View Full Version : Want to Buy
- WTB EG HATCH, not an si, VX CX or DX manual only
- ***WTB: Complete B-series swap, tranny included***
- WTB 370cc RC injectors, Saturated
- Integra OE radio stereo
- WTB: Charge speed LIP kit for eg6 hatchback
- eg hatch parts needed
- WTB: 96-98 power door harness
- WTB: front dark grey cloth LS SEATS, '99 civic MUDGUARDS
- WTB DashBoard Civic 96-2000
- WTB: Oem Honda Head Gasket D16y/z multi layer steel
- WTB GSR B18C1 short block in WI
- WTB: 99-00 Si front lower control arms.
- ***WTB: 92-95 CIVIC EX STOCK INTAKE***
- WTB: Comptech intake 94 GSR
- WTB: 2000 ITR stuff
- *****DC5 Headlights******
- WTB radio harness out of 2002-2004 RSX
- wtb: ls oil pan
- WTB: 99-00 CTR Driver Side Headlight
- CRX Exhaust
- WTB: Civic Wagon 4WD
- WTB: Z6 oR y8 TRAnNY!!
- WTB: eg 92-95 jdm coin pocket & VIS / Seibon Hood Carbing & Cusco DC5 recaro
- WTB: cai intake, d series 4-1 header, and ek exhaust
- WTB DC CLIMATE CONTROL
- WTB/WTT 96-99 hatch parts
- vx head ecu engine hx head ecu engine d16y5 d15z1
- WTB Honda/Toyota/Nissan $4k max.
- WTB: IACV obd-2 b-series
- ((( WTB..)))) D16y5 96-00 civic HX motor in or around MARYLAND
- WANT TO BUY: b16 a2 LMA (Lost motion Assemblies) Need help ASAP
- WTB: hks sport exhaust asap
- wtb> 96 civic d-series cv shaft drivers side
- WTB: Alluminum D series radaitor
- WTB: D-Series Transmission - 5 speed
- WTB: BYS or iBuilt CTR wing brackets/lifters
- WTB: EM1/EK parts!!
- wtb: Tial 44mm inlet V-band clamp.
- WTB: 99-00 Civic Coupe REAR Mudguards
- wtb: one piece headlights, window visors, thin sides, hks twin tip for DA
- WTB: EBP civic si rear lip
- WTB: 99-00 driver side door and more..lok inside
- wtb: 99-00 ex or si lock control box
- WTB: Speedometer sending unit for a B-series cable trans. Cable drive sender
- WTB: Turbo injectors peak and hold
- WTB:Exhaust for 01 gsr
- WTB: EDM ITR Clear signal corners
- WTB: 96-98 Civic Engine harness, vtec solenoid, B20 a/c bracket and more! Take a lookskie!
- WTB: ITR Exhaust near Sac
- 95 LS 2-door stock cat back exhaust
- WTB....greddy prelude turbo kit
- Metra OEM Adapter Honda Accord 03-Up
- WTB: Tein H-tech Springs for civic 96-98!!!
- WTB: Crx Exhaust
- Wtb RSX rear seats Black cloth in ohio
- WTB: ASR Subframe Brace 96-00 EK, Swaybar (CTR,ITR,ASR), Bushings and Endlinks
- wtb: h beam rods and low compression pistons for b16
- WTB.. Looking for a replacement engine swap for my 99 civic si
- WTB obd1 p72
- WTB:jdm front passanger headlight passanger fender and front bumper..for jdm integra front end
- 66mm Throttle Body
- wtt for b-series
- wtt h for b parts
- WTB full ac setup for a 95 integra
- WTB: Comptech Subframe Tie Bar - DC/EG App.
- Parts I need... 96' civic ex
- WTB CW 16" JDM ITR WHEELS 5X114.3
- WTB: Cusco Master cylinder brace for EG
- WTB: EG Mud Gaurds and Duckbill
- WTB Integra gsr timing belt cover
- WTB Integra gsr s80 flywheel cover plate
- wtb: usdm obd2a p72
- WTB 99-00 CIVIC SI OEM Grill Any color
- WTB: DC2 Integra Front Brake Line Brackets that go on the front shocks.
- WTB: Koni Yellows For 92+ Civic
- WTB: Civic/Integra Gauge Cluster (MT W/ Elec. VSS!)
- WTB DC2 Lowering Springs ASAP
- NY: wtt parts/wtb: b series turbo oil feed line kit. asap!
- WTB: JDM Integra Type R DB8 4-door Rear Seats
- WTB: 02-05 civic si
- WTB-CD Accord blackhousing headlights and H22 parts needed
- WB 38mm Wastgate
- wtb 94-97 integra ls midpipe and cat converter
- **** WTB: Apexi VAFC ****
- WTB 5x114 RIMS
- WTB: Forged Pistons (turbo)
- WTB: Ostrich
- WTB: 99-00 Civic Si Rear Disc Conversion
- WTB 01 civic struts
- wtb
- WTB: 1998 civic dx engine
- WTB Left carbon fiber fender....92-92 civic coupe or hatch
- WTB: Seat Buckle
- new or lightly used stock d-series clutch 96 dx, asap
- WTB Integra Type-R Shifter!
- WTB:EG Hatch shell
- WTB: Black civic rear view mirror 92-95
- wtb: obd1 Integra Evap Purge Solenoid
- WTB: 99-00 civic front lip
- wtb: DC2 DC Integra GSR axleback
- WTB One (1) Gunmetal JDM Integra Type-R (ITR) "H" Center Cap
- wtb: rear ef hatch interior panels and rear seat
- WTB: Sohc z6 LMAs
- I need.......
- WTT:
- WTB:INTEGRA WINDOW SWITCH
- WTB: CARBING STICKER!!! (for the 3 point strut bar)
- WTB: 1 D16 Eagle Rod. Used or New.
- 88-00 Civic, 94-01 Integra skunk2 rear camber kit
- WTB: HUBCAP for 92 Civic Si
- WTB: AC and PS parts for 97 civic coupe...
- WTB: DA Integra rear and/or side mount bracket
- WTB: B16 upper timing cover
- WTB: B20 lower timing cover
- wtb: 96-98 4dr emerald green driver side fender and front bumper cover
- ****WANTED**** 2002-2005 SI......possible cash/ trade if interested.
- Turbo downpipe for H22A - 3 Inch Pipe with 5 Bolt T3/T4 Flanged
- I need a eg hood coupe or hatch
- WTB: Type R itr Rear LCA lower control arms
- WTB H22 Transmission
- WTB OEM jdm itr lip
- WTB B20 Block in WI
- WTB: OBDO B16A wiring harness!
- wtb: Tial 44, aeromotive style AFPR, 1000-1600cc injectors and etc
- WTB RSWX type S header
- WTB: 88-91 Hf/Si Engine & Interior harness *UNCUT & COMPLETE*
- WTB:96-98 civic fogs, ctr front lip, and ctr headlights
- WTB: bottom timing belt cover for B-Series & Throw out bearing
- WTB: Rims/Tires, Suspension, and NO2
- WTB: ek vision low rails
- WTB: B-Series Spark Plug Cover
- stock eg muffler. anywhere so cal need ASAP
- Idle Air Control Valve! ny
- WTB: Enkei RPF1 15x7 4x100 +35
- WTB: stock OBD1 B series injectors. Need ASAP
- wtb: 96-00 honda civic EX cluster
- WTB :: Top half of B16 exhaust manifold (OEM stock)
- WTB k swap mounts for eg/dc
- WTB))) Complete d16y7 intake mani w/ tb and all sensors!!!
- WTB//////D16y8 d16z6 parts.
- WTB : 94-01 Integra radiaor And fan
- wtb 1992-1995 hatch
- wtb hydro gsr transmission
- WTB: D-series a/c compressor
- WTB: D series turbo parts / Del sol camber kit
- WTB: 2 GSR Blade center caps, OEM DC2 header (for '00)
- need a motor mount for 90-93 integra da9
- WTB TURBO PARTS
- Robert Stewart/ Mike Wagner
- WTB: Skunk2 rear camber kit 92-95 EG
- WTB: Skunk2 Front camber kit Pro+ 92-95 EG
- WTB: Skunk2 LCA Silver 92-95 EG NEW!!!
- WTB: SIR-G FOG LIGHTS!
- WTB: 98-01 integra gsr/type r engine/main harness
- B-series VTEC cam rails and all the bolts for the caps
- wtb 65mm tb
- wtb. vic X b16/type-r
- WTB ARP Head studs for d16y8 y8
- WTB GSR oil pan
- WTB boost gauge, oil pressure gauge
- WTB: USed circuit hero shifter extender???
- WTB: 01-05 ex only, mid pipe!!
- wtb wings west RS side skirts for 95 civic coupe
- WTT 17" 5zigen rims
- WTB : 92-95 Honda Civic
- WTB: OEM 98-01 Integra Type R lip itr lip
- ****CLEAN AP2 EXHAUST TIPS***
- sk8shorty012's want to buy thread *come take a look*
- Integra Armrest filler piece/badge.
- wtb jdm DC integra hood
- WTB: Radiator DC2
- WTB: Front Bumper, Fenders, and Hood DC2
- WTB: honda civic si honda wheel center caps
- www.importrp.com Import Replacement Parts Review
- WTB: CTR power folding mirrors
- WTB: h22 itb's ASAP~!~ CASH IN HAND!!!!!!!
- WTB: OEM ITR Exhaust
- WTB: Benen Tow Hook Set in Black ( Serial 1242 )
- 92-93 civic black glove box
- WTB - GSR motor
- WTB: CLEAN 90-91 CRX STOCK CORNERS
- wtb: 92-95 civic interior pieces (black)
- wtb d16y7
- wtb ls dizzy
- obd1 integra wiring harness
- WTB: 94 civic hatch ac compressor SOCAL
- Stock DEL SOL DOHC Catback Exhaust
- WTB: ARC DC2 Winglets!
- WTB: BRIDE seat material/fabric
- wtb d16y8 long block
- WTB: OEM or Aftermarket Rims
- WTB: S2000 Center caps
- WTB: TL 99-03 OEM optional sides and rear
- wtb h2b headers
- WTB:96 GSR VSS, SIR-G OR GSR LOW MILES CLUSTER,CLOTH DC INTERIOR
- WTB Need D16 Tranny bolts AND cheap exhaust....
- WTB: 96-00 Civic EX cluster
- WTB: Del Sol Parts
- WTB: d16z6
- WTB- STOCK 94-01 INTEGRA CLUSTER BEZEL
- WTT/WTB: 94 EG hatch Parts
- WTB: 96-98 Civic Engine Fuse Box and Wiring Complete also battery tray ASAP, So. CAL
- WTB: Typus Roof Rack for 92-96 Honda Prelude
- WTB: 92-00 civic hatch shell.(PA)
- WTB Vision Carbon Fiber Type DC Mirror for DC2
- lookin for rear visor for crx 88 to 91
- WTB: Black Leather Arm Rest Cover 94-01 for Integra
- WTB stock RSX front bumper
- WTB: USED EG rear wiper plug (wiper delete)
- GSR b18c IAB box under IM
- WTB: Rear Driver Side Courter Panel Window For A 94 Ex Coupe...
- WTB: RED S2000 SEATS
- WANTED: EDM Integra Tail Lights (Tail Lamps)
- WTB: y7 manifold/cat
- Complete D-series Motor w/hydro tranny
- WTB: (2) 15", 0-offset, 4x100, sportmax or similiar rim....
- Stuff needed to swap b17 into EK
- WTB: GS-R/GS Leather Seats, Door Panels, Armrest
- WTB.....> 91 CRX SI TRANNY
- WTB Rear Disc setup for EF hatch
- WTB Real DC2 JDM Parts
- WTB-Front/rear 2003 civic coupe camber kit
- WTB-2002 honda S2000 hard tops
- WTB: Integra LS cluster 5-speed only
- One Rota Circuit 10 16x7
- WTB Integra Pieces
- WTB: 96-98 Civic climate control stuff
- WTT Xbox 360 for Turbo Parts or Partial Kit
- WTB STOCK D16Y7 Exhaust manifold/cat and oem downpipe
- wtb 1987 civic nose panel
- WTB : Looking for 96 front and rear bumper in midori green
- WTB: Old School DC Sports "DAC" Direct Air Charger Intake or Filter Adapter - Any Integra
- WTB: 1997 honda accord V6 AC compressor ASAP!!!
- WTB: B-series motor
- SCAMMER!!!!! Dont by from Michael Hansbarger (mike@hansbarger.com)
- 94-97 Del Sol VTEC AC bracket
- WTB 91 integra injectors
- WTB Mugen Front Lip or BYS Authentic. For 99 CIVIC.
- WTB OEM 97 integra front bumper
- looking for EJ1 stickers
- WTB honda center caps for GSR BLADES
- 96 Accord LH Front ABS sensor
- Crx Driver side door, fender, and door caps
- steel wheel centers
- WTB: DC5R muffler
- WTB: RT AWD Manual Transmission
- wtb: 92-95 civic EX coupe power door panels.(Black)
- WTB b18a LS valve cover
