View Full Version : Want to Buy
- WTB: 96+ civic seats
- WTB: Takata Harness (long version)
- WANTED : Sleeved GSR / B18c Block
- WTB DEL SOL RHD FRONT CLIP
- WTB new/used lowering springs 99 civic, 92-00 civic
- buying h22(prelude) shifter cables and BRACKET 96 model(5spd)
- WTB: 94-01 Integra shifter console / bezel / trim
- WTB: rims for 5th prelude
- WTB: gsr cluster and AEM cai for gsr
- WTB: 91 Accord Ex Auto Cluster.
- wtb: sprung 6 puck clutch with pressure plate.
- rhd car or shell
- WTB : RHD EG6 Driver Side Power Window Switch (USDM WONT WORK) so cal
- WTT my JDM SIR EF9 rear seats (I want USDM seats)
- Need asap rear 5 lug trailing arm
- WTB: forged LS rods I-Beam
- WTB: Greddy Trust SP muffler - EG
- NEED OIL PAN FOR 99-00 SI
- WTB: Suspension (Shocks and Coilovers) for a 98 4dr civic
- WTB: 16" wheels/tires, or 99/00 SI Wheels/Tires.
- wtb: 96-98 civic ex climate control in so cal
- wtb crx parts
- WTB : EG Duckbill
- Need a motor ASAP
- wtb: full coilovers and LCA's for 95 integra.
- WTB: SOHC SWAP JAX FL
- wtb SSR's type X (black w/red lip)
- WTB: 01 accord coupe lip kit
- WTB: OBD2B to OBD1 harness, jumper, converter
- t-shirt ideas and get $50 bucks..
- engine wire harness
- wtb: passenger FENDER stock for EG
- WANT TO BUY----> Mugen EK 96-00 Guage Cluster
- WTB: 1988 to 1991 CRX HF,SI for around 1000$ in Indiana,Ohio,Kentucky AREA or close to indiana. I wr
- WTB GT30R turbine
- WTB: Spool (b-series) and GSR 4th gear set
- WTB: Mugen MF10L 4X100
- WTB: 95+ DEL SOL VTEC shift linkage for B16
- WTB: JDM ITR 23mm Sway Bar Bushings Brackets.
- [WTB] EK suspension
- inetegra Roll cage
- WTB...B16A SHORT BLOCK ***sO-CAL
- wtb 98 EK CORBEAU SEAT BRACKETS OR ONES THAT WILL WORK ASAP
- WTB 450 dsm injectors
- wtb . sohc vtec head
- WTB: ITR CAMS!
- WTB: Polished Enkei Jspeed III
- WTB: 99-00 Civic Si OR 96-00 Civic EX Front Arms and Sway Bar Stuff
- WTB: a set of bad or broken EG B-series axles for cheap
- WTB ls b18b or b16 longblock or motor in new england
- WTB: 92-95 Coupe or Hatchback Front End
- B&M fpr
- wtb: jdm eg climate control and defroster switch and fog light switch
- WTB: OEM HONDA 3dr "hatchback" 92-95 TAIL LIGHTS
- WTB: [2003 Gauge Cluster]
- WTB: CRX, EF sedan coupe hatch CHEAP SOCAL
- wtb: 99-00 civic depo foglight + housing only
- WTB: 16x7.5 Kosei K1 wheels
- WTB: EG (EX or SI), EK (EX or Si)....
- WTB: k Swap EG/EK must be very clean
- WTB: 88-91 CRX keyless door handles- black
- wtb: d16y8 intake mani and tb.
- WTT: PA pickup only , My jdm zc for a SOHC vtec.
- wtb asap : crx si distributor
- WTB: Pistons
- Wanted 15" MR5's
- WTB: rear disc brake conversion for 90 crx...
- DA9 parts
- coilover wrenches
- WTB: Wings West (or other) Mugen style CRX rear bumper
- WTB: 94+ GSR or ITR (integra) alternator ASAP. new or rebuilt/used but in great condition
- WTB: CRX SI brake booster
- WTB: 96-00 Civic Hatch
- EF SiR Speedo with wires
- 6001/012NSL bearing (for b16 distributor)
- WTB: VSM 99-00 Civic front bumper, A/C lines
- WTB EGR for h22a!
- WTB: New/Used set of black housing rsx headlights
- wtb: usdm itr intake manifold
- WTBUY:
- WTB: oem EP steering wheel.
- WTB integra interior door panels...
- WTB: D16Y7 Cool Air Intake
- WTB: B18 tranny torque mount and bracket (lower passenger side mount :P )
- WTB: 92-00 Prelude shifter cables and assembly
- WTB: CTR cams asap
- wtb tranny
- WTB: 90-93 Integra Engine Mount Bracket for EF B Swap
- WTB WTT B18 LONGBLOCK HAVE TONS OF STUFF TO TRADE OR PAY CASH
- Help!!! WTB Old School Racing Harts Type C's prefer 15" but 16" are cool.
- WTB: CIVIC HATCHBACK REAR SPEAKER BRACKETS!!
- WTB: Lakewood Ti traction bar for EG
- WTB: 94-01 Integra shift linkage DC
- wtb del sol driver side glass
- WTBASAP!!! eg turnsignal wiringharness/plugs.
- WTB: DEL SOL VTEC or CRV A/C bracket
- [WTB] 96-00 civic ek carpet and back seats
- wtb 91 crx parts misc
- WTB: Clover Green 94-01 Integra hood in SOCAL
- WTB 88-89 CRX OEM corner light
- wtb: stock DA exhaust tips
- wtb: stock 96-98 civic header
- WTB: Smoked B-Series Spark Plug cover
- WTB: 96-98 Civic Climate Control Bezel ASAP!!!!! **PIC**
- NEED HEAD OR ENGINE ASAP
- WTB: Control Arm/CV shaft for 92-95 4dr lx civic.
- WTB / WTT - LS Crank (89mm)
- wtb b16header
- WTB: 97 Accord Sedan front end parts
- wtb-tweeters from a eg civic
- NEED TO BUY..NOT WTB: Integra motor parts
- WTB stock B16 rods any year
- WTB === White OEM 99-00 civic hood, oem paint
- WTT === red gt3's 16x7 straight, for silver/gold circuit 8's 16x7 straight SOCAL
- WTB: usdm type r or EP3 front seats
- wtb: y7 stock headers/kat together. odb2
- WTT: coil-overs for lowering springs for an eg hatchback
- wtb ls meshies
- WTB: Exhaust system for 96-00 Civic Ex/Si
- WTB: JRSC for type R
- WT Borrow: TimeSert B series
- WTB: 15" Tires, Koni yellow shocks, 2 GSR blades, Dohc Vtec Badge (GSR), 98 Conversion
- wtb a gsr header
- WTB: 99-00 Civic SI Tweeters
- wtb: single cam vtec motor
- I need your Short Geared Transmission Asap
- WTT eg teal power mirrors for black power mirrors OR WTB
- WTB: map sensor, chipped ecu,MSD
- WTB: vafc
- wtb: 99-00 Civic Si (SiR) front grille
- WTB: LS MESH with good tires or Wheels with good tires < $350 SOCAL
- WTB: SRR (Super Road Racing) Steering Wheel Hub
- !!!**!!!wtb!!!**!!! CRX SEATS 90-91
- wtb skunk2 drag springs
- wtb: 99-00 Si AEM V2 intake
- WTB: LS B18B OEM Head Gasket
- WTB GSR Oil Pan
- WTB: 99-00 Black Type R Front Lip
- registering RHD
- MUGEN SPOILER GEN1 or GEN 2 for DC2
- WTB - CIVIC SI 99-00 SWAY BARS!!
- prelude, h22, accord shifter cable brackets
- WTB: 97-01 Prelude MT Cluster Wiring or Underdash Harness
- WTB: Engine Bay Wiring harness for my 91 crx si
- WTB: Driver side 90-93 Integra DA Door no dents!!!!
- WTB: Y1 B16 Cable Clutch ASAP!!!!
- WTB: Work RSZ-R Valve Stems
- SC61 4bolt Discharge
- wtb 87 civic si taillights
- Need obd1 p28 p30 p72 ecu
- WTT: RO_JA LT5 Neo 17x7 6.8kg for anything
- WTT: Extra clean BLADES!!!!!
- WTB thermal 3 inch exhaust for 94-99 integra 4dr
- WTB: EP hatch Sun roof.
- wtb 96-98 civic...hood, upper core support, bumper cover, fenders, headlights.
- need d16 head a.s.a.p!
- WTB: Stock 99-00 Si springs...
- wtb:block guard b18a/b
- WTB: SKUNK2 CAMS AND B-SERIES ACT FLYWHEEL
- WTB: GSR or B20 transmission cover
- ef9 compelete sunroof
- Suspension 96-2000
- WTB: greddy sp2 exhaust for 92-95 civic hb si
- ******* WTB: LOWER POWER STEERING BRACKET FOR B16 - B18 ANY B-SERIES *******
- WTB: Front USDM ITR seats good Con, NOrCal
- WTB: Honda or Acura Center Caps
- WTT: Walbro 255 hp fuel pump for 255LPH. 88-91 civic/crx
- WtB : LS engine
- WTB: STOCK 99-00 Si EXHAUST
- WTB: REAR INTEGRA FOUR DOOR HANDLES WITH NO KEYHOLE BOTH LEFT/RGIHT
- WTB: Comptech Air filter for Integra Airbox
- WTB: 1994-2001 RS/LS/GS/GS-R Sedan ONLY
- WANTED - Anybody parting out a 88-91 Civic sedan?????
- wtb d16 longblock
- 99-00 Civic Climate Control Console, Mirrors, Side Skirts, Headlights, Grill, Gauge Trim. Ect
- WTB: 1 slipstream
- WTT: 96-98 fenders and grill socal
- WTB: SPOON CIVIC TYPE R GAUGE CLUSTER !!!!!!!!!!
- WTB: EK Side Skirts
- wtb lowering springs
- WTB: 92-95 Civic Coupe Body Parts! (Hood, Trunk, Fenders, Front & Rear Bumpers) NJ!!!
- 90-93 teg parts
- WTB: OIL PRESSURE SWITCH, I NEED VTAAKKK!
- WTB: EK9 ARC Magic wing (SPLITTERS)
- wtb: axle back
- ek want to buy list ... after market and oem ... also list of parts for sale or trade
- WTB === 99 - 00 civic si master cylinder / booster
- WTB: working B-series starter
- WTB: OEM GSR OBD2 Intake Manifold
- wtb : seats carpet glove box for eg
- WTB: CRX Ef8, EF7 OEM Clear Corner Lights, EF7 Headlights
- wtb:eg suspension
- WTB:Stock GSR Headstuds ASAP!
- >>>>>>>>>WANTED: short ram intake for integra LS>>>>>>&
- Integra struts/springs
- struts/shocks, and springs for EF
- WTB: 3" Turbo Thermal Exhaust for 97 civic coupe 2dr
- NEED 97 civic EX stock radio with working keyless entry
- WTB 94+ teggy front tranny bracket and mount for hydro tranny
- WTB MPFI distributor
- WTB: Tenzo R Racing seats
- WTB: B-series shift linkage for 88-91 civic. throttle cable bracket and more.
- WTB: 99-00 SI Front and rear mud guards
- WTB: integra dc2 heater core
- WTB: OEM parts for 99-00 EBP Civic Si
- im looking for 88-89 si front seats
- NEEDED: OBD-2 Lower Timing Gear (the one with the teeth)
- Need Jdm EG2 headlights stanley both
- WTB: D Series
- wtb HID retro fit for 92-95 civic
- WTB: 92-95 Civic Hatch Passenger Side Mirror (Non-power, unpainted black)
- wtb:95 accord cable ring for srs
- WTB: 95 Civic Headlights
- WTB: y8 Intake Manifold or just Throttle Body
- 90-91 LS clutch New or used
- WTB: ★ ★ ★ PIAA 959 ★ ★ ★
- WTB: Comptech Rear Lower Tie Bar for EG/EH
- WTB**B16/GSR/TypeR head**
- WTB:LS/V Motor
- ***** WTB: Blue or Red Rays EXTENDED Lug Nuts - DC2 Rear Lower Tie Bar *****
- WTB: 98 or newer integra front bumper
- WTB: b16 or b18 vtec head
- A EG/DA/DC2-CRX Shell
- WTB cable b16 tranny no grinds (( in or around MD only))
- WTB drivers side upper engine mount
- WTB: Auto P06 ECU
- WTB 92 Prelude VSS Vehical Speed Sensor
- WTT === b17 gsr, b20b, etc for ek swap parts, ie mounts, axles etc
- wtb: vx rim center caps
- Do Luck Floor Bar
- WTB: Hondata s200 w/boost and ecu.
- WTB: EK9 Buddy Club Spec II Silencer
- WTB: P06 ECU CHEAP
- WTB: 01-03 civic headlights
- WTB: integra ls seats (NO TAN)
- wtb: 92-95 civic mirrors in black plasic.. no paint!
- wtb--99/00 ek front...
- WTB: 94-01 integra intercooler pipes, tial wastegate, BOV
- WTB: OEM & Aftermarket B-Series Parts
- wtb 17" tire
- wtb prelude 5th gen oem rear lip
- Stock Integra CD player
- WTB:: REAL SPOON MIRRORS ORGINAL FLAT BLACK FOR DC2
- WTT: My srp 10.5:1 for low comp
- WTB - ray wheels lug nut KEY LOCK
- wtb cf trunk
- wtb lsd h22 tranny
- WTB clean CRX or Eg hatch
- WTB:GT42 and Tial
- WTB JDM EF9 PARTS!!!
