View Full Version : Want to Buy
- WTB rota auto x center cap (red lip)
- 99 00 civic Fenders and hood
- i need a stock 92-95 civic hb/coupe lip. san diego
- WTB: Blackhoused headlights, shocks, & 96-00 Civic Trunk
- WTB: After market LS intake manifold/ Polyurethane mounts
- WTB: IACV for B series engine
- WTB: work ewing center caps or whatever will work!!!!
- Crx Center Cap
- WTB: B18b or B20b or z Head.
- civic/interga rear sway bar d brackets
- WTB: Integra Parts
- WTB: Tial 50mm BOV
- WTB, ONE tire for 2008 civic SI. 215/45/17
- WTB some motor mounts for a b series
- WTB JDM F20/H22 internal dizzy
- 96 - 00 Civic Ex OEM Catalytic Converter
- WTB: 99-00 d16y7 engine harness
- WTB: 96-00 EX front lca's
- WTB ctr muffler
- WTB: 2000 civic EX catalytic & exhaust
- WTB AP1 S2000 Cluster w/plugs
- WTB: 2000 civic EX oil pan with drain plug.
- 2006 Ridgeline Intake System
- obd1 v-tec engine harness
- wtb GSR shift knob
- 92-95 4dr parts needed
- WTB raditor fan ASAP
- WTB delsol vtec cold air intake
- WTB - EG Coupe/Hatch Fog Covers
- WTB: Coilovers for CRX
- WTB 92-95 Civic hatchback Roofskin with Sunroof
- WTB: HX rims
- WTB: 96 - 00 honda civic OEM side skirt
- WTB: Oem 97-01 dc2 headlights
- WTB turbo
- WTB high compresstion part
- ***WTB: 92-95 Civic 4 door w/B18c ITR swap or built GSR (N/A)***
- I NEED a 94-01 integra rolling shell... read details
- WTB: del Sol electric Antenna
- wtb 96-98 ctr front bumper
- wtb Spoon Sports Testpipe
- WTB civic/crx inside mirror covers
- WTB: need parts for my 98 gsr. PLEASE HELP ME REBUILD MY STOLEN GSR!!
- wtb: OEM 98-01 integra bumper lens
- WTB: EF Cargo Cover...
- eg6 hood bra
- WTB: DA Rear Trailing Arms...
- wtb d16a6 cam
- wtb 96-98 ek cpe power window switch
- WTB: OEM honda wheels
- WTB: OEM Bumper lights (98)
- WTB: Driver side headlight harness Accord 94-97
- need a b16
- wtb, cash in paypal......02/04 rsx charge harness
- wtb: iacv
- WTB: Aftermarket Motor Mounts (EG)
- WTB stock OBD2 B-series fuel injectors
- WTB: 99-00 civic si engine bay harness
- WTB: CAI For 05' RSX-S also looking for Hondata K-Pro
- Wtb: Parts for my 99 civic si
- del Sol EDM Rear Fog (LHD)
- WTB CW itr-ctr rims
- WTB: Yakima or thule roof rack for civic
- WANT to BUY: DC2 FOG LIGHT SWITCH
- WTB: misc b-series jrsc parts
- WTB: Shift Knob
- WTB. EK Hatch Cover
- WTB: 99-00 SiR Lip
- WTB: 96-00 Civic Hatch Catback
- WTB: Transmission
- crx bumper
- WTB shift linkage asap!
- h22 harness plastic over valve cover please look at pics
- wtb: upper control arms uca
- WTB: H22 Crankshaft Pulley
- wtb:b16 differential
- WTD: Shuttle rear door (drivers side)
- WTB ek hatch
- WTB DC2 shell
- wtb: b series vss complete manual
- WTB: H22a4 oil pan
- WTB: Drag dr16 Center caps, or 2005 Honda Odyssey EX Center Caps
- wtb:bottom mount recaro rails for DC2
- WTB: B-series vss obd1
- WTB: kkk k04
- WTB: 2003 Civic EX 4dr hub cap (one)
- WTB: 1998 Integra Sedan Sideskirts
- WTB: EG or Ek radaitor.
- WTB: RSX Type-S Tranny
- 97-01 prelude
- Wtb:b20b
- WTB EK Hatch PA/NJ/NY
- WTB!! need center caps!!!
- WTB: Walker Japan 96-98 Civic Front Bumper
- WTB: b16a2 bottom end.
- WTB:92-95 Honda Civic EX stock antenna
- WTB: del Sol Si Gauge Cluster
- wtb: gsr wiring harness
- WTB Harvard blue eg front end or primered
- WTB: Right-side 96-00 Civic folding mirror
- WTB: Fit Sport foglights
- WTB Bseries hydro trans case (NC)
- WTB ASAP B18C1 Vtec Crankshaft
- WTT 89 si w/swap for fully built gsr or r motor
- wtb in socal: motor mounts for 92 civic or d16y8
- Wtb hid kit
- WTB:Tow Hook, Header, Roll Bar, Seats.
- wtb:ek right fender jdm thin side molding
- WTB EM1 99-00 Si Power Steering Pump
- WTT: ITBs
- WTB: B-series Pistons & Rings
- WTB: Manual window assembly 4 98 dx
- GSR obd1
- WTB ASAP B18 Non Vtec Crankshaft
- Arc
- WTB: eg stuff
- WTB: 96-98 Civic Cupholder w/ din space
- WTB: Integra Type R SHELL! Rolling or not!
- WTB: DC2 Driver/Passenger fenders and doors
- blox / AEBS GSR intake manifold
- JDM delsol rear window w/o heatinglines
- wtb:itr throttle cable and bracket
- WTB Door Lock Interior
- Neuspeed tie bars, lcas, +
- WTB: 4x100 rims and tires
- WTB: NEED 96 civic ex or hx engine harness
- WTB: need a rad support 94-01 teg
- Strut bar
- WTB: 95 civic coupe / turbo parts!
- WTB: 05 Civic es2 driver motor mount
- WTB wheels and slicks
- WTB: Few Integra Parts :WTB
- WTB 4 wire oxy sensor
- WTB: 15" 4x100 wheels and/or tires
- WTB: H23 non vtec valve cover
- WTB Eagle LS rods
- wtb stock rad for 94-01 integra
- WTB: STOCK OBD2 LS OR GSR THROTTLE BODY with stock tps included
- Wtb: H2d motormounts
- Wtb 98 oem civic headlights
- wtb
- WTB: skunk2 pro1s
- WTB D series a/c compressor
- Wtb: D16y8
- WTB stock EF Upper Control Arm
- WTB EF Door Panels
- WTB: H22a prelude transmission
- 97 Accord lx harness MT
- WTB 07 Civic Sedan Galaxy Grey HOOD
- WTB:after market GSR manifold ( skunk 2 )
- wtb ek civic or dc integra 6k
- Want to buy list !!!!
- Wtb ctr srd recaros, black and red
- WTB: 99-00 Si
- Jereds NA Build
- WTB: D Series Skunk2 IM & TB setup!!!!
- WTB: TE37 Center caps
- Clutch and Flywheel
- WTB 05-06 RSX type s wheels
- WTB:EF civic hood bra
- *****WTB:D15 OBD1 Distributor*****
- WTB 15 16 17 inch wheels tires 4x100
- ------wtb-----Lenso-------vpd--------
- wtb: eg "lock" piece for manaul doors+window regulator
- WTB: 90-91 integra 5 speed engine harness
- WTB: OEM 1999 - 2000 Civic Headlight Assemblies
- H22 EF! h22 ef
- Wtb: Obd0 d16 distributor asap!!!
- WTB 88-91 ef civic REAR subframe
- WTB gray vtec solenoid plug
- b16 si mount and tranny bracket needed
- wtb mild cams
- WTB: DC2 Backyard Special front bumper
- WTB-oem side skirts Bay Area
- WTB: adjustable brackets for the CTR wing
- Wtb: Crx a/c
- ITR-LS-eksi .... CAI
- WTB: LS head
- WTT- OBD0 ECU for an OBD1 ECU
- WTB- MINT 99-00 Black Head Lights
- WTB Hondata S300
- WTB: ARP Rod Bolts for b16, b17, b18c Acura & Honda 9mm, 208-6401
- WTB: 99-00 Civic Si rear mudflaps
- wtb advan sar3 center caps 1 or more
- want 16" gt3 4 lug rims/rims and tires
- Wtb: 02-04 hondata k-pro
- Wtb dual proportional valve
- WTT: 1989 Hatchback For Coupe
- WTB: Acura Integra Type R Rim/Wheel
- WTB Complete 92-95 A/C system ASAP!!!!
- WTB: b series clutch
- WTB 92-95 civic COUPE interior dome lens cover and trunk interior acces light cover
- WTB: Gold 16x7 Advan RGII (RG2) Rims
- WTT eg carbon fiber hood, mugen lip, si rims SOCAL!!!!
- WTB:B Series Lightend Flywheel!
- WTB: A JDM srs computer for a Dc5
- WTB: Oil Pressure Sending Unit, B series
- OBD2a to OBD1 Jumper Conversion Harness
- WTB: USDM ITR 5 LUG plus Wheels
- WTB K24 alternator n K parts
- Looking 4 ITR wing and 5 Lug Slipstreams
- WTB heat shield
- WTB 1 low compression 81mm wiseco dish piston
- WTB: EG coupe rear trunk floor carpet
- WTB 99-00 Civic FBP Passenger Fender
- wtb sleeved block
- WTB: Civic SI Engine Harness
- wtb-lower control arms
- WTB 92-00 Civic Hatchback Shell Near Sw PA
- MI:WTB: PR3, P30, ITR, CTR or Aftermarket Piston
- WTB D15B7 timing stuff
- wtb in socal: d16y8 tranny mounts or stock 92 civic tranny mounts
- WTB :Oil Catch Can kit
- WTB: 96-98 ex ENGINE harness (manual)
- WTB- 88-91 Civic hood bra "OEM"
- 96 97 98 civic engine harness vtec or non.
- WTT for EP3 OEM seibon CF hood, OEM style headlights
- Wtt: Intgra Ls Parts
- wtb: type r flywheel
- CTR Tailights/JDM EK9 Interior Parts
- wtb old sticking lma's from all heads
- WTB:02-04 stock rsx front lip
- WTB: EK hatch rear rumper/GSR intake manifold......HELP!!!
- WTB: eg parts
- WTB- 92-95 eg hatch carpet black/ and dash
- WTB: OBD2A engine harness and sub harness
- Wtb: 99-00 si spoiler, front lip, grille, foglights, asap!!!
- WTB: Blue Sparco Harness
- b18c headbolts, gsr/ls rod and main bearings
- Wtb 3 Inch Prelude Intake !!!!!!!111
- WTB downpipe
- Wtb: Longblock!!
- WTB: Volk Racing GR-N or GRN-R's 15x7 and +35 offset...
- [WTB:] Shaved and Stripped B Series Valve Cover
- WTB: GSR Crankshaft
- WTB: Texas Instrument TI-83/TI-89 Calculator
- WTB: del sol headlights with the corners
- WTB 94-up intergra and 99-00 civic parts
- WTB: M&W pro 10 w/ harness
- WTB: B Series Vtec valve covers
- WTB Type R struts, springs and rear LCA
- WTB 96-98 Acura TL JDM Inspire Saber parts - Lip kit or ANYTHING!
- **WTB:Type R header heat shield**
- ITR intake cam shaft!!**
- WTB NOW!!!!!! 98-01 Integra Rear bumper
- WTB: 1990-1991 Civic Si or Sir gauge cluster
- WTB: eg cluster
- need sleeved gsr block that is ready to go!!
