View Full Version : Want to Buy
- Wtb v-tec head for the non v-tec del sol
- WTB: 88-91 Si Dizzy
- wtb p28, 255lph walbro, unused arp head gasket and studs-99 civic ex
- WTB: Ferio Interior Anniversary Edition (complete)
- WTB: CABLE TRANNY
- WTB!! Del sol front bumper
- wtb: 1.6 vtec ecu manual
- WTB stock 92-95 civic vc 3 door
- WTB: Integra front seats
- Need!!! b series ek motor mount & si engine harness
- !!***-- WTB: Integra TYPE R FLOOR MATS :) --***!!
- WTB Sleeved B18 Block (agian) or Mildly Built bottomend for Allmotor 1.8 2.0
- wtb 3" crx exhaust in ct
- WANT TO BUY: D16 motor
- WTB: ANY 96-98 OEM Rear Bumper
- mud flaps and sidemolding EF
- WTB B series Axles
- WTB: 92-95 civic ignition switch
- *** Looking For a 96-00 Civic Manual Steering Rack! ***
- WTB: driver side Sideskirt for a 92 hatchback
- WTB: 00-01 ITR/CTR cams
- wtb cheap stock exhaust dc2
- wtb 90-93 integra ls axles
- WTB: Gsr Msd Distributor Cap and Msd wires
- WTB 92-95 ex/si hub caps
- WTB: 94-97 4dr Integra black interior in PA
- WTB: 89-91 civic ac compressor
- WTB: Gsr Bare Block Va/Md/Dc
- WTB RED RECAROS IN NEW YORK!!!!!!!!!
- WTB: oem sir hood for 89 crx
- WTB GSR BLADES
- WTB: full race radiator crx
- WTB: p72/p28/p30 obd1 ecus prefer US Spec
- WTB: LS ALLMOTOR PARTS (crower 404, 65mm TB, Skunk2/BLOX IM, HEADER)
- WTB: LEATHER SEATS for 99-00 Civic Si (or Coupe)
- WTB: 96-98 Civic OEM Hood & OEM Fenders
- WTB 95 D-series power steering stuff.
- WTB: 94-01 OEM air intake system.
- WTB: 96-98 EX Floor Harness
- WTB: CF DUCKBILL WING 96-98
- NEED "B" Shift linkage and driver and rear mounts 92-95 civic
- WTB: D15b Catalytic Converter....... for 93 DX hatch
- WTB: Black 99-00 PASSENGER SIDE (right) FENDER
- wtb: itr/ctr cams
- WTB: CTR CAMS
- WTB: distributor plug OBD2 b series off the engine side
- WTT: '93 Del Sol Si for 96+ EK hatch
- WTB/WTT: My Intake for yours (MD)
- WTB 96-98 EK Wire Harness (NYC)
- b18c1 rods/pistons/valves/springs... anything to build my motor!
- WTB obd2a to obd1 jumper harness
- WTB: EK Tein FLEX or Apexi N1 coilover system
- WTB : GSR or TYPE R head gasket headgasket OEM
- NEED H22 parts aftermarket axles, camgears, pulley, OR 92-95 civic parts
- WTB CLEAN HATCH OR COUPE
- WTB: 4x100 Volk, SSR, Advan, or other JDM wheels!
- WTB 94-01 integra up Axles and Halfshaft Intermediate Shaft
- WTB 90-91 LS 5th Gear Set
- WTB S2000 Shell
- Need Ls Motor and Other Swap Parts 760 $$
- want to buy 99-00 climate control conversion. heater core blower harness
- W.T.B 92-95 CLEAR TAIL LIGHTS for coupe or 4dr
- WTB: DC2 Spoon Cluster.
- wtb: 4th gen prelude WWRS front lip
- WTB: Prelude vtec H22 injectors obd2
- WTB: 15" wheels 4 *100. $600 in hand
- boost parts & tranny
- WTB: 2000 civic coupe carpet/floor mat.
- wtb: mugen or si style front lip (doesnt have to be real) preferably in the NE
- WTB Socal pick up only DA9 parts
- WTB: B-Series Turbo kit for EG *cash in hand*
- tires
- !!!!! WTB: stock DC/EG seat rails !!!!!!!
- i need a new project car
- WTB COMPLETE rear brake disc conversion for 95 civ Ex
- WTB: CRX PARTS
- WTB: 96-98 front and rear black bumpers
- WTB: Ericks Racing Throttle Body 72-70mm Taper
- WTB: GSR WHEELS OEM STOCK BLADES
- WTB EK SHELL
- B18a/b or b20b
- ************LOOKING FOR A SQUARE OIL CATCH CAN**************
- WTB some 93HondaCivic Hatch Parts :)
- WTB: 98+ oem amber DC corners
- WTB: Running Manual Car for 600-700 MAX
- WTB 93 civi hb parts
- eg driver side window rail with crank (manual window motor)
- WTB!! VISION TYPE DC MIRRORS FOR EK 96-00!!
- WTB 99-00 civic pass side front lower control arm
- WTB: 92-95 Civic CX blue int. steering wheel with or without airbag
- WTB: SOHC Valve Cover
- wtb: obd1 civic wire harness
- WTB: 94-97 Integra front bumper and passenger fender SO CAL
- **WTB: KYB AGX shocks for EG** / **Ground Control Coilovers**
- my jdm front integra got stolen need parts...
- wtb omni test pipe
- WTT 93 civc si hatch for a GSR swap
- WTB: 96-98 civic hood, Ont, canada.
- WTB: 90-91 EF hatch front bumper, crash bar and radiator support
- wtb: h2b kit for a DC integra
- WTB $$$ 98+ ls or gsr hydro tranny ASAP
- WTB. Axles that will fit in a 93 civic wit an h22. I need axles
- WTB: 4x100 16" Mag. Blue Volk TE37's or White Work RSZR's!!
- ***WTT SOHC TURBO EK FOR A B SERIES EK***
- WTB: aftermarket H23 cam gear
- wtb 15 inch sa3r
- EK ./. E20 TURBO MANIFOLD ASAP
- WTB d series clutch
- WTB: 6-puck sprung disc *disc only*
- WTB: GSR or ITR Water Line for Oil Cooler Purposes
- WTB: d16a6 civic si motor
- WTB: GSR B18C Cylinder Head
- need an em1 b16a2 block mount.
- WTB: 81.5mm Hastings piston rings..ASAP
- WTB: REAR INTEGRA FOUR DOOR HANDLES WITH NO KEYHOLE BOTH LEFT/RGIHT
- Del sol vtec stock intake
- WTB: GSR Shift Knob
- wtb: crx trim
- WTB: virgin obd1 ecu, integra gauge cluster plastic cover, T3 turbo, more..
- wtb cheap fuel pump (OEM?) 65psi
- got 3000 cash in hand wut u guys got
- 96-98 P2P 5speed ECU
- WTB 5" tach with shift light
- WTB::: oem 94 integra shift console
- WTB: 99-00 radio harness & B SERIES VALVE COVER & EG SI HB AUTOPOWER roll bar - so cal
- WTB/ Want to Buy: OBD1 P72 ECU
- WTB: 92 Hatch Interior. Or 92-95 Civic Interior! ALL!
- WTB: "Buddy Club Spec2" exhuast system for Ek hatch *SOCAL*
- WTB : 96-00 Civic (REAL) Mugen rear upper strut bar
- WTB: turbo manifold and 3" downpipe
- WTB: misc. Turbo Parts
- WTB: Rota,Spun, or ITR wheels
- WTB: vsm 99-00 civic fender. drivers side. 96-00 tail lights for coupe.
- WTB: 92-96 Prelude for Parts Car
- WTB: GSR header A- Pipe ? Lower piece of the header
- WTB: driverside inner door handle/openner with cover of del sol
- WTB: Victor x and big tb for b16/type r head
- WTB.....DA 90-93 integra e-brake cables.
- WTB: Usdm p72 obd1 ecu
- WTB: LS Rods
- WTB 1 work equip 03 center cap
- WTB AEM V2 CAI
- WTB: 88 CRX SI Cluster/Radio subharness.
- WTB WTT 98-01 integra factory corner lights
- WTB: Some used parts for crx..
- wtb: del sol b series shift linkage. in socal if possible.
- Integra Si-Vtec Fog Lights and Turn Signals 94-97 DC
- WTB s2k antenna
- adjustable fuel pressure regulator
- WTB: Amber Corner lights 00 Integra
- wtb: obd0 to obd1 wiring harness...
- WTB: OBD1 P72
- WTB: Time-Sert KIT RIGHT NOW
- WTB: 1999-2000 Civic Front Bumper
- WTB: b20 bare block
- WTB: B-Series Shortblock.....Anything will do
- WTB: TSX projectors!!!!
- wtb: DC5 oem foglight lens
- WTB: ADVAN SIENA GEN II's
- WTT OBD1 LS engine harness for OBD2 b series harness
- WTB 98' Integra rear bumper
- WTB: 92-95 Civic Door Lock Paddle (driver side)
- NEED TO BUY!!! one NItto 450 205/50/15
- WTB: B18C Sleeved block
- pistons
- WTB: Tenzo Rally Seats
- catch tank with breather
- WTB 96-00 Civic Hatchback or Integra
- WTB: b series hydro tranny
- WTB: 92-95 civic ecu
- wtb optional rear lip for dc2
- WTB: 1988 CRX alternator and radiadator
- WTB: Seats / Bumper / Exhaust Manifold
- wtb mugen horn button and nrg quick release
- WTB: GSR Head and B18b block, also random ls/v stuff
- WTB : IAT senser
- WTB: OBDII GSR injectors for 96 dc2
- WTB Rear Discs 94 95 civic ex or si just need drivers side
- WTB: Falken Hanabi
- need D16 tranny.. 5 spd
- wtb: jdm itr bumper support
- WTB: GSR leather front seats/type r front seats/del sol front seats/recaro seats socal
- WTB 99-00 GENUINE MUGEN FRONT LIP for ek
- WTB 97-01 Prelude Rear Bumper Cover & Left side rocker molding.
- WTB D15
- 1991 Honda CRX dx Seats
- WTB: 99-00 black Honda Civic hood in socal
- WTB: p28 ecu
- WTB << BSA rim 18.75 >>
- WTB: 96-98 civic Dark Green front bumper
- WTB 99-00 Hood or CF Hood ((SOCAL))
- 1990-91 integra distributor
- WTB: CTR or ITR Exhaust cam!
- WTB::: F22 RODS!! OR H23 RODS!!!!
- WTB: Kenwood Music Keg.
- wtb MOMO Millenium Steering Wheel ... have srs ctr wheel to work trade around
- WTB: **TYPE R TRANNY**
- WTB LS Parts (ecu, mani, harness)
- looking to buy an ef shell or ef with blown engine have to spend 400 bucks
- WTB: EG or DA in Colorado
- WTB: B series clutch alignment tool ASAP
- WTB: Type R ITR / CTR Cams and springs
- WTB~Headers
- WTB: Spoon rims SW388's 15" or 16" 4x100
- WTT: 15" rims
- WTB: SPOON N1 exhaust CIVIC 96-00 hatchback
- WTB: HKS HI-POWER exhaust CIVIC 96-00 hatchback
- WTB: RED DC HOOD
- WTB Any D series engine
- WTB4EG: RED RECARO-LIKE seats w/ eg brackets/sliders, mugen front lip, yellow fogs
- WTB:B-Series Skunk2,Buddy Club,Toda,Spoon...etc. valves, springs & retainers
- WTB CLEAN TITLE 99-00 CIVIC SI EM1
- WTB an exhaust for by turbo gsr
- WTB: K-Swapped EG/EK/DC2
- WTB: Garrett T3/T04E, .42/.48 A/R, 50 trim.
- WTB rims for integra (cheap shit)
- WTB Passenger side Front SPLASH GAURD 98-2001 Prelude
- WTB: hydro gsr trans NY area
- WTB: 1 SEKI G-Racing Wheel - 17" - SC
- WTB: JDM DC2 OEM front bumper
- wtb all ef parts...and sohc vtech
- WTB: 92-95 Honda Civic Foglight Covers
- WTB: Completey built (for boost) B16A2 head....
- WTB: 05-06 RSX S AFM Exhaust MD
- WTB: front seats from any car any make and any model nj
- W2B:EG stanley corners,oem lip,z6 header
- WTB: OEM header/exhaust mani +gaskets +piping 99' SI
- WTB : 94-01 Integra Ls OEM side skirts ..name a price..need shipped as well
- WTB: 96-00 Civic Parts
- WTB DX blue 88-91 fender
- WTB: 94-01 Front white skirts/Lip
- WTB OLD Alternater
- H22, Type-S Pistons, OEM Oil Pan, Stage,2or3 Cams/Gears
- WTB: 98-01 USDM Integra Type R Lip
- wtb: stock eg hatch taillight driverside
- WTB: clean blades w/caps & tires (shipped to ohio if you're far away)
- WTB: A set of (4) 06-07 Honda Accord 17" 9-spoke Wheels
- WTB: OBD-1 ECU WHAtever a single cam non-vtec is. p07 pm7 i think
- WTB 99-00 Si Interior/Cabin Harness
- wtb any b series hydro tranny prefer slc utah
- WTB: odb1 dohc vtec dist.
- WTB: Tan Leather Integra Headrests
- WTB: 2000 Civic Si Armrest
- WTB: 2000 Civic Si Fenders(Flemenco Black)OEM
- WTB: 96-00 Civic front bumper clips! NEED ASAP!
- need 97 honda civic hatch latch
- wtb: 99-00 si conversio
- WTB D16 5spd Tranny
- WTB 92-92 GSR tranny
- WTB virgen p28 auto ecu , front windshield for 92-95 civic coupe & eng mount in socal and low price
