View Full Version : Want to Buy
- WTB: Any Exhaust for a 92-95 4 door civic EX.
- Integra air conditioning hose
- ~~~ GREDDY TURBO KIT FOR INTEGRA LS ~~~
- WTB: 89-93 Teg DA 3dr P/W switch
- need d-series turbo kit
- WTB: B18C1 GSR main bolts
- WTB: HasportMounts/Skunk2 Pro-series Valvetrain,Pro1 Cams/Fluidyne/Bisimoto/etc.- CHICAGO
- looking for D15b or any throttle ody that might fit
- WTB: 15" or 16" rota rims with tires San Diego
- WTB - aem short ram or cold air intake
- obd0-1 dizzy/ o2
- WTB: JDM ITR Lip JDM ITR Headlights DC 98-01 Tail Lights DC2 Rear Hatch + MORE!
- looking for a BLOWN s2000 steering wheel airbag cover
- WTB: HYDRO TRANNY
- WTB: B Series stuff (mounts, starter, axles, shift linkage etc..) tristate
- WTB: Skunk2 Cam Gears for B-Series
- WTB: Civic SI / CTR Suspension
- WTB 92-93 Civic Black Glove Box Non-SRS
- WTB: EG heater check valve, miscellaneous interior pieces
- WTB: Ek9 parts!
- wtb/wtt: white 15' rota slips
- WTB integra window moldings and door trim molding
- WTB: integra 2dr. rear quarter panel glass window.
- WTB: B Series AC Compressor
- WTB ITR catback, header-back
- WTB: 3" ITR CAI [with or without filter... doesn't matter]
- Looking4Integra,Civic
- 2nd Gen CR-X headlights L&R Freebies
- 91 si tranny
- WTT - Shoei Helmet size XL for any size M helmet in good shape >>
- looking for a b series motor either b16 or b18c
- WTB COMPLETE GSR HEAD ASAP!!!!!!!!!
- WTB LS CAI
- WTT: 16x7 Rota GT3 Royal black for any 15-16" wheel.
- WTB LOW COMP PISTONS AND RODS
- WTB *** H22 -Header-Intake Mani.-Type s Cams-!!!
- WTB: 98-01 integra front bumper, headlights
- WTB: VTEC solenoid
- W.T.B. OEM DEL SOL SIDE SKIRTS
- W.T.B. OEM DEL SOL REAR BUMPER
- WTT: in nj a b-series longblock for a full y8 swap,also WTB: turbo kit for a D
- 92-93 tranny
- WTT: replica ctr wing for cf wing
- WTB: OBD1 or OBD2 Sohc Non Vtec Distributor | Los Angeles, CA |
- WTB: B Series spark plug wire cover
- wtb camber kit
- WTB: ITR rear LCA'S
- WTB 96-00 Civic HX
- WTB b18C5 shortblock or longblock
- WTB: Civic/Integra Headlight Switch.....
- WTB:crx rubber boot from tb to air box!!!!!!!!!!!
- I NEED IT A.S.A.P.
- WTB: D16Z6 block in columbus ohio area
- looking for a cheap ef rolling shell, hatch? crx? Washington
- WTB: DSM 450cc injectors
- WTB: 99-00 Si obd2 dizzy and wiring harness
- WTB NOR CAL: 88-91 CRX PARTS
- WTT/S: 97-01 Black Prelude Cloth Seats for seats for an EK - NY/NJ/PA/CT
- WTB: OBD2B Sohc Non-Vtec Distributor | Los Angeles, CA |
- need a honda/acura ASAP!!! please help
- WTB: SiRII B16A Swap COMPLETE ~~~ NC and surrounding area
- H22 Shift Linkage for EG Swap
- wtb d series missing link
- WTB B16B2 BARE BLOCK
- WTB: Suspension (Coilovers) for EK 96-00 Civic
- WTB: Integra AC System
- wtb::: 1997-??? prelude brake master cylinder
- WTB: got 4k for an EG in norcal
- WTB B16 timing cover plastic **** asap
- WTB: accord engine wiring harness
- Need a B16A2 block, anyone?
- WTB: 310 cc injectors OBD2 prelude
- WTB 4 HX rims with or without tires shipped or with-in 250 miles.
- WTB: DSS stage 3 axles
- WTB: del Sol Parts and Misc Suspension/Brakes/Wheel
- WTB: Driver Side Fender for an EG Hatch
- WTB:Mugen style front lip for EG
- 99 si front lower control arms and strut forks
- WTB: D16A1 tranny ASAP
- WTB!!
- WTB 90 CRX Si RH front corner lamp
- WTB: ITR Crank
- Eh2 Rear Bumper. Spoon Replica Wing So CaL
- WTB Del Sol SI Radiator for H22 to EG Swap
- H22 H22A into EG Civic Performance Axles
- looking for 99-00 civic si cluster or gsr cluster
- H22a1 Head
- WTB: H&R race or Neuspeed race springs for Integra
- WTB: red/clear tail lights for a 97 ex coupe civic
- WTB: Smog Legal Header for a 97 EX coupe civic..
- CRX/Civic Si Chassis Harness
- WTB: Hasport b-series mounts and linkage for 88-91 civic
- Ridgeline badge/emblem
- WTB: AC Condenser for 99-00 civic Si
- WTB: Radiator for 99-00 civic Si
- WTB:4 inch exhaust for eg
- WTB: Front camber kit for 96-00 civic
- wtb: itr jdm front end
- WTB: Passport 8500 Radar Detector.
- wtb 96-98 gsr in dash wire harness
- wtb h22 crankshaft!!!!!!!!!!
- WTB: RC 310's
- cheap used 15's in so cal
- WTB: D2 Coilovers
- WTB: type r rear abs sensors!!!!!!!!!!!
- WTT: GREDDY Turbo Timer and Electonic Boost Controller (have Canon Digi Camcorder FT)
- WTB: 96-98 civic CF hood - oem
- ek front calipers
- WTB GSR or JDM B-Series Cable Transmission ~ AZ
- WTB! EK hatch shell (east coast)
- wtb: obd1 LS 5speed unchipped ecu
- WTB Civic D16Y7 Exhuast Manifold with catalytic converter
- WTB: EK passenger side airbag
- WTB: Outside mirrors EG
- si 99-00 motor mounts
- WTB: Map Sensor
- wtb: 4-wire o2 sensor new york
- WTB: JDM D15B VTEC Oil Pan - Must be a JDM D15B Oil pan.
- WTB: NSX rear calipers
- WTB:civic test pipe 2.5"
- WTB: Integra throttle cable
- WTB: EF9/EF8 88-91 Civic SiR cluster
- wtb civic northern indiana
- WTB: S-13 in VA/MD/DC areas
- !!!!!!!!!!!!!!!LOCATED IN FL..wtb: Red recaros, K20 PARTS/motor, and 5 lug USDM!!!!!!!!!!!!!!!!!!
- WTB: P28 ECU for an AUTO tranny
- wtb CLEAN black b series valve cover uncut
- WTB 17 inch stock 06 5 spoke Rsx type s wheels
- WTB: 96spec JDM Integra Type R (ITR) 4-2-1 Header
- 96-00 civic coupe door panel
- WTB eg civic black bumper
- WTB: White EG hood
- WTB: P54 Del Sol AC bracket
- Mugen BB4 Headlight Covers
- Wanted: Integra LS internals... 4th gear
- WTB :: 94-97 Accord Rear Lip
- WTB: integra rear hatch window molding and front window moldings
- ******WTB: b18b short block********
- wtb a p28
- WTB: EG Si dash harness uncut
- $$$$$$$$WTB P30$$$$$$$$$$$
- WTB: '95 P30 USDM ECU
- wtb 94-97 integra front lip
- wtb type r service manual
- ~~> Want EK !!!! <~~~
- WTB: 98 Civic HB parts - seatbelts, sunvisors, sunvisor clips, clothes hanger, floor mats, center co
- crx parts wanted
- Cheap OBD0 ECU.
- WTB prelude cable linkage
- wtb.knock sensor h22
- WTB: CTR CAMS!! HAVE MONEY
- WTB: 1992-1995 Civic tan glove box!!!!
- WTB: wiring harness for 88-91 civic Si
- WTB: A vehicle
- WTB: complete set of Stock B16 valves NOT BENT!;so cal
- 99-00 Civic si engine wiring harness ( Local PA )
- WTB SSR Comps 15x7 4x100
- WTB: EG hood, fenders, headlights plus more front end fun stuff
- WTB: 96-00 Civic Coupe EX or SI OEM muffler
- WTB or WTT CP, Weisco, Endyne, etc... pistons. 81.5-84mm will work
- looking for a turbine housing
- WTB: Mugen MF8/MF10 center caps!!!
- any one selling a dc sports shift knob
- wtb: bare head
- I need front integra brake set up
- wtb: h22 quaife lsd
- WTB: roof out of a CRX
- wtb eg hatch door seal
- WTT: 98 Mercedes Benz C280 Sport Package (So. Cal)
- WTB: used catback or axleback exhaust00 integra ls/ jdm itr front lip (MA)
- WTB: Radiator hoses
- WTB Cable B16 tranny S1/J1/Y1
- WTB,,, Fat Five rims with tires.
- WTB: 92-95 civic HB BLUE Armrest!!!
- WTB: 97+ Honda Prelude Manual Transmission
- WTB 99-00 civic Si complete intake assy
- Looking for a 1992-1993 Civic H/b
- WTB: rsx shift linkage
- SOCAL PICK UP- WTB:- 15inch steelies, 4x100 offset, with OEM Honda hubcaps from 01-05 honda civic
- WTB: 92-95 civic HB hatch door/tail gate/trunk lid
- WTB rims w/ tire
- wtb: steering wheel
- >>>WTB hondata S100 chip for NA<<<
- NEED!!! stock EG/EK black (non-painted) sideskirts!!!!
- WTB: RC 310cc injectors,
- WTB: Integra Rear Interior Panels. Socal
- WTB: gsr throttle body
- WTB: B16 turbo log mani
- WANTED: Cruise control setup for 2000 ex,manual with b16. help
- WTB CRX roof panel
- WTB: h22S heat shield
- WTB ASAP I NEED A DISTRIBUTER CHICAGO AREA
- WTB: 02-05 Civic Si or RSX-S Throttle Body with sensors
- WTT Vtec head and cash for an aem ems 92-95 OBD1
- WTB Integra Ls Hydro Transmission
- WTB: 1994-1997 Accord Ex E-brake cables
- WTB: AEM CAI for eg
- WTB 97-01 CRV cluster auto or manual
- WTB: H22A longblock
- dc2 driver rear caliper ::: pass. rear hub & caliper-bracket
- WTB: Tranny
- want to buy si power steering pump
- Mugen Or Spoon Steering wheel
- 92 95 Civic audio Cansole
- wtb 4x114 dounuts or accord rims ex of a 95 accord
- WTB: 1996-2001 Integra SRS Reel
- Fuel Pressure Regulator civic integra
- Ft: 92 95 civic Hatch Cover
- wtb EG/EK/Teg rear bumpstops
- WTT D16y7 head
- WTB: D16Y8 (Complete Motor)
- WTB: EG cluster with tach
- WTB: B16 Oil Pan
- WTB: 90-91 in dash/cabin wiring harness for EF civic
- WTB: 94-01 Integra heater control also looking for 1 GSR fat five
- WTB: 99-00 front tranny mount
- WTB: STOCK EG headlights
- wtb- front eg torque mounts
- WTB: 92 -95 civc cluster w/ tach ( manual prefered) miles not important
- WTB:test pipe for 97 civic 2.5"
- WTB: SI CLUSTER!!
- WTB: 94-97 integra fog switch ,cheers
- wtb: RANE SERATO FOR MAC
- i need the mirror switch plug!!!
- WTB: Cusco Strut Bar
- gsr greddy sp exhaust!
- OEM GSR or ITR Rods
- WTB: RC 550cc Injectors (High Impedance)
- WTB: 1-wire knock sensor connector plug
- WTB: FRONT COILOVER SETUP (96-00 civic)...<teins, omni, skunk2, apexi..etc>
- WTB: Honda obd2b ecu pins and two 2-wire iacv connector
- need 1 slim fan for radiator asap thanx
- WTB: SI-R REAR BUMPER (EK HATCH) NEED ASAP!!!
- CAN SOME CARFAX FOR ME thanks
- WTB: 92-95 hatchback rear glass
- ~~~*** LOOKING FOR GSR W/ LSD ***~~~~
- Need Eg
- Possibly in the market for a b16 block
- WTB: One GM ITR Rim
- WTB: B series vtec valve cover
- wtb: EG CLOCK!
- WTB: 4 or 6 puck clutch and lightweight fly for D-series ASAP!!!!
- WTB 89 crx si driver side seatbelt
- Used Dc Header?
- WTB: 99-00 Civic Front end!!
- SELL ME your old suspension!!
- WTB HX wheels
- WTB - obd1 o2 sensor plug from engine harness side, not o2 sensor side.
- WTB: 99-00 civic coupe tails, 96-00 civic spoiler, neuspeed front strut bar
- WTB Del Sol seats !@#$%^&&
