View Full Version : Want to Buy
- WTB: 92-96 Prelude OEM side skirts
- WTB: CRX/Civic HF Front Swat Bar
- wtb: b18b obd2 distributor
- WTB typeR ITR muffler axel back
- LOOKING FOR A JDM H22 LONG BLOCK....
- WTB: 92-95 CIVIC COUPE/HATCH STOCK HOOD AND STOCK FRONT BUMPER
- WTB: Base 02 Rsx AEM cold air intake with CARB LEGAL or stock intake LOCATED IN SF
- WTB: RHD trunk and gas door release cables EG6
- WTB: VTEC OIL PRESSURE SWITCH
- WTB: INTEGRA SEATS CIVIC SEATS DEL SOL SEATS
- WTB:: 97-01 Prelude 5spd
- WTB/WTT: 94-97 White Integra exterior (bumpers, lights, corners..)
- WTB: OBD2 Alternator Plug
- WTB: Complete B16 or GSR Swap SOUTHEAST
- WTB: RED EG HOOD
- WTT: 96-98 Civic Front Poly-Urethene Type R Style Lip!*Pic
- i need a manual trans for a 95 saturn sl1
- need oem stock 96 crv springs... willing to trade skunk2 coilovers for 96 cr-v
- WTB: TP Sensor
- WTB - B series VTEC valve cover
- WTB: honda civic hatchback 99-2000
- 1999-2000 civic ex manual ecu computer
- WTB B-seires engine mount brackets
- WTB: jdm ef9 sir front bumper filler piece
- Comptech Supercharger
- WTB, Decent B18a/b bottom end, cams, and/or all parts needed to perform an obd0 - obd1 conversion
- WTB 99-00 ITR or CTR cams
- WTB: 99-00 CIVIC SI CLUSTER! ASAP!
- WTB: JDM radiator support
- wtb 99 si or ls mesh rims
- WTB: 1990 CRX HF FRONT BUMPER!!!!!!!
- WTB: 96-98 CTR GRILL REPLICA
- k20a dc5 ecu
- WTB: External Wastegate 35-38mm
- D series Supercharger
- VSS need help
- Wanted MemoryFab S68 in San Diego.
- WTB: EG6 SiR II Long Armrest
- WTB B SERIES TURBO KIT (USED )
- WTB: Someone or shop to remove EVERY ding from my exterior! ATLANTA, GA!
- WTB RSX STEARING WHEEL
- WTB: Blue OR RED DC5 Recaros with rails
- WTB: K20 TYPE S LOW MILES
- WTT my 94 jdm gsr cams for itr or ctr cams $$$$$$$$$$$$$$$$$$$$$
- WTB: Del Sol Hood in the tri-state area
- WTB: 96-98 civic SIR headlights
- WTB: stock parts for my EH2.
- WTB: ITR/GSR/B16 tranny in ontario
- B series head internals
- WTB: 96-00 OEM Hatchback silver spoiler
- WTB: boomslang VAFC-2 Plug & Play Harnesses obd2a-obd1
- WTB: Type R seats or recaros front & back OEM wheels and oem ITR exhaust
- WTB: Type R seats or recaros front & back and oem ITR exhaust
- WTB: 2001 civic exhaust manifold or used header.
- WTB Crower H23 Cams, Springs, Retainers
- ecu
- WTB: H22 Block with crank and B series tranny casing
- wtb- AMP (DFW area preffered) 700w peak, 400 rms
- [B]WTB[/B] - Passenger side mirror for 91' Accord LX
- wtb: p28 with crome
- WTB: 92-96 Prelude Parts
- WTB 94-97 or 98-01 integra rear bumper
- wtb:db8 gsr interior
- WTB: DC2 // EM1 in the NORTHEAST
- WTB Skunk2 coil over springs
- WTB 38MM TIAL WASTEGATE AND P28 OR P72
- WTB:AEM 5 bar map kit
- wtb..k series parts,,,CT
- WTB: Shifter Console
- wtb: apexi safc 2
- WTB: EG Carbon Fiber Duck Bill (NO LED)
- I need a crank for my DOHC ZC?
- WTB: PCV valve for a skunk 2 b-series manifold
- WTB: Omni power or equivalant coilovers for DC!
- WTB: Valve Cover Powder Coating Services
- ** WANTED: Integra Type R ITR RPM GAUGE ***
- WTB. b16 cam caps/oil rails, rocker arms and shafts.
- WTB: B-series header with o2.
- WTB: Both Vtec Cam Rails,& 1 Exhaust Cam Cap And Cam bolts and nuts
- WTB: D16 or D15 engine
- WTB RHD Audio console for 93 civic.
- WTB: Boosted Si or JDM front integ
- ***WTB*** CRX driver door complete
- WTB:JRSC, type r cams and valvetrain
- WTB del sol parts
- WTB: 96-00 Civic Sun visor driver side
- WTB:ITR/CTR/Y21 LSD,or aftermarket LSD..
- Wtb.................i pod 30 or 60 and digital camera Will trade MUGEN POWER WATCH
- WTB 98+ integra headlights
- WTB::: 96-98 civic OEM hood, headlights, radiator support, grill, and bumper and bumper support
- WTB: Honda motorcycle stupid hurts stickers
- WTB: LS/Vtec oil line kit AL
- WTB:: Front door panels and seats for a DB1 (4 door DA)
- WTB: Carbon fiber spark plug cover
- WTB: **GSR LONGBLOCK!
- WTB: 66 Tooth B16 4.40 10 Bolt RING GEAR!!! ASAP!!
- DC2/EG aftermarket and turbo stuff for trade
- WTB: 4040 Prop Valve for 89 CRX Rear Disc Swap
- WTB: Civic SI Power Steering Pump
- JDM Integra metal hood
- wtb 2 stock eg/dc front shocks, or the brake hose brackets.
- wanted mugen mr5 centres and lug covers
- Want to buy some cheap suspension
- WTB: Black Dash Interior Conversion, COMPLETE
- WTB: 98+ USDM front and rear bumper
- WTB: B16 Valve Cover
- WTB: eg fogs, pass side b-series axle, teg E-Brake cable
- WTT:MY MINT SI RIMS W/O FOR YOUR MINT GSR BLADES W/O TIRES IN NY
- WTB:88-91 Civic CRX Driver Mount Bracket
- WTB: fat fives with tires
- WTT: 17" MOMO GT2 rims for smaller (15 or 16") rims wisconsin illinois area
- WTB: OBD1 B18 lower timing cover! Can also trade for OBD2 covers
- WTB: Clear or Smoked B-series VTEC Sparkplug Cover
- WTB: 94 Gsr driver side door panel/ driver side kick panel/black driver door sill/passenger air bag/
- WTB: Full, or nearly full MPFI swap (d16a6 parts)
- WTB: D16Z6 Cam Camshaft
- WTB: Clutch lines that will fit the 94 eg chassis
- WTB: 92-95 Civic 4 door sedan JDM thin side moldings new or used
- wtb eg in nova area
- WTB: GSR throttle plate cam and throttle cable bracket. ASAP!
- [WTB] 90-91 crx fenders
- WTB:IPOD
- WTB: 66 Tooth B16 4.49 10 Bolt RING GEAR!!! ASAP!!
- wtb center cap for gsr blades
- CTR headlights.
- Timing cover side motor mount.
- WTB: LS Integra Vehicle Speed Sensor VSS
- WTB: GSR Short Block
- 90-91 EF cluster with tach
- wtb: windshield wiper assemby switch for 95 civic
- WTB: 88-89 crx front bumper
- wtb: pioneer wiring harness
- WTB: Airwalker Japen 'Walker Japan' decal
- WTB 93 accord se cluster.
- wtb: 94 integra oem ignition coil
- WTB: EX D16Y8 header and cat
- WTB GSR or ITR crank crankshaft
- WTB: 94-97 INTEGRA HEADLIGHTS
- WTB D16A6 engine (90-91 Civic/CRX Si/EX) - Pennsylvania
- WTB: mint '98+ headlights
- Looking for JIMFAB Front Torque Mounts....
- wtb 97 dx auto trans
- wtb: integra fan switch
- ** WTB : B SERIES into EF parts SoCal **
- WTT: Rota Group Ns Black w/red lip for Rota slipstreams
- WTB: honda crx si 1988 only....so cal!!!!!!!! shoot me cars
- WTB: Del Sol parts
- wtb: VX or SI interior wire harness
- WTB: CRX HF Front sway for ANY price
- WTB: 99-00 Civic Si power steering pump.
- WTB - Misc Parts
- WTB:HONDA AROUND KY OR IN.
- WTB: Stock Sway bars
- WTB: 90-91 crx si main harness and dash harness
- WTB CATBACK EXHAUST 92-95 CIVIC B SERIES!!!!!
- looking for gsr bare block...
- wtb 90 accord control arms
- WTB: GSR Tranny
- WTB: egt gauge + sensor in exelent condition.
- WTB B-series Vtec Rocker Arms ASAP
- WTB: 92-95 HATCH
- WTB: 98-02 Accord V6 Intake Manifold
- WTB: gsr headgasket and arp,aebs, or ge head studs
- WTB: transmission for my b16
- 92-95 Civic headlight/blinker control lever
- WTB: BBK Intake manifold b18c1
- WTB: Integra Type-R Front Driver Side Lower Control Arms - Sway Bar Link
- WTB: full coil over set up for 5th gen prelude
- wtb rhd eg wiper cowl
- WTB: JDM integra front lip
- WTB Catalytic converter
- OMNI POWER REAR LOWER CONTROL ARMS DC/EG (OLD STYLE)
- wtb d-series 5spd tranny hopfully ex/si
- WTB 90-93 da6 inside door handle driver side and rear garnish
- wtb 92-95civic coupe, or 97-01 prelude 7000in hand
- WTB STOCK AIR INTAKE FOR 90-93 Integra QUICKLY
- WTB: T25 Turbo and D series manifold
- turbo h22
- WTB: JDM EG Climate Control & Cluster
- WTB: 40-40 prop valve for abs delete
- ~~~WTB 98+ INTEGRA PARTS~~~
- WTB: OEM EG/EJ1 BLACK CARPET
- obd0 dizzy needed d-series
- WTB: PURGE SOLENOID FROM OBD2 LS MANIFOLD ASAP SoCal
- AJ's HUGE WTB Thread: Mainly DC Integra Parts, OEM Water Pump, Oil Pump
- WTB: Stock Civic EX Header
- WTB: JDM Integra Front lip
- WTB: 95 Ls power steering
- WTB '89+ Hatch or any year CRX HF (Near Colorado)
- WTB: 2500 word research paper
- WTB EE9 EDM LHD Power Window Switches
- wtb: 88-89 civic hatchback oem corner light
- JUN EK wing or Carbon Jun Style EK Wing
- WTB: Front bumper for 05' Honda Accord
- rsx ep3 stock mounts and parts
- WTB: ASAP 1999-2000 OEM SI Front LCAs
- WTB oem integra optional rear valences
- WTB: H22 H22a Head and Manifold
- WTB: expired takata harness
- WTB: OEM Stock Integra Type R Axleback or Catback In Good Cond.
- Looking for 16 inch or 17 inch 4X100 Rims with usable tires.
- Exhaust for 94 LS Integra
- WTB: Mint Integra LS OBD1 Valve Cover
- wtb angled exhaust for 92-95 hatch
- wtb apexi n1 exhaust for 92-95 hatch (angled)
- wtb 99-00 stock si shift knob
- WTB:gsr parts
- wtb: VTEC spool solenoid valve
- I need an H22 shift linkage
- wtb rear leather seats
- WTB: CIVIC CENTER CAPS FOR MY STEELIES!!!!!!!!!
- wtb: Integra interior
- WTB: Honda stuff! Help!
- WTB: 310cc injectors and FMU
- WTB: 99-00 hatch shell
- WTB: B series VTEC Solenoid
- WTB: '99-00 Civic Si Dash Harness
- WTB: MPFI OBD-0 Civic/Crx IACV/EACV (For D15B6)
- WTB: Stock b18b or b18c short block. pref, low miles.
- Anyone Selling a GSR CRANK?
- WTB: OEM Si wheels or LS Mesh wheels!
- WTB: 96-00 Civic cluster $40
- WTB-willing to pay 200 for real ctr grille, 96-98!!
- NEED P75 ECU IN SOCAL
- WTB: Laptopfor engine management
- WTB: 96-00 civic EX catalytic
- WTB: Wheels ROTA.Nippon.OEM.Ect
- WTB: 3" catback exhaust for civic EG hatch
- AEM wideband gauge only
- WTB GSR blades in Maryland
- WTB 88-91 SI HUBS
- wtb: obd1 ls dizzy distributor
- gsr cluster
- WTB: TD41 Distributor [TD-41] Civic D15b Non-VTEC 1992-1995
- WTB ls head off a 94-00 integra
- WTB:P28,P30 and p72 ecus!!!!!!
- wtb: 03 acura TL FULL FACTORY GROUND KIT
- WTB: ARP headstuds for D16Y8
- 95 newer 4DR integra
- WTB: integra 4dr grey leather MIAMI
- WTB: safc or vafc or chipped ecu
- WTB: 96-98 Civic Coupe Silver Hood
- wtb: sohc jackson
- WTB - Radiator fan PLUG
- WTB: 38mm Wastegate Dumptube
- WTB A CAR
- WTB: B series TB with Map Sensor on the TB
- WTB ABS sensor del sol (rear)
- wtb: Distributor for a 93 accord?
