View Full Version : Want to Buy
- wtt 94-01 4 door integra seats. leather cloth
- Wtb: Aem fpr 25-300
- WTB Coilovers for a CRX
- Wtb : 15 or 16' 4x100 wheels
- Wtb: Obd2a - obd1 jumper harness
- Wtb: Edm parts
- wtb....euro R intakemaifold
- WTB D16 Block &/or Crank
- wanted USDM CRV A/C BRACKET
- wtb-99-00 front DAP ONLY
- WTB: Si Grill and s2k Steering wheel
- WTB: DSS axles stage 3.9(stage5) or higher
- WTB:: crx full coilover
- WTT turbo kit or built b16a2!!!! must see!!!!
- WTB spoon n1 silencer
- WTB: JDM CRX Front Bumper
- WTB: Need white bushing for steering column
- eg 92-95 civic oem nose mask/bra
- wtb: DOHC ZC Power Steering bracket
- delete
- WTB: project kics R40 w/locks
- WTB: EK B-Series Swap Parts
- Rocket motorsports m22xx
- Wtb: 96+ civic floor harness for power windows 99-00
- d16y7 harness
- WTB 88-91 civic/crx coil over set up
- looking for a few things to finish my ls/v in southern PA
- WTB EG HAlf Size Aluminum Radiator
- WTB: Need Some things engine bay caught fire take a look.
- Wtb: Vsm civic parts
- WTB: OEM Integra Type R Intake Air Box/Pipe
- Wtb: Parts for my Ej1
- WTB: The Integra interior door handles and cups
- WTB: OBD1 Non VTEC ECUs
- WTB: jdm itr passenger headlight (right), itr hood
- WTB: EK HEADLIGHT RETAINING CLIP it holds headlight
- wtb spark plug covers
- WTB 84.5mm dish/S300/fuel items/
- Need lots of stuff hit me up. PLEASE ASAP
- WTB: Momo Hub horn ring.
- WTB: D16A sohc vtec soloniod (obd1/2) asap
- WTB: integra OEM optional rear valance(white) w/ hardware
- Wtb: Oem sideskirts & headlights 96-98 coupe
- WTB: EF(civic/rex) mounts
- WTB obd1 gsr harness
- WTB: B series VTEC valve covers
- wtb: aftermarket valvetrain b series
- WTB complete steering columns and Glove Boxes
- wtb; d16z6(92-95 ex/si) transmission
- WTB: GS-R Crank Pulley
- WTB Cams/ Clutch/ FlyWheel
- WTB 96-00 Civic Headlights
- WTB: 99-00 civic si engine harness *uncut*
- wtb: ek driver side sail panel (non-tweeter panel)
- WTB ITR exhaust cam!!***
- WTB: 14" or 15" wheels
- WTB: 99-00 Civic hood near Tennessee
- Wtb steering wheel with hub
- WTB: 99-00 Civic SI rear mudflaps
- WTB: GROUND CONTROL COILOVERS FOR 94 CIVIC SI. LS MESHIES f/s or f/t also
- WTB: F23 Accord vtec SOHC valve cover asap
- WTB: NRG Slim Hub for CRX
- wtb: 96-00 ek
- WTB: 96-00 civic hood latch cable
- Wtb::: Jdm sir-g fenders
- WTB: B series VSS, Fuel Rail, OBD1 injectors
- WTB complete GSR motor
- WTB 96-98 CIVIC ex/dx/hx/cx/lx harness
- WTB: 96-98 harness ASAP
- WTB Si Passenger Seat 90/91
- need some stuff... pleae look inside
- Wtb gsr part
- WTB: RSX Radiator FAN
- WTB: h22 skunk2 intake manifold
- Wtb: Cheap b series headers!!!
- wtb: 92-95 civic oem carbon fiber hood
- wtb 99-00 civic rear bumper
- WTB morose h22 oil pan and fluidampner
- WTB 205/45/R16 tires....
- WTB Crx Fenders and LS Victor X Manifold!!
- WTB: B16A2 obd2a vtec OEM DIZZY
- Wtb: H22 mount ek swap
- wtb: b18b ls intake manifold
- WTB: 99-00 Civic Si Rear Seat Base
- WTB: EK coupe taillights (Si or 50/50 preferred)
- Need Wiring Harness
- Need integra rails/sliders
- WTB 2000 SI B16 A/C tensioner assembly
- wtb: 96-00 civic dx,cx distributor (PA)
- WTB: EK/SI B-series Swap parts
- WTB vtec B-series exhaust valves
- WTB steering column ignition + key eg
- WTB DOHC Transmission
- WTB: 4 door teg parts :WTB
- WTB: SSM EP3 PARTS (hood, bumpers) & Window Sill Garnish
- del sol b16 a/c bracket
- wtb mugen parts for dc2
- wtb 90 91 crx si dash harness
- wtb b series twin disc clutch
- WTB: B16 stock cams, cam caps/bolts, cam gears with cam bolts
- WTB: Cheap 4x100 15" Wheels with Tires
- EG parts
- wtb sleeved b series shortblock
- WTB: Hub rings for TE37
- WTB: '00 Civic Si Catalytic Converter
- WTB: ls short block or long block
- WTB: RS*R exmag exhaust for 91 hatchback
- WTB: Skunk2 Pro2 B series cams
- WTB: 99-00 Civic Mud Flaps/Splash Guards and Civic Si Bra
- WTB: ITR SHIFTER CONSOLE, A/C Vent
- wtb: obd1 gsr harness
- WTB Civic Rsx Integra
- Power door lock control unit
- WTB: Bride Vios 3 Replica
- WTB: Windshield Weather Stripping & Thin Side Molding
- wtb:JDM ITR or SIR-G headlights, GSR SEATS
- Wtb wtt: 96-98 civic ex floor harness
- Sprint hart competition purple lug nuts
- wtb: rhd complete front clip for del sol for conversion
- hondata s300
- rc injectors
- WTB: P73 2000-2001 USDM Type R ECU
- WTB: Broken B & K series Trannys Cash In Hand
- wtb boost solenoid
- WTB: EK sideskirts for EG hatch
- Wtb: Car stuffs.....
- WTB EG6 JDM Cluster & GSR Headers
- WTB b16 Injectors
- Need a integra ignition ASAP
- WTB Del Sol parts
- WTB:Rota Gt3's 16" 4x100 Royal Gold
- WTB: ek b-series swap mounts
- wtb 96-00 civic hatch left rear speaker cover
- WTB B17 Crank and rods
- WTB: ITR Intake Manifold
- wtb: CRX rear seat, armrest, and sidemarkers
- WTB: NEW Retainers and Keepers
- wtb: oem 94-97 type r lip
- WTB 93 or 93 samba green or black del sol si.
- 96 and up GSR tranny
- WTB: 99-00 Civic Si Rear Endlinks & Hardware
- WTB: '92 Prelude A/C CONTROL HEAD:
- WTB: 94-95 Accord VTEC Distributor (Hitachi) -- OR CORE
- WTB: GSR outer Upper Timing Belt Cover
- WTB: Round EF Foglights
- WTB Urgent 94-01 integra intermediate Halfshaft
- Blown Trannys
- Wtb: Built or Stock B18c Head
- 99-00 CTR headlights
- I need a couple B series hydro B16/ITR parts
- wire harness
- WTB: 96-98 Civic EX Engine harness
- WTB electric cut out
- WTB: OEM Acura emblems
- WTB sleeved b16 block
- WTB:OBD2 A Engine Harness
- WTB:CTR wing base (just the base)
- 4- 15x(6/6.5) 4x100 lug pattern steelies
- WTB PASSENGER inside fender piece PIX of what I need inside!!
- Wtb dizzy!!!!
- wtb ef9 mud guards!!!! asap
- WTB: 90-93 integra...IA
- WTB: B21A1 Head
- 4040 Prop valve
- wtb:88-91 hatch cargo cover
- WTB: 92-95 OEM Hatch Right Outside Tailight!
- WTB OEM LS oil pan gasket, oil pump O ring
- EK Cypress Green Parts
- 1992-95 eg body parts needed asap
- looking for an ecu for an accord ex
- WTB: jdm front for a 91 civic 4dr sedan
- WTB: Cable VSS / OBD1 PR3 ECU / OBD1 DOHC VTEC distributor
- WTB: 96-98 Working Radiator
- Hydro B series trans manual
- WTB: OEM NSX Wheels 16" 17"
- WTB: Water Pump, ITR Oil Pump, OEM Main and Rod Bearings
- WTB: 92-93 Integra Gs-r hood insulator (Virginia only)
- 72mm trottle body asap
- WTB: EK Battery Tray
- Wtb: Aem epm + 96-00 tweeters
- WTB - 98 jdm itr 4-1 header
- WTB:99-00 Civic SI wheels
- WTB EF Parts
- wtb em2 stock mud guards
- Wtb
- WTB aftermarket radiator for a eg
- wtb: 2001+ 15x6 stock civic steel wheels 4x100
- wtb f22a sohc head
- wtb: CTR or ITR tranny
- Wtb. Vehicle speed sensor for GSR
- SoCal: WTB s2000 sidemarkers
- WTB: 13" wheels with 23" slicks, h22 valve cover/oil pan
- Hondata S300
- wtb civic auto trans & distributor
- Integra Mud Guards, strut bar,
- WTB: Pm7 Ecu - Sparco Seat Brackets
- WTB: B18C1 Eagle Rods
- 98-02: F23 ECU, ignition lock cyl, keys
- b16 oil squirters please!!!!!!!!
- WTB Good LS Running Bottom End
- looking for an ECU for my 95 teg
- carbing 3pt strut bar
- wtb: 92-95 civic hatch stock taillight
- Working STOCK CAT for 88~91 Civic
- WTB: HX or VX RIMS
- WTB: 2 Mugen CF48 13X5 +38 offset
- WTB F22B oil pump
- Wtb
- WTB: EK Driver Side Sideskirt, Pearl Green G-95P
- WTB: SS Brake lines for Integra, Rear only!
- wtb : jdm ef rear bumper with rear lip 90 civic.
- wtb 4.4 final drive
- WTB: 98-01 all red 2DR integra tail lights
- WTB: stock 94-95 integra fuel injectors
- WTB:: Integra A/C Tensioner Pully
- wtb h22 longblock
- WTB:obd2 to obd1 conversion harness
- WTB Hydro B series Tranny (bad condition accepted) (ITR, CTR, GSR Civic Si, etc...)
- WTB EDM JDM rear fog light..!!
- fuel level sensor for eg needed
- WTB Transmission, GSR or TypeR, Hydro
- ***wtb: Wideband and chip burner***
- Need a obd1 d15 dizzy.please asap
- WTB: Any RHD drive parts for a EG
- WTB: H22 valve cover
- WTB: EG coupe floor matts in black
- WTB many crx & civic hatch parts 88-91
- wtb crx exhaust stock or aftermarket
- WTB: KYB or Tokico for 98 gsr Front Pass
- AC Condensor for 01' CIVIC EX
- WTB: B16A2 Long Block Or Short
- wtb 5 lug conversion+ rims
- WTB 92-95 Civic Interior Door handle
- WTB/WTT skunk2 tunner 1's or 2's
- ~!!wtb ef interior!!~
- WTB: JDM Integra Recaro, only need single seat black or red
- WTB b-series tranny
- WTB stock dual bend dc2 shifter
- WTB: DC sports Header 96-00 D16
- WTB: J's, T1R, or ARC shift knob
- WTB OEM GSR Axles
- WTB: GSR rear L brack 19mm bolts
- WTB: Integra Ground Control coilovers for Koni
- WTB: Bare B18B Block
- eg mugen lip or eg6 vison lip
- WTB: !! D16y Oil Girdle or main caps!!! ASAP
- Chipped or someone to chip PR4 ecu
- WTB: Camber kit for DC integra
- wtb: 98-01 integra black knee panel
- ***99-00 Em1 front Lip/grill and CTR rear lip/mirrors***
