View Full Version : Want to Buy
- WTB: 99-00 Si Electron Blue Pearl Fender!!
- b16 p.s bracket
- WTB: 02-05 EP3 Rear Bumper Cover
- WTB: 1st gen b16a exhaust manifold
- WTB gsr throttle body pully
- wtb: rhd eg2 wiper cowl and all windshield componets. wipers/motor ect
- WTB: S2000 S2K AP1 Cluster
- WTB: 97" AND UP OBD1 PR4 ECU & 4-1 DC B-SERIES HEADER
- EG civic sedan front fenders and bumper cover
- WTB: EK ac vent pocket!!! (ny)
- wtb;braided fuel line civic/integra*
- p2t 99-00 si ecu
- WTB: Stock EF upper exhaust manifold
- Wtb: Vision type dc mirrors
- WTB:cheap b16 spark plug cover
- WTB: OBD1 P72 ECU, OBD2B to OBD1 conversion harness
- UCA, Header
- WTB: Timing Belt Pulley
- WTB 44mm tial wastegate
- Wtb k parts needed
- Rota Torque
- WTB: Z6 oil pan
- wtb: inexpensive 15" or 16" wheels and tires (GA/AL Line)
- WTB 99-00 Civic LH Headlight Housing Assembly
- WTB: ITR Camshafts
- WTB B18c1 block
- Wtb: Ef9 Ef8 Right Hand Drive Manual Rack and Pinion
- wtb: valve cover bracket
- WTB: Golden Eagle Intake Manifold for D16y8
- WTB eibach GC springs 700L, 250ID, 650 Spring rate.
- WTB: DC2/EG front LCAs and front UCA mounts...
- WTB: AEM TruBoost
- WTB: 92-93 Integra JDM One Piece Headlights
- WTB: Eibach Sportline Lowering Springs EG
- WTB: S2000 REAR FOG LAMP
- WTB: d16 75mm pistons
- wtb: ls p75 obd2 throttle with all senors in la
- wtb dc itr oem springs
- WTB asap! Fuel rail hose, motor mount, washer bottle EM1
- WTB aftermarket struts for my eg civic
- WTB EG hatch rear speaker conv.
- WTB z6 head
- WTB: DC2 shell and parts
- obd2b p72 gsr ecu
- WTT: My gold EK emblems for your chrome ones (MD)
- WTB: Full shell or car SoCal
- H22/H23/F20 Euro R Type S Cams
- Wtb: hondata boost solenoid
- WTB: Eg/dc or ek coilovers
- WTB: running d16z6 motor
- WTB CRX SI FLOOR MATS!
- Rare JDM bits.....Hoods, Coilovers, Interior, Exterior.....anything
- WTB: Black S2k Hood
- WTB: 96-98 Civic SRS cable reel
- wtb: blitz bov filter
- WANTED: STD Cam
- 626/951: EK/EJ Interior & Exterior Parts
- Wtb iacv
- WTB:EG Parts&Some Other Randoms
- WTB:B series clutch
- WTB: CTR 81mm Pistons
- 1st Gen Skunk 2 Mani
- wtb: pairs of enkei rpf1 16x7 and jdm cw itr
- WTB: 1998, 2000-2001 ITR ABS ECU
- WTB: s300 with boost
- 92-95 civic Left side oem headlight
- DC2 K-Swap Parts: 02-04 RSX Type S Engine Harness, Charge Harness, Half Shaft & more
- WTB EK hatch optional lip/s
- hx ecu
- WTB: OEM 99-00 SI Airbox and Intake Arm
- WTB: OBD0 O2 SENSOR PIGTAIL!! (For 89 Lude Si)
- Wtb: b16b shortblock
- Stock OBDI P72 (So. Cal)
- sohcturbo92vx's official *$*WTB;*$* therad check it out i need your parts
- wtb: 96-98 Civic Coupe EX interior harness
- Where can i find a 5 speed eg civic hatch
- wtb 2006 Civic Coupe OEM Headlights
- WTB del Sol wheels
- Wtb Honda valve covers
- WTB: EG Hatch Tail Lights
- WTB: Anti Roll Bars 7th gen
- WTB: Mechanic to fix my ignition key cylinder
- WTB: 92-95 hatch carbon fiber
- WTB 96 GSR ECU 37820-P72-A02
- wtb del sol si
- wtb: honda domani "H" and "DOMANI" trunk badge
- WTB EG RHD RACK AND PINION
- WTB: 96-00 EK ASR subframe brace
- WTB: Rear sway bar Civic EK
- 92-95 Civic hatchback seat belts
- wtb 900cc+ injectors tonight
- WTB: EF hatch interior (BLUE), Old MOMO wheel
- wtb 4 door dc integra tail lights
- wtb 90-93 integra springs.. 1.5" or less drop
- WTB 90-93 Integra Driver Door Handle
- ••WTB: Bseries sparkplug covers••
- *WTB: Mugen SW Steering wheel**
- ((((((((((((((((WTB H22a And EG 92- interior and mods)))))))))))))))))))
- looking for 92 EG tailgate
- WTB DA Stock Spring
- WTB AP1 Trunk Lip/Spoiler
- wtb 96-00 civic coupe parts
- WTB EM1/00 HATCH
- wtb:ek aluminum radiator
- WTB: crx or eg hatch shell
- 13x8 drag rims with slicks (used)
- WTB: EDM EK4 CIVIC WHITE CLOCK
- WTB: 1000HP Garrett Air to Liquid Intercooler Core
- WTB: D16Y7 Starter
- WTB: OEM integra dual-bend shifter!!
- WTB: 99-00 Civic Coupe Si rear lip
- wtb: tial 60mm (V60) flange and clamps
- AEBS manifold.
- wtb b16 upper neck, obd1 ecu, dizzy
- WTB: Honda N600 Project
- WTB: JDM ITR Front End
- WTB CIVIC EP3
- WTB Bronze RPF1's
- WTB: D16Y8 oil pan
- 2000 GSR stock catback
- WTB: B16 Header (Stock)
- wtb pair of rear dc/eg coilovers
- WTB sc61, 60-1, gt35 must be .82 t3 housing
- WTB: STOCK D15 or D16 ENGINE
- WTB: Civic Em1 SI Stock Cat back or Aftermarket EK
- WTB: B series harmonic race damper
- WTB EG 4 door gray carpet
- WTB: B-series parts
- Wtb b16 turbo parts
- Wtb b series parts
- WTB: '96 - '00 Civic Coupe/Hatch MANUAL door panels
- ** 92-95 Rear speaker brackets **
- wtb: OEM CR-V skid plate (Gen 1)
- aftermarket h22 cams gears
- wtb turbo t3 flanged,v band exhaust, cabable of 650-700whp
- wtb / wtt for 89 crx side molding
- WTB White 94/95 stock gsr. Cash on hand
- WTB SPOON sw388 or Desmond Regamaster Evo
- WTB: Hydraulic LS 5th gear set
- oem h22 main studs
- WTB D16Z6 s2 manifold
- WTB: 14" Honda Civic HX wheels
- Looking for a steel bracket for my spoiler I lost one... I have pics of what i need.
- WTB: D16Y8 transmission (s40)
- WTB EK HATCH SHELL los angeles CA
- WTB. CIVIC 96-00 Sway bar brackets
- WTB: 1 MOMO X-43 RIM
- WTB: 99/00 Civic Si Rear Seats
- Injector Pawn Shop!!!!
- WTB: obd0 pr3 ecu and 1st gen b16a ex mani
- wtb obd2a to obd2b jumper harness
- WTB: short ram intake for LS or ITR
- Hydro non-LS B-series differential
- lf usdm itr seats
- WTT: 16ft car hauler for 99-00 civic coupe shell
- WTB CRV Radiator/97
- WTB: PBR/AXXIS Ultimate 45-05030U
- Needing b-series parts and del sol parts and turbo parts
- WTB: 4 door interior
- WTB eg civic si seats for front only
- WTB: good set of shocks and springs
- *** WTB: Defi D-Gauge boost gauge ***
- WTB:B18C GSR Block w/caps
- wtb b series cable tranny [pedals/ and linkage
- WTB 96-98 civic 4dr ws2 exhaust / ctr grill / coilovers
- WTB: Endyn D16y8 Oil Pump
- WTB:93-95 Del Sol bumper cover-Captiva blue
- WTB:obd0 dseries motor
- ***WTB DC2 MOTOR MOUNTS***
- 1 b18b exhaust manifold head stud an nut
- WTB F7 FUNCTION LOWER CONTROL ARMS FOR RSX
- WTB.. Civic wagon 4wd parts
- !!!!!!!wtb oem dc2 optional sideskirts and rear valance!!!!!!!
- WTB 90 EF ENGINE HARNESS
- WTB: 94-97 Integra OEM Bra
- WTB: JDM/EDM 96-00 Civic OEM front strut bar
- WTB - PRB ECU!
- WTB b18c1 crankshaft
- wtb: vsm ej8 ek oem parts
- WTB: EG J's lip / C West front bumper
- Looking for Defi D-Gauge Boost gauge
- 92-95 civic aftermarket steering wheel
- WTB: B-series Pistons
- WTB Spoon N1 Exhaust
- WTB BUILT b-series BLOCK COMPLETE
- itbs or victor x
- WTB: Civic EK steering column with light
- wtb wagowagon trailing arms
- WTB comfortable recliner racing seat
- WTB: Work meisters 16x8 4x100 or 5x114
- WTB: OEM ITR rear lower control arms
- WTB: 16x7 wheels with chrome/machined lip and silver integra pass fender. nh-583m
- 98-01 usdm integra front parts/rear parts
- 99-00 EM1 cluster
- deletee
- WTB Del Sol Parts
- WTB: D Series LSD
- dseries cam skunk2
- WTB: GSR intake arm
- WTB: S2000 AP2 Front bumper
- wtb b16a/b18c stufff.. take a look
- wtb b-series cable box full conversion
- wtb water methanol kit
- WTB: 90-91 CRX REAR BUMPER COVER/ REINFORCEMENT
- WTB: JDM D15B VTEC (92-95) crank
- WTB: EG DX cabin wiring harness and k20a2 engine harness
- wtb: bucket seat side mounts/wedge engineering base
- wtb- itr or ctr cams.
- wtb precision 750hp intercooler and some other parts
- WTB: Alternator for 2000 LX (D16Y7)
- WTB JDM 36mm Front Axles
- looking for gsr front hubs???
- 14" hubcaps
- Wtb Eg rear jdm interior
- Low Profile Recaro DC2 Rails
- Looking for 92-95 civic si oem catback
- WTB: 2 stock 15" 4x100 rims
- WTB: B20 crank pulley and GSR intake tube
- wtb: k series valve covers
- WTB: 5 point harness and 40/40 prop valve
- WTB: 92-95 Civic Hatchback Cabin Harness
- WTB: OBD1 socketed hondata ecm for 2001 gsr
- WTB: H22 Clutch Kit and Flywheel
- WTB: TURBO PARTS....TAKE A LOOK
- CA: 96-98 CIVIC HATCH *SHELL* WTB
- WTB: EG/EK COUPE or 5th gen prelude
- WTB: 40/40 Prop Valve
- WTB B18B1 OBD1 Long Block
- WTB Oem center caps
- Wtb-crx edm/ukdm crx rear bumper
- WTB: AEM Serial Gauge
- WTB: SLICKS 24.5x8x15
- WTB: OBD-2b GSR ecm
- WTB: ITR PCV hoses, Intake manifold bracket
- WTB ef jim fab traction bar in socal
- WTB: ITR throttle cable and bracket, B-series Vtec vented VC
- WTB SMALL-ISH TURBO!!!
- WTB: obd1 parts for jdm b16
- WTB: 89 WAGON PARTS (TAIL LIGHTS MOLDS AND MORE)
- WTB Front Camber Kit For my Ek
- Wtb: exhaust for a 95 integra Gsr coupe
- WTB prelude half shaft(H22)
- wtb manual conversion parts
- wtb - aem uego wideband kit
- WTB ASAP - Broken 06+ Honda CBR 600 or 1000RR ECU
- (CA) Wtb... OEM EK coupe rear lip
- WTB: Front LCA from 94-01 integra
- WTB: OEM DC2/ITR parts ...
- WTB: CTR/ITR cams
