View Full Version : Want to Buy
- wtb hondata s300 in ecu
- WTB 2000 accord headlights
- wtb eg hood
- WTB Eibach 2010 Tickets!!!
- NY --> WTB --> 93-95 Del Sol Si Parts
- WTB: EG or DC Shell
- WTB:99 CIVIC HATCH CARGO COVER
- WTB: 90 CRX PASSENGER FRONT FENDER
- WTB: P72 PS bracket and DelSol Vtec AC bracket
- WTB: b20 motor mount forks (left+right)
- WTB: CRX parts
- WTB: 98 prelude SH crankshaft & rods
- wtb: DC/EG/delsol oem front upper control arms
- WTB 92-95 civic ex parts
- WTB ECU
- wtb: stock ek door panels & others
- WTB: 97+ Prelude Injectors
- ///////////WTB REAL DEAL SPOON SPORTS EG6 FRONT LIP CARBON FIBER
- WTB OEM CIVIC EM1 SI GRILL 2000
- WTB: 1 Kumho AST tire 205/50/15
- WTB: H22 Skunk 2 tuner 2 or Blox B camshafts
- wtb: gsr head studs
- WTB: ITR b-pipe
- WTB ek d series mounts
- WTB: Rear integra body piece
- wtb p30 b16 manifold....
- WTB: d-series motor
- Wtb: 75mm pg6 piston set
- WTB: 94-97 DC Si-VTEC Turn Signals Corner Lights
- WTB: AP1 STEERING WHEEL <<<<<<<<<<<<<
- Wtb: civic 96-00 Rear stock camber kit
- h22a valves/good head/cams
- WTB: 2003 mitsubishi evo, or 04-05 STi 13k
- WBT CIVIC EXHUAST FOR 06+
- in need of parts for my Em1 Si Socal LA area
- IDLE AIR CONTROL VALVE!!!!!
- WTB: h22 hasport mounts
- wtt: b16 jg manifold for gsr jg
- WTB: Mugen H22 Downpipe
- wtb BC spec2 silencer
- skinny tires!!! 24-3.5-15
- wtb starter mounting bolts
- WTB: Silver 99-00 Type R Grille!
- wtb short ram with bpi
- WTB: ITR throttle cable bracket
- WTB WIRE HARNESS, DOOR (DRIVER SIDE)
- WTB: ESM 011's*Work Equip 03 reps*15x7 (any color) lmk what you got
- WTB S2000 seats
- wtb: d series turbo manifold and 660 injectors
- WTB: 1 ls eagle rod
- WTB: JL Subs (WASHINGTON AREA ONLY)
- FS: Precision 525cc injectors (high impedance, no resistor box needed)
- WTB OBD2a to OBD2 b conversion harness
- WTB: 94-01 integra Air conditioning parts
- WTB: 92-95 Hatch Taillights / passenger or both sides
- WTB 96 accord parts
- WTB: D15b7 Parts
- WTB: GSR Final Drive
- WTB: Del Sol SiR Steering Wheel
- WTB: Personal Box & other ITR cf parts
- WTB: 1 single p30 piston
- ctr headlights.. si grill.. oem si lip
- WTB GSR HONDATA IM GASKET ASAP !!!
- WTB: 96 OBD2 P13 Ecu
- WTB Progress sway for Prelude (97-01)
- wtb Domani Front End
- WTB: 96-00 Civic coupe
- wtb: d15 iat sensor
- wtb: d15 iac sensor
- wtb pr3 complete p/s bracket
- WTB D16z6 Motor and Trans in or near Wisconsin
- wtb: 06 rsx-s speed sensor and connector, dc2 drivers door. ect switch connector
- new tranny!
- mr5 eg9 seats all
- WTB: B-Series VTEC Valve Cover
- WTB: D Series Parts, Rods, Studs, Pistons
- WTB: catch can with block fittings and lines
- D-series motor
- i need a p54 ac bracket asap
- WTB: D series Si Cable Trans
- WTB: Civic Wagon door
- NEED h22a4 aluminum oil pan
- srt8 cut 4speed
- wtb 92-95 eg civic abs pump
- wtb good 205 70 15 tires or 5x114 wheels with good tires
- Black Eg Hatch Dash, and Door panels
- SoCal WTB:EE2 or ef parts
- WTB: B-Series Transmission HYDRO
- WTB: Honda S2000, S2K, 12k cash in hand!
- WTB: 1998 4 dr integra passenger window.
- WTB: 04 05 or 06 Acura TL Rims OEM
- wtb: p13 usdm ecu + injectors
- WTB:3 post driver side motor mount..ASAP
- wtb: extended wheel studs
- wtb: d15b7 rod and piston
- WTB - Cable to Hydro conversion
- I need a D17a1 ASAP!
- D16Z6 Timing Cover
- WTB:obd1 h22 vetec spool solinoid,idle speed controller
- WTB: obd1 z6 swap
- WTB: oem honda spark plug wires
- WTB: Dyno
- Holset turbo
- WTB: Strut King Gas Pedal for EP3
- Type-R cams
- Energy master bushing set EG
- WTB:STOCK A/T TRANNY MOUNT AND REAR T BRACKET
- WTB: Everything for ABS removal in 95 Integra
- WTB: Black cloth or rsx seats
- WTB: GSR 96-01 OBD2 Engine Harness
- WTB: 99-00 si cluster..
- WTB hondata s300 installed or not/will trade chipped p28
- 90-91 USDM Civic Si: Mint parts Needed
- WTB a CLEAN!! gsr,ek, or eg (hatches only!) shell
- WTB eg6 rear plastics and seats!
- WTB: cluster bezel for ek with ap2 cluster
- WTB-Splash hub for ek/ap1/dc5
- WTB: B series torque mount for eg
- TN:WTB: 97-01 Prelude Front Bumper
- WTB: Catback or Axleback/ 2piece CAI + more
- obd0 to 0bd1 conversion
- Injector dynamics top hats
- Catalytic converter 99-00 si
- WTB: OEM Prelude SH/Honda Civic Si Shift Knob
- WTB: USED D16z6 N/A Stage-2 Camshaft
- WTB: 98+ integra front bumper and lights
- WTB:EBP Hood, Front Bumper, and Front Lip
- wtb leather front seats,3" muffler or resonator,manual boost controller,and 15s or16s
- WTB: Civic RT4wd Wagovan transmission and transfer case parts
- WTB: CLEAN hubcaps
- WTB: WI: B16/17/18 Vtec Head Bolts/Studs
- wtb trans and injectors
- wtb:d16a6 d15b1/2 civic/crx lower engine timing cover
- WTB oem Honda 4 lug wheels
- WTB: AP1 CUSCO 6pt cage w/harness bar ! J's rear diffuser !
- WTB Civic/Integra Sedan NJ
- h22a transmission lsd
- WTB:96-98 and 99-00 CIVIC Coupe/Sedan parts
- WTB:6 SIX 370-450cc injectors.
- WTB 99-00 si cluster
- WTB d16y8 motor or block
- WTB: B series Engine mounts
- WTB: Vison Type DC mirrors EG
- WTB: 4.7frinal drive an integra type-r LSD
- Dkahn18s WTB thread
- WTB::::: External Fuel Pump ::::::::WTB
- WTB: Cheap Honda! 3,000 or less!! (CALI)
- WTB!!! B18 ls OBD1 Harness
- WTB: Skunk2 Intake Manifold for H22A
- WTB: 02 accord EX-L drivers seat
- WTB:
- 98-01 Integra Tail Lights
- WTB: Clutchmasters FX300 or FX400 B-series
- WTB: 16x8 +20 Rota grid offroad
- wtb d16 pistons and for stock or forged
- wtb extended wheel studs
- WTB: Gunmetal ITR wheels
- WTB: Skunk2 pro series intake manifold GSR
- WTB sunroof glass for a 95 civic coupe
- wtb: accord top hats for 95 LX 4 cylinder
- WTB 91 Accord Parts
- WTB b series block to transmission braces/supports
- WTB 4G Prelude motor mounts
- WTB b series trany
- WTB: NOKIA YELLOW LIGHTS
- WTB: PA/NJ/MD Acura RSX type S 8k cash in hand
- wtb Coilover system for a ek.
- WTB 1999 Prelude automatic transmission
- WTB 96+ civic motor mounts.
- WTB..JOJO front end
- WTT Type R skirt pad with girl type titty
- WTB: SLicks and maybe a roof rack
- WTB: 94-97 Accord Hood Bra/Hood Deflector/Bug Deflector/Front PLastic
- WTB: EK B-series trans mount bracket
- wtb db8 stuff
- WTB: GSR crankshaft
- wtb ostrich 2 emulator (NOW)
- WTB: oem or comptech Type R lip
- wtb: ek parts=rear t si bracket, coilovers+more
- WTB: D16y8 intake Mani
- WTB HASPORT AXLES H22 EK..
- WTB: 97-01 prelude engine wiring harness & 96-00 civic engine wiring harness & parts
- ** WTB: H22 TYPE-S OS .25mm PISTONS (BNIB)****
- WTB COILOVERS for a mk3 supra!!!!!!
- WTB: 06-09 Civic Driver Side Mirror (Coupe)
- WTB Lexus gs300 98-02 SoCal!!
- WTB GSR Block and ITR Crank
- WTB type R throttlebody
- WTB Skunk2 intake manifold and cam gears and throttle body and cams
- WTB: ITR/CTR 5 Lug Rims
- WTB AP1 cluster plugs *SoCal*
- WTB ECU
- WTB: Ls seats, steering wheel, Honda Wheels
- DEL SOL VTEC or CRV AC BRACKET
- Wtb Type R side skirts!
- wtb rmf drag header
- WTB Fuel Pressure Regulator FPR for GSR b18
- WTB: 4 Door...
- WTB: b18c motor parts
- WTB: 2000 Civic SI Front & Rear Stock Springs
- WTB: ek p/side door speaker cover
- WTB P13 ECU
- WTB:Integra driver side seat belt buckle for my recaro seat
- WTB: Leather Seats (TAN/TAUPE)
- WTB: Civic EK 97-00 coupe/hatch
- wtb civic ek 96-00 rear lower tie bar
- WTB 1 STARK III Centercap
- Trade Your 4dr Civic 4 My Bike???
- DC2 Integra Optional Side (Passenger side only)
- WTB: Vision DC mirrors
- WTB: ek hatch thin side moldings and rear fog
- wtb civic springs
- WTB: B-series b!tch pin
- WTB 88-89 civic hatchback motor mounts
- WTB USDM ITR FRONT SEATS
- WTB: Civic 92-95 Sedan Interior Door Handle Driver Side
- wtb hondata and a wideband
- wtb civic climate control
- WTB: ATI STEEL Dampener GSR
- wtb: integra parts
- WTB: Integra or Civic hatch shell((Aiken/Augusta area))
- type-r axle back or equivelent
- wtb: gsr victor x
- WTB: polished GsR blades
- WTB WTT: Brand New B20 LS Eagle Rods & Hondata S200 FULL option for Hondata S300
- WTB > Atlanta, GA. > 98 Accord 5spd Conversion parts
- WTB: AEM Short ram intake for 97-01 GSR
- WTB: CRX
- WTB; 92+ Bseries Clutch
- wtb aftermarket muffler and oem bra for eg coupe
- wtb bare h22 head
- wtb: Obd1 distributor
- wtb: amber bumper lights 94-97 teg
- WTB: 1600cc injectors
- WTB: da b18 ls automatic interior wire loom
- WTB: 94-01 Front Windshield Passenger side Molding
- WTB Advan SA3R 16's
- WTB: Complete d-serie turbokit
- WTB: 99-00 Civic Si parts *EM1*
- WTB: Turbo Parts, PR4 w/ Hondata, Tranny, more misc DA teg parts
- wtb b16a cable trans
- WTT/WTB GSR BLOX CAMS & VALVETRAIN/ECU
- WTB DA brake master cylinder
- WTT: MY IPOD 40GB
- full amber corner lights for late spec ef2 civic
- WTB ITR Wing!!!!
- WTB: Sell me your JDM Rims!!! must be 16" and 4x100 only!!!
- DA traction bar
- OBD2 CFK Sensor (GSR)
