View Full Version : Want to Buy
- WTB: 96-00 4dr civic trunk interior panels
- WTB: Stock eg hatch suspension and wheels
- wtb 96-98
- WTB: Stock Integra dual bend shifter
- WTB virgin usdm p73 ecu
- WTB Blue Tophats for ID1000 B series
- WTB: CRX HF front sway bar and shift linkage
- WTB EK Ferio/four door Parts
- Wtb: white volk te37 17x7.5+40 5x114.3
- WTB a integra exhaust
- WTB: 16x7 4x100 TE37 or Regamaster
- WTB: gsr coupe driverside door panel
- wtb: stock 97-01 honda prelude shocks & sprigns
- WTB: Pair SSR Reverse Mesh 15s WTT: Formula Mesh 15s
- WTB: B20 crank pulley CRV
- wtb ep3, s2k, or em2 steering wheel
- stock fifth gen prelude base intake
- wtb coil overs or full bodys
- WTB: OEM DB8 GSR Sedan axle-back muffler ...
- WTB Integra flywheel and axle bolts
- WTB:96-00 Window Visors/OEM CTR Wing/CTR Rear Seats
- Wtb 1600-2000cc injectors
- WTB: 94 Civic HB Power LOCK kit
- WTB k20a3 ecu
- WTB: Hydro GSR Tranmission
- 92-95 civic e brake
- Wtb rsx interior parts.
- WTB:2003+ accord
- WTB: OBD2A 10 pin B series VTEC distributor ASAP!!!
- WTB: Integra Shell
- WTB: rota grids 16x8 4x100 +20
- WTB 1 rear EG / DC Tokico Blue Shock
- WTB: Mugen parts. Valve Cover. Header. Steering Wheel. Oil Pan. Strut Bar.
- WTB: JDM ITR TRANSMISSION LSD
- Race Harness belts: G-force, RCI, RJS
- WTB: 99 EK Vi-RS grille
- WTB Full D series swap kit.
- WTB: VX rims
- 92-94 Eg civic r12 ac lines
- WTB: b16 or itr intake manifold
- WTB Ek 96-00 civic H22 Hasport mounts
- wtb: b series tapped oil pan for turbo and gauges
- WTB: EG sedan hood bra
- WTB 99-00 si power steering pump
- WTB EF traction bar
- WTB: SPOON EK AND EG CLUSTER
- Want:::::: Si Grill / OBD2 Jumper Harness
- WTB: LS arp headstuds and/or arp rod bolts
- WTB/borrow OBD1 P72 94-95 Integra GS-R ECU
- RSX-S Shorty header
- EX Valves b16 b18
- WTB Vtec solenoid/spool valve assembly
- OBX ITBS B16 head
- WTB: EG hatch parts
- WTB:94-01 Acura Integra LS front spindle (passenger side or both)
- WTB: Hasport h22 mounts for EG and axles
- WTB EF SEDAN
- WTB: OEM Single Din pocket - CLEAN!
- WTB 97-01 prelude auto to manual conv. parts
- WTB: GSR Crank
- WTB ITR ARM REST, US ITR CLUSTER , CIVIC FAL FAN,CATCH CAN
- sedan or wagon DD--$4k cash.
- WTB: EM1 Si Cluster and SI GRILL and CTR Cluster
- WTB Tokico 5049f spring
- Wtb k24 block
- WTB: 92-95 civic hatch aftermarket duckbill
- WTB: 88-89 CRX Passenger Door Molding
- WTB: P8R B20 CYLINDER HEAD
- WTB: 96-00 Civic Hasport B-Series mounts
- wtb intermittent wiper control
- wtb: 81.5 mm LS piston
- wtb: 1999-2000 civic parts
- 88-91 awd wagon rear trailing arms
- WTB. EK GAS & BRAKE PEDAL ASSEMBLY (5speed)
- EG hatch Sideskirts(CX black unpainted) SSR Reverse Mesh 15"(Pair or complete)***
- WTB: 94-01 Integra Access Visors
- WTB: B18B1 long block 99-00
- WTB: Clean CRX
- wtb a 99-00 si cluster
- wtb d15b7 dizzy asap
- WTB: 16" 4x100 TE37
- WTB: JACKSON RACING SUPERCHARGER FOR DC2R
- wtb: QSD h2b kit
- CenCal: WTB OEM 2002 Base RSX intake
- 13" drag slicks & rims 23" prefered
- Yakima Roof rack with basket, S. Cali
- CT-WTB k24 oil pan
- WTB: h22 header
- WTB: 99-00 "EK" stuff
- Wtb 92mm crank for b series
- WTB: Scion TC fender
- gsr eagle rods
- WTB 1000cc injectors for b series obd1
- WTB: EF9 bumper lights
- WTB: B series ATI street damper
- WTB: 90-91 Civic Cluster with Tachometer.
- ltb cam gears for b series
- WTB: Innovative B series cable mount 75a for CRX/EF Civic
- WTB: LS Transmission
- wtb:skunk2 gears
- WTB: 28T caliper brackets
- WTB D17 Coils
- wtb obd2 h22 310 injectors
- WTB 1996 EK Sedan Passenger Side Fender n headlight
- WTB: 1 PAIR of BBS LM 19" 5x114.3 any condition
- WTB: EK9 CTR CLUSTER
- WTB: Fullbody EK Coilovers!
- WTB: 96-00 Civic Fog Light Switch
- WTB: B series VTEC and H22 vtec valve covers.
- Liberty casing (GSR)
- wtb - 99-00 civic si fuel pump - OE type
- Wtb: z6 crank
- WTB: OEM B18A1 Integra LS fuel injector connectors
- wtb:b and d series input shaft bearing
- WTB: whale dong intake
- Wtb EG 3 piece front end
- WTB/WTT EG HATCH
- WTB: D17 headers- stock, oem
- WTB moonroof sunshade 96-00 ej8
- Wtb oem catalytic converters
- Injector Dynamics 1000cc
- Wtb 99-00 SI climate control amber bulbs
- WTB: dc2 oem parts
- WTB: Vtec solenoid pressure sensor harness/clip f
- Wtb: 94-01 integra ls rear brake calipers
- Wtb 96 ek sedan parts
- WTB: 92 INTEGRA ECU - PR4-A61 STOCK ENGINE
- WTB: 99-00 Si Engine harness
- wtb:optional usdm center console civic eg 92-95
- WTB 94-97 Integra RS Brake Booster
- WTT S2000 AP2 V2 for Lip or Diffuser or Quick hub
- Wtb hubcaps
- Wtb: 99-00 civic ex/hx/si engine harness
- wtb:92-95 civic hatch oem spoiler
- WTT: Mugen exhaust
- Del Sol Seats
- WTB : D16y8 SOHC Cylinder Head
- WTB: Integra 94-01 DB8 Visors
- wtb: nice set of integra center caps
- Coilovers,ati,oem,5.9
- WTB H22 Moroso and arp main
- WTB evo 9 turbo
- WTB: Cash in hand! ARC Winglets. Ready to Paypal or meet (socal)
- 757 WTB: 99-00 civic si engine harness complete and uncut 757
- wtb: rsx type s head.
- looking for a Canadian civic sir p2t ecu
- WTB: b16 injectors p28 ecu eastern PA
- Need d16y8
- WTB: JDM ITR shift boot
- wtb: LS/b20 forged rods asap
- WTB Uncut Interior Wiring Harness for 1990-1991 Civic DX
- Wtb: Del Sol Greddy exhaust
- wtb: turbo kit
- WTB: Various B series parts
- WTB OEM prelude axle back/muffler or good oem muffler
- WTB OEM ONLY CTR FRONT LIP AND THIN SIDE MOLDING
- WTB: DIAMOND RACING WHEELS 16X5'114
- WTB: 98+ Corner light Brackets
- WTB: EF9 JDM front bumper lights, JDM LED wing.
- WTB: A/C vent clip
- Wtb: Snap On Valve Keeper tool #GA317
- WTB: 04 TSX Tan Parts
- WTB: Civic Wagon RT 4WD -- NJ
- wtb:92-95 civic steering wheel
- Wtb: Black or grey oem eg coupe carpet used
- ID 1000 Injectors
- WTB: D SERIES SPEED SENSOR D16
- i need this part plz
- WTB: Integra OEM top hats and Cowling
- wtb: blox weighted shift knob
- 3 Bar Map sensor
- I need jdm delsol door handle rods for map lights
- WTB: Integra fenders, Vtec valve spring compressor
- wtb 96-00 b-series manual tranny top mount
- WTB: Forged LS/B20 Rods....
- TurboXS RFL OR Tial Q
- WTB: Honda Element 5-speed black shift knob
- WTB 99-00 civic si engine harness
- Rywire Harness B series EG
- WTB 99-00 SI Oem ReAR Lip
- Scammed. Watch out
- WTB: cheap b series vtec stock valvecover
- wtb obd2b to obd1 jumper harness, wiper stalk and dizzy
- Wtb: 9004 & H3 HID lights.
- WANT TO BUY- NH-90-93 INTEGRA CANADIAN MANUAL SEATBELT CONVERSION
- WTB RC 750 Injectors high impidence/saturated
- WTB: 98 Spec JDM ITR 4-1 Header
- WTB: Crower valvetrain
- WTB: EG6 Parts and Etc.
- WTB: GSR Leather Seats
- WTB: edlebrock victor x manifold for gsr and other b series and eg hatch parts
- Victor X, AEM Fuel Rail, 68mm+ TB, Cam Gears
- WTB: B16/itr JRSC cash in hand
- WTB: Honda Civic 88-91 Si Dc Sports Header
- WTB: Carbon fiber hood/Fiber glass used 92-95 hatch
- Wtb eg black glove box complete
- Wtb h22 crank gear
- WT: D-series (EK) A/C Compressor
- Just bought a 2003 Type-S and I need parts...
- WTB S2K.......
- WTB: OBD2 GSR Timing cover
- 68-70mm throttle body
- MAC solenoid (aem, hondata, etc.)
- Tail Lights for 92 Eg 4 door
- Wanted: broken/damaged B16 cylinder head
- WTB: Glove Box complete for DX Hatch
- 94-01 Acura Integra Carbon Fiber Trunk
- WTB EK Full CoilOver Setup In Located In CT
- WTB: CTR Muffler
- WTB - 4040 prop valve
- WTB: Christmas Gift 30$ avoiding fake parts.
- WTB: OBD1 GSR Engine+Cabin Harness+P72 ECU
- WTB Antenna and Dome light for 2000 Civic EX
- WTB usdm b16 pistons
- rear upper/lower control arms, rear camber kit
- WTB ITR Exhaust Cam
- Wtb 89-91 civic si transmission
- WTB 90-91 civic main and dash wire harness uncut
- wtb: 98-01 oem integra type r lip
- WTB: D16z6 (Automatic) Throttle body or throttle body lever/Linkage
- wtb eg sedan front driver side mud flap/guard
- WTB: 88-91 CRX HF/DX shell
- CRX Jdm/Edm "GLASSTOP ROOF" 88-91
- WTB OBD1 CATALYTIC CONVERTER WITH 02 (EG/DC)
- WTB. Civic 99-00 Hood bra and EBP wing
- B series Fully Built Head
- WTB: DOHC ZC Head and Parts
- WTB: em2 stuff
- WTB: Seats!! Recaro, Bride, OEM JDM
- wtb: skunk2 pro2
- WTB: OEM Single din block off plate.
- wtb delsol or crv ac bracket
- WANTED: 16x7 5Zigen Div.3 N1R Center Caps
- WTB: Your Stock Civic 15" steel wheels and hubcaps that you have laying around
- WTB: 1.6 96-00 Acura el trunk lid w/inner tail lights
- WTB lowering springs or coilovers for Integra
- WTB: FEMALE KNOCK SENSOR PLUG
- 92-95 civic vx Internal bumper grille cover see pic.
- Wtb b16a2 camshafts
- WTB ukdm/edm front bumper or complete fog kit
- WTB: B Series trans with 4.7 or higher final drive + LSD
- WTB: Logic/High End h2b header
- WTB: OEM 99-00 Civic Si front upper strut bar
- wtb 88-89 civic hatch seat rails and pan, window regulators
- WTB: Harness plug for Temp gauge sensor
- WTB: TSX THROTTLE BODY! ASAP!
- WTB 92-95 Civic VX Exhaust manifold
- Wtb Catch Can
- WTB: B series flywheel
- WTB: Eg9 Civic Ferio SiR (or Vti) rear console! (top)
