View Full Version : Want to Buy
- WTB: CTR Red Carpet...ASAP
- WTB: Eg civic center console, Shifter console, glove box,and airbag
- Wtb: Usdm p30 asap
- WTB OEM CF HOOD 99-00 civic
- WTB: 96-98 Civic coupe taillights.
- Wtb: Gsr skunk2 intake manifold
- WTB 90-91 crx dx body harness
- WTB RSR Exmag for Integra Sedan
- WTB Fastline shifter
- WTB..blox gsr manifold
- WTB: 1 TL - Type S Wheel
- Wtb: Driver side door lock actuator
- WTB ASAP: Radiator for my CRX (civic) NJ AREA?!
- wtb suspension for 96-00 civic
- Wtb: Sohc vtec longblock or a sohc 1.6 block
- WTB: 96-00 Tail light Sockets
- WTB: EJ6/8 coupe SI-FL taillights
- WTB: JDM ITR front end DC2
- WTB stock oem eg wing with led brake light
- WTB: itr or ctr cams
- wtb; sohc d16z6 jackson racing supercharger kit
- WTB/WTT: PIC Performance Select P2 for ITR (VA)
- WTB SI (EM1)Stock Radio Harness
- WTB: B16A intermediate shaft (or 90-93 teg?)
- WTB b-vtec rocker arms
- Wtb em1 or ep3.i have cash now
- B16 head upgrades
- Looking for a jdm dc2 head light
- Shift linkage for b16 eg
- Wtb itr or aftermarkter cams
- WTB 94'+ ITR or GSR Crank pulley
- WTB: eg cf hood
- WTB: obd2 ignitor
- wtb: EF9 optional blue interior pieces
- wtb: power antenna for 98 integra coupe
- WTB: Driverside Exterior Hatchback Pillar
- b16 header please
- WTB 94-00 Integra shell
- WTB: driverside window motor. (99 integra.)
- Wtb 99/00 2dr tail lights, ek power lock motor si seats and cluster md
- 15 or 16" Spoon SW388 wheels, 4x100
- Tein Coilover Wrench
- WTB: LS/ GSR bottem end. Turbo Kit
- WTB asap GSR dizzy gsr speed sensor cable B trans
- WTB s2000 muffler
- WTB: 90-93 Accord Parts
- WTB: Prelude camber kit
- WTB: 99-00 EX (D SERIES) Throttle body
- WTB cat back exhaust for 97 civic 4door
- -->WTB: 98+ ITR Climate Control ASAP!<--
- WTB: EK CTR sway bar and asr brace kit
- WTB: 88-91 EF Civic (SI) harness
- WTB new or used 4 wire oxygen sensor
- WTB: exhaust cut out/94+ teg lower springs
- WTB:Adjustable test pipe
- WTT my BC wheels for your 04-05 Ep3 or 02-04 Rsx wheels
- WTB: Front LCA's
- WTB: Kosei K1 Wheels | 15"
- Wtb: Itr/ctr cams!!!!!
- WTB RSX type S or TSX long block 04+
- Wanted: plug from 4 wire O2 sensor
- WTB:Left side 1-piece Headlight For Da integra
- WTB: Power steering setup 99-00 Si
- WTB OBD1 LS Distributor, ECU , 88 hatch fender hood etc..
- WTB EK CIVIC POWER LOCK ACTUATOR and ANTENNA BLOCK OFF
- WTB integra 94-01 shift linkage for b swap.
- WTB: 96-00 Civic Hatch mudflaps
- Integra AT to MT parts ALL!
- WTB YOUR 96-00 CIVIC EK CLUSTER BEZEL(s)- MANY NEEDED!!!
- Wtb: B18c1
- wtb: 96-00 civic hb parts
- WTB: H22 Shift linkage
- wtb - plx wideband or innovate lc1 wideband
- WTB: 92-95 Civic Sway/Strut Bars
- 2 wire IACV
- wtb:MF10L mugen stickers for rims
- WTB: Painted Valve Color
- WTB: B series mounts for CRX
- WTB some eg parts
- WTB: Turbo Part.
- WTB: Door Panel and carpet for 00 Civic
- gsr lsd
- WTB: wheels for a white 4dr civic
- wtb b series perfomance parts
- wtb: b16,ls,type r,gsr hydro tranny casing
- WTB: electric oil pressure gauge w/ sensor
- WTB: ITR Dc2 OEM Intake
- WTB Integra front window covering
- WTB: OBD2 D-series knock sensor
- WTB B series Hydro Tranny!
- WTB stock Del Sol S front bumper
- WTB newer ls valve cover
- WTB: Cheap OBD1 P75 ecu for chipping (manual or auto)
- WTB: Recaro SRD Seat- Black
- WTB: Eg Si Tail lights
- WTB: 02-04 rsx type s ECU
- wtb gsr oil pan
- WTB: (2) A PAIR OF VOLK TE37 - 5x114.3, 15x6.5 or 15x7, BRONZE
- WTB Mugen Rear Strut Tower Bar EG/DC/EK
- wtb: green extended lug nuts 20
- wtb: valve cover b series
- wtb obd2A to B conversion harness
- Need a Motor
- WTB:A Clean Honda
- WTB: 96-00 Civic Cluster
- WTB: 99-00 headlights
- I need a 88-91 si harness .......
- WTB. White Lettering Recaro SRD For dc2
- WTB: D series
- WTB 15" or 16" Bronze TE37's 4x100
- Wtb oem rsx type s floor mats
- Ctr Folding Mirror Switch
- WTB: TPS for D16
- WTB: b-series clutch for 400 whp
- WTB Black Golden Eagle Fuel Rail
- WTB: busted Blox LCA bushings.
- WTB: H22 obd1 distributor
- WTB full coilover setup for EM1 Civic
- WTB: EG Sir Lip and duckbill
- WTB - 90-91 EF JDM Front
- wtb pair of 15x6.5 or 15x7 volk te37 4x100 any color
- Need obd1 ls
- WTB: good used or broken d-series lsds- obx/quaife/etc
- WTB: 92 to 95 civic rack and pinion
- wtb 96-00 ek hatchback have 8,5000..
- WTB: GSR B18C pistons 81mm cheap
- WTB: Ostrich 2.0 and LC-1
- d16y8 intake manny with all sensors
- WTB: SCREWS/PINS for fender liner and push pins for trunk carpet
- WTB: IACV for a 98 civic lx
- WTB resistor box/ looking for a B16 head for a buddy
- WTB: Mugen Tailgate Fastener
- WTB cheap, nonworking d-series and b-series distributor
- WTB: B series adjustable cam gears asap
- WTB: 92-95 civic bumper!!!! Shipped
- WTB - SSR Reverse Mesh Caps
- 99-00 si engine harness
- WTB OEM B18C5 Headgasket and ARP headstuds
- WTB: brand new oem itr/99-00 si oil pump
- WTB: K20A2 pistons rods
- Looking to trade my 97 GST for a 96 and up civic
- WTB: Civic or Integra Shell
- WTB: 88-91 Civic HVAC & Misc. Parts
- Wtb:boost gauge and wastegate
- wtb 92-95 civic hatch rolling shell
- WTB: EG hatch driver side mirror
- WTB : RC440 cc insetcors
- WTB : B series 68-70mm TB
- **WTB** EG Hatch Door pannels
- wtb:92-95 civic coupe white driver side
- WTB: LS intake manifold
- WTB: USDM Integra Type R Driver seat SoCaL
- WTB ASAP B16a/Gsr Obd1 Dizzy!
- WTB: rc750cc high impedance injectors
- WTT 2004 Ninja 500R for import SoCal
- Wtb eg hatch socal
- **B16 Intermediate Shaft/Half Shaft**
- Radiator Support
- WTB: ITR front crossmember and ITR steering rack & pinion...
- WTB OBD2 B16 intake manifold and TB
- WTB ARC Winglets
- 99-00 Civic Hood
- WTB: KY- obd1 B series distributor
- wtb: tial wg 44mm inlet vband clamp
- WTB: Pressure plate for d-series
- wtb arp rod bolts and arp headstuds for lsvtec
- b18c1 turbo pistons and rods wanted
- WTB: Front & Rear Tow Hooks, and some b series parts
- WTB eg cluster w/tach
- WTB: Skunk 2 Upper Control Arms for DC
- WTB: Kamakazi B series header
- WTB: LS eagle rods new or used cheap cheap
- Wtb: I need a dizzy!!
- WTB: EG6 JDM SIR Headlights/w Corners
- WTB:ObD2 Ls Harness&ecu
- SOCAL B16 stuff - USDM OBD1 P30, tranny, oil pan, axles, linkage
- WTT my 99-00 em1 REAR mudflaps for your 96-98 ej REARS
- Usdm itr ecu
- WTB: A set of Weds Sport SA-90
- WTB: Kenwood KDC CD player
- qsd kit
- WTB SIR HOOD ef9 ef8
- WTB: B16/GSR Cylinder head
- WTB: hatch with swap, NY AREA
- WTB: Small vtec assembly spring
- WTB: Throttlebody pulley from a non-GSR throttlebody **PIC
- WTB: Aftermarket CRX Intake
- Need OBD1 USDM GSR HEAD ASAP!
- WTB Endyn breather tank
- WTB:obd 0 ls harness and intermediate shaft
- WTB: 95-01 Acura Integra Daily Drive-able **Riced Out Beaters Stay Out**
- WTB Integra Grounding mount or bracket
- WTB: Stock EK Rear Seat Brackets (gold)
- wtb ..NJ 99.00 ex underdash harn
- Wtb: Supertech ti retainers
- wtb bushing
- WTB: Del sol suspension
- WTB: brand new EK floormats, dark grey
- wtb : s2000 cluster swap .
- wtb: 99-00 Honda Civic Front Bumper & Fender
- wtb: front camber kit for 96-00 honda civic
- wtb jdm itr tranny 4.7 fd
- Wtb: Itr 5 lug conversion for my dc2 (nj/ny/pa)
- WTB:DC teg header catback fake spoon mirrors black
- WTB: OBD1 P72 ECU Stock/Virgin 1995 GSR
- WTB: four drilled and slotted rotors
- WTB Z6 motor 5 spd full swap LOW MILES
- 2000 si radio bezel
- wtb 1 obd1 injector clip
- wtb 99 si radio bazel
- WTB: LS Mesh
- WTB ASAP!!! 99-00 EK Front Bumper!!!!
- wtt/wtb 00 si underdash harness
- D16z6 Vtec Solenoid
- WTB:92-95 DX P06 ECU,1.5 Dizzy and Intake manifold
- throwout bearing
- WTT: Bride EK9 Rails for Bride DC2 Rails
- Wtb hydro transmission no fukin grinds!
- wtb b series motor mounts for a eg
- Still looking to buy a pair of denji's
- Decent price oem ctr headlights???????
- WTB: 92-95 Eg hatchback PARTS thread!
- WTB: Aftermarket rear mount
- WTB: C/F ITR d/s window switch
- WTB: 96+ LS VC or K series VC
- wtb:: rmf b series headers
- Milano Red 99-00 Civic Hood OEM
- WTB: EG QSD H2B Kit
- wtb: steering column cover
- WTB gsr BLOCK
- wtb: aftermarket fuel rail for my GSR
- WTB: 92-95 hatch tailgate / lower gate
- WTB: ITR FPR Fuel Pressure Regulator
- WTB: H22 Type-s pistons
- WTB: ITR trans, 94-01 teg sedan interior, etc
- Mitsubishi EVO wheels
- Looking for headers!
- wtb: complete, uncut 88-91 crx dx dash harness
- WTB: Toda Headers (B18)
- Wtb 95 GSR AC Bracket
- WTB: 94-01 integra rear quarter panels
- WTB: EK Side Skirts/ vr6 jetta/ 88 series integra lip
- DC sedan rear seats
- WTB: 14" HX Wheels SOCAL!!!
- WTB: DC shift linkage, b series vtec crank pulley
- WTB: Tial 38 mm Wastegate with 1 bar spring
- civic parts
- WTB: 98+ gsr cluster
- WTB: 99-00 civic si blue EBP OEM fenders/front bumper mint mint
- wtb:obd1 94-95 gsr intake manifold
