View Full Version : Want to Buy
- 4dr DA e-brake cables
- WTB 99 CRV auto AWD trans
- WTB:DB8 WS2 axleback
- WTB 2nd Gen CRV Cluster - KM/H
- WTB -10an block fitting
- WTB: kosei k1 15x8 4x100 +32 to 36mm
- wtb for 35 shipped
- wtb: ef9 fender (driver's side)
- WTB Civic swap parts and Integra subframe brace
- k swap for sale
- WTB: Oem cat for DC2 Integra
- 94-01 Integra front bumper stiffner brackets
- wtb shocks and springs for 92-95 civic 94-97 DC
- WTB H22 cams, springs retainers h2b header
- WTB P28, and distributor
- b16a2 PROCHARGER!! lol. Wtb!
- WTB- b series vtec valvecover and catch can
- WTB: Upper GSR p72 p/s bracket
- WTB:EP stock seats
- WTB 4x100 14" OEM alloys near St Louis MO
- Wanted: HX wheel
- WTB: OEM hydro flywheel cover
- WTB EKK2'S... k-swap mounts
- WTB 95 Civic Evap Purge Control Solenoid
- Wtb:Del Sol VTEC or CRV A/C bracket
- d series turbo kit
- San Diego Wanted: Integra GSR B18C1 OEM exhaust manifold
- Motec PLM
- WTB EF9 Sir Bumper
- wtb wtt im looking for some integra coilovers
- WTB; D16z6 Complete Long Block
- LOOKING FOR: HONDA OR ACURA!!!!!
- wtb ef9 bumper lights
- WTB JDM 36mm Front Axles
- WTB 99-00 Civic Si Fender Driver Side Blue
- WTB 99-00 CIVIC Si Interior
- WTB: 00 integra a/c bracket, a/c wire harness(under hood), a pillar
- driver side exterior door handle black
- WTB: Radio/Climate Control Plastic Trim Bezel 1996-1998 Civic EX Coupe
- WTB: EK Hatch Interior panels
- WTB: Integra RS or Type-R headliner
- WTB oem pass side eg corner light
- WTB: Lowering springs for my 95 EG Hatch
- WTB - EK Civic Plastic Fuse Cover/ USDM Armrest Delete
- wtb: civic EK Vi-rs
- WTB: ITR front and rear calipers
- WTB: COMPLETE H2B KIT FOR EG
- wtb 97-01 prelude shift boot with the boot plate included
- wtb ac compatible turbo downpipe for d16
- [WTB] RS*R Exmag for 96-00 Sedan
- wtb: 1991 civic si dash harness and main harness
- 02 Sensor EM1
- Wtb ls starter eg headlights main relay
- WTB 2.992 76mm Piston rings 1.0mm 1.2mm 2.8mm
- Wtb: 96-98 pass. side ctr headlight
- WTB: ps3 in san diego
- wtb:type r sideskirts (99 integra)
- wtb del sol carbon trunk
- WTB: A Ton of DB8 GSR Sedan Stuff (TX)
- WTB: Hasemi ssr center caps
- WTB! 4 door integra sedan, or eg
- WTB Accord 90-97 Shifter 5spd with cables
- WTB: USDM ITR Wheels (Gunmetal)
- tow hooks n accesories
- WTT: Z10 block girdle, AEBS main studs & eagle rods for hondata s300 or neptune rtp
- WTB: 99-00 Civic Si Front Bumper Milano Red
- WTB: CRV Power Steering Bracket ASAP!!!
- WTB: EG side mount seat rails!
- WTB: Buddyclub super low rails for DA9 driver side or both
- WTB: LS bottom end in MD
- WTB EF Door Panels
- WTB:T2W4 or T2T4
- gsr hydro tranny
- WTB: WINGSWEST TYPE II FRONT LIP FOR 94-97 INTEGRA
- WTB 93 Civic Headlight harness
- WTB: CTR/ITR Exhaust Cam..
- WTB complete 98-02 accord LX head
- WTB: EK hatch oem or ek9 side shirts in SOCAL!
- GSR P72 upper power steering bracket
- wtb eg9 cluster with abs and tcs
- fs: VSS speed gear on bseries tranny
- JDM EK9 RHD Throttle Cable
- WTB any year del sol manual
- B18 Aftermarket cams PLEASE ASAP
- WTB: RSX Type S Red or Black front seats
- complete drivers door latch with rods 98 civic ex 4dr
- WTB: 15" or 16" GOLD Gramlight 57c's 4x100
- WTB: 98 civic ex 2dr dash harness
- wtb: gsr lsd
- parts
- WTB: AEM 3" ITR CAI
- anyone got a cheap gsr trans?
- WTB red or black Recaro type r seats !!!
- Wtb 92-95 civic outside door handles with key?
- WTB: OEM Jdm valvecover halfmoon
- WTB WELD SKINNIES ASAP
- WTB D16 cam gear w/timing belt
- WTB: EF dseries cable to hydro kit..
- WTB B18C1/5 Bottom end, no spun bearings please
- WTB: 98+ rs proportion valve
- wtb 92-95 civic rear lower strut bar
- **WTB F23A transmission**
- wtb 88-91 crx parts and b-series
- WTB H2B kit
- WTB: SSR ex-c(fins and mesh) rings, collars and caps
- WTB: 99-00 Civic Si Engine Harness
- WTB cheap B-turbo kit
- wtb: Exhaust for 96-00 coupe
- WTB Valve cover bolts
- WTB: P28 Chipped W/ Type R Basemap
- WTB:Spoon parts for my Em1
- WTB: P08 Ecu
- WTB: TODA ITB's B16/B18C-R
- TN: WTB ASAP: D-series flywheel & clutch bolts, slave cylinder, & clutch fork!
- EDM/UKDM DC2 Integra Taillights
- WTB: P/S Bracket and P/S Pump
- SO CAL WTB: GSR SEATS FRONT AND REAR!
- wtb: black 94 integra fenders
- anyone know where i can order a hood bra online for 92 civic ??
- WTB:[AU] EF9 Front End
- WTB: S2000 CR wheels/wing/lip/ Black S2000 Interior pieces & door panels
- WTB LIST - EK Parts - H Series Parts - Engine Parts - Suspension Parts
- need to buy! gsr windage tray, pickup line, and oil pan!
- D16A6 camshaft
- wtb wideband and boost gauge
- 99-00 civic wiring harness
- Wtb: H22 Pro 1 cams
- WTB CF Hood for a 88 91 CRX, TX
- Carbon or Kevlar Roof for Integra
- WTB: JDM DRIVER SIDE EF9 FENDER ONLY!!!
- WTB: 1999 honda civic si fenders
- WTB Del Sol Si Center Caps
- OH: WTB: 4TH GEN PRELUDE SHELL
- WTB: 99-00 civic si b series shift linkage
- WTB 99-00 Civic OEM Honda Sunroof Visor
- WTB 99-00 FBP Si Wing
- WTB: Hondata, AEM EMS, Neptune, ECTUNE, etc...some type of eng management...
- WTB: AP1 S2000 AEM EMS & 1000cc + Injectors
- [MO] WTB: dc integra parts! aftermarket/oem!
- WTB: 4040 proportioning valve
- I am in need of parts!!
- WTB GSR lower timing belt cover, ls won't work
- WTB: EM1 99-00 Civic SI Shift Linkage
- WTB: Integra Window Motor
- ****WTT ECU's****
- wtb : Tial 44mm Wastegate
- WTB - Momo tuner 350mm with red stitching wheel.
- Wtb: obd2a manual p75 ecu
- ♣♠♣♠♣wtb - ek parts♣♠♣♠♣
- h22 pro 2
- SELL/TRADE MY FULLY BUILT TURBO MOTOR FOR YOUR FULLY BUILT K OR H ALL MOTOR
- WTB: CT - Trunk Lid in White for '00 Civic
- WTB 1997-2001 PRELUDE M/T GAUGE CLUSTER
- WTB: 99-00 civic Si Shift linkage / turbo return line
- wtb wideband dynojet
- wtb h22 water tube
- WTB: Lenso skinnies exospeed
- WTB: stock 94-99 gsr cat-back
- WTB: MA 96-00 CIVIC power steering set
- Looking for H22A1 head!
- wtb:2000-2001 acura integra evap charcoal canister
- WTB: OEM ITR flywheel
- WTB CRX hood and Passenger Fender (New York)
- CANON 5D MARK II $2300 to Spend
- WTB: 98 civic lx Exhaust maifold/cat!
- WTB: B16 INTAKE MANIFOLD (JG,VICTOR X, ETC)
- CAWTB:d16z6/b18a/b will trade hacked PS3
- WTB -VICTORX FOR B16/ITR
- WTB: s2000 for around $8k-9500 SoCAL
- WTB: Edelbrock Victory X intake manifold
- WTB: REAR DEL SOL SPEAKER BRACKETS
- Looking for a v-band turbo downpipe.
- WTT: K20R Longblock for Sleeved B18 Bottom
- WTB: B16A PowerSteering Brackets,Bottom Crank Shaft Pulley
- WTB: 92-95 hatch driverside door
- WTB D16z6 Engine Harness OHIO
- WTB: EIBACH SPORTLINES SPRINGS FOR 92-00 CIVIC
- WTB: b series turbo kit
- fully function s2000 cluster for ek
- WTB: P72 (GSR) Power Steering Brackets
- WTB auto d16y8 intake manifold
- WTB .......02-04 RSX-S Charge Harness
- socal wtb s2000 ap2 exhaust tip
- wtb: b18 obd2 or b20 spark plug cover
- B20 Torque Plate
- Si center caps
- wtb precision sc34
- WTB: 97 Civic Exhaust Manifold
- WTB: 94-95 accord lx or ex dash harness
- -10an fittings
- WTB A HATCH
- WTB: 94+ integra complete Air conditioning system
- WTB: B series A/C Compatible Turbo manifold
- Wtb: 99-00 Civic Milano Red Bumper
- WTB: 99-00 Civic SI Tail Lights
- WTB: B16 intake, Rota slips, EK coilovers
- Wtb: LS Engine 94 up
- wtb jdm itr brake booster and master cylinder
- Alpine ERA-G320
- WTB 86-89 integra parts car (running ok)
- WTB: 2.25 axle back exhaust
- WTB EG Civic 5 speed swap NJ
- wtb: obd1vtec dizzy
- wtb - light grey 96-00 civic EX coupe door panels
- wtb: 00 *ivi* *o*pe aftermarket *atba*k exha*st
- WTB: Main Relay
- WTT: Volk wheels
- WTB. AEM FPR
- WTB: JDM 01 DC2 ITR Cluster Plugs/Pigtails
- WTB: p30 or chipped p28
- WTB: ITR TB Cable/bracket
- wtb ek gauge cluster
- WTB Sparco EVO seat
- WTB: EP3 IDLER PULLEY
- WTB: D16z6 block
- wtb:2000-2001 acura integra gsr evap system
- WTB: Skunk2 Cam Gears / Silver / B series
- WTB: D16 Intake Manifold - Blox, Skunk2, JG
- WTB: ..a poopload of stuff
- WTT: JDM P30 ShortCase Rare!
- WTB: 98-01 integra sedan rear bumper
- WTB: JDM type R OBD2B P73 ecu
- WTB: 99-00 Civic SI 40/40 non abs prop valve
- WTB H22A AEM Cam Gears
- map sensor, oil sandwich adapter, ect.
- WTB ::: F22 non.vtec!!
- WTB: GSR Catalytic Converter
- wtt/tw: rota slips
- wtb: 2 front H&R sports spring for EG/DC
- WTB: QSD h2b FULL kit for eg/dc chassis CASH IN HAND
- wtb f20b crank and rods
- WTB: Acura Legend Lip (coupe)
- WTB aftermarket Fuel rail B-series
- WTB 99-00 Si Wheels (DFW)
- WTB: 04-05 Civic Sedan Tail Lights!
- WTB: 92-95 civic optional lower audio console
- wtb del sol exhaust
- wtb: b series hydro clutch and b series stuff
- WTB: Driver side conversion mount
- WTB drop springs 97 4 door
- WTB GSR OIL PAN
- 98 GSR Alternator pulley
- 4dr bimmer is looking for a honda to trade
- WTB: Civic SI Exhaust manifold
- PA - WTB: 2000 Civic SI
- Lenso Exospeed skinnies
- Wtb: 99-00 civic Si Milano Red Bumper/Si Grill
- WTB 13" WELD's & 24.5X9 MT Slicks
- WTB: 02-04 Mugen/Replica/TypeM RSX Front Bumper
- LS-vtec kit
