View Full Version : Want to Buy
- WTB:OBD1 to OBD2A Harness Adapter
- WTB: JDM P30
- parts from boosting b18c4 in the UK
- Wtb...oem sir bumpers
- WTB XXR rims for 5th gen honda prelude
- WTB: lexan Windows EJ1 94 coupe
- WTB: OEM Light grey or CF airbag delete tray 96-00 Civic
- **WTB** EK sunroof Visor**
- al.willing to travel, WTB: Hatch prefer ek other models ok,looking for one swapped
- NC: WTB 98-01 Integra front and rear bumper
- WTB Eagle rod B18A/B, B18B1 Crank
- WTB: Borg Warner
- EG subframe, 94+ Teg Black Dash and 94+ Teg rear trailing arm w/abs
- WTB: 96-00 Civic EX 5 sp wiring harness
- WTB turbo kit
- **WTB: Replica BYS lip**
- WTB pro street manifold s2000
- WTB K20 Complete Swap
- WTB: Velocity Stack
- wtb 99-00 parts
- WTB 92-95 HB Headliner and Glovebox
- wtb driver motor mount bracket for ek
- WTB: Door Handle - 1994-2001 Integra Passenger's Side Exterior (must fit 2dr/Coupe)
- WTB:EF DX harness converted to MPFI
- WTB Em1 ebrake cables
- 96-00 ek door speaker covers.
- wtb center caps
- WTB: After market exhaust and cat for '98 GSR
- WTB: Regamaster Center Caps
- wtt supercharged 89 f150 lifted on 38s. fresh motor n trans
- WTB 89 CRX DX Main Harness ASAP
- WTB 98 CIVIC COUPE PARTS
- brian crower N/A 3 cams for bseries and gsr block for sale
- WTB:Clover Green Hood for Integra in Socal
- WTB: OEM ITR Vavles (low miles, BNIB,), OEM ITR Pistons + rings (must be BNIB and OS)
- WANTED: Low Comp/Turbo Pistons for MY GSR...
- WTB...EG optional audio console and other parts..
- HOndata S200 with or without ECU
- WTB Gauges!! (wideband, oil pres., boost)
- WTB Tial 38mm wastegate or 39mm PRecision
- WTB CB7 EDM Thin Side Molding
- wtb: 99 Ek interior
- WTB:b18c1 aftermarked intake mani. fuel rail. adjustabe cam gears
- W.T.B decals and stickers
- WTB D16Z6 Swap, Central Ohio, Looking for one cheap
- WTB 96-00 Y8 throttle body
- Zc oil cooler
- WTB: OBD1 GSR IACV + other stuff
- wtb 1997 del sol manifold back exhaust
- WTB: NC- ARP pressure plate/ flywheel studs
- WTb: skunk2 gsr mani, ITR TB,
- WTB: B-Series GSR Drivers Side Axle
- w.t.b b16a ac compressor
- WTB: Kics R40 Neo Chrome Lug Nuts (Your Extra Ones)
- WTB: exhaust valve for D16A6 head, OEM size, titanium perferred
- w.t.b uk eg/eh civic trunk licence plate holder
- WTB D16Z6 Alternator IN CENTRAL OHIO TODAY!
- wtb: 1992-95 A/C compressor
- GSR oem oil cooler part NEED ASAP
- WTB : OEM EF8, EF9 USDM Corners
- WTB: Hondata S300
- wtb: ACT or CM pressure plate
- WTB/H22a JDM engine wire harness good condision.
- Need 91 civic sedan body parts
- WTB: 99-00 Civic SI Wire Harness
- WTB 00 TYPE R TIMING BELT COVERS
- WTB: need B series act streetlite flywheel and clutch kit
- WTB::::Paradise Blue Green Pearl Panels BG-33P
- anyone got a window
- WTB : Aftermarket Intake Manifold (05' 6spd TSX)
- wtt arp headstuds, b16 for gsr
- WTB: 92 Teg Driver side Mount
- EF8 & EF9 Vision Mirror, block off plate etc
- WTB: MacBook Pro Charger, Apple 85W MagSafe Power Adapter (15" MacBook Pro)
- WTB: 2001 Integra (NHBP) Front bumper, hood, or fenders
- WTB: Tires 215/45/16
- wtb b series power steering brackets and pump
- wtb-82mm forged pistons and rods for gsr
- WTB: 6 1/2 speakers
- WTB: DC2R Front SPLITTER.
- WTB:CDM rear seats/civic type r fronts
- wtb: nrg engine damper for integra
- WTB S2000 Cluster with VSS convertor OR 1.6 EL cluster with pigtails
- WTB EG parts...
- WTB: B16 or GSR Sleeved Block
- ek hasport mounts
- WTB a H22a engine wire harness to a 93 civic
- WTB: VSS For 94-01 Integra 5 speed
- wtb eg dr fender w/o molding holes
- EM1 Si loom b16a2
- WTB B16a2 parts!!!
- WTB: 99-00 Civic Si EM1 B16A2 Parts!
- WTB- Integra Radio Tray
- WTB: I.A.C. Valve D16y8
- WTB Greddy SMI Control Unit
- WTB: Intake arm and velocity stack
- WTB: 99-00 Civic si Hood Bra
- obd2 civic ex harness
- WTB: B SERIES OBD1 STARTER
- WTB: 92-95 civic top hats
- WTB: CF Whale P*nis
- wtb: b-series aem fuel, aem adj fpr
- WTB: '92 to '00 Civic with k20 - note: i'm from Europe
- WTB: SRS Cable Reel for 95 Civic EX w/Cruise Control
- wtb 92-95 eg civic abs pump
- WTB: OEM 92-95 civic front lip w/ hardware
- WTB: 92-95 Civic Ignition Key/switch 5spd!! asap
- wtb: aem, eagle fuel rail , obx lsd 9200, 750cc injectors d16z6
- WTB: ECU Pins
- WTB: SOCAL!!! ONLY---> JDM ITR FRONT PARTS!!!
- WTB: gsr parts
- WTB: Skunk2 or VictorX Intake Mani For B18c
- Looking for EG8/9 Ferio SIR parts
- WTB: Factory DC2 GSR suspension
- WTB: 96-00 CIVIC SEDAN FRONT DRIVERS DOOR HARNESS PLUGS w/wires
- WTB: 94-01 integra skunk2 coilover
- OEM 92-95 Cvic coupe/4door Taillights
- WTB: 92-95 Prelude Vtec MAP Sensor
- WTB jdm ef9 front end
- WTB: GSR speedo
- WTB 05 Rsx type s exhaust mani and cat
- WTB: D16a6 distributor
- Wtb: wheels
- WTB:...Tokico Illumina shock (front)
- WTB: 96-00 civic floor mats
- milano red trunk with spoiler for 99-00 civic
- WTB: D15b7 Engine Mount driver side ( Attached to block )
- WTB....ANYONE WITH 99 00 SI OR GSR BLADES WITH TIRES
- Wanted: 1992-1995 EG Hatchback Shell
- Wtb 97-01 crv ac bracket or 94-97 del sol ac bracket
- H22A knock sensor
- Looking for rolling shell in WA
- wtb: gsr 4-1 or 4-2-1 header, em1 coupe exhaust, em1 ek front camber kit
- WTB: OEM 98-01 Headlights & Turn Signals
- WTB: OEM 99-00 EM1 radio and cruise control switch
- 1993 Honda Civic 4 door Part out
- wtb stock gsr cams
- WTB: 94-up DC teg parts!!! ASAP!!
- WTB: Skunk 2 Pro 2 cams for B-series
- WTB:
- WTB: Uncut OBD1 GSR engine harness
- WTB: b series vtec obd1 distributor
- WTB Del Sol Bra
- WTB: B Series Aftermarket Pressure Plate
- WTB: Power Steering Reservoir Bracket
- WTB MUGEN WING
- WTB: NC- B series flywheel
- [MD] things for eg hatch/coupe, turbo parts
- WTB: USDM or JDM ITR Cams
- wtb: D series Header
- wtb: 94-97 grey accord floor mats
- WTB: BLACK JDM DC2 RECAROS *MINT*
- wtb: MINT TD-42U DIZZY oem only
- WTT NEW EAGLE "ESP"H-BEAM RODS b18/b20 ls
- WTB: MPFI swap
- **WTB: EK4 Dark Gray Power folding Mirror Switch/ EK Bumper Pole Switch**
- wtb: neptune tunerview
- wtb apexi ws axle back
- WTB: DC2 Suspension & K20A3 swap
- Too Many Parts To List
- wtb: ep3 after market axleback exhaust
- arp headstuds
- WTB: wiper switch 96-00 civic
- WTB bucket seat bride or sparco
- I need a ac compressor for em2
- WTB:: Accord 2009 LX SEDAN FRONT BUMPER! SILVER
- WTB:Full Header back exhaust 92-95 Honda Civic Hatch
- WTB: Oil Catch Can
- looking for 98 + integra headlights
- WTB: integra headlight jumper
- wtb d16z6 parts
- WTB!!! ALL MOTOR BUILT BLOCK
- D series tranny
- WTB: Old Crx or Civic
- wtb tial 44mm wastegate and 50mm bov
- WTB: honda OEM Brand new 92-95 A/C compressor Sanden
- WTB: SPOON RECLINABLE SEATS (PAIR)
- WTB: B-series
- Honda ECU OBD1
- skunk2 cams
- WTB: MD inspection for beater civic
- wtb 96-00 civic coupe parts
- WTB: 96-00 Civic DX, LX, front struts/shocks
- WTB:96-98 Civic Silver front bumper & passenger side fender
- WTB: '97-01 Prelude center caps and mud guards
- WTB: 96-98 CIVIC OEM RADIO & POCKET ASIDE TO THE RADIO
- wtb 99 si rear trans bracket manual
- WTB b series vtech cams
- WTB: TN: EK Headlights, Tails, Seats, etc.
- WTB: 99-00 Ek Civic Fender Pass Silver
- WTB eg hatch
- acura RL calipers and bracket
- WTB: Spoon Shift KNOB
- wtb denji headlights
- want to trade for s2k cluster setup in dc integra
- WTB: stage 1 clutch kits for 92-93 gsr da integra
- LUKIN FOR ITR OR CTR CAMS!!!
- wtb p72 obd2
- WTB: 98-up GSR ABS prop valve/dist block
- WTB: 00' d16y8 exhaust manifold
- WTB: 01 accord front seat belt
- WTB: B Series Hydraulic Transmission
- WTB: Oem navigation system for 2008 civic
- WTB: eg cat converter, rear lcas, and sway bar
- WTB EK HATCH!
- 4 Blox extended wheel studs
- obd1 manual ecu
- WTB Motegi FF7 19'' Glossy Black
- wtb 90 - 91 da rear tail light
- wiper switch for 92-95 civic
- WTB: Integra Type R Cluster
- WTB: WI, 99-00 SI IACV, Vtec Solenoid, OBD-II B-Series Throttle Body
- b16 fuel rail/ fpr setup
- 98+integra head lights and 4dr teg parts
- WTB: ITR wheels 4x114.3
- WTB : Skunk2 Pro Series Stage 2 B16/B18C
- WTB: Integra/Rsx Type R 4th gear
- WTB: Shocks/Struts for my 00 Civic si (EM1)
- WTB: h22 Obd2 engine harness and 88-91 ef engine harness
- WTB: EK9 parts and EM1 rear lip (steering wheel, pedals, etc.)
- WTB: 96 97 del sol b16a2 obd2a ecu
- wtb some parts
- WTB Nardi deep corn 350mm wheel and hub
- wtb b16 spark plugs socal
- wtb: carbon fiber power chamber intake
- need p28 ecu
- want to buy 03-06 Honda Accord EX or EXL manual
- WTB QSD H2B Kit
- WTB: 3.0 CL Cold Air Intake
- WTB:WA-Coilovers for a 98 civic coupe
- WTB hydro gsr trans`
- D16Z6 Transmission
- D16Z6 Alternator
- WTB B18 cable trans
- WTB:M/T ET STREET 225/50/15 EG CF FENDERS
- WTB: Hondata s300 with installed ECU
- WTB: driverside A pillar piece 99 integra
- WTB: Buddy Club N+ dampening Coilovers
- WTB: 99 00 civic parts
- WTB 81.5mm piston rings
- WTB - Sport Compact Car magazines
- WTB,94-00 GSR power steering pump Bracket
- WTB: amber 20% tint scraps
- WTB: GREDDY TURBO KIT 96-00 Civic EX
- Ef Cable Transmission
- WTB: GSR VTEC SOLENOID
- WTB: 96-00 Civic Parts * Steering Column *
- WTB 600cc or bigger injectors and 3bar map
- wtb: EG Navy Blue center console
- wtb b16/itr transmision
