View Full Version : Want to Buy
- WTB h22 4.64 final drive
- WTB: Integra Type R Crank Pulley
- WTB: EG dash harness
- WTB: 96-00 civic ek sohc driver side engine mount bracket
- H series tucked loom
- window regulator motor
- wrb aem uego gauge only
- Wtb b16 Gsr head
- WTB: Need ASAP 97 to 01 Honda Prelude SH engine harness
- WTB: 1996-2000 OEM Honda Civic Sunvisors L + R (Grey)
- WTB: B SERIES ENGINE PARTS
- WTB your Dead S80 1996-2001 Integra Transmission
- WTB: B18C GSR Aftermarket Manifold
- WTB: DB7/DB8 All clear tail lights!!!
- WTB Seat rails (Recaro) 90-91 Civic
- wtb CROW Racing Harness Cam Lock
- WTB EG Clear Corner Lights. No cracks or breaks.
- ***** CRX Eibach SPORTLINE springs ***********
- OBD1, d16z6 Transmission, manual.
- WTB: EF9 Bumper Corner Lights
- Performer X for GSR
- WTB: 98-01 Integra Type R Nose Mask/Front Bra
- WTB: 99-00 climate control swap
- ARP main studs or GSR girdle bolts
- WTB 2001 civic coupe COILOVERS
- WTB blue eg glovebox latch
- WTB: EG6 oem clear corners T.O, canada
- WTB: 92-95 EX/SI differential
- wtb: gsr or b16 exhaust camshaft
- WTB (NYC) Blades/Swirlies
- WTB:EK 2dr driverside door panel
- ODB1 wiring harness
- Need an Eagle Rod and stock crank for B18B1
- Need A Wiseco Piston and Rings
- WTB: Cable DOHC ZC gearset/Any A6 performance parts
- WTB: 12mm shoulder nuts for Todd's Caster plates
- WTB: p72 gsr UPPER power steering bracket
- Wtb Rhd 92-95 civic dashboard brackets
- Wtb. Obd2 gsr timing cover
- Wtb ssr type x wheels 4x100
- WTB k20 swap header for EK
- WTB 26mm front sway, FLCAs, forks 99-00 SI/EK9
- WTB: ITR flywheel & ITR door panels
- WTB: Kpro, kswap dc conversion harness
- Need a dc/eg buddy club seat rail with bracket passeger side
- wtb buddy club spec 2 exhaust for 96-00 civic hatchback
- 16x8" 4x100 rota slips
- WTB ef hatch a/c parts
- WTB type r cams
- WTB: Itr lsd, and Itr/Gsr ring gear and countershaft 4.4 fd
- wtb twin disk clutch
- WTB : honda civic eg dashboard side tab
- WTB : Integra DB1 ('90-'93) Sunroof Glass
- WTB : Honda s2000 AP2 clean or salvaged in California
- WTB: evap canister
- WTB: Racing Hart Type C Tracer center caps
- WTB: CKF Plug GSR OBD2 EK
- B16 HEADERS??
- Wanted: gsr/itr 4.4 ring gear and countershaft
- WTB: Bucket seat
- wtby 15" itr/ctr wheel
- Wtb: suspension
- WTB: Honda civic Bay Area
- NEW MEXICO
- wtb: del sol p30 upper ps bracket
- GSR oil pan & GSR girdle
- WTB USDM ITR Carbon fiber trim interior
- WTB Rota center cap
- WTB: OBD1 Ecu's
- WTB Hydro B16 Final Drive & Pinion ASAP!!!
- WTB: AP2 driver side HID ballast
- WTB: EM1 wiring harness & other parts
- WTB DA9 (or other compatible) ebrake cable brackets
- 02-04 k series transmisssion
- Gsr/type R
- WTB integra type-r final drive and LSD
- WTB: RBC Intake Manifold and RSX Password JDM Intake
- wtb: civic b swap whale penis intake
- Wtb Integra Driver Door Handle
- WTB 2001-2003 CIVIC HOOD BRA
- Gsr girdle & Gsr oil pan
- WTB : Civic Si 06-11 FlashPro
- WTB h22 p13 93-96 prelude power steering bracket and mounting bolts
- WTB prelude jrsc jackshaft pulley
- WTB: D Series Aftermarket Cam - Turbo
- Wtb B Series Vtec Head & Virgin OBD1 p72/p28
- WTB Driver side spoon replica mirror
- wtb d16 after market valves stock size
- B series PLM TA header
- WTB: reliable stock car
- WTB: obd1 b16a distributor or gsr
- WTB: OH: In need of b17 crankshaft only
- WTB: Rims OEM or Aftermarket
- Wtb: iacv 98 integra gsr
- WTB EK 96-98 Civic drivers front fender
- WTB OEM EK9 WINDOW VISORS
- 99-00 obd2b Si harness
- WTB: Looking for D Series Aftermarket LSD
- WTB 37820-P2J-011 ECU
- WTB rear drag coilovers
- 98-01 GSR Cluster Harness
- P73-A03 98 spec itr ecu
- WTB: TIAL 38MM 2bolt WASTEGATE FIRE RING / VALVE SEAT
- WTB: Ek Hatch front and rear mud flaps
- Ctr for itr pistons?
- wtb kpro ecu
- wtb k eg-headers and wilwood brake kit
- WTB: Spoon Sports EG6 Gauge Cluster and First Gen Steering Wheel
- H22 cams
- WTB: Integra lowering springs
- Wtb front integra bbk..
- WTB:B series short block in South Jersey
- WTB: Toda B Series Header
- Ltb crower 404s,Ef , b series parts
- WTB: TODA B SERIES HEADERS
- WTB c's driving position shifter
- WTB B16 Air Intake Box Setup or COMPTEC ICE BOX
- WTB EK 96-00 Power Mirror switch
- WTB Vehicle speed sensor
- Need Vision Type DC mirrors
- Want to buy 94-01 integra gsr IAB sensor.
- WTB: ~81mm forged pistons 10-11.5 CR
- WTB: tapped or normal k20 aluminum Oil Pan ASAP
- WTB:Stock 92-95 Civic LCAs
- WTB: Adjustable cam gears b18c1
- WTB: B16 HEAD STUDS, OBD2/OBD1 Matching set of injectors (240-450cc)
- WTB: 99-00 EBP Si parts (PDX)
- WTB: 96-98 SOHC VTEC 5spd Engine harness
- WTB - 4 lug hubcaps (wheel covers) 4x100
- WTB: 1 piece coil overs for EG
- WTB:92-95 civic gauge cluster or WTT GSR cluster for eg cluster
- C's short shifter dual bend DC2 version?
- wtb non vtec obd1 ECU
- WTB: 3" Exhaust for EK
- WTB: JDM headlights, Recaro seat rails, trim pieces
- wtb h22 arp head studs
- N. TX WTT: Mint Seibon Carbon Fiber hood for factory hood EG sedan
- WTB:96-00 CIVIC COUPE OEM SPOILER
- H22A motor
- WTB: JDM 4.7 final drive or 4.9 final drive
- WTB: JDM ITR DC2 Steering wheel with srs
- WTB: 4 injectors 370cc-540cc that fit h22a4 stock fuel rail and manifold
- WTB: need 4 d16y7 obd2 injectors!!
- WTB JDM H23 vtec automatic chipped ECU :)
- ac tensioner 97 civic ex
- B series vtec valve cover, power steering
- Wtb msd 2 step controller
- WTB: 99-00 civic si engine harness
- adjustable k series exhaust cam gear
- WTB: NEED NEED P72 GSR B18C1 VTEC Upper Power Steering Bracket! NEED***
- Wtb obd1 h22 engine harness to fit 92-95civic/integra
- WTB p29 ecu. For the DOHC ZC D series engine. ASAP!!!!
- WTB: K20 transmission
- WTB used full coilovers 4 eg/DC
- wtb: h2b kit
- Wtb: One 82mm ctr piston or 4 82mm b-series pistons
- WTB GSR ARP HEAD STUDS
- WTB: Purge Cut Solenoid, B16 (P30) PS brackets
- Cams for N/A B18A, springs and retainers
- WTB - 1 single GSR Fat Five 15" rim
- wtb 99-00 ek4 auto cluster
- Wtb old skunk2 posters
- Wtb: password jdm intake for d/b series "whale penis"
- wtb: QSD H2B Oil Pan
- WTB: GT35R T4 CASH IN HAND
- WTB 1x SW388 15x6.5" 4x100 ET45
- WTB: 06-08 civic sun visor both sides
- WTB: d16z6 distributor
- iso: springs
- WTB: DC2 or EK Tein Flex
- WTB: idle air control valve for 98 crv ASAP!
- WTB: NRG quick release any color
- WTB: EK9 PARTS
- Wtb msd digital 6 plus
- WTB: toda replica header
- WTB: Traction Bar for EK
- WTB AEM 6050 or 6040 V2 EMS
- Wanted : civic slim fan and shroud
- DC5R Brembo's
- obd1 map, 4 wire o2
- WTB: Autopower race rollbar 92-95 civic h/b
- WTB UNCUT! Acura ITR 98-01 Engine Harness
- WTB: B16A JDM Hydro Transmission w/ LS 5th
- B16 transmission outer casing
- WTB: 96 -00 EK Front Lower arms, sway bar
- WTB: 96-00 EK CIVIC COUPE DRIVER DOOR WINDOW CHANNEL MOLDING SASH
- WTB: jdm eg/ej stanley clear corners
- WTB: Edlebrock Performer X Intake Manifold
- WTB: B series vtec top power steering bracket
- Looking for dc kswap parts
- WTB sw388
- WTB: B SERIES REAR MOTOR MOUNT BOLTS.
- WTB B16 Edelbrock Victor X Intake
- Wanted: Ek9 Oem axleback
- Wtb moates burn1 or 2
- WTB: 3" vband downpipe
- WTB: MS Design del Sol front lip
- Want cams for f22a
- WTB ASAP b18b1 LS complete engine harness/ LS Shift linkage
- WTB 1998 Hona Civic DX Automatic Transmission
- wtb bseries lsd
- wtb eg k swap header, kpro ecu
- Wtb Lsvtec boost parts
- WTB: (4) 13 or 14 inch 4x100 steelies w/tires
- WTB EM1 mounts
- WTB: ECU
- WTB: JDM ITR GUNMETAL WHEELS and any other oem itr parts
- WTB EF and Type R Parts
- WTB: DRAG DR-20 MATTE BLACK WITH RED STRIPE (2) WHEELS NEW 15x7 4x100 40mm OFFSET
- Wtb DB8 ALL CLEAR tailights
- WTB Power Folding Mirrors Civic Vg
- Fg2/fa5 seats
- Wtb: coilovers or lowering springs
- WTB OEM RSX / DC5 SIDE MARKERS
- RSX EXHAUST ASAP!
- sw388
- ek hatch dx steering joint
- WTB: 2003 Honda civic front bumper and hood
- OBD2B to OBD2A ecu jumper harness asap !
- AP1 S2000 Parts List
- K20a2 or k24a2 engine?
- WTB: LS/B20 blox/skunk2 intake manifold
- WTB 96-00 2DR/3DR Driver's Crank Door Panel
- Wtb : springs/retainers, fuel rail, fpr, ls arp,
- WTB: P7J CRV A/C BRACKET!
- WTB GSR/LSVTEC headstuds
- Wtb stock front sway bar and brackets 96 ex civic
- WTB: Vibrant muffler.
- WTB: d16z6 head
- WTB: GSR or B16 Valves set
- WTB: OEM 92-95 civic coupe car cover
- 90-93 integra t bracket for cable trans
- Wtb: 98+ front lip
- IN: J Swap for EK, Need everything
- DC Integra rear lower control arms
- B series rear t bracket
- Wtb eibach multi pro r2 suspension
- wtb: virgin usdm obd1 p72 manual ecu.. II
- WTB: GSR crankshaft & GSR block
- Looking for 88-91 Civic DPFI TPS
- LTB z6 camshaft
- Integra bumpers. Florida Alabama Georgia Missisippi Louisiana Texas
- WTB: B16/LS Oil Pickup, Windage Tray, and Oil Pan
- WTB LS Vtec build list:
- WANTED: APEXI SAFC SAFC 2 or NEO
- WTB - Urgent - D series OEM Gears
- Wanted: Jdm itr cat or universal OBD2 2.5"
- wtb Dc2 Parking pole
- WTB: 2WD Civic Wagon Rear Mudflaps
