View Full Version : Want to Buy
- WTB integra Shell
- wtb...itr/ctr cams..!!!
- WTB 94-01 Integra RS brake booster
- WTB: OEM P61 / B17A / B17A1 Rods
- WTB d16y8 parts
- WTB: NRG Hub
- WTB: 14" VX, 15" Fat Fives ot 15" meshies
- Lookin for struts and coils for 89 hatch
- WTB 205/45/16 yoko S.drive of KDW
- wtb 91 dx interior parts
- wtb - dc integra dual bend shifter
- WTB ; 90-91 integra clutch and pressure plate
- WTB Racing Hart Type C2 16" or Tracer
- WTB: Mugen Intake (DC2)
- WTB: Jackson SC kit for 1.6 SOHC
- WTB: PA/DE/MD - 92-95 Civic Hatch Rear Bumper Cover
- wtb 85mm High compression pistons
- Looking for 2000 civic si rims
- WTB: b20 vtec parts..
- WTB Car
- 88 crx si flywheel and flex plate
- Looking for a Single Cam VTEC motor
- WTB: EG Parts
- WTB: OEM Pocket Din - INTEGRA
- WTB: 92-95 Brake booster vaccum check valve + driver side seat belt buckle
- WTB: OBD2 IAT pigtail
- WTB del sol a/c bracket
- WTB: Green Stripe Del Sol seats.
- CA: WTB 17in 4lug rims
- wtb: d16z6 or d16y8 ported head
- WTB: 90 EF DX to SiR converted harness
- WTB: A'pexi V-FACII instruction manual
- WTB: TIAL MVS 38MM WASTEGATES
- wtb eagle rods b18
- WTB Dtec D-tec M8 Wheels 15x7 4x100
- WTB 1993 del sol si quarter panel
- dash Parts: PANEL ASSY and Dimmer Switch cruise swithc cover
- WTB: Pass Side EBP Fender Molding
- WTB: B series cam gears
- WTB - 99-00 CIVIC SI SEAT HEADRESTS
- WTB:integra non abs brake booster
- WTB: EK HATCH SHELL - CLEAN BODY NO RUST
- WTB: H series DC and EK parts please look
- WTB: CRX HF with Highest MPG and A/C
- WTB in MN or WI: GSR rims
- WTB EG 92-94 EX gauge cluster
- WTB: ef9 front filler
- WTB GS-R PARTS
- WTB turbonectics t3 exhaust housing
- <<<<<WTB h22 flywheel bolts>>>>>
- WTB:99-00 EM1 civic si
- 99-00 civic ex or si engine harness.
- B18C4 ARP head studs and rod bolts
- 215/45/17 or 205/40/17 Tires
- USDM ITR/GSR oil pump with CKF sensor
- WTB eg coupe rpm cluster
- WTB: 94-01 Integra P/S Pinion gear
- WTB GSR Jackson Racing Supercharger
- WTB/WTT: 1994-1997 Honda Accord Wagon EX
- WTB: OBD2 Integra engine wiring harness
- WTB: Integra (DC2) Front Brakes
- WTB KOSEI K1's
- WTB: 97 hatch stock exhaust/axleback
- WTB: cheap GSR Throttle Body
- WTB: Stock Del Sol Parts - Injectors / Headers / Oil Pan
- WTB: 1988-1991 Mitsubishi Alternator
- WTB: Apexi WS2 for 96-00 civic hatchback
- h22 usdm harness
- WTB:OBD1 GSR P72
- WTB - 90-93 Accord Battery Cover
- WTB- OEM 94-01 integra shifter
- WTB: CRV crank pulley!
- WTB: EK dark grey fog light switch, mint shape or bnib
- WTB:EK Spring/Strut Combo OR Coilovers.
- WTB: Civic SI Hatch
- WTB Momo style steering wheel hub
- wtb: gt3076r
- wtb: OEM ITR Springs
- WTB: Stepper pulley for JRSC
- i need 2 of these rims. anyone selling?
- wtb Aftermarket Clutch and flywheel b18a1
- Wanted - intercooler
- WTB: D-Series Cable to Hydro Conversion
- wanted; civic cluster with tach
- WTB: Integra GSR 98-01 Brake booster
- WTB Innovate DB Gauge or Innovate Compatible Wideband Gauge
- WTB: 50MM H22 CRANK ASAP
- WTB: VERTEX LIMITED EDITION 10TH ANNIVERSARY 350mm Rally Wheel
- i need an A/c bracket!! HELP
- WTB: I WANT THIS STEERING WHEEL EG6
- WTB OBD2 DIZZY!!
- WTB: MINT Gab sport wheels 16x7 +32 offset in Silver with polished lip
- Need a Knock sensor
- dc interior
- Rhd Integra dc2 parts needed!
- WTB - ITR Front Lip OEM
- WTB amber corners for dc2
- WTB:B18 84mm sleeved block
- WTB: LS crank pulley!
- WTB: TYPE S Throttle body & EK K20 swap header..
- WTB: Dizzy
- WTB:need exhaust for 99 civic coupe!
- Obd2a to Obd1 conversion harness
- 96-98 civic ex engine harness
- 99-00 SI MOUNTS
- WTB 96-98 CIVIC LX 5 SPEED ENGINE HARNESS
- WTB 2 Front OEM AP1 Rims
- WTB: Knockoff Wastegate!
- WTB: knock sensor and d-series header
- PA WTB Integra Bumper and mirrors (Citrus Silver Metallic)
- wtb b20 block by the 15th
- WTB: 05 rsx-s oem passenger side mount
- WTB: RHD eg6 parts!
- WTB- 98 Civic EK rear bumper (Black)
- WTB: 92-95 Civic Hatchback (NW Ohio)
- WTB 2001+ Coupe 5spd Sub 100k miles In PA/NY/NJ Area
- wtb: 7-9lb flywheel for b-series hydro
- wtb: 2 ground control springs
- Anyone by chance have parts?
- DC2 Black window switch's
- WTB: 98-01 oem integra dc2 rear bumper /// PITTSBURGH PA
- WTB/WTT: EDELBROCK VICTOR X / SKUNK2 PRO SERIES MANFIOLD
- WTB SIDE MOLDINGS FOR DC2
- WTB: NYC 1987 Honda CRX SI 5spd radiator
- WTB: OEM ITR Exhaust, All Red Tails
- WTB Type R 5 speed trans
- WTB: 5.0 final drive and tsx 6th gear???????????????????????
- WTB OEM Sunroof Visor for 94-97 Accord
- wtb h22 mani and more
- WTB:Honda CBR1000RR or CBR 600 RR
- WTB gsr skunk2 intake manifold
- WTB CR-V OEM RIMS & TIRES
- WTB: B-series front axles
- WTB: S2K Projectors
- WTB: OBD1 Civic / Integra ECU's P06,P28,Pr4,P72,P75
- WTB: Apexi WS2 or Noir for 96-00 Civic Hatch
- WTB: 90-91 SI Cabin/Dash Wire Harness!
- WTB: 88 CRX fuel pump hanger and sending unit
- WTB S2000 AP2/02-05 TSX Ballast + EP3 Steering Wheel
- b-series BLOX cast turbo manifold
- WTB nice clean HX wheels
- WTB: 02 sensor
- WTB: 88 - 89 Civic Wagon Parts
- wtb:left side ek9 Arc winglet
- 2000 coupe or hatch in jacksonville florida
- WTB: 99-00 Civic A/C Control and Double Din Dash Panel
- WTB: 91 Honda Civic engine
- WTB: hasport civic EG B16
- WTB: JDM ITR front end parts
- Need H22 D series A/C bracket!!!!
- wtb: Nitrous kit for GSR- Prefer a wet kit, or a gsr plate kit
- WTB: BR catchcan/breather kit and valve cover with -10an bungs
- WTB: OBD-0 B16A Intake Manifold
- Want to Buy Dynapack 3000 2wd or 4wd
- WTB: STOCK CIVIC FUEL PUMP AND HANGER!!!!!!!
- wtb 4x100 wheels in midwest IA
- wtb 3in velocity stack and filter asap!
- WTB: ap1 or ap2 R & L fenders
- 90-93 accord T-bracket(rear) 5spd only!!!
- WTB: (SoCal) civic 96-00 stock top hats
- WTB: Stock intake for 95 Civic EX
- Fuse box assy for Integra '98-01
- WTB: CRX Exterior parts
- WTB purple driver door handle eg
- skunk2 pro IM for GSR
- WTB: Odyssey PC680
- WTB: B16 Intake Manifold
- WTB lowering kit for 01 prelude
- I NEED OBD1 LS PARTS...help me out here
- Del Sol heater a/c knob
- WTB: 99-00 si p/s pump with "GSR" mounts
- WTB OEM ITR INTAKE ARM!!!
- WTB/WTT..B16 Stuff...92-93 GSR Wheels Forsale/Trade
- WTB:>>>>>>Subaru WRX<<<<<<<<
- WTB: forged LS rods and Forged B series pistons
- WTB: Kseries Exhaust Manifold
- wtb: 96-00 civic ex front lower control arms
- GSR Differential
- WTT FOR 99-00 si or 96-00 ex coupe
- wtb fmu 10:1.
- WTB: 99-00 Honda Civic SI OEM Exterior Parts
- WTB: ITR lip
- WTB: RSX-S MUDFLAPS, EK HATCH PARTS
- wtb:del sol parts
- WTB: crx si e-brake cables and under dash fuse box
- DC Black Carpet and interior pieces
- AEM alternator pulley in silver or blue
- WTB: YELLOW RECARO SEATS (pair) mint
- lenzo or v2 compentition wheels
- WTB 5x114.3 16x7 or 16x8 white regamasters or sprint hart cp-r's
- WTB transmissions B SERIES ONLY
- D16Z6 Complete bottom end, Need one cheap, OHIO
- WTB: GSR INTAKE MANIFOLD!!skunk2 or aebs
- catch can
- WTB CLEAN CIVIC/INTEGRA
- WTB integra wires
- B16 OBX Lsd
- WTB: 12:1 FMU
- WTB: Y21 or S4C transmission for B16A3
- WTT jdm D15 vtec for D16A6 trade or buy
- WTB: B-Series starter and GSR Throttle Body
- WTB: 99-00 P2E AUTO ECU
- WTB: USDM ITR CF INTERIOR DASH PIECES NRG MOMO hub
- WTB 92-95 Civic Foglight Parts
- WTB: ECU / Dash harness 95 EX auto
- wtb obd1 p72 ecu etc...
- WTB: Blox/Skunk2 gsr Intake Manifold
- WTB: STOCK CATALYTIC CONVERTER FOR INTEGRA
- engine for accord 78
- WTB: 95 Civic EX Front/Rear Calipers ABS NJ
- B16 victor x manifold and throttle body
- WTT: Integra Leather Door Panels
- WTB Feel's shift knob
- WTB: catback, amber turns, red tails, seatbelt, spoiler DC2
- WTB B SERIES ENGINE HARNESS, ECU... etc
- WTB: JRSC for D16
- WTB 95 GSR Exhaust
- WTT: my type R tranny for your gsr/lsd tranny
- !WTB! CTR or USDM ITR 5 lug conversion.
- WTB CRX HF Engine Harness 88-91
- WTB: TW FA5
- WTB: 98+ Integra rear bumper and garnish asap!
- WTB: b20/vtec kit
- wtb db8 R doors
- WTB: AEM BOOST, OIL PRESSURE, WIDEBAND(w/ o2) DIGITAL GAUGES
- WTB: Complete AC System for 98 Civic EK
- WTB: oem dc2 rear valance
- wtb b20 ac bracket!!! in cali
- WTB: 92-93 Integra Front Lip
- Jackson Racing Supercharger D16Y8
- WTB: Complete A/C System
- WTB driver side B series motor mount
- WTB mix of B mounting and bracket parts
- WTB S2000 Parts ASAP
- WTB: JDM Front Integra 2door coupe/hatch
- wtb b16 pro1 cams skunk2
- WTB-gsr head complete
- WTB: Ferio / SOHC Parts
- WTB: 96-00 Civic 2/3Door Left Side Folding Mirror
- WTB!!! Apexi -NOIR AXLE BACK !!
- WTB: DC2 parts:: exterior, suspension, etc.
- WTB: d17 motor
- WTB: Skunk2 B Series Throttle Body
- dpfi to mpfi extra ecu connector for pins!!! d series tranny bolts
- WTB: civic or del sol shell
- wtb EK B series engine mounts[aftermarket]
- WTB:2500$ for a car
- WtB Maddddddd PartS!!
- WTB GSR 5 speed.
- WTB: parts for a del sol
