View Full Version : Want to Buy
- WTB- 04 plus civic
- DC2 Rear Sway Bar ; Cash- Before Sunday!
- DA Suspension
- wtb ef hatch/rex
- Need a b16 head asap!
- wtb civic 96-98 floorboard harness!!
- wtb ek hatch stock
- WTB: Stock D16y7 or d16y8 Longblock with Tranny
- WTB: Tial,precision,RC..turbo parts
- need to buy a CLEAN EF
- WTB S2000 AP2 PARTS ASAP
- wtb: vehicle 5-10k, details inside... post pics an price- nothing over 12k
- WTB Lowering Springs USED OR NEW 1.5 DROP
- WTB: P72 must be obd2a or obd2b local only
- WTB D Series SOHC Motor In San Diego.
- WTB: SPRING/ SHOCK COMBO, DC2, LOW MILES
- WTB - 96-00 HATCH SHELL!
- WTB: JDM EK4 SIR REAR SEAT..... USDM DRIVER REAR UPPER PART WITH HEADREST
- WTB 68mm Throttle Body(TB)
- WTB EG COILOVERS!!! just one pair or all 4. that fit koni yellows
- WTB passenger door lock panel
- wtb mid 90's honda accord parts No VA
- WTB: HX center caps
- WTB: Eg Hatch carpet!!
- WANT TO BUY: Aftermarket steering wheel
- Volk Racing Formula Lug Nuts 12X1.5 for Type-R
- WTB 92-95 Civic Gauge Cluster 5sp...chipped p28 to trade?
- Wanted d16y8 Civic EX 5-speed manual transmission-Ohio
- Civic EG hatch parts
- Looking for some rear aftermarket lowercontrolarms for EF used is OK 2 sets wanted...
- WTB: b18a1 OBD0 harness
- wtb 92-95 ukdm cluster
- wtb: center caps
- ** Rebuilding motor! Need some Oem or autozone parts! **
- WTB: 96-98 Civic front lip
- WTB: 1992-1995 Honda Civic back seats for coupe [So. Cal]
- WTB: Aftermarket Struts for 2000 Si (cdn)
- WTB - B18C Turbo Manifold with T3 Flange
- WTB: 92-95 EG OEM Hatch/Tailgate
- WTB: 92-95 eg cx/dx/lx knuckles non-abs front spindles
- WTB: Amber OEM Headunit (must have CD player)
- WTB DC Tie-bar for an 95 TEG
- I need these parts
- WTB: SI Cluster or SI Tach
- WTB: COMPTECH Lower tie/sway bar in silver for a dc integra
- WTB JDM Prelude H22 pistons
- WTB!!!! ws2 muffler for 99-00 si!!
- wtb: jdm integra non-hid headlghts
- Looking for CRX front end !!! Fender Hood Head lights HELP!!
- WTB> EF Si/zc ecu, cluster, tranny
- Integra Kyb AGX and Eibach prokit
- need a b16 tranny! asap
- WTB: b16 rocker arms
- WTB- WHITE SPRINT HART CPR 16X8 OR 16X7 5X114.3
- WTB/// B-series lightweight flywheel
- WTB 96-00 Civic or 94-01 Integra Armrest Pieces
- WTB: Flywheel (D16z6)
- WTB: B series vtec valve covers
- WTB red ap1 seats
- WTB: and D series complete swap for 93 civic hatch
- WTB: NA1 90-96 NSX Front Calipers
- WTB: D-Series Swap
- wtb 91 crx bracket for motor mount
- EG civic manual steering rack,pinion,crossmember,front lower control arms & forks
- WTB: Flasher Relay
- WTB: B Series LS TRany
- WTT 00 Civic SI Cluster for your S2K Cluster
- wtb:b series SI hydro trans
- WTB: B16A2 OBD2a Engine Harness / 96-98 EX 5spd Engine Harness (no cuts / mods)
- WTB-06-08 Si Sedan front lip-NC
- WTB CTR 96-00 EK9 REAR LIP
- WTB: EG Lip 92-95
- WTB: Integra 98-01 OEM Front Bumper, Headlights & Tail lights for 4dr!!
- WTB: 92-95 Ex or 94-95 GSR engine harness & 92-95 P28 ECU
- WTB: 16inch Spun Supermesh
- WTB: 2dr DC2 Acura Integra driverside power window switch (black)
- WTT: My 96 ls ecu for your obd1 ls ecu
- WTB Vtec Harness
- WTB: IACV B SERIES******************************************** ***************
- WTB: Complete PY/CW ITR Shell w/o motor
- WTB CRX PARTS - BRA/VISORS/SUNROOF/SPLASH GUARDS
- WTB 96-00 Honda Civic OEM REAR Mud Guards / Flaps ASAP!
- I want to buy a B-series tranny torque mount for my integra
- s2k coilovers
- crx parts - rear glass garnish, corner lights, door sills
- WTB: CRX RHD dash
- WTB Smog in Ca
- WTB - OEM CTR Grill!
- 05 - 06 RSX type S front Upper grill with emblem
- WTB CARB STICKER FOR INTAKE
- b16 oil pan
- WTB: CTR / ITR Cams | P28 ECU | OBD2 -> OBD1 Conversion Harness
- WTB: buddy clud spec 2 axle back...socal
- need parts
- wtb: datalogging hardware
- Super Chargerrrr?
- Aluminum civic radiator and slim fan
- Lower din unit for stereo relocation (EK)
- WTB: big throttle body
- looking for 15/16 mc with integra brake booster
- WTB: 92-95 Civic HB Driver Side Rear Window
- 99-00 D-series Dizzy
- WTB JDM ITR FENDERS AND BYS FRONT BUMPER
- WTB Wed Sports SA90s Bronze 4 bolt
- WTB CRX FOG LIGHT (RH side)
- pre cat sensor 98 hx
- WTB 1 advan sa3r hex nut
- WTB: BBS RS Center Cap - Complete | Pics Included
- WTB: exhaust manifold////down pipe
- In need of Civic Si engine harness.
- wtb-b series tranny case
- WTB: *********RSX VSS*********
- WTB: JDM Integra Fenders + Other JDM Front End Parts (PA)
- WTB: RSX-S Shift Knob (Picture Inside)
- WTT p72 for a p28...
- WTB: Acura RSX So Cal
- WTB EK Swap Parts NY Area
- WTB These two things
- WTB ef civic brakes integrs
- WTB: Edelbrock Pro-Flo Header for GSR
- WTB: DB8/4DR INTEGRA COMPLETE SUNROOF ASSY
- WTB: VISION AMBER CORNER FOR EG PASSENGER SIDE! ASAP!!!
- WTB:spoon sw388 fos a S2000
- WTB: LSD
- WTB: Stroud Parachute, etc.
- WTB d16y8 VTEC OIL PRESSURE SENSOR
- WTB: 90-93 integra da greddy sp2 or rs*r exmag
- WTB: jdm one piece headlights for 90-93 integra
- WTB: EG TAIL LIGHTS
- WTB: Keyless Entry Wiring Harness for 98-01 Acura Integra
- WTB: 97 PRELUDE SHIFTER LINKAGE
- WTB: ITR P73 ECU. OBD2B.
- WTB LS 5th gear
- Want to buy Skunk2 Pro2 cams.
- NEED D16 TRANNY 5SPEED ASAP!!!!!
- wtb: gray eg glove box
- WTB: Autopower cage for civic EG
- WTB: autopower cage for EG. buy atuopower roll cage for eg hatch. I'm located in cinci ohio. will p
- wtb d16y8 block cali BADLY
- WTB: B20Z Bare Block
- wtb skunk2 or b16 TB not gsr
- WTB eg/dc shocks. maybe springs.
- WTB: Del sol driver sided turn signal assembly corner lens
- WTT B16 trans for LS trans
- need parts (struts/wheel)
- Looking for 12k and 18k springs
- WTB GSR INTAKE GEN3
- b18b1 head neaded badly obd1-2 not really care
- WTB 88-89 Prelude fog lights
- WTB: OBD1 non-vtec distributor ASAP
- WTB: DEL SOL rear trunk lid, and rear bumper cover.
- WTB: 88-91 Civic hatch Shell NE area
- WTB: JDM ITR parts (bumper support, radiator support)
- WTB a decent set of 195/60/14 tires
- WTB/WTT Regamaster Evo's or Rota Slipstreams 4x100
- WTB GT28R, GT28RS, GT30R, bullseye borg warner
- wtb complete ac unit for ls motor
- WTB- p28 ecu- also a ef si cluster 90-91
- 07-08 oem stock civic SI axleback
- wtb K24a2 clutch any brand as long as its stage 4 or better
- WTB: 98-01 Integra bumper, headlights, corners, dr. fender, rear bumper
- WTB: Drivers side B-series axle for EK!!!!!!
- WTB: RACING HART C2's 3 piece 18' 5x114
- wtb:99-00 em1 front and rear lip
- WTB-B-series tranny asap
- WTB 99-00 civic MUDGAURDS CASH IN HAND
- Ny: Wtt my parts for Turbo parts
- WTB:SSBP or PURPLE TEGG/EBP SI!!!!NORTHEAST!!!
- WTB: 16" wheels
- WTB: DA 90-93 Integra seats
- WTB: 96-00 AC Condenser Chicago, IL
- WTB/NTB CTR Front Suspension Fork
- Wtb 88 civic dash wire harness. Chicago il
- Full Race 1/2 size EF radiator
- WTB civic intercooler piping kit with greddy flange
- 92-95 obd1 singel cam engine harness
- wtb: obdo dropout/ fuel pressure regulator
- WTB Civic Ex/Si SOHC Tranny for 92-95
- wtb obdII to obdI ingnition conversion harness
- wtb: 68mm tb gasket
- wtb: 06+ civic si coupe grill
- WTB: hx wheels socal area!
- WTB rear gsr seats or ferio seats
- WTB: OEM 99-00 Civic Si shift knob
- wtb ek4 SiR front/rear bumpers/front lip
- WTB p2p out of a 5sp 96-98 civic ex.
- WTB: Full Air Conditioning system for a DC2 (GSR)
- WTB > Integra Type R replica Front Lip
- WTB Injectors 550cc+
- 4 Honda centercaps
- WTB 99-00 civic coupe splash guard
- wtb one civic and one integra cat catalitic converter
- wtb: b18c1 low compression pistons and aftermarket rods
- WTB: DC2 ITR MUGEN gen 2 rear wing
- WTB: honda s2000 HID projectors and HID hardware
- 92-95 civic hatchback rear speaker grills
- cf hood and fenders
- wtb: 94 eg hatch parts
- Wtb jdm itr tranny w/4.7 fd
- WTB: H22 transmission
- WTB: 15'' 4x100 MINT steelies
- WTB: integra parts
- WTB: Side Mount Racing Seat... Memory Fab S68, NRG, Sparco EVO, Recaro PP, etc.
- wtb:b16 ecu SOCAL
- Where can i get a Honda-Tech Decal?
- WTB: 96-00 Civic OEM Steering Wheel
- crx hf
- WTB: DB8 ITR spoiler
- WTB: GSR (B18C) Head bolts *Cheap*
- WTB d16a6 si motor
- WTB USDM ITR cluster
- trade
- WTT: 2004 civic lx for RHD
- 92-95 OEM Civic Corner Lights
- WTB DOHC VTEC Head in New England
- wtb clips for 94-01 integra sideskirts
- wtb: h22 balancer shafts
- WTB: H&R Sport springs for 96-00 civic
- lookin for sum jdm fogs for my delsol
- body work and paint
- WTB: ITR 5 lug 15" Drag wheels
- WTB: H22A IAB vacuum control box
- WTB: 310 or 330cc saturated (high impedance) Injectors
- WTB EK arm rest
- WTB: OEM Integra Car Cover // Master Brake Cylinder & Brake Booster // Shifter
- WTB STOCK D16Y7 Exhaust manifold
- Who was selling an OEM fuel line (filter to rail) for $10?
- WTB: ITR Gathers CF Head Unit
- WTB: 92-95 civic sedan gray rear doors nj/nyc
- wtb crx hf
- WTT ssr street sweaper for jdm itr tranny
- wtb airwalker or bys 99-00 civic front bumper
- power window conversion for eg
- WTB: EF hatch Or Cheap Civic
- WTB: B16 REAR T BRACKET!
- WTB: Neuspeed front strut bar for EG
- WTB: 96-98 ctr grill trim piece.. the part thats colored
- wtb: 40/40 prop valve (NON abs)
- WTB: Eagle Rods This Week! (Socal)
- WTB ur old worn/crappy/stained/rusty 96-00 interior visors
- wtb: 2 rims only for 99 si
- WTB 92-95 2/4-door Taillights
- HONDA SI CENTER CAP 99-00
- Want to buy: iacv for h22
- WTB ITR wheel hubs
- WTB: integra manual gauge cluster, hood, fenders, and manual ECU
- h22 injector
- WTB: WHEELS
- WTB rear jdm strut cover in black.
