View Full Version : Want to Buy
- WTB.Trhottle Body 65 mm Bseries
- wtb: honda air stopper tool for locking vtec
- wtb id2000'$ 500 or under shipped
- wtb: carbon synchro set for gsr
- WTB: P28 ECU
- WTB: 92-93 Integra Parts
- WTB: 96-00 Civic Center Console
- Looking for SKUNK2 Intake manifold, D series
- wtb: ecu
- Parts to complete my swap
- Eg hatch or EF hatch in socal
- WTB: Comptech exhaust dc2 99 gsr
- wtb: 92-95 civic 2/3 doors civic cabin harness
- 00 EX Engine harness needed
- WTB: B18C block guirdle
- WTB: 1998 and up DB8 sedan parts
- WTB D16Z6 swap
- innovative steel motor mount 92 93 DA
- em1 b16a2 post mount and b series front mount
- WTB: minty wrinkle red DOHC VTEC valve cover
- WTB D16Y7 Block
- WTB: 1996 Acura INtegra GSR rims and tires
- ::WTB:: Complete k20 swap for eg or ef
- WTB: Secondary 02 Sensor for Civic/Integra
- Wtb: Buddy Club spec 4 cams, AEM cam gears
- WTB: ITR LSD Transmission (4.4 or 4.785 FD)
- WTB: 99-00 Civic Fog Light Covers
- B-Series VTEC Compete Rocker Arms
- WTB: H22 EK Swap Axle
- WTB: 92-95 2/3 door MIRROR BLOCK OFF PLATES!
- WTB: 96-00 Civic EX 5 Speed tranny
- WTB: B series VTEC valvetrain
- WTB: B series high comp. pistons under 250$
- WTB:Pistons 82 mm 12:2:1 Bseries
- MUGEN RNR WANTED
- WTB GSR block
- ek suspension
- wtb fast clean civic
- WTB: CA 99-00 Civic Si Rims Wheels and Tires
- Wtb Neptune rtp
- WTB: B20 shortblock or 84mm B-series w/GOOD crank
- WTB Fuel Pressure Regulator (non b&m)
- WTB b16 rods
- PDX FT: One Piece DA9 Drivers Headlight
- WTB : mugen gen 1 wing for dc2
- WTB upgrade map sensor
- Looking for wheels, 15x7- JSpeeds?
- WTB: b series cam gears and fuel rail
- wtb 2001-2005 ecu manual ecu
- Wtb Ek Sedan Sun Visors and Radio pocket
- WTB: Stock eg wheels/tires
- Bys carbon lip
- del sol roof rack
- WTB - SI or Integra prop valve
- Wtb: obd2 USDM manual ls ecu
- Wtb: civic parking pole ASAP!
- Wtb: d series headders~~
- WTB: OEM Integra ITR lip
- 91 crx cluster hood
- Wtb: 92-95 civic front caber kit
- :wtb: b16 throttle body
- WTB Civic/integra parts
- WTB: High rise J's type wing (for sedan..etc) & EG6 J's wing
- wtb brand new black housing jdm itr headlights
- WTB: EG9 Sir lip.
- WTB: JRSC Alternator Pulley
- WTB-92-95 coilovers
- WTB 3-piece front end for EG hatch
- WTB: OEM CTR Spoiler base
- WTB - LS Mesh // OE 99-00 SI's
- WTB: JDM EJ7 VIN Plate
- WTB: B16 EF MOUNTS hydro tranny
- Sleeved B18 block in good shape.
- WANTED!!!!!! 99-00 Honda Civic Si OEM Rear Lip Top Dollar will be paid
- 96-01 OBD2 Integra GSR Dizzy b18c1
- F/S skunk 2 rear section muffler 92-00 civic coupe
- hpc H22 ac bracket for a eg
- WTB: Valves bnib
- Wtb:CTR muffler or full with b pipeing everything
- oem si lip 99-00 wtb
- WTB y7 regrind cam
- WTB B16 B18C1 rocker arm synchronizing pins
- WTB: 2(two) HX rims OEM stock unpainted
- WTB in NOR CAL ek hatch interior panels
- WTB: 16" Volks CE28 (5x114.3)
- WTB GSR injectors
- WTB: Buddy Club Spec 2 Exhaust for 94-01 Integra GSR
- WTB: Hasport Mounts B-series (DC)
- FF type 2 coilovers ek civic WTB
- WTB B18C1 (GS-R) Thermostat Case P/N 19320-P72-000
- WTB: del Sol/Integra RS/Mini Blade CENTER CAPS
- WTB: DC integra 2 front hubs/non leaking steering rack
- Wtb: ek lca's/ parts
- wtb...regamaster wheels
- WTB 99-00 AUTHENTIC mud guards no BS adjusting it and what not I WANT REAL SHIT!
- WTB Thermal Racing TURBO 3 Inch Exhaust FOR CRX
- WTB: Stock LS or B20 Crank
- Hx shifter cable bracket !!!
- WTB CTR HEADLIGHTS 99-00
- Good condition OBD2 B-series Alternator
- wtb: 750cc or 1000cc injectors
- Si em1 lip 99-00 oem wtb
- WTB: 99-00 Si oem rear sway bar and/or endlinks
- wtb ID 725s or ID1000s
- odd trans brackets and stuff needed! 99 civic
- WTB: 88-91 CRX Double Din Radio Bezel
- WTB: DOHC ZC 3/4 Gearset
- WTB Skunk2 Tuner 1 Cams
- WTB 94-01 integra front/rear camber kit
- WTB: ITR or GSR Valvetrain
- Wtb catalytic converter for 2000 civic EX
- Wtb LS-T parts(valve train, pistons, etc...)
- WTB: Ls/b20 rods
- WTB: 92-95 2/3Dr Fenders/Hood
- WTT: WRX swapped 99 Impreza 2.5 RS coupe for S2000
- WTB: 1997 Civic EX Sedan (EK5) Body Parts
- WTB: B16/b18c t4, 38mm 2-bolt manifold NO TOP MOUNTS unless made to fit EF
- WTB b-series fuel rail
- 98-01 Integra RS Brake Booster
- Integra Trailing arm parts
- WTB - OEM 99-00 SI shift knob
- WTB: OEM GSR cams or type R
- WTB Map Sensor
- IN NEED OF A D16Z6 OBD1 DIZZY ASAP
- WTB: ZC Gear set / 3rd and 4th
- WTB: JDM 4-1 OEM Integra Type R header w/ heatshields
- WTB 62mm TB
- WTB: 94-01 Integra Body Moldings
- WTB: b16 cam caps and bolts
- WTB: Roof rack 2DR Civic 96-00
- wtb bwr ek polished lcas and tie
- WTB .: H22 Head parts . Valve . only performance...
- Wtb d16y7 Iacv
- WTB:ITR OBD II distributor
- WTB OBD2 CAT......... Going on a 1st gen CRV.
- WTB 94-01 integra driver exterior door handle MR
- WANTED: JDM OEM DB8 4 DOOR INTEGRA RAIN GUARDS (DOOR VISORS) WITH HARDWARE
- WTB: RSX Type S tranyy
- WTB 99-00 Honda Civic 2 Door Coupe OEM Mud Flaps Splash Guards
- wtb lenso skinny
- WTB: D16Y8 long block
- WTB: EK Hatch OEM DX rear wing
- WTB: EP3 Power Steering Rack
- WTB: 98-02 Accord 5-speed shift linkage
- DC2 MOMO SRS Steering wheel
- wtb: one gsr eagle rod(big both) and 84mm 9:1 piston
- WTB: 96-97 integra civic del sol crv evap canister
- WTB:90-93 manual shift cables
- W2b: 92-95 civic radiator overflow tank/reservior
- WTB D16 sleeved block
- Wtb 96-97 accord sir flush mount trunk lip duck bill spoiler wing
- WTB parts for 92 Honda prelude
- 1996-1998 Integra LS ECU
- Wtb-eg d16 motor mounts and t braket
- wtb:ASAP 1 pc KICS R40 Revo gun metal 12.1x1.50
- jackson racing supercharger b16 jrsc
- WTB: 98+ JDM ITR transmission (4.785 FD, LSD)
- WTB B18 timing cover (all 3 pieces)
- WTB low-mileage GSR. Cash in hand.
- KY: WTB Clean EG hatch.
- looking for a apexi ws2 exhaust
- WTB 97 Civic hatchback trunk shocks
- WTB: Brake line brackets 94-01 integra
- XXR 521
- wtb 2000 ex cluster & eg manual rack parts(r&p to firewall grommets
- Wanted!!! EG manual cluster with tach.
- WTB: 23mm JDM ITR Rear Sway Bar
- WTB QUICK RELEASE!
- wtb b series parts
- WTB: BLOCK and CRANK LS/GSR "cash in hand"
- wtb 46mm wastegate
- Stock/Oem K20 Rods
- H2B Alternator Relocation Bracket
- WANTED: blocks, heads, and transmissions
- WTB EK Sedan Parts/suspension parts (Updated often)
- ltb 88-89 civic ef 4door dx wire harness
- GSR crank, or ls crank with rods
- Wtb dc2 fenders
- wtb: wr250r/x
- WTB: B16 iacv
- WTB D series t3/t04e oil feed and return line
- 94-97 2dr gsr tan leather
- WTB: EG coupe parts. (list inside)
- WTB methanol/water injection kits
- WANTED!!! In a need of a Innovate wideband.
- wtb: jdm itr/ek9 recaro slider/rails
- WTB: 99-00 CIVIC SI OEM SHIFT KNOB/99-00 HID RETROFIT
- WTB b16 header intake oilpan ecu
- Looking for oem trunk and driver side taillight 2007 Accord Coupe
- WTB: GSR Z10 Breather Tank Kit Z10-6011K
- wtb tial 44mm v band clamp
- ***WTB: B SERIES VTEC STOCK VALVES***
- obd 1 gsr throttle body with sensors
- OBD2B EM1 99 Si Engine Harness
- Coilovers EK 96-00 wtb
- WTB integra optional side skirts
- Wtb Crx Edm/jdm parts.
- TODA V2 HEADER B18C
- WTB: 1 B-series rocker arms
- EUDM EG6 SIR/Vti 5 Spoke's rims
- LTb b18a1 obd1 ecu
- WTB:ITR parts, takata harnesses
- WTB d16y7 crankshaft pulley
- WTB: ITR doors
- WTB: H22 Crank Gear, h22 Crank Pulley, h22 Water Pipe
- WTB Top One Rear Diffuser for EK Coupe
- WTB: 01-05 Civic LX exhaust manifold w/ cat
- WTB: ITR rear lower control arms
- WTB: Mr Alex ctr wing risers must be authentic please and clean & 5x114.3 Rims
- ltb 90-91 civic ef 4door dx wire harbess
- 89 prelude cooling fan control module
- wtb: a honda del sol car cover
- WTB: Honda CRV Crank Pulley and MVM Stepper Pulley
- wtb integra 2dr quarter panels & RS/ITR roof skin!!
- 92-95 Civic eg6 hatch only seat belts
- NEED: s300sx-60-66, gsr DSS spool
- WTB ITR or CTR exhaust cam.
- WTB EG km/h speedo and 99-00 si tach
- WTB: EK manual trans conversion parts
- Wtb: nrg hub/quick release/wheel/fixed back seats
- WTB Gsr short block
- WTB: 1998 Honda Civic driver side fender in black
- 96-00 Civic Automatic Gear Shifter Assembly
- WTB Integra NON-ABS Parts!
- WTB NRG HUB & QUICK RELEASE w/Some Steering Wheel
- WTB: full b-series greddy turbo kit...
- WTB SK2 Pro IM for b Series, Aftermarket Throttle body
- WTB: AEM boost and oil pressure gauge, JDM CTR Holder, GSR Timing Belt Cover
- wtb: skunk2 pro valve spring and retainer
- Wtb 92-95 civic fr. Bumper and hood oem only 562/714 socal
- Wtb: obd2b-obd1 Ecu jumper
- Wtb sohc greddy turbo kit
- WTB: Cable LS 5th synchro sleeve (small spline)
- WTB - RHD CRX SIR B16 main chassis harness
- Wtb:d16z6 breather box~~
- WTB: H22 Skunk 2 Intake Manifold / 98-01 Prelude PS Pump & Hose
- WTB: ASR subframe brace
- wtb: philly, nj 96-00 civic hatchback oem exhaust
- WTB LS H-Beam Rods
- WTB: carbon fiber driver side headlight scoop
- EG Coilovers
- LTB ef parts,z6 parts
- WTB ek4 Sir Door Panels..
- WTB: EF9 FRONT FILLER
- WTB: 1999 - 2000 civic si e-brake cables
- wtb jdm eg bumper moldings & grey ferio door panels
- WTB: OEM EG Coupe Taillights
- WTB: 88 hatch dpfi to mpfi stuff
- WTB: Lightened B series flywheel
