View Full Version : Want to Buy
- WTB: 92-95 CIVIC P28 VIRGIN ECU
- WTB: Cluster with Tach perferably SI
- WTB: LS BARE Block with the only thing needing is a hone... (tristate)
- WTB: Hondata K-pro with DC5 ECU and AEM Wideband Lambda
- WTB: Seats in the Cleveland Ohio area
- HEads! b18c5 b18c1 Gsr Type r
- WTB: Black Halo headlights for an 88-89 crx
- WTB: HID kit for a CRX
- WTB: EDM/UKDM ITR/DC2 Guage Cluster
- WTB EK-B-Series motor mount
- WANT TO BUY - BRIDE EK/EG/DC TYPE RO SEAT RAILS AND SLIDERS
- WTB: Center taillight piece for a 90-91 crx
- d series block
- k24a2 into EK Swap Parts!!!!
- wtb: ground control coilovers and koni yellows or kyb's
- ~~~~FS:/FT JDM GM ITR WhEeLs~~~~
- WTB: cheap OBX d series intake mani. only really need plenum
- WTB::: Clean Hatch stock or not dosent matter Cali!!!
- WTB: Obd2a Ecus's LS, GSR, ITR CTRP74, P75, P72, P73, P2T
- Need Civic Hood in MD,Va,PA, DE
- WTB: OEM Optional Type R kit
- WTB: 96-98 OEM Front End Parts
- WTB: Stock Oem 00-01 Integra GSR B-pipe or Exhaust
- Straight a/c in columbia sc
- WTB: 2002 or NEWER civic
- WTB: 99-00 civic ex/si front bumper
- WTB OEM h22 fuel rail & reg
- WTB: b series vtec head, cams, etc
- Stock 94-95 Integra LS Intake
- WTB: Front Window Moldings and Roof Moldings
- wtb: type r style carbon fiber lip!!!!!!!!!!!!!!!!!!!!!! 97+ integra
- wtb itr lma's
- WTB: JDM ITR Final Drive
- Wanted HEADLINER !!!
- WTB: B16 Motor Mounts for 1996 Civic
- wtb C's Driving Position Short Shifter for EK/DC.
- WANTED: NEW JDM ITR VALVE COVER W/ LASER CUT CAMGEAR HOLES
- WTB: EK ARMREST!!
- WTB: JDM EG door panels *SOCAL*
- WTB: eg coupe parts
- WTB: Rear-disc conversion NOR-CAL
- WTB: GSR or ITR Longblock
- WTB: NON GSR THROTTLE BODY PULLEY
- WTB Integra Rear Bearing / Hub WITH ABS
- ***** WTB: CARBON FIBER CARGO COVER 96-00 CIVIC HB *****
- WTB ITR Pistons
- WTB S2000 STEERING WHEEL, 99-00 CIVIC REAR SEATS, 99-00 SEAT RAILS
- WTB SoCali Stage (2 or up) for gsr tranny
- WTB: d series motor and trans mounts for a 94 hatch
- need a lower control arm for a 97 civic ex
- WTB EJ1 Parts
- 1990 Acura Legend parts **ARIZONA**
- wtb h23 trans
- WTB: Non ABS 4040 Proportioning Valve
- WTB: GSR Black Leather Seats & 99-00 Civic Si Parts
- WTB: Integra 4040 40/40 brake valve in S California
- WTB: 98-01 Acura Integra Mud guards mud flaps with no mud please lol
- 1 Bogart Pro 4 rim
- i need 99-00 civic parts
- WTB: Apexi v-afc
- need a frost white integra hood asap
- WTB: 94-01 Oem Gsr Header
- WTB:CRV Cluster. 96-00
- WTB: aftermarket struts for my 90 integra 2 dr
- wtb beater car in Michigan
- WTB: 99-00 OEM Civic Headlights
- WTB: 14'' HX wheels....
- WTB::STOCK Z6 DOWNPIPE and/or MANIFOLD::
- wtb ek axle back
- WTB: **DC STAINLESS STEEL HEADERS**
- WTB: Stock EG airbox and intake arm
- WTB: Greddy emanage support tool and cable
- fs: civic and integra hoods
- Need Help!!! Carfax.
- WTT: my EK Type R wing for your Spoon duckbill
- WTB: Integra 90-93 driver side headlight stock
- WTB: Timing chain covers for 95 accord sohc
- WTB: "1 or 2" Michelin Pilot HX MXM4 215 45 17 *ASAP*
- WTB: 205/45/16 tires
- CA.WTB 2 Drag Radial Tires for 14' and stock EG rear Trailing Arm( drum) passenger side
- WTB: H23 Block
- WTB: black carpet from a civic coupe, hatch, or Integra
- WTB: RHD EK or DC
- WTB pr3-3 or pr3-4 head
- WTB: EDM sohc vtec valve cover civic
- wtb: GSR BLADES/LS MESHIES IN SOCAL
- NEED MAIN RELAY FOR CRX SI,RZ-0063!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
- WTB: P30 Intake manifold w/ throttle body - as complete as possible - So Cal
- WTB: B-series...
- WTT: Black 1992 Prelude S
- WTB 99-00 si gauge cluster
- WTB: Electronic Boost Controller
- WTB--WTTod1 p13
- wtb : sohc civic d-series turbo manifold for t25 a/c compatible
- WTB: 99-00 civic coupe HOOD, FRONT BUMPER, TRUNK
- WTB: SRR lower control arms for EK
- WTB ex 5spd gauge cluster and drivers side airbag cover drk grey&steering wheel
- WTB: GSR or ITR Dual Bend Shift Knob
- WTB : EF parts
- WTB 88-91 heater duct out of a non A/C civic hatch.
- WTB: 99-00 Si rear T mount and driver side mount on engine...
- $$$$$$$$ ITR LONGBLOCK $$$$$$$$$$$$$
- WTB *MINT* 94-97 2dr acura integra taillights *Must be Mint*
- wtb or trade for some type r seats mostly front want rear also but front mainly !!!
- wtb.. someone here had BRAND new front n rear eg hatch bumpers
- wtb:crv b20
- 90-93 DA
- WTB OBD1 DIZZY
- wtb: Apexi WS2 Muffler, Integra
- WTB: Camber kit for 90-91 EF civic
- wtb b16 head
- wtb: 15 or 16in wheels
- wtb stock 05+ s2000 wheels
- WTB: black civic hatch carpet for eg 92-95
- WTB side mirror block off plates for 96 teg?
- WTB: H&R sport springs for 90-93 teg
- WTB: 88-91 crx /88-91 CIVIC CATBACK EXHAUST ASAFP
- WTB - 90-91 crx si gauge cluster.
- WTB: (NJ area) Clean Stock/Close to stock '96-'00 civic EK coupe under 200k miles
- WTB: Skunk II intake Mani for D16z6
- WTB: stock EG airbox and intake arm (so. cal)
- WTB: B16A OBD1 wiring harness
- WTB Black Caps with Red Honda Logo for 15 Rotas.
- WTB: EG Rear TAILGATE + Driver-side rear INNER Lamp SO CAL
- WTB: D16Y8 Throttle Body with TPS
- WTB OBD1 parts
- WTB: B18c1 Silver Aem Fuel Rail #25-100
- WTB: 1991 EF Civic SiR Carbon fibler hood for USDM headlights and bumper.
- ::WTB:: Wideband o2 sensor
- WTB: gsr cluster with 100-120k
- WTB: B18A1
- WTB: B18C6 Crank. Hurry
- WTB> 94 Integra Driverside Fender
- WTB: 99-01 Carbon Fiber Lip Seibon MG-Style
- WTB: D16Z6 IN WISCONSIN
- wtb: p54 ac bracket with pulley
- ***WTB B SERIES LINKAGES ASAP***
- WTB: 1999 - 2000 civic si engine brackets
- WTB: Boost Gauge
- wtb: tow hooks and side markers
- wtb gold volk GTU 17x7.5 5x114 40+ offset.....
- wtb asap walbro 255 pump for integra
- WTB: TYPE R IACV
- WTB: PWO or PR3 ecu
- wtb vx diffuser
- wtb - 95 prelude stock/oem exhaust
- WTT my 16in sparco rims for your rota/spoon's
- i need a type r suspension and some other parts 4 my ek
- B series manual hydro trans NJ
- WTB: A S A P EF Shift linkage and D16A6 Dizzy !!
- WTB: 94-01 Integra GSR OEM/Stock Exhaust (Axle Back)
- WTB: front struts aftermarket 91 Integra strut shock kyb agx koni *CASH*
- WTB: Complete JDM EG6 Interior *SOCAL*
- license plates from diff. states cheap
- HCP EG H22 AC BRACKET
- WTB Streetable Velocity Stack
- WTB Hydro Tranny for my 98 GSR
- WTB: D16Y8 alternator working cheap
- WTB: All Black Del Sol seats ** pic included **
- WTB: EK pass side air bag block off
- WTB: rsx shift linkage
- WTB: UKDM Integra taillights
- wtb: 98 type r head...
- wtb:***Black Golden Eagle Fuel Rail B Series***
- WTB: P28 ECU I need 10 of them.
- D Series Alternator
- WTB: s2000 trunk liner
- looking for 96-00 civic ex gauge cluster
- WTB Quad
- WTB D16z6 Crank pulley
- WTB: Smashed/Dented DC header with Carb plaque still on it.
- wtb b series throttle body or TPS
- WTB: Rear spoiler screws and bolts (all of them), plus other hardware.
- WTT: JL 1000/1 & JL 13" W7 in W7 Pro wedge box for ***94 Integra GSR Parts***
- WTB Grenada black Integra Door Protector molding
- wtb 16" rota slips
- WTB: Integra LS 5speed (94+) SEPA (Philly)
- WTB: Import Tuner Magazine Back Issue
- WTB: DC Sports Lower Tie bar 94-01 INTEGRA
- wtb h22 spark plug cover, good condition
- Wtb: 91 civic cable tranny
- WTB: ASAP!!!!! h22 downpipe w/ 3 bolt flange
- wtb - '02-04 RSX-S k20a2 PRIMARY o2 sensor need asap
- WTB: Toda header.
- Victor X Intake Manifold throttle Bracket.
- Headgasket
- -------WTB: OBD1 GSR DISTRIBUTOR DIZZY --------VA
- WTB: eG oem front bumper!!!
- wtb 70 to 75 b series tb
- WTB: Stock ITR Shocks & Springs
- WTB: 98-01 Integra Front USDM OEM
- WTB: Carfax Report - 5$ to the first guy...
- WTT: D series overbore rings for stock rings
- WTB: OBD1 ecu's
- WTB: D series fuel banjo bolt and valve cover grommet
- Wtb: Aebs intake manifold for a gsr...and throttle body if you have one.
- WTB: 15/16 MC for GSR disc brake conversion
- WTB: 94-95 Civic EX Coupe Driver side door with functioning window and mirrors
- WTB: 92-00 civic front end, 92-00 Civic A/C system, 92-00 complete Dash+center console, and 94-01 co
- WTB one OEM ZC piston or equivalent.
- WTB Misc, JDM Conversion Parts
- WTB: 4-1 Header with 2.5" collector
- WTB: complete D-series swap (OBD0 or OBDI)
- WTB: JDM CRX Corner Lights
- LS SWAPS OUT THERE FOR SALE??
- WTB: 91 Civic auto Tranmission (Seattle)
- wtb: gsr tb in so cal
- WTB: Used aftermarket Fuel Rail for B series
- WTB Stock airbox complete for 96-00 Honda civic ex
- Does anyone have a header CARB EO plaque? Need one badly
- WTB cheap b series header ASAP -- eastcoast -- SC
- WTT: 95 GSR tranny+ cash for LSD tranny!
- WTB Integra driver side door and fender SOCAL
- WTB Bose RSX Spare Tire Subwoofer
- WTB:90-93 Integra Carbing
- WTB: TSX Projectors and HIDS
- 94+ third brake light for integra
- D16Y8 Intake Manifold
- wtb: 99-00 civic red front bumper
- WTB H4 casper shields for HID
- WTT PW0 for P28 ECU
- WTB: Element Armrest
- WTB: 94-00 integra lower center console
- wtb obd2 wire harness
- wtb real ctr/sir 96-98 headlights
- WTB: SPOON STEERING WHEEL!!!
- WTB: AEM FUEL RAIL & FPR!
- WTB: SKUNK2 GOLD LCA'S AND COMPTECH REAR TIE BAR!
- WTB: CTR OR SKUNK2 STAGE 1 CAMSHAFTS!!!
- Cam plug/seal for f20b
- WTB: d16a6 or d16 block for rebuild.
- WTB: 96 Integra Front Sway bar endlinks complete
- WTB blown turbo
- 88-91 civic/crx si distributor (complete w/ cap and rotor)
- WTB: ASAP 0BD0 Distributor - NJ, NY
- WTB: 90-91 CRX Doors
- WANTED: rsx-s axle back exhaust
- wtb z6 intake manifold support bracket
- WTB - gsr Kamikaze header and rsr exmag exhaust
- i need a carfax please
- WTB~~~~~~~~~~~~~~> 98-01 INTEGRA TYPE R LIP!!!!!!!!!!!!!!!!!!!!!
- WTB: Z6 Distributor Housing
- WTB: 99-00 Civic Si or GSR Brakes/discs Complete (SoCal)
- WTB: Stock Ex Coupe 97-00
- WTB: full Z6 gasket set, from valve cover to oil pan, ASAP!!!
- si rear T mount
- WTB: Roma Red EK Power Doors
- obd coversion harness and a p28 or p72 ecu and crome pro or hondata
- WTB: GSR obd1 engine harness
- WTB 94-97 2DR JDM spec INTEGRA Taillights
