View Full Version : Want to Buy
- WTB: 95 Honda Accord EX calipers (driver side)
- WTB D16Y8 long block/ D16 short block.
- Looking for 4th gen prelude carbon fiber parts
- I WANT HEADERS
- WTB: D16ZC
- WTB wheels/tires
- wtb jrsc b16 manifold
- WTB-P28/Chipped/GSR Map/02 Sensor Delete
- 99/00 Civic Si
- WTB: B Series VSS
- WTB LS Aftermarket intake manifold
- WTB: The cleanest EJ2 you've ever seen!
- WTB: ek hatch suspension parts
- WTB silver front bumper for 1998 ek and a few other parts
- WTB: DC2 2dr 5spd
- WTB integra hub adapter
- ***WTB: OBD1 OR POSSIBLY OBD2 B SERIES VTEC DISTRIBUTOR (B16-GSR-TYPE-R)***
- WTB: Hytech Tri-Y replica header or SMSP replica
- WTB: EK Stuff!
- WTB : 1992/1993 Accord JDM One-Piece Headlights
- WTB: Prelude 92-96 OEM intake
- Tx-ok need h22 bent valves
- wtt/wtb wide band and injectors, fuel pump
- WTB: running d16 or cheap b swap
- WTB: ARP Head Studs - B18b1 - LS
- WTB/WTT: OBD2 GSR stock intake manifold
- WTB ef sedan parts
- Parts wanted for a 1993 Del Sol!
- WTB OEM USDM Integra foglights (Raybrig)
- 05 TSX Dashboard
- WTB: jrsc gsr manifold
- WTB: 90-91 Civic Hatch Front End (Fenders, Hood, Bumper,Filler) So Cal or Shipping
- WTB 96-00 civic suspension, motor mounts , turbo, ect..
- LS hondata CPR conversion hold down
- WTB: DEI 7-pin remote start harness
- Obd1 b16 tucked engine harness!!!! Need ASAP
- LS ported head
- WTB: 96-98 Civic EX OBD2a 5 speed engine harness
- wtb: Hondata s300 with p28 ecu
- WTB: JDM Front integra carbon fiber hood -located in NJ
- Accord OEM Rims
- WTB:D15Z1 VTEC-E 5 WIRE ENGINE
- Wtb dp manifold and dumptube for bseries 38mm
- WTB- P28 Virgin ECU
- wtb rear EK3 VI-RS seats
- Integra 94-01 Hood BRA
- Wtb: 3" exhaust cutout
- WTB: Del Sol Oem Spoiler
- WTB 1999 Honda Accord Stock Exhaust & Stock Steering Wheel
- edelbrock Performer X, ASR plate, chamber arms for eg
- wtb j's racing gt wing eg6
- wtb p30 or what ever runs a b16a2
- WTB VX UNDERDASH HARNESS
- WTB: AEM EMS - COP - CDI
- JDM DC2 Fenders
- WTB: OEM B16 header
- Attention looking to buy koni yellow shocks in the tampa area
- WTB: Z6 JRSC Blower Pulley
- B16 parts and boost parts
- WTB: 99-00 Civic SI stock Wheels
- wtb B series starter (orlando)
- Need 92-95 hatchback Brake light for carbon fiber wing
- WTB: 92-95 Civic Corner Light Pigtails + Driver Side Door Lock Tab
- d16a6 lower timing cover
- WTB Obd0 ECU
- Wtb 99-00 civic si fenders ,grill , spoiler ,complete ac system
- WTB DC integra 4 door brake line and e-brake cables
- WTB: Del sol harness bar and Nrg harnesses
- wtb: ITR brake booster/GSR MC
- 1996-2001 Acura Integra GSR (OBD2) Engine Harness Needed ASAP!
- WTB: 3" crx exhaust thermal r&d turbo
- WTB: PERSONAL STEERING WHEEL (RARE EDITOIN LOOK)
- Wtb: civic type r spoiler 96-00 hatch
- PA WTB 8th gen civic coilovers
- WTB acura el 1.6 center console
- WTB ASAP 2000 civic si uppper trans bracket
- WTB 94-01 integra near Wilkes-Barre, PA
- Wtb: 98+GSR Cluster or Type R
- NEED A BEATER
- Wtb looking for a b series oil pump 15100-P72-A01
- wtb 2005 civic black interior
- WTB 96-00 Civic Tein S tech springs
- wtb rsx shifter cables
- WTB: 99-00 Civic Si stereo brackets
- WTB: b18b (ls) crank
- WTB: D16A6,D16Z6,D16ZC
- WTB: dss 5.9 axles for h22 in del or eg
- WTB:fuel rail fittings, lines ,fpr,inline pump for h22
- WTB: 96-00 Civic OEM Shift Boot / 96-00 SOHC Timing Cover (Upper)
- WTB: Wideband/AEM Tru-Boost
- WTB jdm milano red eg rear spoiler
- WTB: T3/T4 internal wastegate turbo
- WTB car. payments preferred, not required
- LTB Wideband and SAFc
- WTB: 96-00 Civic Coupe Interior Parts (Carpet, Door Panels, Steering Wheel)
- WTB DC2 integra bumper light socket/pigtail
- wtb civic em1 headrest "URGENT"
- WTB: 95 Accord Driver Door - Sherwood Green
- want to buy Civic EK visors
- WTB ; 97 5Spd D series parts steel clutch fork , transmission bracket etc.
- WTB h22 auto air control valve
- GT28 turbine housing
- wtb 2001 steering wheel center horn pad
- K24a2 complete block 06+
- Wtb integra gsr or itr spoiler painted satin silver
- Wtb itr nose mask/ bra must fit itr 98-01.
- Wtb Ek Civic Complete Stock Shell
- WTB: 96-99 OEM GSR CAT. CONVERTER
- WTB: EF ecu - 37820-PM5-A580
- AEM FPR
- WTB T3 4 bolt .63 AR Turbo Exhaust Housing
- Em1 dizzy
- WTB:GSR oilpick up and windage tray
- WTB: Payn Tech 8 rib Vortech pulley kit
- WTB: 15" Volk Racing TE37 - Bronze - Must Be Authentic
- wtb: 97-01 integra coupe driverside window switch
- aftermarket intake manifold b18a b18b b20b non-vtec
- WTB: Ej1/2 rear passenger side tail light
- WTB SI Cluster
- Urgently WTB: H22 turbo manifold T3 - paypal ready
- Wtb:aem fuel rail and reg
- wtb gsr shift knob
- Want to buy Stock 91 Prelude Intake
- ATi Super Damper D16z6
- wtt for skunk2 b18c manifold
- WTB: EK civic parts
- wtb:skunk2 main part
- WTB: GSR THROTTLE CABLE PULLEY
- WTB: 98-01 Integra HID Retrofit Headlights
- WTB: D16Z6 engine.
- WTB: 550 rc injectors
- WTB or rent: 92-95 Civic Hatchback wing with brake light
- WTB: Skunk2 IM GSR
- wtb:obd1 ls parts
- wtb:bseries parts -motor mounts, fuel rail, injectors
- WTB Gsr black leather front seats
- Wtb itr throttle cable and bracket
- WTB: OEM ITR front lip or comtech lip 98+ dc2
- rrc manifold
- WTB: B18C Crankshaft
- wtb 2005 civic 2 door black rear seats
- SC WTB: STOCK EM1 CAT BACK
- Wtb: integra Ls stock diff.
- Want to Buy: GSR Block
- WTB: LS forge Pistons
- Wtb: 99-00 civic climate control
- WTB: 28t Legend GS Caliper brackets
- 96-98 oem ctr headlights
- WTB B16 Throttle cable
- WTB GSR throttle body rotor and bracket
- t3 turbo for d16 300whp, tial spring and fire ring
- WTT:B16 JRSC Manifold for GSR JRSC Manifold
- WTB 99/00 Civic Cabin Wiring Harness
- Looking for good intake manifold
- WTB: OEM 99-00 Front Lip
- WTB: Desmond Regamaster wheels 5x114
- WTB : AFTERMARKET STEERING WHEEL . Nardi/momo/sparco perf.
- wtb skunk2 pro1 rm24xx
- WTB: DSM 450cc Injectors
- WTB: Suspension Techniques LCAs EF Civic
- WTB: mirror block off plates for DC
- Looking for h22 head, cams, valve cover, vtec solonoid
- wtb ef9 sir bumper lights asap
- Wtb: 89mm h22 pistons
- h22 block,cranck,dss 5.9,fuel system
- Wtb: Enkie rpf1's (NJ)
- WTB 6UL rims
- OH: WTB or WTT+$ for K20A2 or K20Z1
- WTB: Mugen RNR center caps for black/silver wheels
- wtb: B series parts
- wtb non abs 40 40 prop valve
- WTB: 94-95 Acura Integra GSR OBD1 Engine Harness
- NEED FULLMARK CRV TAILGATE!! read inside....
- wtb: 3" s2000 exhaust
- WTB EP3 Seats or DB8 Type R Seats
- WTB: 92-95 OEM Fuel Rail
- WTB: B-Series Flywheel/PP bolts
- WTB: 99-00 civic stuff (oem)
- WTB: 92-95 eg hatch bomex wing
- WTB Full air condtioning unit!!!
- looking to buy built k series trans asap.
- WTB 95 integra coolant overflow resevoir
- ek motor mounts
- 00' Civic rear right backlight
- WTB: 96-98 OEM GSR parts
- WTB: 92-96 Prelude Lowering springs
- GSR or b16 tranny
- WTB: F&F suspension for EF
- WTB CRX Glass Roof and accessories
- WTB: 94-97 integra front bumper and ITR lip hardware(219)
- Wanted: EG hatch rear wiper blade and arm
- wtb: jdm itr red stitch shift boot
- WTB: eg/ej gas / temperature gauge from ex cluster !
- wtb 92-00 lowering springs
- WTB guage cluster for EG Hatch w/ tach
- WTB D16y7 full A/C unit
- wtb s2k cluster set up
- Looking for usdm/jdm itr or ctr cams!
- beware of scammer email by domfc3s@yahoo
- WTB: DART Block
- B-SERIES LSD TRANS
- WTB: eg climate control
- WTB buy obd1 b series vtec dizzy
- wtb: vtec soleiond and egr for 2003 civic
- WTB obd1 94-95 GSR ECU 5 speed
- wtb: 92-95 civic or 94-01, rear oem tow links, and rear oem lower control arms
- WTB ** qsd h2b kit for ef/da
- Looking for DC5 Brembos or FD2 Brembos.
- I'm looking for FD2 parts for my FA5.
- WTB: FD2 parts.
- WTB: Pair of Recaro Universal Sliders
- WTB: Hasport driverside engine mount bracket
- WTB: B-Series Vtec Distributor
- WTB: OE Rear LCA's for DC integra
- WTB Ostrich2 / EEPROM Burner
- WTB Del Sol Core Support
- WTB: B-series VSS
- WTB: Sanden TR70 Compressor (88-91 Civic/CRX)
- WTB: 99-00 Driver Side Type-R headlight
- Back in the game. WTB: Extra miscellaneous nuts and bolts
- WTB: 88-91 EF parts (exhaust, headers, rear garnish, etc)
- B18C GSR Tranny
- wtb oil pick up tube for b16
- wtb d16z6 ti valve spring retainers
- WTB: OEM D16 VTEC EX MANIFOLD AND CAT
- Wtb: OEM S2k Driver's side top latch and AP2 exhaust tip
- wtb clean first gen crv shell
- wtb: integra coupe driver window motor
- WTB: STOPTECH ST-40/STR CALIPERS
- WTB: EG climate control
- WTB VENOM FUEL RAIL BRACKETS
- WTB: D-series JRSC High Boost kit
- wtb aftermarket ignition
- wtb: acura integra tape deck
- 96 civic coolant overflow tank with hose
- Wtb: wa state area. 13" VX rims
- WTB honda civic 8th gen SI skunk2 cold air intake
- WTB 92-00 civic exhaust and coilovers
- WTB skunk2 drag springs
- WTB OEM EM1 front Lip
- wtb b20z crank pulley
- WTB AP1 Cluster
- WTB: B18C1 Crankshaft.
- WTB J-series swap parts ( 94 EG )
- WTB: IPS K2 cams and valvetrain kit for 2007 civic si
- LTB : EK 96 under dash harness.
- WTB: 88-91 civic cusco type ST front strut bar
- Anybody have JUST front OEM floor mats for 96-00 civic?
- !!IN NEED OF EK K SWAP PARTS!!
