View Full Version : Want to Buy
- WTB ASAP 96-98 Civic Coupe 2Door Driver Fender & Driver Mirror
- WTB: 2.5" exhaust donut gasket flange
- Ep3 half shaft
- WTB 38mm tial wastegate spring ref small or yellow small
- WTB: EM1 99-00 Civic Si Front Shock Forks.
- Civic Type-R EK9 OEM Strut Tower Bar
- WTB B series/EF parts
- WTB OEM Catalytic Converter
- D16z6 Poly mounts (street/light track use)
- WTB: OBD1 Non vtec b series distributor
- WTB: EG 50/50 Tails
- WTB: stock exhaust for 98 dx
- WTB: B-Series Flywheel Bolts and Pressure Plate Bolts
- want to buy a degree kit
- skunk 2 pro 2's trade for pro 1, skunk 2 stage 3 tuner or jun 3
- WTB: ITR Crankshaft Pulley need before Nov 10th
- eg civic air duct
- WTB: 97-01 Honda Prelude IACV
- WTB: D16 Y7 dizzy (MD)
- WTB: Eg hatch 2k obo (chicago)
- WTB - Auto Meter Gauge Bezel for '99 CX
- WTB 99 ek hatch trunk carpet
- WTB: Integra IAT sensor and harness
- WTB Sard Stack cluster
- WTB> DEL SOL Leather seats & 92 EG rear window hook lock to trunk
- WTB: 92-95 eg front lip (used, broken tabs, etc OKAY!)
- WTB: Dseries Cable Trans
- WTB:LS vlave cover
- WTB Da stock pulley steering wheel battery pass headlight & DC LCAs &rear suspension
- WTB: ITR Exhaust Cam and Dual Valve Springs
- WTB...h2b kit plates and mounts
- WTB fully built/ modified civic in trisate nj/pa/ny
- WTB: h22 euro-r ecu or any obd2 ecu that will run that engine
- WTB: ASR Sway Bar!!!!!! Or CTR, ITR sway with all hardware
- jrsc bypass/butterfly bracket
- WTB: 96-98 Civic EX VTEC Engine Harness Complete
- WTB: 96-98 engine harness A/T non Vtec
- WTB: 96-00 Civic dark grey center console/shift boot console
- WTB: GSR DIFF w/ FINAL DRIVE
- acura el / honda domani
- WTB 95 GSR Oil Pan and Gasket
- WTB: Hasport/Innovative B-Series Mounts for Hydraulic Transmission in 88-91 Civic/CRX
- LF: Mint EM1.
- Project-Ek9's WTB Thread!!!
- wtb ek manual door regulator and drivers door panel
- adjustable cam gears b series
- b series fuel rail
- [TN] Wtb cheap'ish DD
- WTB:B-Series (NY)
- lookin for ef traction bar
- skunk 2 pro 2 B series cams trade for skunk 2 stage 3 or pro 1
- WTB mike belben drgree kit
- WTB: Mint condition 99/00 civic si wheels (EM1)
- WTB; EK parts; EX Auto Tranny, Sunvisors, Kick Panels
- WTB: EJ8 EK parts
- Wtb: Jdm Ctr ek9 rails for recaro seats
- WTB: 94-01 Integra Power Window Switch (Driver)
- **WTB** Eg B series power steering swap.
- WTB: ef9 civic hatch bumper lights (wrap arounds)
- WTB: OEM ITR LIP USDM
- 81.50mm NPR ring set
- wtb: password intake carbon or kevlar
- wtb b series tranny
- WTB: EDM GRILL 96-98
- Wtb Dc2/RSX swap parts
- WTT: LS crank/rods for B18C crank/rods
- Want to buy a good set of cam gears for my b18b
- WTB: Brian Crower Cams & Supertech Valve Springs n Retainers.
- WTB: 90-93 integra rack and pinion
- WTB LABELED Obd2a Integra engine harness
- wtb: VTEC SOLENOID PLUG
- WTB: USDM ITR shocks/springs
- need a distributor
- WTB: front end body pieces
- WTB: S2000 push start with relay
- 99-00 Honda civic Si rear disc swap
- WTB 92 93 DA6 XSi Cluster or DB2 Cluster
- wtb: Test pipe 92-95 eg coupe
- wtb eg parts
- wtb f20b/h22 tranny swap
- WTB: Valves and engine bearings
- NJ - wtb - Stock p06
- WTB: Honda radio pocket with brackets
- WTB: f/h ARP headstuds - DC2 cluster
- need help finding some rims(giving a finders fee)
- WTB EG Wiper Stalk + Glove Box Handle
- WTB Skunk 2 Coilover springs only
- ---- wtb gsr victor x intake manifold ----
- WTB: Hydro B-Series VSS
- WTB: EG sedan fenders, hood, and bumper
- WTB:obd2 manual ecu for 99dx civic d16y7
- WTB ITR Calipers.
- WTB integra parts
- Wtb billet bell housing b- series
- EK Hatch Dark Grey Interior parts needed
- wtb steering wheel set up, qiuck release, hub to
- quad-pod cluster for integra
- WTB 15" MRR, Enkeis, Axis, Traklite
- WTB: one or two 16" spoon sw388 in 4x100
- 99-00 civic si lip
- GSR Lpwer timing cover/Civic Wagon Corner Lights
- Looking to buy/trade for: Weld Racing Magnum Import Drag Gold Rear Skinnies
- WTB: 97 Delsol SRS Unit + Misc Parts
- WTB obd2a and obd2b engine harnesses
- EF Si K-swap harness
- domani/ acura el trunk
- B series hydro tranny
- WTB: stock GSR muffler
- WTB: Fender Liner, Turn Signal Bracket, 2x wheels
- ***WTB: ITR 4 DOOR BOTTOM REAR SEAT AND 2 DOOR UPPER REAR SEAT***
- WTB: 96-00 Rear Civic suspension and LCAs - Stock is good!
- WTB: H22 cams and header
- WTB: H22/23 Twin Disc
- WTB 99-2000 championship white CTR grill
- WTB: Front / Rear Sway Bars for EG
- WTB: DC2 ARC INUCTION BOX
- WTB: Integra OEM/Raybrig fog light harness
- WTB EK STRADA`
- WTB EK SI rear t-bracket and transmission bracket
- WTB: Gsr Sedan black seats
- WTB: 98-01 integra rear mud flap
- WTB: MPFI SWAP
- WTT (my) B16 tranny for (your) LS tranny -FL
- WTB: complete ac system for 2001 prelude!!!
- WTB: Catch Can vtec vented v/c b series
- WTB- Stock P28 ECU
- WTB: Catalytic Converter for my 98 Civic LX
- WTB: 99-00 Em1 Hood bra, SI Cluster,99-00 Rear mudflaps
- WTB: Complete cylinder key set for 96-00 Civic AND 97-01 CR-V
- wtb ek tie bar(comptech) & usdm b series valve cover
- WTB: 96-98 Civic OEM headlight (driver)
- Jackson racing supercharger either vtec/non vtec
- WTB: ANY SOHC VTEC SWAP LONGBLOCK LOW MILES CALIFORNIA NOR CAL
- WTB: OBD1 Honda Harness
- WTB:Lots of Turbo Parts, Mishimoto, Skunk2, 44mm WG, etc.
- Wtb--type r,ek hatch, eg hatch exhuast pipeing!
- ef wagon awd/s2000 parts
- WTB: ID2000 with 14mm tops
- WTB: Mugen DC2 Front Bumper
- Wtb: 92-95 Civic (hatch/coupe) hood bra
- WTB 84MM Low Comp Forged Pistons!
- D16a6 Transmission (CRX/EF)
- WTB: 6266 T4 .81 or .96 exhaust
- WTB 99 CTR Headlights
- WTB> B Series Tranny ( b16,ls,gsr)
- 99 CIVIC SI EBP
- WTB: CRV parts - Fullmark rear, Depo tails, and Euro Front
- WTB: OEM GSR Cams
- WTB 2009-2011 Civic Si driver side fender (taffeta white)
- WTB OEM 2009-2011 Civic Coupe headlight
- WTB ATI Damper
- WTB:BARE GSR BLOCK WITH MAINS
- WTB OEM 98+ USDM Integra foglights
- WTB: 95 oem integra fog light harness
- WTB; Aem big brake rotor kit integra/civic
- WTB: Blox Type C Intake cam!
- WTB: OEM B Series Ring Gear Bolts (92-93 GSR YS1)
- wtb:eg hatch muffler and pipeing
- WTB oem 98 honda civic ex exhaust manifold
- WTB: DC2 Front Camber/Upper Control Arm!
- WTB: 90-93 Integra Floor mats
- WTB ITR OR CTR Springs
- Wtb registered eg6
- OH; WTB 225/40R/18
- WTB jrsc for b18/b20
- Project Kics R40
- JDM HONDA CIVIC EG6 SPOILER
- WTB: DC2 Black Housing Headlights
- please help! ! ! ! ! !
- ***WTB : CIVIC 06-11 OEM Navigation system***
- wtb b16a3 balancer off 95 del sol vtec b16
- WTB: GSR LOST MOTION ASSEMBLY- LMAS B18C1
- WTB acura LS wheels
- ARP head studs for B18B,Head gasket,and clutch
- WTB: 4x100 15" set
- LOOKING FOR PROFESSIONAL TO HELP TUNE AEM SERIES 2
- k20a2
- wtb d-series manual tranny front torque mount and bracket for manual swap
- WTB: 94-01 DB8 Driver Side Master Window Switch
- WTB: 98+ Integra front end. Fenders, Hood, bumper, bumper&headlights. frost white
- WTB: EF 3-spoke steering wheel
- WTB: Turbo S2000
- WTB Benen Tripod Strut Bar
- WTB: Eg Parts list inside
- Wtb: Bard 96-00 civic hatchback
- WTB: XO Vision stereo harness
- WTB: EK Recaro seat rails/brackets
- WTB: EF9 REAR LIP + other EF parts
- WTB Stoptech Rotors
- js racing 60r eg6
- WTB: dc2 type r cluster
- wtb dc integra cluster plugs
- wtb: bseries spark plug wire cover
- h23a block ( vtec ) with crank
- FL Wtb: itr cams
- WTB: Full body Coilovers for a ek
- Wtb eg hood
- WTB: GSR Speed Sensor
- MD: WTB P8R CYLINDER HEAD
- WTB: 94LS 3dr Tailgate Lock assembly/glove compartment lock
- WTB 95 civic power steering reservoir
- WTB. 99-00 Civic EBP OEM Grill
- WTB: Buddy Club Spec 2 Ek 2/4 door
- CT wtb OBD2 stock cat for 98-01 integra
- WTB JSRC FOR LS, B20 SOCAL
- Wtb : eg6 cargo cover
- wtb VITARA/EAGLE RODS & D16A6 OR Z6 CRANKSHAFT
- WTB: 2002 Civic sedan LX stock used Suspension
- ek9 parts wanted
- WTB: 96-00 Civic Coupe Hx stock parts
- WTB: D16Y8/S40 Transmission
- 88-91 Prelude rear ashtray
- WTB: 96-00 sedan driver side panel & 99-00 sedan driver corner tail light
- WTB 99-00 SI Front Shock Forks
- wtt for 92-95 coilovers
- WTB: Vtec Oil pressure switch on Solenoid
- wtb f20b alternator rectifier assembly
- WTB Ac condenser fan
- WTB Acura key for wheel lock!!!!!!
- WTB: SI or DC e-brake brackets | EG or DC ignition switch
- WTB: Type R /GSR Oil PUMP like NEW
- WTT ys1 trans
- wtb: d16z6
- comptech ek tie bar ek kit wtb
- WTB;Bseries ATI,S300,2000cc
- WTB 92-95 Civic Optional Audio Console (BLUE)
- WTB: xxr 531s platinum
- WTB crx tailgate glass
- WTB 2008-2012 Accord Exhaust Finisher (tip)
- WTB: 99 civic coupe door hinges w/ hardware
- WTB OEM Optional side kirt DC2
- Wth: 600 hp+ intercooler no eBay please
- wtb big brake kit
- WTB: 96-00 sedan rear driver panel & 99-00 red/clear tail lights
- WTB: D16Y8 exhaust manifold
- Need custom sized acl race bearings.
- wtb 99-00 civic si post mount bracket
- WTT:Fully built LS-VtEC+1000hp fuel setup+turbo setup for bike or car.
- Wtb: 88-91 crx/civic alternator
- Looking for Integra part out!! WTB a 96 or 97 Integra LS Main Harness!!
- WTB: AEM big brake kit
- WTB gsr crank pulley
- Crv se stereo
- WTB: obd1 engine harness [IOWA]
- wtb 99-00 oem intake tube
- wtb aftermarket integra ls fuel rail
