View Full Version : Want to Buy
- WTB B Series Hydro Transmission
- WTB: Garrett or Precision .50 Trim
- WTB CTR OR ITR CAMS
- wtb 95 civic traction bar
- wtb 44 mm waste gate
- DOHC ZC adapter plate
- WTB A SET OF ALL CLEAR TAIL LIGHTS FOR A EK HATCH
- WTB: 15x6 or 15x7 4x100 Wheels
- hondata s300 in san diego california
- WTB: After market headers
- wtb-civic auto to manual swap parts
- WTB: oem usdm 98-01 integra type r lip
- WTB:B Series Vtec Solenoid
- wtb a carbon fiber hood 96-98 civic
- WTB: B18C GSR ITR Timing Covers
- wtb itr pistons jdm or usdm
- GSCT1 cams
- Kosei K1 15x8 4x100
- WTB: T25 ramhorn
- WTB: wings west eg front lip/ sir headlight &corners
- WTB: k20/honda motor co. valve cover
- D16Z6 cam - Comp 59300
- WTB: Hondata S300
- Anybody know where I can buy and import a K20c1 motor
- wtb: ek hasport mounts or innovative billet style mounts and b16 skunk2 pro mani
- WTB: Power Mirror Switch for Accord
- wtb dual fuel pump hanger for crx
- wtb: v-band 3"/ Garrett coolant line kit
- WTB: AEM V2 OBD1, EPM and ID 750cc
- WTB B Series VTEC valve spring removeal tool
- Can anyone help a EF9 owner from the UK find a lip?
- wtb obd2 oil pump for b series. OEM
- H22a differential speedo gear and sensor.
- Wtb: 01-05 civic suspension ep3
- WTB: Fuel pressure regulator, clutch, and throttle body.
- WTB: B18C Lower Timing Cover
- WTB: cheap F22B/F23 header
- Need ASAP --99-00 civic si engine harness ...mint
- wtb: jdm/edm EG headlights and clear corners
- Wtb: eg parts
- WTB: OBD1 P72 Ecu
- Wtb back issues of honda tuning
- wtb ek vti lip for coupe/sedan
- WTB D16 aftermarket intake manifold
- WTB K24 Crank and Bare Block
- Stock Crx Si front and rear lcas
- wtb: front camber kit eg/dc
- ISO TOP1 eg winglets
- WTB: RSX Type-S 05-06 REAR SWAY BAR
- wtb: gram injectors
- Wtb: 93 civic hatchback tanabe concept g exhaust system
- Wtb civic cat
- Wtb mugen bb6 parts
- wtb 0bd0 b series dizzys for parts.
- The Enthusiast's WTB Thread (Updated 3/20/15)
- WTB: ACL RACE BEARING (GSR)
- Wtb ef9 parts
- Wtb: 95 integra non abs brake lines
- WTB: Avid or Hasport mounts B series EG
- WTB: EG Coilovers, LCA, Rear Brace
- wtb: skunk2 b16 intake manifold pro series
- wtb: b series obd2a dizzy
- Wtb toda reps in like new condition for b series
- 96-00 civic/ EL stock muffler in good conditon
- looking for LSD transmission
- WTB A/C setup for Ef hatch
- WTB: D16y7 non VTEC distributor
- Iso/wtb sleeved b series block.
- Eibach Pro Kit
- Wtb black oem eg civic steering wheel
- Blinker and Marker Light
- wtb: endyn/moroso catch can
- TSX Intake
- b16 timing covers and oil pan
- WTB: 98-01 GSR Power Steering Hose
- wtb id 2000 cc injectors
- HYPERCO/EIBACH/SWIFT
- WTB: 1st Gen CR-V EDM Front bumper and side bars prefer new.. II
- WTB INTEGRA Steering wheel cruise control block off panels.
- wtb gsr & b20 timing covers
- Wtb: ep3 transmission
- wtb buddy club 3+ exhaust cam(b series)
- WTB: OEM 96-98 SIR Front Bumper & Raybrig Circle Fogs
- need 99 civic ex manual engine harness asap
- WTB ac compatible b series manifold or downpipe.
- Wtb: ctr n1 crank pulley with belt
- WTB: DPFI tps or throttle body
- WTB NJ: OBD2B CTR (PCT-J11) ECU
- ISO EG6 or DC2 clear sidemarkers
- WTB: Bride seat rails for EK or EG
- moates ostrich or hulog
- wtb k24 6 speed transmission
- wtb 14b or t25 turbo for my d16
- wtb: coilover sleeve and perch
- WTB p73-a04 ecu. obd2B from 00-01 integra type-r
- WTB Canadian SiR cluster Fuel/Temp gauge
- Looking to buy a 2014 honda civic si sedan (let me know what ya got!!)
- wtb Integra rear t bracket
- wtb 6 point boltbin roll cage. eg/ek/dc
- WTB NJ: 99-00 Honda Civic Si / EX Engine Harness
- D16z6 Crankshaft wanted....
- WTB: 94-01 integra trunk w/o wing and type r front lip
- WTB: 2 x 25mm bolt on spacers 5x114.3(5x4.5)
- Mugen Mf10s
- WTB: 4 bolt A/C friendly DP (Inline Pro Manifold)
- WTB: 1or 2 jdm itr pistons. or piston and rod.
- Wtb ac compatible t3/t4 turbo manifold for b series.
- WTB ITR or Aftermarket valvesprings for B-series
- WTB Aftermarket GSR intake manifold
- WTB EF chargespeed rep style spoiler
- wtb 1992-95 civic d series exhaust manifold socal sgv
- WTB P73-A03 USDM Type R ecu
- WTB : Harness bar for EG
- WTB 98-01 Prelude H-series power steering pump bracket
- WTB: ITR front brake set up
- WTB: Euroexport B series valve spring compressor
- WTB: Good Basemap for my H22 Euro-R
- WTB: 1999 civic si steering column
- WTB:SSR type x center caps
- WTB: Wedge or Planted EG/DC Seat Bracket + Recaro flat mount sliders/rails
- JL audio vantage box integra 3X10
- WTB Integra Shell
- WTB : Garret ar .63 57 trim turbo or any other similar one asap
- wtb wavetrack lsd
- wtb mugen b20 valve cover
- WTB: OEM 15 inch 4x114.3 Type R wheels
- WTB 96-00 coupe egr visor
- WTB: Spoon Sports EG6 Cluster
- WTB: DC5R JDM 6th gear
- WTB: Itr spoiler and Front Lip. Also 96+ Driver Mirror
- WTB ITR or CTR Cams
- WTB Looking for hydro ls tanny
- Wtb- J's racing eg axle back-mint spoon twinblock calipers.
- Looking for SIR EG corners
- wtb: LHT b16/itr jrsc after cooler manifold
- Wtb: Axis maglite 15" wheel 1-2 of them
- I want to buy ef front strut bar
- WTB: 99-00 Civic Si cluster
- wtb: Razo RA93 Carbon Quick Auto Shift Silver
- WTB JDM Integra Eyelids, 98-01 2DR Rear Bumper
- wtb k series parts
- wtb hondata s300 with ecu
- Mpfi swap parts
- wtb rsx steering wheel
- WTB: Eibach Pro or H&R OE for EG/DC
- wtb aem version 2
- WTB: Integra sedan rear door handles - White
- wtb: 99/00 civic Carbon fiber or kevlar hood
- WTB 2008 Acura TL Type S Wheels
- wtb 13x8 wheels/slicks
- WTB stage1/ctr exhaust cam for gsr also intake manifold
- WTB: 99 Integra GSR OEM Catalytic Converter
- H22a rocker arms and camshafts
- Turbo B20v parts needed
- WTB B series manifold mini ram, tubular log, or inline pro
- Front splitter for eg
- WTB Garret or good brand turbo
- wtb: b16 adjustable cam gears
- WTB: eg power door conversion harness
- WTB: Integra Type R Trunk Mat, DB8 Window Visors, PY ITR Lip MINT/NEW
- WTB: Recaro Tomcats
- Wtb: gsr aftermarket intake manifold
- Alternator
- WTB: OEM JDM DC2 Hood
- Wtb 7th gen accord coilovers
- WTB: Y8 S40 Transmission, shift linkage, and 37820-P2E-A12.
- Need a short block for (F22B1)
- WTB oem distributor for 1995 integra gsr
- WTB: k20z1
- wtb: obd2b to obd2a jumper harness
- WTB: hondata s300
- wtb: eg center console
- WTB JDM B16B EK9 ECU (37820-PCT-J11)
- WTB FMU!
- WTB: B16/GSR Transmission
- WTB: 96-97 Honda Accord Coupe Shell
- WTB: B series hydro tranny
- I'm looking for a D15 swap
- 99-00 civic hatch tail lights
- wtb: catch can
- WTB: Kamikaze Header for B-Series
- WTB: 94-97 Integra 3-door Front and Rear OEM bumpers
- Looking for 15' skinnys
- WTB: Honda Civic EG 1992-1995 Sedan Ferio Mugen Parts Accessories ect
- WTB: 2002 Accord Coupe Fog Lights
- wtb kswap header!
- wtb passwword jdm headlight scoop for eg
- Wtb hondata s300,tunerview rd1 or CNC staging brake
- WTB: Honda Crx Struts/Springs 90-91
- WTB: 98-01 Integra parts- Taillights and bumper lights
- WTB: 98-01 Integra Oem Parts + Turbo Stuff
- Wtb team dynamic 15x7
- 97-01 Sunroof
- WTB: 96-00 Honda Civic Access OEM Roof Rack
- WTB: Tan 92-95 Civic Steering Wheel
- WTB: EK Optional Center Ashtray Replacement
- wtf d16 skunk 2 intake and throttle body
- iso 2.5 exhaust
- WTB: 96-00 Civic Ex/Si door panels w/ switches
- WTB: JDM GSR block with internals
- WTB used EK/EJ8 coilovers
- WTB: OBD1 P72 GS-R ECU
- WTB: GT3071R turbo
- WTB: s300 V3, wideband, catch can, tb...
- WTB Mugen MF10 5x114 Socal
- Wtb steering wheel combo
- WTB B18c1 AC compatible Supercharger
- WTB: (1) Rota Slipstream 16"
- wtb h22 header
- WTB 2001 ITR CRANKSHAFT
- WTB: ce28n replica wheels 16x7
- Skunk2 74mm Throttle Body. B Series. Black ONLY!
- WTB b-series torque mounts
- WTB: Wheels 17"/18" Volk Wide
- Looking for em1 parts
- WTB Thermal R&D 3" Exhaust
- WTB: 98-02 Honda Accord Coupe Tail Lights
- Houston, Tx local civic parts
- WTB: Del Sol Instrument Cluster
- WTB: Double Din with Backup Camera; Speakers
- WTB: Spoon Monoblock
- WTB: EG Audio Console and 32mm 5-LUG conversion
- WTB: 02 Instrument Cluster
- WTB: 17in Racing Hart / Work lips and barrels.
- WTB: Forged 84-84.5mm 10.5 - 11:1 CR pistons
- Wtb oem axle back si
- WTB EF PARTS
- Wtb: Street tune for Prelude
- WTB: d16y8 head and eg coupe parts DFW
- WTB::: Recaro SRD drive side seat bracket andslider for Ek
- WTB: OEM ITR or CTR springs
- wtb h22 adj cam gears
- WTB: Tan 94-01 Interior Parts (window controls, door scuff plates)
- WTB: USDM ITR
- wtb 5 lug conversion
- WTB Ac turbo manifold
- wtb: itr exhaust cam and Gsr intake cam
- wtb 440cc injectors or more h22a
- WTB 450cc dsm/S2 exhaust
- WTB: 96-98 Civic EX Power Window Conversion
- WTB: Set drag racing wheels
- wtb: cd5 parts
- WTB: OBD1 B Series VTEC Distributor
- wtb integra dc quarter panels
- H22/H23/F20B Retrofit coil pack
