View Full Version : Want to Buy
- WTB EG SI HATCH
- Mugen Gen two wing
- WTB: Integra Optional Side Skirts and Rear Valences, and LS/GSR Wing
- Want to buy 3 fuel rail bolts studs b/d series /maybe others? m6x1.00x22mm bolts
- WTB P28 A50
- WTB OEM 3030 prop valve for VX, CX etc.
- WTB: Integra ABS Delete Brake Lines/ Prop Valve
- WTB.. A p28 ecm for 92 civic si stock
- WTB: 2000 Civic Coilovers or Koni
- EG Coupe/Hatch side skirts
- wtb Dual 10an Catch Can
- WTB 94-95 Integra Left Door Handle BG33P
- WTB: 92-95 eg ignition switch wiring only
- Wtb PR4 obd1 ecu
- Wtb bseries/ef swap parts
- WTB: H22 H23A VTEC Parts
- B16 82mm 9:1 forged pistons
- WTB: Sleeved B Series bare block used
- WTB: oem ep3 muffler / axleback WA
- D16 Cable Trans 4.7 final drive
- 93 Honda Del Sol S
- WTB: 96-00 Coupe/Hatchback driver side manual window regulator
- WTB: 15x8 Wheels
- 98 civic b20 motor ac and tran Torque Bracket need
- WTB INTEGRA COLD AIR OR SHORT RAM INTAKE
- WTB: 96-98 Civic ROUND Fog Lights
- WTB 99-00 EM1/SI GRILLE AND FRONT LIP
- WTB: 15 inch ITR wheels
- LH quarter mount tail light and LH front inner fender needed
- [WTB] BB1 Prelude Front Brake Calipers
- b20 vented valve cover
- WTB: EG CLUSTER
- WTB Defi (dssc)
- WTB Precision 6262 T3
- WTB: Takata/Willans Harness and Mugen Hub rsx
- WTB: EM1 rear lip
- WTB: Stock '92-93 GSR 4th gear pair.
- WTB: Election Blue Bumper + Trunk + Fender
- WTB: Coilovers Honda Civic si
- WTB: Hondata S300 v3 or with boost option
- WTB obd2 GSR inner and outer upper timing covers
- WTB: D16z6 Bisimoto cam gear
- wtb: light gray ek air bag delete tray
- WTB AEM Fuel Rail & Regulator and 1000cc injectors
- Wtb H2D kit
- Wtb USDM ITR intake manifold
- WTB: EG dash board
- WTB 94/95 DC windshield wiper switch
- WTB TIAL 44MM Wastegate and TIAL Blow Off Valve
- 98 spec itr header lower shield or equivalent
- D17 complete OEM intake manifold
- WTB: D16 head for boost
- Need a 98 Honda Civic cluster
- WTB: Oem B series spark plug cover
- Anybody looking for a job? Need at least 3 people.
- WTB: Engine mount kit for 88 Civic - HYDRO B SERIES
- WTB TUCKED ENGINE HARNESSOR CONNECTORS
- Wtb 96 integra mugen or charge speed replica side skirts or any that kids if style
- WTB GSR B18C1 or B18C5 Vtec Head
- WTB B18 Vtec Head
- WTB: AEBS B16 Intake Manifold
- GSR 4th gear
- Mishimoto thermostatic sandwich plate
- WTB: Sunroof Visor for 96-00 Civic
- Looking For OEM Black Leather GSR seats
- WTB: 01 Integra Oil Pan
- WTB: B16a2 transmission (S4C or Y21)
- Toda Cam Gear Allen Bolt replacement
- WTB: GSR Parts
- WTB: Spoon SW388 16x 5x114.3
- WTB GSR Oil Pan
- Wtb usdm itr intake manifold in good condition
- WTB: 4th Gen Prelude OEM Hood Prop
- Wtb 88/91 crx sunroof panel
- WTB: 94-95 INTEGRA MANUAL INTERIOR CABIN HARNESS DC2
- OEM ITR Carbon Faux Wire Cover
- WTB: OBD1 Engine Harness
- WTB: P54 AC Bracket
- Wtb b18 block Southern IN will drive
- WTB: P28-A51 or P28-L51 ECU
- Wtb exhaust for ek hatch
- WTB ITR seats and door panels
- WTB: OEM Integra GSR exhaust (axle back) 94-97
- WTB clean jdm EF9 front bumper, filler and bumper lights
- WTB: 99-00 Civic passenger front fender
- WTB 96-00 coupe/hatch oem window visors
- WTB: d16z6 Crank Pulley, Gear, Bolt, and 90-93 Integra Non ABS Brake Booster
- WTB: Tial wastegate
- wtb integra type R rear ABS sensors
- Needed b series misc vtec head parts
- WTB: Any CLEAN 92-96 Honda Prelude
- WTB: 98-01 Integra Front Marker Light Brackets
- Single Mugen MR5 15"
- Needed a power chamber style intake plastic or carbon
- ITR P/S Bracket
- OEM Helical LSD For A B-Series GSR
- WTB: Inlinepro Manifold
- WTB: 1999-2000 Civic Bumper
- WTB hondata s300
- Honda Civic EF - Window Molding Asembly
- WTB 99-00 Ek Body parts
- WTB oem manual shifter for 96 civic
- WTB: 96-00 side skirts
- 91 Prelude door
- WTB LS/B20 Complete head
- WTB: Ray's TE37 wheels of several sizes and configurations
- WTB: ITR or GSR FINAL DRIVE
- WTB 92-95 Civic Si muffler
- WTB: B18A1 Coolant Pipe 19505-PR4-A00
- WTB late 80s early 90s SHELL
- WTB (NY) - EK subframe brace and tie bar // rear caliper // stainless brake lines
- Wtb em1 ebp oem rear lip
- EBP EM1 Passenger side Fender, Bumper and Hood
- WTB-Acura tl flywheel bolts
- WTB-ITR CAMS plus retainers/springs
- B Series VTEC Valve Cover
- WTB: Insight with engine swap
- WTB 90-91 CRX SIR
- WTB RBC intake manifold and other stock components
- WTB: DB8 ITR Sedan Bottom Rear Cushion
- WTB 92-95 or 99-00 si
- WTB: Toda header for b-series
- 92-95 eg coupe parts tan color
- wtb d16 piston oil rings
- 1992-2002 F series adjustable Cam Gears
- WTB obd2 del sol under dash harness
- WTB: 94-97 RS Proportioning Valve Non-ABS
- Rear Bottom SEDAN GSR Confetti seats - Dark Blue/Black
- Harness 98 civic Ex
- Wtb b-series ek mounts
- WTB: 1988-1991 CRX SI OEM Wheels
- wtb: ep3 front bumper
- Accord V6 3.0L VTEC 1998 coupe
- WTB: 98+ Integra Rear Bumper; Frost White (SoCal)
- WTB:4040 Non ABS prop valve
- Looking for a B16 Head
- CA::: WTB::: CRV P7H or Del-Sol P54 A/C Bracket
- WTB quality complete turbo set up b18c 81.5mm bore!!
- WTB 88-91 Cargo Box/Tray
- WTB d16z6 motor
- WTB: R OEM Side Skirt for 99 Civic
- F22, SOHC adjustable gear
- WTB: Pigtail connectors for Cooling fan & A/C
- WTB Integra gsr
- WTB: Side Skirts for 99 Civic coupe
- WTB: 06+ TSX A-spec LEFT(or both) foglight garnish/bezels
- WTB stock ITR springs
- WTT: Current Skunk2 Pro Series GSR Intake in exchange for Skunk2 Gen1 version
- WTB: Eg Gathers Map Light Roof Tweeters!!!
- dss 5.9 or equivalent axles for b18c
- WTB K swapped Integra..Clean type s or tsx
- Looking for a quality aftermartket JDM ITR header.
- Wtb JDM ITR Header
- WTB: ASR 32 mm Rear Hollow Bar
- WTB: 92-95 Civic blue audio console
- WTB: Catback Exhaust
- Wtb cold air intake y7!
- WTB: Civic Front Bumper Bolts!
- WTB : Apexi W2 Catback Exchaust
- WTB: 5x114.3 Weds wheels
- 1996 Civic Sedan Body Style Stock Suspension
- WTB/WTT JRSC B18C5 intake manifold for (JRSC) B18C1 intake
- AEBS Intake Manifold for GSR Engine B18C1/B18C4
- WTB: EM1 trunk spoiler, B series VTEC turbo cams, Hondata S300
- DPFI to MPFI harness
- Integra Brake Lines ABS delete
- wtb: Cheap d series parts
- Wtb - oem 99-00 si lip & flamenco black pearl nh592p outer driverside for handle
- WTB: Accord Coupe CD7 in GA or HI
- WTB: OBD 1 P72 ECU
- WTB: 1992 - 1993 Civic si Cabin wire harness and ecu harness to fusebox and headlight
- Wtb eibach ground control springs
- wtb: clean built car around or near nyc
- Want to buy hasport EFKHCL EF K SERIES cable conversion lever kit
- Koni Yellow Shocks - Ground Control Integra/Civic DC/EG
- WTB: b16 cable LSD / Full trans
- WTB: GReddy Turbo CARB Sticker for Integra
- WTB: Lock set with key 1998 Civic coupe
- MD WTB: Built D16A6 parts
- WTB del sol parts
- cylinder head cover bolt needed!!
- WTB CF Invader style hood USDM INTEGRA
- Looking for a fmu
- WTB: Vortech Supercharger for B-Series
- Stock Hatch Spoiler
- 96-98 jdm sir front bumper
- WTB Big H EDM grill 96-98 Civic
- WTB: Looking for 90-91 integra GS center caps and charcoal seats DA
- Looking For a K Series Intake and Header
- LF Exhaust/Muffler
- WTB: OBD1 P28 or P30 ECU
- Skunk2 Tuner2 cams and valve trains
- WTB: Auto to manual transmission mount
- Catch can set up, EG
- WTB: IAT plug/pigtail
- Wtb - stock Obd1 p30 ECU and obd2b to obd1 jumper harness
- WTB: Automatic transmission parts
- P72 gsr Obd2b 00-01 ecu
- WTB - 06-11 Civic Si Flashpro
- DC2 power steering lines
- WTB: Prelude H22 JRSC Kit
- WTB - Cusco DC2 GT Wing
- ISO: Spoon Ek Strut Bar (s) and B series Plug cover
- Wtb 99 civic window visors
- Wtb ek bezel cluster gauge mount
- WTB : Real Racing R2
- B-Series Power Steering Hose Valve Cover Bracket
- WTB: CRX Front sway bar brackets and gas tank straps (PA)
- EM1 engine harness
- EF 5 LUG
- K20 gearbox cases
- WTB: PLM H2B Header
- JDM k20 ecu with immobilizer
- Wtb b16 dizzy
- WTB JDM ITR cooling plate
- WTB: 88-91 CRX Rear Sway Bar
- WTB: 99 CRV AC compressor and Condensor
- WTB: 8th Gen Si aftermarket parts
- B series Buddy Club Cam Gears
- WTB: CTR cams
- Hondata s300
- WTB::: EK Axle Back Exhaust (CA)
- WTB: eg sir floor mats + interior pieces
- WTB: 94-95 R134a A/C Compressor
- wtb: GM itr center caps
- WTB DA integra sunroof, wheels, powdercoated valve cover
- WTB Spoon SW388 - 5x114.3
- H22 shifter with cables
- WTB: CSS or Sleeved B-Series Block
- WTB::: EK/ DC Honda Access Roof Console / Sunglasses holder (CA)
- WTB: civic si exhaust
- WTB Neptune demon ECU
- WTB: 99-00 EK Hatch Tailgate Harness
- WTB: EK 5 speed conversion
- looking for 97 driver side door lock assembly
- WTB: JDM ITR Header and cat
- Wanted to buy b16 final drive 4.4 ring and pinion
- WTB: Nobori Flags / Banners.
- WTB: ITR Armrest 00-0083
- 99-00 civic si/ex gauge cluster wiring harness
- Looking for OBD1 to OBD2 wire conversions
- WTB JDM ITR 98+ srs deploy module
- WTB: ED/EF Civic Cooling Fan Pigtails
- Wanted: Kseries Fuel Rail/Ktuned TB/3"Ktuned turndown
- Looking for the retaining clips for the cargo cover 88-95 Civic Hatch
- WTB: A D16Z1 OR D15Z1 LONG BLOCK local .L.I NY
- Competition clutch stage 2 disc
- WTB: Cali approved Integra R catalytic converter
- WTB : Integra parts 94-01 Interior / Exterior
- PNW WTB 90-93 Integra 2dr 5spd
