View Full Version : Want to Buy
- wtb: p28 ecu
- WTB: 94 AND UP INTEGRA DC REAR HATCH/TAILGATE PARTS (SHOCKS, HINGES ECT.)
- wtb: bride or recaro seat
- WTB: Spoon Carbon/Kevlar Direct Floe Ari Pipe for Ek chassis(SO. CAL)
- wtb: Air Assist Solenoid Valve from y8 thermostat housing
- WTB: B16 Oil Pan
- WTB: stock OEM 98 civic DX exhaust manifold
- WTB: front upper strut bar for 02 acura tl-s
- WTB: Will Pay CASH... Phillips 4300k HID Kit 9006 for an Integra GSR
- WTB: GSR Blades *DFW*
- wtb: d15 exhaust manifold heatshield
- WTB: OEM ITR B-PIPE
- WTB: 92-95 SI/EX cluster
- wtb: tsx block
- WTB: 88' Honda CRX ZC motor head gasket
- WTB: 96-98 Honda Civic Ek VSM Silver Front Bumper...Socal (if possible)
- WTB: ASAP 99-00 Civic EX guage cluster 5spd
- Wtb: Aftermarket Steering Wheel
- WTB: One GSR Fat five rim
- WTB: 99-00 EK PARTS (fog lights, steering wheel, seats, C/F hood & hatch, etc...) *ATL*
- WTB: obd2 gsr throttle body with sensors
- WTB: CRX Tail Lights!
- WTB: s2000 centercaps...taking a shot before i resort to dealership
- WTB: rear sleeve for ground control coilovers for an eg/del sol/integra
- WTB: H23 Vtec or H23 Non-Vtec
- WTB: 95 Integra shiftlinkage bushing - socal
- WTB: recaro SPG, any color... will even consider knock offs!
- WTB: Integra/Del Sol/ Civic rear DISC brake setup
- wtb: spoon sw388 16x7 4x100
- WTB: Rear hatch glass Integra 94-2001 ASAP
- WTB: obd1 ecu p28 distributor
- WTB: Vis OEM 92-95 hood
- WTB: EG hatch exhaust and springs
- WTB: Complete Integra shifter
- WTB: 96-00 D-Series AC Compressor....
- WTB: clean eg black door panels.
- WTB: BOGART LUGNUTS!!
- WTB: stock air box-> civic
- WTB: 99 gsr ecu
- WTB: Big Brake Kit
- WTB: B-series Valve cover with side cut or moon cuts...
- WTB: 15'' Volks TE37s, Works RSZ-Rs, or CPRs ****NORCAL****
- WTB: 2000 Civic SI ECU HARNESS & 2000 GSR ECU
- WTB: OBD2 Integra LS engine harness uncut
- wtb:gsr skunk2 intake mani, asap
- WTB: Sensor From a 1995 GSR Intake Manifold!!!
- WTB: stock eg side mirrors; or spoon replica- so cal
- wtb: eg black front bumper
- wtb: 93-95 honda civic OEM power window and lock kit
- WTB: DB7/DB8 Integra sedan parts
- WTB: OBD1 B16 DIZZY
- WTB: Comptech Sway/Tie Combo for 00 civic si
- WTB: GSR Cams + Gears *Norcal
- WTB:Shifter bushing
- WTB: 92-95 civic LCA Lower Control Arm
- WTB: Hondata 0BD-0
- WTB:: 5th gen lude HOOD
- WTB: stock obd1 LS ecu
- WTB: GSR Valves
- WTB: Stock EG coupe or sedan exhaust CT/NY/NJ
- WTB: 195/50/15, 195/55/15, 205/50/15 tires in New England/New York area...
- WTB: Arp headstuds for b16, boost,af,oil press.,egt, autometer gauges
- wtb: 98+ OEM or Replica ITR lip
- WTB: Rota Wheels...
- WTB: 12K front and 10K rear coilover or other spring rates.
- WTB: 1992 - 1995 Civic 5-sp Vehicle Speed Sensor! Working Condition!!!! ASAP
- WTB:::::: DOHC VTEC Head... GSR, or B16a, dont care, as long as its cheap. @@@@@@@@
- WTB: EP3 JDM window visors and Carbon Fiber Hood
- WTB: Plastic Trim around radio & climate control for 92-95 civic Chicago, IL
- WTB: complete rsx-s swap
- WTB: 88-91 CRX Door moldings,ASAP
- wtb: 13" or 14" slicks with rims now.....$$$$$
- WTB: OBD1 D Series Long Block around Illinois
- WTB: Hydro B16 Transmission
- WTB: Autometer 5" tach foam
- wtb: cam gears (so cal)
- WTB: Hondata s200 w/ boost option
- WTB: Bare ITR Throttle Body and broken or used OEM FPR from GSR or ITR
- WTB: 4x100 rotas
- WTB: complete Ls/Vtec oil line kit
- WTB: black eg hatch carpet in good condition with door sills attached asap!!!!
- WTB: D16Z6 in or near wisconsin preferrably
- WTB: 96-00 Engine Harness.
- wtb: OEM 1999-2000 Complete Intake System
- WTB:SoCal only. Need off a Civic 92-95 hatch. Brake line n rear trunk hinge.
- WTB: your old cell phones!
- WTB: A REPLACEMENT LIP FOR MY 96 - 98 EK HATCH and spoon (manual) mirrors
- WTB: Prelude parts
- WTB: 92-95 coupe OEM front lip. Pref. within D.D. of NYC metro
- wtb:obd1 P75 Ls Ecy in socal
- WTB: MOUNT + ENGINE HARNESS + o2 SENSOR
- WTB: 94-01 Integra Climate Control Buttons
- WTB: 1 ENKEI 17X9 RPF-1 RIM, ASAP!!!!!
- WTB: AIR/Edwyn CF intake manifold
- WTB: 98 Spec JDM ITR Tailights
- wtb: crx windshield wiper motor
- WTB: VTEC SOLENOID AND OBD2 GSR DIZZY
- WTB: glove box for eg6
- WTB: 91 Civic HB Passenger side door protectors/trim, black
- WTB: d16y7 or 16y8 complete BLOCK northeast
- WTB: 16" Rota GR-8
- WTB: OEM 99 CIVIC FOGS. AS CHEAP AS POSSIBLE PLEASE
- WTB: h22a O2 sensors and knock sensor
- WTB: 90-91 CRX Si LIP!!!!!!!!!!!!!!!!!!!
- wtb: stock gsr cams and gears
- wtb: B18B longblock
- WTB: obd1 gsr harness
- WTB: p30 pistons
- WTB: Clutch bracket (cable tranny) & Throttle cabe bracket
- WTB: Oxygen Sensor
- WTB: OBDII LS Dizzy..........ASAP!!!!
- WTB: ****88-91 CIVIC HATCH DRIVERS SIDE TAILIGHT****
- WTB: HONDA/INTEG/CRV Parts
- WTB: 99-00 VSM Fenders!
- WTB: Aftermarket Steering Wheel Hub 92-95 Civic
- WTB: 4-2-1 Header with 2.5" collector! So Cal
- WTB: STOCK 94 Civic CX Motor
- WTB: BENEN REAR LOW TIE BAR(SILVER!!!!0 FOR 92-95 civic, 94-01 integra
- WTB:!!! 96-00 civic hatchback passenger door and fender!! SOCAL
- WTB: 3" inch Flex Pipe !!!!! NEW or USed!!!!!!!!!!! ***********SOCAL***********
- WTB: Upper Non-VTEC power steering mount
- wtb: accord springs
- WTB: VIS CARBON FIBER DUCKBILL SPOILER FOR EG!!!!
- WTB: VTEC stuff
- wtb: 92-95 EG gauge cluster w/tach
- WTB: JDM ITR front lip or CF spoon-style
- WTB: DA Latch Cable for JDM conversion
- WTB: 92-95 civic fron shock
- WTB: Fat Five Centercaps "Acura"
- WTB: CRx/ef civic clutch cable LOCALLY -CT area
- WTB: 92-95 Civic hood, headlights, and front bumper
- WTB: 96-98 Civic Hatchback Bumper Cover in RED
- WTB: EK SIDESKIRTS
- WTB: GSR hydro tranny case ( bell housing )
- WTB: Crank pulley H22
- WTB: Volk CE28 Rims 17" 5x114.3 in gold
- WTB: ARP Head studs for H22a
- WTB: sohc motor non vtec (92-95) ef sedan radiatior. so. cal.
- WTB: GSR Swirlies
- WTB: p28 man or auto
- wtb: DB7/DB8 parts
- WTB: Muteki lugnuts BLUE OPEN-ENDED
- WTB: 94-99 GS-R Comptech 4-2-1 header
- WTB:// 99-00 Si CLUSTER SoCal Preferred**
- WTB: ITR Front Lip
- WTB: d16z sensors
- WTB: B-Series flywheel cover
- WTB: A/C Assembly 99 GSR
- WTB: mudguards for 97 GSR
- WTB: AC bracket
- WTB: 96-00 EK Front End*FENDERS*BUMPER*HOOD*HEADLIGHTS*CORESUPPORT*GRI LL*
- WTB: USDM OBD1 Del Sol VTEC Intake Manifold
- WTB: 98-01 Integra Rear Bumper
- wtb: DA Radiator In San Diego Area
- WTB: 96+ B-series or H22
- WTB: OEM RSX WHEELS IN BLACK OR WHITE.
- wtb: 00 civic si catalytic converter
- WTB: 15 or 16 Rota GT3's in Black 4x100
- WTB: SPoon N1 axleback EP3 Si (maybe buddy club III)
- WTB: Apex-i N1 cat back for 96 Civic Sedan.
- WTB: H22a Head
- WTB: Misc Parts from your crashed or gutted integra!
- WTB: bogarts, welds or lenzos with slicks
- WTB: Hasport EF Bseries shift Linkage
- WTB: 98-01 4 Door Integra Taillights
- WTB: CTR Muffler
- WTB: OEM honda s2000 antenna
- WTB: KYB AGX Shocks for DC2 (non ITR)
- wtb: cat for obd2 teg ls
- WTB: EJ1 Sidemoldings ASAP!!!!!!!!
- WTB:91 CRX Si tranny
- WTB: OEM 94-00 ACURA PARTS SEE TEXT!!
- Wtb:***GSR Arp Head Studs And Ls Arp Rod Bolts****
- WTB: Cable LS tranny (DE,MD,PA) YS1, S1, A1
- WTB: Greddy Evo
- wtb: looking for a complete swap for my EG *socal*
- wtb: del sol seats in so cal
- WTB: Misc DC2 interior parts.. (have you gutted your DC lately?)
- WTB: Aftermarket camgears B series
- WTB: D16Y8 in or around Minnesota
- WTB: 88-89 STOCK CRX LIP *SOCAL* OC
- WTB: Driver's Side Power Window Switch (Integra)
- WTB: Greddy SP exhaust for 96-00 Civic Hatch.
- WTB: DA 90-93 Integra Front Driver Caliper
- WTB: 92-95 civic stuff 2D or HB and gsr suspension w/brakes
- WTB: SoCal need vent or center bezel for 00 civic EX...
- WTB: 1 15" integra gsr SE sunflower rim
- WTB: 92-95 CIVIC OR 88-91 CRX
- WTB: in socali...... walbro pump and 310's or bigger!
- WTB: Honda Civic Del Sol Air Conditioning Bracket P54 B16A
- WTB: SOHC ZC camshaft or D16A6 camshaft
- WTB:::: stock crx corner lights 90-91
- WTB: 99-00 Civic OEM Climate Control
- WTB: 96-00 EK obd2 Wiring harness for civic manual! NEED ASAP! TODAY! So Cal
- WTB: Red Ignited Push Start Button.
- wtb: 98+ integra Right side power mirror and right fender.
- WTB: "D" series ex, si, z6, y8 tranny no grinds in WA
- WTB: EK dx/cx cluster, any mileage, no auto trans please.
- WTB: LS mesh, GSR blades, or SI rims
- WTB: Ground Controls 92-95 Civic DX coupe or camber kit
- WTB:I need a OBDI gsr throttle body..
- WTB: 1992-1995 Honda Civic washer fluid resevoir/motor/connector.
- WTB: B16 or GSR hydro trans...
- wtb:usdm passenger seat or reaccaro passengerside seat for my dc2
- WTB: Your Damaged 98+ Dc Headlights!
- wtb: door harnesses and window switches from a 94+ 4 door integra
- WTB: 98+ dc2 Integra Passenger Side Taillight
- wtb: 91 civic si mats and hatch cover
- WTB: Used/NEW Front shocks for DA.. plzz LOWBALL me!
- WTB: 2 Yokohama AVS ES100 205 45 16...with good tread left...
- WTB: 89-91 CRX Cage
- WTB: front acura emblem (91 ls or any other that will fit)
- WTB: SAFC
- WTB: Radiator support for 92-95 coupe/hb
- WTB:Sohc, ex/si tranny
- WTB: ITR JDM HID HEADLIGHTS
- WTB: Black EG dash and vents (Nor-Cal)
- WTB: d16z6 valve's or complete head
- WTB: '92-00 Civic stock midpipe
- wtb:ITR lip for 95 integra
- WTB: 2001 type r door panels/carbon fiber parts/center console
- WTB: 97+ Prelude distributor
- WTB: ARP Head Studs
- WTB: 1 Del Sol SI wheel. Good condition.
- WTB: Black Leather GSR Seats Front and Back in Washington WA
- WTB: JDM ITR 4-1 header
- WTB: ECU for a (P75-A05) 01' Integra LS
- WTB: cheap 4 channel amplifier???
- WTB: 98-01 USDM Amber Bumper Lenses ASAP
- WTB: Comptech Race Header Adapter!!
- WTB: 98+ Accord Alloys
- WTB: 96-00 Ashtray & Lighter (Dark Grey)
- WTB: 1 person with a lot of swap/turbo install experience
- WTB:90-93 integra Axles
- WTB: 98+ integra rear bumper and itr lip
- WTB: Wiper Switch for 98 Civic Coupe
- WTB: MOUNTS ! ! !
- WTB: 99-00 SI rear leather seats
- WTB: GSR throttle body
- WTB: brand new tires or at least w/ 99.9% tread
- WTB: ITR or 5x114.3 Spare Tire
- wtb:94-01 GSR COMPLETE SWAP IN NC AREA
- wtb: d16z6 near NY
- WTB: USDM TYPE R BLOCK
- WTB:********98-01 Integra 4 Dr Sedan Rear OEM bumper**********
- WTB: B16 Cable Tranny
- WTB: rims for honda 98+ Accord, lower springs, spoiler,..........and more.
- WTB: AEM CAI, Catback exhaust for 91 Prelude
- WTB: Mint 91 DX/SI CRX door panels...
- WTB: 1 GSR AEBS headstud
