View Full Version : Want to Buy
- WtB 1991 Si hatch back parts
- wtb - Lenso exospeed skinnies
- WTB: OEM CRX LOUVERS FOR MY 2ND GEN [CALIFORNIA]
- WTB: D Series AC/ PS compatible turbo setup!!!
- WTB: Tial 38mvs or 44mvr wastegate
- WTB: EG6 Jdm Purple tweed door panel
- wtb b series turbo kit
- WTB OEM Milano Red dc2 type r spoiler
- WTB: Traction bar - civic EG
- WTB: 99-00 Si Headrest/ 99-00 cupholder insert/ Si muffler tip piece
- WTB 96-98 Sir Lip
- WTB: 95 Integra Driver Door Window Switch
- WTB: USDM B18C5 (98+) Complete Change Over
- WTB: B-series Edelbrock Turbo Manifold
- WTB: 15" Axis Maglites 4x100 SoCal or PayPal
- big bore d series
- WTB B16 LSD
- WTB: 1994-2001 Acura Integra Factory Radio
- B18c short block running condition
- WTB ISO Blue Stripe Del Sol seats
- WTB: 99-00 EX Civic Cat
- WTB EG Rear Panel Liners / Trim
- Wtb b series obd2 dizzy and alternator
- WTB EF Si white front bumper
- WTB sheepey b series header, skunk2 ultra race manifold, 90mm tb
- WTB: Integra Steering Column U joint
- Ek power folding mirror 4 door
- Bushing Kit for DC2 ITR or 92-95 Civic
- WTB: 1996-2000 Civic Non-VTEC OEM Exhaust Manifold
- WTB: B18A/B Rods w/ ARP Rod Bolts
- WTB: Rywire B Series Budget Harness
- wtb crx front bumper rebar
- Ek Omnipower usa rear lcas
- Twin scroll manifold
- WTB - EGR Vacuum Solenoid
- WTB TSX 2005/1st Gen Parts
- TODA Spec C
- EG JDM Left Side Mirror Block Off Plate (Coupe/Hatch)
- Wtb: itr flywheel
- WTB: 89 Civic Si or DX Door Panels
- EBP 2000 honda civic si grille
- WTB Civic JDM Double Din Upper Console / Dash
- DA INTEGRA HOOD LATCH CABLE!
- WTB: steering wheel for 02 Accord, Lapis interior
- WTB: Integra steering rack
- Em1 oem air box and resonator with hardware
- WTB GSR LHT JRSC intake setup
- WTB CRV Crank Pulley
- WTB Rear Coilover or Threaded Cartridge
- wtb: b series mugen replica valve cover
- Looking for Varrstoen V1 16" 4x100, +15 or +25
- Mugen DC rear spoiler badges.
- WTB Rear 2004 EM2 coupe tail light
- WTB 16" 5x114 Desmond Regamaster Wheels
- DC2 Double Din blank
- transmission B16 gsr
- WTB: B16a/B17a1 lower timing belt cover
- WTB Em1 rear disk conversion
- WTB: 1000cc injectors for D-Series!!!
- WTB: Civic 96-98 Front Grille 'H' Emblem
- S2k cluster conversion for 96-00 civic
- WTB Short ram intake D16Z6
- 99-00 civic coupe passenger power window regulator with motor
- DC2 A/C Blank Switch
- WTB: Misc. 96-98 civic parts and wheels
- K24/k20 Fank :)
- ef sedan all clear tailights or lightly smoked oem taillights
- WTB: Hondata s300 v3
- WTB: TIAL MVR 44mm wastegate
- WTB: D16Z6 crankshaft
- WTB: PLX sensors
- ISO: Eg coilovers/struts
- b18 ls motor pistons and rods
- WTB: JDM D15B 3 Stage VTEC (Northeast)
- WTB CRX Ef8 sh3 foglight R
- WTB: EG mugen air box, EG6 door inserts purple, EG mugen strut bar.
- wtb lsd mfactory
- WTB
- WTB 98+ spec Integra parts
- WTB DC4 Black Carpet (TX)
- WTB 1991 Honda civic Si hatchback seat
- B16 head
- WTB: B16/ITR Victor-X/BBK SSI intake manifold
- wtb: d16z6 valve covers
- WTB 1992 captiva blue civic si
- WTB: Neuspeed Rear Strut Tower Bar for EF
- VA: WTB Distributor Dizzy for my '95 GS-R (TD-44U TD-68U)
- WTB y7 throttle body
- WTB: OEM Integra Type R Intake System
- 96-00 civic 3dr DX 'SIR' rear spoiler
- WTB civic eg headlight harness
- Need the trim from 2004-2005 civic coupe grille
- WTB: PGM TESTER
- wtb: 1 stock front shock for integra
- Dom's List 'O' Stuff
- Looking for B series turbo stuff.
- WTB: SoCal DAP EK | 5 Speed | Clean Title
- WTB 99-00 Civic MT Dash/Cluster harness
- WTB: Upper Power Steering Bracket P30/P72/P73
- WTB oem honda "2000" or "3000" deck
- power mirrors 88-91 civic hatch
- WTB: Skunk2 Ultra Race Manifold and 90mm TB
- WTB: B sereis turbo manifold / Downpipe / Dump tube combo
- wtb manual steering rack for eg
- 2 or 3 breather oil catch can kit
- WTB Del sol oem corner lights
- WTB EJ1 (ABS) cabin & rear wire harness
- LTB: 95 civic hatch headlight and coilover
- WTB Typus OEM Roof Rack for EG Hatch
- 3 BREATHER OIL CATCH CAN W/LINES
- WTB 96-98 Dash Bezel
- WTB: 98-99 Acura CL 2.3 Front Knuckles 4x114
- WTB - EM1 EBP oem body pieces.
- WTB (1) 16x7 +42 5x114 ce28
- WTB: EG9 Rear wiper assembly
- Wtb: ac components for an ek
- WTB MOROSO OR LIKE INCREASED CAPACITY OIL PAN FOR D16Y8
- WTB D16Y8 VALVE COVER WITH BUNGS
- 4th gen prelude jdmsh!t front lip
- WTB D15Z1/D16Y5 VTEC Valvetrain
- WTB: 99-00 Civic Si Trailing Arm Bushings/camber kit/LCA's/Rear Subframe Brace
- Wtb: b series hydro transmission
- WTB: 00 EK Suspension
- WTB 94-01 Integra APR Carbon Mirrors
- 99-00 EM1 Si Headrests
- 99-00 civic coupe/sedan right rear mudguard
- need a crank damper ati/Fluidampr
- S20 CX/VX ring and pinion gears
- WTB: 96-00 Civic Mechanical Steering U joint
- WTB: 00 Civic coupe rear LCAs
- WTB: OEM USDM EG, and EF headlights, corner lenses, taillights, interior bits etc.
- WTB 99-00 civic si throttle cable and bracket
- CRV Manual Trans any condition
- Wanted: Damaged B16 Cylinder Head (Georgia)
- WTB: ITR/CTR Camshafts
- WTB BUILT TURBO CAR
- WTT Virgin USDM p30-000 ecu for..
- WTB: Integra DFW/TX
- itr rear back seats or black rear seats
- WTB: B series VTEC valve cover with bungs for breather
- WTB : A Factory RSX Type S Bose Suwoofer
- Rear Speaker pods 88-91 civic hatch
- MA/NH: WTB EG Si b-pipe
- Ltb h22 cams & b18 rod
- 96-00 civic front mudguards
- Wtb p28/p08/ any ecu to run d15b obd1
- Sparco EVO 2 seats
- DC2 Heater Duct
- WTB: ITR/CTR cams
- WTB: 96-00 Civic Koni Sturts all 4 or just front/rear
- WTB Victor X manifold B16 used
- wtb integra rs rear lower seat
- WTB Colt Cams d16a6 Tri Flow 2
- Body Club 4 or Skunk2 Tuner 2
- WTB /LF 92-95 civic rear panel
- WTB: 90-97 Accord Lowering Springs
- WTB - greddy 18g turbo kit down pipe
- looking for a few used parts
- Wtb:// Apexi N1's 241-H008 Rear Coilovers
- wtb: type r muffler
- Wtb: b18c1 windage tray
- WTB: 94 Integra GSR Pilot bearing and TOB
- WTB CRX DFW/TX
- 3 breather filtered oil catch can
- WTB: D16z6 head/block
- WTB spoon sports battery and tray
- Del Sol/Civic Rear View Mirror & DS Air Vent
- WTB: AEM V2 OBD1
- Iso: si/sir/jdm cluster for ek.
- Kamikazi S/C B-series header
- WTB: OEM ITR intake and Mugen intake
- WTB heat shield off of a b16a exhaust manifold
- Wtb GSR valve cover
- WTB: Base map chip
- Wtb: skunk2 im for gsr...or similar
- WTB hood that will fit 94 hatch
- Desperately need DS Seat for my 95 Civic! (WI)
- WTB: Cusco B Series Cam Gears.
- iso d16z6 dizzy
- WTB: D16y8 Wiring Harness
- WTB idle air control valve b18b1
- WTB:07 CR-V or 07-09 RDX A/C compressor
- Parts for my car
- Wtb : rsx,civic,integra
- WTB: PAIR Sprint Hart CPR 4x100 16"
- WTB: 99-00 EM1 Traction Bar
- WTB: CD5 CD6 F22 94-97 Accord ANY Parts
- PA: 90-93 Integra Black Leather interior
- WTB: Various B series parts!!!!
- B series differential + transmission internals
- Wtb wilwood calipers
- Wtb: comptech subframe brace for DC integra
- WTB: TODA B-series header
- Looking for Del Sol shift linkage
- iso used pistons
- Wtb: apexi decs tachometer
- 04 to 08 tl parts wanted
- Wtb pr3/p30 piston w/ rods
- Parting out 99 Integra LS auto 4 dr
- WTB Race jacket, suit
- Wanted: Sprinthart CP-R 15' 5x114.3
- dc integras oem shift knob
- WTB: b16/itr header. 2.5" collector
- WTB spoon sports racing suit
- Iso caliper brakets 05 -12 rl advice
- WTB OEM chrome "SI" badge from CANADA EJ8
- WTB OEM Integra Type R Springs
- Integra 94-01 Spindle Set up
- AEM FPR orifices silver and gold
- skunk2 rear lca's for 96 integra
- wanted: 06-08 TSX longblock k24a2
- WTB: 98-01 integra headlights
- WTB: 98+ ITR Full Nose Mask
- WTB CTR steering wheel
- Honda Insight
- TURBOS!!!! ISO
- Type r floor mats
- WTB H22 Crankshaft, Engine Harness, Rod, ETC....
- Iso jumper harness
- WTB 1992 D series head or cam.
- WTB: Apexi VAFC 2 or Neo
- WTB CC twin disc for b series
- Wtb 92-95 civic hatch right side door lock
- WTB: Skunk2 Camber kit for EK Civic
- WTB:Rywire OBD1 B seriers Wire Harness
- Wtb. OG comptech subframe brace w/ sway
- WTB: Integra 98-01 OEM Front Bumper
- WTB: 92-95 Black Civic Coupe / Hatch Hood
- WTB: 88-91 crx edm wing
- WTB: OBD1 chipped ECU
- WTB: GSR Seats
- WTB: GSR trans mount bolts
- WTB 92-95 honda civic SI door panels
- WTB: 96-00 civic 4dr sunroof
- D16z6 stock compression pistons
- WTB center cap overlay
- WTB: B16 transmission mainshaft
- WTB: B-Series Parts
- wtb B20B crank pulley harmonic balancer asap.. II
- Wtb obd1 b16a engine harness/p30/p28 / distributor
- Wanted EG Coupe Mid Atlantic
- Need 2000 civic parts
- PA - WTB: 88-91 civic hatch SI interior and parts
- WTB: 92-95 Civic hatch/coupe ORIGINAL Milano Red OEM front bumper
- 1992 da working on kswap
- WTB: Del Sol Catback
- WTB: 4.4 Final Drive for Acura trans
- Wtb b16a2 vss
