's or SK2 Pro)
- WTB: B18a/b Thermostat housing w/ sensor
- WTB OBD2 H22
- WTB: 97-98 ITR in white, salvage/high miles, $10k or less
- WTB: CW ITR sideview mirrors
- wtb ZC LSD tranny
- WTB: OEM 99-00 Si leather shift knob & 99-00 OEM headlights
- WTB LIST : please need these parts
- WTB crx or civic battery tie down
- WTB: 1994 frost white Civic Si hatchback with ABS
- WTB EK4 FULL ITERIOR SET
- Wanted: B series stage 1 cams
- WTB: OBD1 to OBD2B harness
- WTB: 0em hood bra for 92-95 and 96-98 Civic
- WTB: JDM ITR CAT CONVERTER
- wtb Type R wheels
- WTB: 90-93 Integra LEFT axle
- WTB Victor X Intake Manifold for GSR
- WTB: 99-00 Civic SI A/C system
- WTB: 92-95 EX/SI Cluster - Manual - w/ABS indicator
- WTB OBD2 OEM Vtec Dizzy
- WTB F22B oil pump
- WTB Complete H23 Block
- F23A5 shortblock
- WTB D16Z6 FULL SWAP
- Looking for B18c1 or ls block.
- Want to buy! 94 - 97 Del Sol.
- Want to buy! 88-91 crx
- Want to buy! 88 - 91 hatch!
- wtb 96-01 integra bseries parts
- Type R Axleback For Sale?
- DB8 master window switch A.S.A.P
- WTB: Slider and Hub for B16/Type R Tranny (Wisconsin)
- Oil Pump
- WTB: RC 550cc injectors (SL9-550)
- WTB: P7J CR-V BRACKET
- WTB ek suspension
- WTB: S2k Seats or GSR Seats,
- WTB: H23 non vtec valve cover
- WTB: 88-91 Civic Si tranny
- WTB: Wiring harness for OBD-1 B-Series Vtec, cut, uncut, plugs missing.
- WTB 90-91 LS ENGINE HARNESS
- WTB city light sockets and wiring harness for ctr lights
- wtb a dc2 passenger side window regulator
- 2000$$ WTB: eg or ek hatchback LOS ANGELES
- WTB: 98-01 Integra Drivers Side Headlight
- WTB:B series Hydro Trans!!
- wtb: CRX Parts
- WTB: d series clutch kit (hyrdo)
- looking for D16Z6
- WTB: JDM ITR CAT
- wtb: ek dizzy, caliper, fender
- Integra GSR Cloth Rear Seat Base
- WTB: Alarm pager 2 way style.
- WTB: B series Fuel rail, with end cap
- delete.
- delete.
- wtb fastline shifter and jdm sir2 eg6 armrest
- wtb; honda 400ex
- WTB: 01 civic tan sun visor DS
- wtb: type r intake cam gsr intake manifold
- EK shell
- WTB: stock virgin bseries vtec valvecovers
- WTB: Drag Radials 15"
- WTB: NON ABS Rear Disc Prop Valve
- WTB b18b LS crank
- WTB: D16Z6 Fuel Rail retaining nut and Cap
- Need B16 Oil Cooler and Bolt. Must have bolt that goes with it.
- WTT 90 5.0 Mustang for Civic/Integra
- WTB - Rear Seat Belts in Black/Grey for 93 Si
- GSR block Wanted in the Northeast
- wtb 6 speed tranny
- looking for parts to complete my turbo build
- WTB 90 91 crx si shell
- WTB ITR /ctr cams asap!!
- wtb intake
- WTB K-SERIES SWAP PARTS
- WTB 1992 - 2000 Honda Civic Clusters
- WTB EG GSR Parts Tach, Wheels, Suspension, etc...
- wtb nice leather seats for eg
- WTB: replica bys spoiler
- wtb b18c1 or b18c5 crankshaft
- WTB ITR JDM FRONT HEADLIGHT CLIPS
- oem 99-00 si rear sway bar w/endlinks
- WTB: ITR cams
- WTB EK hatch
- WTB: SI Parts
- wtb h23 engine or a cheap h22!
- wtB: bride seats
- looking for hatch in Miami
- WTB: interior parts
- WTB CTR Interior Parts/S2K AP2 Cluster w/Pigtails
- WTB: ODYSSEY,BRAILLE,DYNA BATT,BUDDY CLUB battery
- WTB: 99-00 Si lip
- WTB: 92-95 Civic integra stuff. wheels Ferio
- WTB: B-Series Vtec Solenoid
- WTB pair of TSX projector bowls/shells
- WTB: AEM CAI for ITR
- WTB ($40 reward) 1 16x7 black racing pron1 ANY COLOR 4X100
- WTB: 99-00 civic si air intake
- WTT: timing belt side hasport EGSTK for DCSTK
- WTB H22 Intake Manifold stock/carb
- WTB: Ek door internals or drivers side door
- Wtb Autocheck
- WTB: Hondata S300
- WTB: OEM Speaker Connectors W/ Wires
- WTT: Integra LS mesh rims black
- WTB 00 Civic SI Engine Wiring harness
- WTB: Wheels
- WTB:: OBD0 DOHC Distributor In so cal.
- NEED 90-93 integra or 88-91 civic main injection/fuel pump relay! FAST!
- wtb jrsc part for b16 !!!!supercharger!!!
- WTB: Stock B Series Cam Gears
- need motor
- WTT: rota slips (polished)
- WTB- bottom half of header
- ------WTB:99-00 CTR Replica Headlights and HID Kit---------
- WTB: 94-01 Integra 4dr Rear Seat!!
- WTB: OBD2-A (96-98) LS 5 SPEED ECU VIRGIN
- wtb: braided fuel lines
- WTB stock 96-98 civic radio
- wtb:b18c arp head studs and rod bolts
- 1 16x7 black racing pron1 ANY COLOR 4X100
- WTB: Power Steering line. DC Integra
- 96-98 optional front and rear lip kit as well as
- wtb s200 w/ boost option
- WTB: ITR/CTR 5 Lug Conversion
- WTB driverside headlight and amber corner 1998 itr
- wtb hasport hydro tranny mount for crx
- *wanted* obd2b 99-00 Honda Civic Si P2T ECU
- TB: EG hatch rear wiper motor housing
- B series Torque Mounts for EJ Coupe
- Torque Mounts
