View Full Version : Want to Buy
- Wtb,b18b1 arp headstud,catch can,motor mount,an fitting,mb battle-xxr 527 tons more
- WTB B18B SUPERCHARGER
- tci 500 hp axles hubs
- WTB: nardi horn button
- Need 1 ssk type 31 16x7 penny bronze wheel
- WTB: 1999-2000 Honda Civic Si
- wtb:b16 trans or parts
- WTB: 02-04 RSX Type S engine harness un-cut.
- Wtb vtec solenoid 99 gsr
- Wtb: 95 Honda accord suspension CD5
- WTB: Retrofitted 99-00 Civic Headlights
- WTB H22 head
- WTB oem eg bra or mudflaps
- WTB: DB8 Parts
- WTB:Honda parts
- WTB b series hydro tranny for all motor setup
- WTB:00' 01 WHITE GSR CLEAN TITLE
- WTB: Integra Type R Cylinder head (PR3)
- wtb:***EXOSPEED 3 Piece Front End (CARBON FIBER)
- WTB-Indiana-Midori Green oem or aftermartket grill
- WTB Carbon fiber hood and Carbon fiber trunk!!** DC2 94-01
- wtb LS turbo parts
- WTB PR3-3 head
- Wtb radiator support
- WTB: USDM BLUE AUDIO CONSOLE (Jdm version)
- WTB: ITR Brake Booster
- Finish my b20 swap
- WTB: Timing Balancer Belt Drive Pulley
- WTB: B-Series JUN 3 Cams
- WTB : Ek9 Ctr red carpet
- wtb gsr block
- WTB - 99-00 Civic Si E-Brake cables
- WTB:EG/d series parts
- WTB ASAP : bseries hydro tranny bell housing
- WTB- 93 del sol REAR D.S. quarter panel
- WTB P72 GSR power steering bracket
- WTB: complete auto to manual swap parts 96-00 civic
- Obd1 LS ecu
- WTB: GSR Vtec solenoid, Non-Abs disc brake PROP valve, GSR PS bracket
- WTB: Del Sol rear garnish
- ef/da ST drop forks.
- WTB: Integra db8 rear seats
- Wtb Jrsc pulley
- IAT sensor for 2002 civic
- wtb: bogart pro 4 skinnies asap!!
- WTB: Volk TE37 15x7 +42et 5x114.3
- WTB: LS Crankshaft Pulley !!
- WTB b18b forge piston
- WTB D16z6 timing cover
- WTB: coilovers for EG del sol
- WTB: Toda or SMSP rep header
- wtb: Moates Ostrich 2.0 and hulog
- WTB: Parts for EG
- WTB-B series Hydro clutch release fork!
- need sparco seat sildes
- wtb itegra type r parts
- wtb:74/76mm throttle body!
- WTB: 2 Tial 44mm MVR wastegates
- WTB B18B1 Cincinnati, OH
- WTB: 84.5 mm b series pistons
- WTB: Rear Calipers/Brackets EP3 SIR/SI
- WTB: OEM ITR 4LUG WHEELS
- WTB Si wheel
- WTB GSR 3rd and 4th Gears
- WTB Honda delSol beach towel
- WTB bunch of parts LOOK
- WTB:D15B7 Crankshaft
- WTB: 3 post bracket!
- WTB: Eg Gauge Cluster and Bezel
- So Cal - WTB: GS-R Head
- WTB: 91 Integra engine/trans mounts and others!!!!
- WTB:JDM INTEGRA HEADLIGHTS
- wtb: d16z6 distributor
- !!!LOOKING FOR H23 COMPLETE HEAD!!!
- Wtb: Neptune Demon Rtp and software licence
- WTB Stock EG si Axleback
- 09 Fit Sport Driver Airbag
- WTB: OEM B series knock sensor.
- WTB: AUTOMETER CLUSTER BEZEL
- WTB: 99-00 EK sedan chrome grill
- 92-95 Civic Power window motor/Regulator Driverside 2dr EJ1
- IndianaWTB: Ek Hatch parts armrest,fog lights,and 50/50 taillights
- SoCal WTB Eg/Dc Stock Suspension
- WTB: Turbo Manifold
- WTB:H2D kit w/o mounts
- WTB: EF sedan manual pedal assembly with cruise control
- WTB: Skunk 2 h22 Mainifold !! asap
- WTB: Door handle rods 1990 CRX
- WTB 99-00 OEM SI LIP ASAPPPPP
- WTB: 90-91 Civic Si Lip
- WTB idle air control for d16y8
- PA WTB: D16Y8 5- spd
- wtb: d16y7/y8 valve covers
- WTB:p84-901 ecu
- WTB: Del sol quarters
- WTB: 92-95 Civic EX Dome Light
- WTB: eg suspension, clutch, and other misc. parts
- WTB: EK CTR rear lip (authentic)
- Stainless Steel Brake Lines: Integra/EG civic
- WTB PR-3 head
- WTB: D17A2 CROWER STAGE 1 CAM
- WTB: Cold Air Intake AirBox
- WTB: usdm obd2a type r ecu
- *WTB B16 OR GSR HYDRO TRANNY*
- WTB: 00 CR-V EDM Front Bumper!
- WTB- 92+ integra dual bend shifter
- Wanted B series Tranny Gearset
- WTB: 99-00 Civic Si OEM Side Sill Electron Blue
- WTB: intake manifold with throttle body
- WTB 92-95 Civic hatchback eg oem muffler (axleback only)
- wtb bisimoto or plm header
- LA only! Looking for p30/p72 with knock sensor, manual
- Wtb cams for b18c
- WTB: SINGLE or PAIR of 16x7 +42 4x100 rays te37
- So Cal: WTB S2000 AXLE
- socal WTB: ef hatch back coilovers complete
- LTB B18b Blox intake manifold
- WTB H22 or H23 engine parts
- WTB: PANEL .. LOOK !!!!
- WTB: OBX h22 ITB
- WTB: OBD2a-OBD1 Conversion Harness
- WTB PR-3 head
- WTB: 99-00 em1 engine harness or used wire tuck harness!!asap
- wtb prelude shift boot
- WTB eg hatch taillights
- WTB: 92-96 Prelude SI or SI Vtec
- 98gsr stock springs
- VA - WTB: 94-01 Acura Integra for $4k
- wtb: competition twin clutch spec c 4-8026-C
- wtb: good k20a2 crank
- WTB 89-91 crx si interior harness
- wtb itr left fender for jdm frontend
- Wtt: 2000 civic Si em1 aftermarket parts for oem plus cash
- WTB: OEM EM1 Grille
- wtb: recline mechanism 90-91 civic hatch PLEASE HELP!
- WTB: Vision Mirrors, Test Pipe, Mugen MF10.
- WTB: Black Racing Phantoms center cap
- WTB: Third Brake Light for Integra coupe.
- Wtb:h22cam caps
- WTB: 99-00 EK front fenders (OEM)
- wtb 92-95 civic front windshield finishers/molding
- WTB D17 CRANK AND RODS AND .5 OS D17A1 PISTONS
- WTB: ITR or CTR Exhaust CAM
- WTB: coilovers for eg
- WTB: 96-00 Civic Coilovers - <$600
- WTB ASAP!!! 1994 integra car and engine harness
- wtb 99-00 civic taffeta front bumper SO-CAL
- WTB 92-94 Civic radio/climate control bezel
- WTB:Left rear mudflap for the Honda Civic EF9 to fit the rear bumper lip.
- WTB Civic EF B series Mounts
- WTB: 16 Skunk2 extended lug nuts
- EK power door panels
- I need a set of cam gears for b series
- WTB: B series turbo kit
- wtb: 5.9 b series mid shaft
- eg f7 lca,ek sideskirts,air bag tray
- WTB air bag tray
- BNIB RS Race Spec Pistons Integra Type-R Style (81.5 mm) with rings
- wtb used gsr bearings
- need used bearings
- WTB: OBD1 GSR Throttle Body w/ Fast Idle Valve
- Looking for Integra Type R ITR steering wheel non-SRS
- WTB WI: Fiber Images USDM SiR Style CRX/EF Hood
- AEM fuel pressure regulator for b16
- WTD B series 700hp clutch
- WTB 88-91 CRX HOOD AND DRIVER SIDE FENDER
- wtb Carbon fiber hood for 98 Civic
- Wtb crx cabin harness
- WTB: LHT JRSC
- WTB: del Sol shifter linkage - d16z6
- WTB: 88-91 civic ground control coilvers, for koni yellows
- B series cam gears
- WTB: JDM Steering Wheel and/or Quick Release
- WTB some parts for my EK build
- Wtb: sleeved 81mm b16 only
- WTB: MFactory or Liberty Cuff / Shaft Brace!
- WTB: 96-00 2/4dr Civic mudflaps/splash guards (All 4)
- WTB 93 integra front bumper and jdm da parts
- wtb cheap stage 1 or 2 cams
- WTB: 94+ Integra Front Transmission Torque Mount Bracket for B-Series Swap
- b-series LSD diff
- WTB eg dash harness
- Cdm type r rear seats
- *wtb* oem b series dizzy
- integra dc2 OEM parking pole
- WTB: 5 SPD d16y8 intake manifold or Skunk2 IM
- WTB v2 competition bronze skinnies
- WTB: GSR Oil Squirters
- built ls,gsr or itr shortblock for turbo
- WTB: FullRace/equal quality B series top mount
- WTB 84.5mm piston
- steering coupler manual
- WTB 1997 del sol ecu
- wtb crx siR jdm front bumper
- Eg9 Vti/Ferio Sedan 5door Eg Parts
- WTB: Blox IM for GSR head
- WTB 1200cc Injectors
- wtb: sleeves bseries gsr ls 84mm block ready
- WTB: 99-00 Civic Coupe OEM Mud Guard
- Where to buy Honda Parts in Toronto, Canada?
- aftermarket bseries intake manifold
- ntb civic/integra fuel rail
- need a b18c5 crank
- WTB driver side eg windshield moulding, driverside
- WTB BLOX
- WTB EG Hatch Emblems
- WTB: Fiberglass or Carbon Fiber light weight EG Hood
- WTB: sleeved gsr block
- WTB : Throttle body spring
- WTB: Z6 rear main seal housing
- WTB: One 4X100 16X7 Rota Slipstream wheel SOCAL
- WTB B18B FORGE PISTON/VALVE TRAIN
- wtb d16z6 tapped oil pan for turbo
- d16a6
- Shocks and Struts for Civic HB
- WTB P72 virgin OBD1 ecu, EG6 4, 5 gears
- wtb 93 integra front bumper
- WTB --- stock eg6 rear LCA, Camber Arm
- WTB....Usdm type r AC vent
- wtb eg cf spoon lip
- WTB 75.5mm piston ring
- OEM TYPE R HEADER
- WTB: B16 cam caps
- wtb gsr block
- 84.5mm b20 pistons
- WTB Ls parts
- WTB:d16 dc headers and skunk2 manifold
- WTB: 94+ Aftermarket Integra suspention
- WTB- 90-91 Wagon Parts!
- Wtb: CTR spoiler
- WTB: EG Coupe Nose Mask
- WTB: B series Distributor
- 99-00 civic 5spd conversion, MT P30 ECU, RSX Beige leather Steering wheel
- WTB-- spoon sport wheels
- WTB: 99-00 civic ex hub cap
- WTB engine parts.
- WTB: 99-00 Si OEM CD Player
- Wtb: 00-01 ITR cams or CTR cams
- WTB: Traction Bar
- wtb dss 5.9 axles and hubs for 04 ep3
- wtb lenso's, exospeed's, spinwerks 15" 5x114.3 ASAP
- WTB: OEM ITR Limited Slip or Aftermarket 1.5 way (Quaife, Wavetrac)
- I Need Turbo Map Sensor & Saturated Injectors
- WTB Honda/Acura AC delete duct part# 79810-SR3-A01
- WTB Del Sol Parts
- WTB : ek9 recaros and carpet
- WTB: EDM Integra Tail Lights
- 1k for honda shell
- WTB: DC2 back truck floor mat
- WTB: B series turbo manifold
