View Full Version : Want to Buy
- WTB: Civic/Crx 90-91si under dash harness, and mpfi engine harness
- WTB head
- WTB: HARD DRIVE (SO CAL)
- WTB: D-Series Aftermarket Headers
- WTB: FLYWHEEL
- WTB: D16Y8 longblock
- ef si harness
- wwtb: ek9 parts 96-98 and wheels..
- WTB GSR stock block sleeved or stock bore block
- WTB OBD2 B16A2 HEAD!!!!!COMPLETE
- WTB: seat rails
- WTB: stock d16z6-OR-d16y8 cam--sohc--vtec
- WTB: 2.5' cat!
- WTB bogart 15 inch skinnies with tires for 91 crx
- WTB:Greddy oil return flange tube (pan side).
- WTB: vtec solenoid, ps pump, ssqv, boost gauge
- WTB 96-97 DEL SOL BUMPER
- i need parts for my zc motor who knows where they r?
- 98-01 Accord OEM Special Edition Rims/Wheels or or EX Rims - 4 LUG
- WTB: ONE HX RIM! JUST ONE!
- WTB: 92-93 integra driver side motor mount
- WTB:: REAR BUMPER DIFFUSER
- WTB: GT4088R, GT4094R, GT42R
- WTB obd1 b16 ecu. Chipped p28? p30?
- WTB: 94-97 jdm integra foglights. yellow or clear
- wtb: crx climate control unit
- WTB: EG Hatchback front fenders(local pref, md,va,pa)
- WTB: OEM 92-95 Civic Spoiler (Coupe)
- WTB: P28 Virgin ECU- NJ
- WTB GSR TRANNY
- WTB: 94-96 Prelude Dash Harness and cluster
- WTB: obd2 cat stock only pls - LA area
- Need 92-95 civic of 94up integra rear lcas
- 94-01 intermediate shaft
- WTB: CABLE TRANNY
- WTB: Gas Cap for 97 Honda Civic
- WTB: ITR Axle back!
- WANT TO BUY 90-93 INTEGRA SHELL. INDIANA OHIO AREA
- WTB : HEADERS FOR 93 INTEGRA
- WTB: 98+ Integra Passenger side Headlight
- 92-95 si wiring harness uncut, del sol vtec throttle cable
- wtb: bra for dc2 front bumper?
- WTB: 99-00 Civic Si power steering pump
- wtb parts from b series head(lost motion assembly)
- integra center console black, and db8 rear seat
- WTB : Knock Sensor for H22A
- WTB 5 lug conversion for eg hatch
- WTB: i-vtec intake manifold cover for 03 rsx & stock air intake
- WTB: SI rims
- WTB: GSR breather chamber
- wtb: defi boost d-gauge BLACK face ONLY
- WTB Greeen Teg Driverside Fender
- WTB: OEM ITR Spark Plug Cover
- WTB Spoon N1 Axel BAck for RSX Type S/DC5.....Located in Southern California
- WTB: Wheels
- WTB: 92-95 Civic Ash Tray
- WTB: Skunk2 coilovers
- WTB: Stock 96-00 Honda Civic CD Player (non Si)
- wtb: complete or near complete b swap for eg
- WTB 3rd gear gsr
- WTB:INITIAL D VIDEO GAMES FOR PS2 AND PSP..
- looking for pass door and fender for 89 ef
- WTB: DC2 Interior Pieces
- 92-95 Civic Hatch Interior Door Lock Paddle (Driver Side or Both)
- Looking for i love my honda decals!
- WTB: Civic d16y8 head***
- WTB: 15x7 Kosei K1 5x114.3 +38 offset
- WTB: 550 RC injectors saturated
- WTB: 96-00 Civic foglight switch, amber
- WTB: OBD1 GSR Knock Sensor
- WTB: norcal. sacramento area and north of it!!! head gasket asap OEM:::STD bore
- 1990-1991 Honda Civic DPFI Throttle body
- WTB: 99-00 Civic Head lights
- WTB: Side molding CLIPS! 96-00 side molding clips
- wtb~used crx cat/gaskets
- WTB freshly rebuilt gsr tranny.
- WTB: OEM B16 Head Gasket
- WTB: H22 EG turbo piping and parts !!!
- WTB: [j][D][M] Honda CRX SiR Bumper Lenses/Lights jDM sh0n!!!
- wtb: oem b16 vtec black valve cover
- Transmission for a 90 crx si
- WTB 89 CRX 1.6l CRANKSHAFT! THX!
- Looking for INTEGRA parts OEM 1998-01
- WTT: GSR swaped EG hatch for a turbo car
- WTB:Obd1 GSR Injectors need fast
- WTB: ITR cams
- WTB: 92-00 Blue window crank
- WTB: 96-00 civic/94-01 integra parts
- WTB - 99 d16y8 auto swap in maryland area.
- WTB: OBD1 OIL PUMP
- WTB: Driver's Fender For 95 Integra
- WTB. LS engine (with harness, OBD0/1), DA axles.
- WTB: s20 or S40 EX/Si Countershaft or Scrapped Gearset(s)
- gsr console without the arm rest
- WTB: Greddy Turbo Kit!!
- WTB: Set of 15in. Black Slips
- WTB: Stock EG Engine Harness
- WTB: Misc. EK Dash Parts, plastic pieces
- WTB: ewing mesh center caps for 15"
- WTB: exhaust for 99 GSR (2.5in. catback)
- WTB: 92-95 stock civic shocks/springs
- wtb 99-00 civic si tail lights
- WTB: si cluster w/around 80k or can trade for 99-00 fogs
- WTB: 94-01 Integra hatch carpeting
- WTB: Del Sol Shell or w/Bad Motor Or If Really Cheap w/motor
- wtb CDM wastegate
- WTB LSD
- WTT: my 95 honda civic hatchback for a eg 4dr ex
- wtb: aem ems 30-1040
- WTB/Trade: 84.5mm JE 9:1 Pistons for 85mm 9:1 Pistons
- WTB: 94-95 GSR P72 OBD1 ECU, stock/virgin
- WTB: ball joints and bushings dc2
- WTB LS Timing belt, light flywheel, and cam gears
- WTB: GSR Block, complete long block, fully built or not.!
- WTB: 96 hatch sir lip!!!
- WTB: OBD2 gsr tb
- need a passenger side headlight. 98-01 teg.
- WTT: My Seagate 5.0GB Pocket Hard Drive for Your...
- WTB:p28 ECU
- 1990 Teg parts......
- Rollbar for Delsol?
- wtb: obd1 non vtec ecu
- KSport Coil Overs - New or Used
- WTB: EG9 Gathers rear speakers
- b16 head ported and polished
- WTB JDM HONDA RED EMBLEM For DC2
- WTB: P28 W/ CROME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 15/16" rotas w/tires OR work emotions work cr kai w/tires
- wtb siR jdm cluster
- B16, b18, b20 motor with or w/o trans
- Looking for y8 head, complete with mani. PA area
- b16b intake manifold
- WTB: Toda header for B series.
- ek springs/coilsleeves dallas
- WTB: B-Series 97 EK Motor Mounts, Conversion axles, and shift linkage,etc.. WT for EF9 Parts
- Looking for William, selling s200
- WTB: GSR Blades, MUST BE OEM WHEELS, no knockoffs
- SLEEVED B-SERIES BLOCK
- WTB: OEM 94+ GSR intake
- WTB: Looking for sir front lip for 96 hatch
- WTB: 16" wheels and tires
- wtb jdm DA integra fenders
- wtb 14b or 16g turbo.....
- WTB: 92-95 EG Hatchback or 96-00 EK Hatchback
- WTB: 96-00 civic ex tranny
- WTB: RHD 94-01 Teggy
- WTB: 87-90 AWD Civic Wagon 6Speed
- WTB: 92-95 Civic SI front sway bar
- WBT cam caps and oil rails
- wtb--88-91 crx/ef shell or 90-93 da 2/4 door
- WTB B-Series Tranny Center shaft and Exedy Twin disk rebuild
- WTB: 99 civic dx hatch exhaust manifold/cat
- WTB- Del sol FRONT END
- WTB: Tial 44mm Wastegate or Turbosmart 48mm
- wtb: 97-01 prelude stock cat, and knock sensor
- I Need!: BASE MAP for a stock D16z6!
- WTB: 90-91 EDM CRX rear spoiler
- WTB B-series Obd II alternator!!!
- WTB: sohc alternator
- WTB: 96 honda civic airbags and hubcaps
- WTB: '94-01 Integra parts
- WTB: 94-01 Integra side skirts, DB Chassis
- WTB: MAP Sensor for a 1987 Civic Si
- WTB: DPFI - MPFI wire harness conversion for 91 hatch
- Need stock springs for a 90 Civic DX help
- WTB: 96-00 CIVIC PARTS
- WTB 1.5 or 1.6 dxor lx short block
- WTB: 90-93 integra 3dr rear bumper
- b series tapped oil pan for turbo with fitting in it. asap in nothern va
- WTB : 94-95 DC4 2-door 4-pcs Flat black door and quarter panel Molding
- WTB: Cluster with tach for ek, 96-00 auto or manual
- WTB: J's Racing Carbon Intake
- WTB: 99-00 OEM Si Lip Perferebly FBP
- WTB:15g Oil return line/oilpan fitting only
- WTB: Integra 94-01 Front Passenger Side Suspension
- WTB: 14B Turbo or parts
- WTB: 96-98 Civic Radio Bezel (Climate Control Bezel)
- wtb: 92-96 prelude ignition coil
- rocker arm assembly off of a D16Z6
- WTB: 96 LS Belhousing
- WTB: Cheap/Ebay intake for my EX coupe with Bseries TB
- WTB K24 Rods maxi light,pistons etc
- must buy! Z6 injectors (stock)
- WTB: Catalytic converter for 99 ex.
- WTB: B18A Crank.
- WTB: a down pipe ASAP !!!!
- WTB: ep3 coilovers
- wtb fake mugen wing for a ek sedan/ coupe
- WTB:VSS for 97 accord
- WTB: Tailgate wiring harness for '96+ Civic HatchBack HB
- wtb: 20 mugen lug nuts
- WTB: F22a6 (must be the a6!!!) intake manifold. no sensors needed!
- GS-R or LS Longblock
- Want To BUY: Any cheap Cingular or NEXTEL phone
- WTB: F series Prelude head and/or longblock! South NJ!!!!!
- wtb: cheap seats for ef hatch
- WTB: Hatch with b-series swap.
- wtb:cheap mesh 15s (bbs)
- WTB: H.I.D. retrofit for 99-00 civic coupe.
- WTB: one eagle rod D series
- I need a d16a6 throttle body asap!!
- wtb: EG SIR-II wheels/rims
- WTB:96-00 Civic stock suspension
- wtb:eg parts
- WTB: B-SERIES FLAT FACE VALVES!!!
- WTB: EF Front Bumper Filler
- WTB: DC integra tranny side torque mount
- CAR TOATLED :( WTB: 92-95 hatch 5 speed
- GSR Throttle cable
- WTB: USDM P72 ecu
- WTT: B series turbo kit ss autocrome t3/t4 for a CRX
- WTB: OBX LSD
- wtb kit to relocate licensi plate (jdm)
- wtb a d16 for cheap
- WTB itr or gsr crank pulley b18c5 integra type r b18
- WTB: CTR n1 crank pulley
- WTB: EG hatchback stock tail lights
- WTB: 96-00 Civic Side Skirt
- wtb ef hatch
- WTB: H23 thermostat housing
- WTB: obd1 P72 or P30 engine harness
- WTB DRIVERS side EG quarter
- WTB: type r 5 Lug conversion
- WTB vss for b series slc utah
- WTB: pass. side skirt for 94-UP dc2
- WTB PARTS for 91 Integra LS
- I need a tranny
- WTB 2000 honda civic rear bumper
- WTB 99-00 Civic Si dual Core Radiator and also fan
- WTB: 98-01 oem 2dr integra tail lights!
- WTB: D15B7 TB, DX/LX hubcaps, EG Turn Signals, Grey Ignition Cover....more!
- WTB: 4 wire o2.
- WTB: Skunk2/Blox B18C1 intake manifold (Located in Germany)
- WTB: White 92-95 Civic Hatch Rear Bumper
- WTB your oem b series parts and oem wheels slc utah
- WTB: Del Sol Auto To 5spd parts
- 94 gsr axles
- WTB: J'S RACING CARBON FIBER INTAKE OR PASSWORD!!!
- Looking for SAFC
- WTB One GSR Twisty Blade, Wheel
- WTB-=-=-= D16y8 vtec head
- WTB JDM EG Audio Console in BLACK
- looking for a obd-0 complete wire harness that is mpfi already
- WTB: Obd2 jdm h22
- wtb 1 99-00 si wheel!!!!
- WTB: B series Top Half of Trans Case
- WTB: JDM ITR HEADER///Apexi Ws2 axelback
- 92-95 driverside fender needed!!!! SoCal
- WTB obd-0 ls dizzy and starter
- WTB: GSR block/built/semi/or OEM
